master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/powerpc/booting-without-of.txt
drivers/atm/Makefile
drivers/net/fs_enet/fs_enet-main.c
drivers/pci/pci-acpi.c
net/8021q/vlan.c
net/iucv/iucv.c
We can simply use the qdisc->q.lock for all of the
qdisc tree synchronization.
They logically all want to trigger a schedule for all device
TX queues.
The private area of a netdev is now at a fixed offset once more.
Unfortunately, some assumptions that netdev_priv() == netdev->priv
crept back into the tree. In particular this happened in the
loopback driver. Make it use netdev->ml_priv.
This effectively "flips the switch" by making the core networking
and multiqueue-aware drivers use the new TX multiqueue structures.
Non-multiqueue drivers need no changes. The interfaces they use such
as netif_stop_queue() degenerate into an operation on TX queue zero.
So everything "just works" for them.
Code that really wants to do "X" to all TX queues now invokes a
routine that does so, such as netif_tx_wake_all_queues(),
netif_tx_stop_all_queues(), etc.
pktgen and netpoll required a little bit more surgery than the others.
In particular the pktgen changes, whilst functional, could be largely
improved. The initial check in pktgen_xmit() will sometimes check the
wrong queue, which is mostly harmless. The thing to do is probably to
invoke fill_packet() earlier.
The bulk of the netpoll changes is to make the code operate solely on
the TX queue indicated by by the SKB queue mapping.
Setting of the SKB queue mapping is entirely confined inside of
net/core/dev.c:dev_pick_tx(). If we end up needing any kind of
special semantics (drops, for example) it will be implemented here.
Finally, we now have a "real_num_tx_queues" which is where the driver
indicates how many TX queues are actually active.
With IGB changes from Jeff Kirsher.
There is no need for a feature bit for something that
can be tested by simply checking the TX queue count.
alloc_netdev_mq() now allocates an array of netdev_queue
structures for TX, based upon the queue_count argument.
Furthermore, all accesses to the TX queues are now vectored
through the netdev_get_tx_queue() and netdev_for_each_tx_queue()
interfaces. This makes it easy to grep the tree for all
things that want to get to a TX queue of a net device.
Problem spots which are not really multiqueue aware yet, and
only work with one queue, can easily be spotted by grepping
for all netdev_get_tx_queue() calls that pass in a zero index.
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2:
[PATCH] ocfs2: fix oops in mmap_truncate testing
configfs: call drop_link() to cleanup after create_link() failure
configfs: Allow ->make_item() and ->make_group() to return detailed errors.
configfs: Fix failing mkdir() making racing rmdir() fail
configfs: Fix deadlock with racing rmdir() and rename()
configfs: Make configfs_new_dirent() return error code instead of NULL
configfs: Protect configfs_dirent s_links list mutations
configfs: Introduce configfs_dirent_lock
ocfs2: Don't snprintf() without a format.
ocfs2: Fix CONFIG_OCFS2_DEBUG_FS #ifdefs
ocfs2/net: Silence build warnings on sparc64
ocfs2: Handle error during journal load
ocfs2: Silence an error message in ocfs2_file_aio_read()
ocfs2: use simple_read_from_buffer()
ocfs2: fix printk format warnings with OCFS2_FS_STATS=n
[PATCH 2/2] ocfs2: Instrument fs cluster locks
[PATCH 1/2] ocfs2: Add CONFIG_OCFS2_FS_STATS config option
Currently VLAN filtering is enabled when the first VLAN is added.
Obviously before that there's no point in receiving any VLAN packets.
Now that we disable VLAN filtering in promiscous mode, we can keep
the VLAN filters enabled the remaining time.
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
As discussed in this thread:
http://www.mail-archive.com/netdev@vger.kernel.org/msg53976.html
promiscous mode means to disable *all* filters. Currently only unicast
and multicast filtering is disabled. This patch changes all Intel
drivers to also disable VLAN filtering.
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (68 commits)
sdio_uart: Fix SDIO break control to now return success or an error
mmc: host driver for Ricoh Bay1Controllers
sdio: sdio_io.c Fix sparse warnings
sdio: fix the use of hard coded timeout value.
mmc: OLPC: update vdd/powerup quirk comment
mmc: fix spares errors of sdhci.c
mmc: remove multiwrite capability
wbsd: fix bad dma_addr_t conversion
atmel-mci: Driver for Atmel on-chip MMC controllers
mmc: fix sdio_io sparse errors
mmc: wbsd.c fix shadowing of 'dma' variable
MMC: S3C24XX: Refuse incorrectly aligned transfers
MMC: S3C24XX: Add maintainer entry
MMC: S3C24XX: Update error debugging.
MMC: S3C24XX: Add media presence test to request handling.
MMC: S3C24XX: Fix use of msecs where jiffies are needed
MMC: S3C24XX: Add MODULE_ALIAS() entries for the platform devices
MMC: S3C24XX: Fix s3c2410_dma_request() return code check.
MMC: S3C24XX: Allow card-detect on non-IRQ capable pin
MMC: S3C24XX: Ensure host->mrq->data is valid
Manually fixed up bogus executable bits on drivers/mmc/core/sdio_io.c
and include/linux/mmc/sdio_func.h when merging.
Manual merge of:
arch/powerpc/Kconfig
arch/powerpc/kernel/stacktrace.c
arch/powerpc/mm/slice.c
arch/ppc/kernel/smp.c
There are a lot of crappy controllers out there that cannot handle
all the request sizes that the MMC/SD/SDIO specifications require.
In case the card driver can pad the data to overcome the problems,
this commit adds a helper that calculates how much that padding
should be.
A corresponding helper is also added for SDIO, but it can also deal
with all the complexities of splitting up a large transfer efficiently.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
When I removed the special "default" meaning from the QoS
parameters, I forgot to update drivers and this lead to
warnings because some drivers were checking for the special
values and putting in defaults. This fixes that by removing
the default special-casing completely.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Now that we have a specific lock to protect the network
device unicast and multicast lists, remove extraneous
grabs of the TX lock in cases where the code only needs
address list protection.
Add netif_addr_{lock,unlock}{,_bh}() helpers.
Use them to protect operations that operate on or read
the network device unicast and multicast address lists.
Also use them in cases where the code simply wants to
block calls into the driver's ->set_rx_mode() and
->set_multicast_list() methods.
There was a bug in some versions of the mlx4 driver in
mlx4_alloc_fmr(), which hardcoded the minimum acceptable page_shift to
be 12. However, new ConnectX firmware can support a minimum
page_shift of 9 (log_pg_sz of 9 returned by QUERY_DEV_LIM) -- so with
old drivers, ib_fmr_alloc() would fail for ULPs using the device
minimum when creating FMRs.
To preserve firmware compatibility with released mlx4 drivers, the
firmware will continue to return 12 as before for log_page_sz in
QUERY_DEV_CAP for these drivers. However, to enable new drivers to
take advantage of the available smaller page size, the mlx4 driver now
first sets the log_pg_sz to the device minimum by setting a
log_page_sz value to 0 via the MOD_STAT_CFG command and then reading
the real minimum via QUERY_DEV_CAP.
Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il>
Signed-off-by: Vladimir Sokolovsky <vlad@mellanox.co.il>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Handling the zero STag in receive work request requires some extra
logic in the driver:
- Only set the QP_PRIV bit for kernel mode QPs.
- Add a zero STag build function for recv wrs. The uP needs a PBL
allocated and passed down in the recv WR so it can construct a HW
PBL for the zero STag S/G entries. Note: we need to place a few
restrictions on zero STag usage because of this:
1) all SGEs in a recv WR must either be zero STag or not. No mixing.
2) an individual SGE length cannot exceed 128MB for a zero-stag SGE.
This should be OK since it's not really practical to allocate
such a large chunk of pinned contiguous DMA mapped memory.
- Add an optimized non-zero-STag recv wr format for kernel users.
This is needed to optimize both zero and non-zero STag cracking in
the recv path for kernel users.
- Remove the iwch_ prefix from the static build functions.
- Bump required FW version.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Add support for handling the IB_QP_CREATE_MULTICAST_BLOCK_LOOPBACK
flag by using the per-multicast group loopback blocking feature of
mlx4 hardware.
Signed-off-by: Ron Livne <ronli@voltaire.com>
- Add a new rdma ctl command called RDMA_GET_MIB to the cxgb3 low
level driver to obtain the protocol mib from the rnic hardware.
- Add new iw_cxgb3 provider method to get the MIB from the low level
driver.
Manual fixup of:
Signed-off-by: Michael Chan <mchan@braodcom.com>
Add support for configuring secondary unicast addresses. There
are 4 additional perfect match filters which can be used for
secondary unicast address support.
* Modified bnx2_set_mac_addr() to be more generic in handling
the setting of the perfect match filters
* Changed bnx2_set_rx_mode() to handle the unicast dev_addr_list
Signed-off-by: Benjamin Li <benli@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Negotiate with boot code and ASF firmware to see if it can
support keeping VLAN tags in the RX packets. If supported
by firmware, the VLAN tag will be kept in the RX packet
unless VLAN acceleration is registered.
ack=1 means wait for firmware acknowledgement, and ack=0
means don't wait. All current callers will set it to 1.
In the next patch, new calls will set ack=0.
Signed-off-by: Benjamin Li <Benli@broadcom.com>
The device may be in D3-hot state and may crash if we try to
configure the speed settings by accessing the registers.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
This patch removes references in drivers/net/wan/Kconfig and
net/wanrouter/Kconfig to Documentation/networking/wan-router.txt
which was removed in commit 99971e70fdc1862e120f3319fc0a4dba8c728acf
("[WANPIPE]: Forgotten bits of Sangoma drivers removal.").
Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net>
Please see the following thread to get some context on this
http://marc.info/?l=linux-netdev&m=121564433018903&w=2
Basically the issue is that current multi-cast filtering stuff in
the TUN/TAP driver is seriously broken.
Original patch went in without proper review and ACK. It was broken and
confusing to start with and subsequent patches broke it completely.
To give you an idea of what's broken here are some of the issues:
- Very confusing comments throughout the code that imply that the
character device is a network interface in its own right, and that packets
are passed between the two nics. Which is completely wrong.
- Wrong set of ioctls is used for setting up filters. They look like
shortcuts for manipulating state of the tun/tap network interface but
in reality manipulate the state of the TX filter.
- ioctls that were originally used for setting address of the the TX filter
got "fixed" and now set the address of the network interface itself. Which
made filter totaly useless.
- Filtering is done too late. Instead of filtering early on, to avoid
unnecessary wakeups, filtering is done in the read() call.
The list goes on and on :)
So the patch cleans all that up. It introduces simple and clean interface for
setting up TX filters (TUNSETTXFILTER + tun_filter spec) and does filtering
before enqueuing the packets.
TX filtering is useful in the scenarios where TAP is part of a bridge, in
which case it gets all broadcast, multicast and potentially other packets when
the bridge is learning. So for example Ethernet tunnelling app may want to
setup TX filters to avoid tunnelling multicast traffic. QEMU and other
hypervisors can push RX filtering that is currently done in the guest into the
host context therefore saving wakeups and unnecessary data transfer.
Signed-off-by: Max Krasnyansky <maxk@qualcomm.com>
allmulti might overflow.
Commit: "netdevice: Fix promiscuity and allmulti overflow" in net-next makes
dev_set_promiscuity/allmulti return error number if overflow happened.
Here, we check the positive increment for allmulti to get error return.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
Acked-by: Patrick McHardy <kaber@trash.net>
dev_set_promiscuity/allmulti might overflow.
In bond_alb and bond_main, we check all positive increment for promiscuity
and allmulti to get error return.
But there are still two problems left.
1. Some code path has no mechanism to signal errors upstream.
2. If there are multi slaves, it's hard to tell which slaves increment
promisc/allmulti successfully and which failed.
So I left these problems to be FIXME.
Fortunately, the overflow is very rare case.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
net/netfilter/nf_conntrack_proto_tcp.c
This patch adds support to the RGMII handler in the EMAC driver for
the MII PHY mode such that device tree entries of the form `phy-mode = "mii";'
are recognized and handled appropriately.
While logically, in software, "gmii" and "mii" modes are the same,
they are wired differently, so it makes sense to allow DTS authors to
specify each explicitly.
Signed-off-by: Grant Erickson <gerickson@nuovations.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Jeff Garzik <jgarzik@pobox.com>
* 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6: (64 commits)
firmware: convert sb16_csp driver to use firmware loader exclusively
dsp56k: use request_firmware
edgeport-ti: use request_firmware()
edgeport: use request_firmware()
vicam: use request_firmware()
dabusb: use request_firmware()
cpia2: use request_firmware()
ip2: use request_firmware()
firmware: convert Ambassador ATM driver to request_firmware()
whiteheat: use request_firmware()
ti_usb_3410_5052: use request_firmware()
emi62: use request_firmware()
emi26: use request_firmware()
keyspan_pda: use request_firmware()
keyspan: use request_firmware()
ttusb-budget: use request_firmware()
kaweth: use request_firmware()
smctr: use request_firmware()
firmware: convert ymfpci driver to use firmware loader exclusively
firmware: convert maestro3 driver to use firmware loader exclusively
Fix up trivial conflicts with BKL removal in drivers/char/dsp56k.c and
drivers/char/ip2/ip2main.c manually.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (241 commits)
[ARM] 5171/1: ep93xx: fix compilation of modules using clocks
[ARM] 5133/2: at91sam9g20 defconfig file
[ARM] 5130/4: Support for the at91sam9g20
[ARM] 5160/1: IOP3XX: gpio/gpiolib support
[ARM] at91: Fix NAND FLASH timings for at91sam9x evaluation kits.
[ARM] 5084/1: zylonite: Register AC97 device
[ARM] 5085/2: PXA: Move AC97 over to the new central device declaration model
[ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC drivers
[ARM] 5147/1: pxaficp_ir: drop pxa_gpio_mode calls, as pin setting
[ARM] 5145/1: PXA2xx: provide api to control IrDA pins state
[ARM] 5144/1: pxaficp_ir: cleanup includes
[ARM] pxa: remove pxa_set_cken()
[ARM] pxa: allow clk aliases
[ARM] Feroceon: don't disable BPU on boot
[ARM] Orion: LED support for HP mv2120
[ARM] Orion: add RD88F5181L-FXO support
[ARM] Orion: add RD88F5181L-GE support
[ARM] Orion: add Netgear WNR854T support
[ARM] s3c2410_defconfig: update for current build
[ARM] Acer n30: Minor style and indentation fixes.
sound/pci/Kconfig
This includes PXA work up to the SPI changes for the initial merge,
since e172274ccc55d20536fbdceb6131f38e288541e0 depends on the SPI
tree being merged.
arch/arm/configs/em_x270_defconfig
arch/arm/configs/xm_x270_defconfig
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits)
IB/umad: BKL is not needed for ib_umad_open()
IB/uverbs: BKL is not needed for ib_uverbs_open()
bf561-coreb: BKL unneeded for open()
Call fasync() functions without the BKL
snd/PCM: fasync BKL pushdown
ipmi: fasync BKL pushdown
ecryptfs: fasync BKL pushdown
Bluetooth VHCI: fasync BKL pushdown
tty_io: fasync BKL pushdown
tun: fasync BKL pushdown
i2o: fasync BKL pushdown
mpt: fasync BKL pushdown
Remove BKL from remote_llseek v2
Make FAT users happier by not deadlocking
x86-mce: BKL pushdown
vmwatchdog: BKL pushdown
vmcp: BKL pushdown
via-pmu: BKL pushdown
uml-random: BKL pushdown
uml-mmapper: BKL pushdown
The configfs operations ->make_item() and ->make_group() currently
return a new item/group. A return of NULL signifies an error. Because
of this, -ENOMEM is the only return code bubbled up the stack.
Multiple folks have requested the ability to return specific error codes
when these operations fail. This patch adds that ability by changing the
->make_item/group() ops to return an int.
Also updated are the in-kernel users of configfs.
Signed-off-by: Joel Becker <joel.becker@oracle.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: (31 commits)
avr32: Fix typo of IFSR in a comment in the PIO header file
avr32: Power Management support ("standby" and "mem" modes)
avr32: Add system device for the internal interrupt controller (intc)
avr32: Add simple SRAM allocator
avr32: Enable SDRAMC clock at startup
rtc-at32ap700x: Enable wakeup
macb: Basic suspend/resume support
atmel_serial: Drain console TX shifter before suspending
atmel_serial: Fix build on avr32 with CONFIG_PM enabled
avr32: Use a quicklist for PTE allocation as well
avr32: Use a quicklist for PGD allocation
avr32: Cover the kernel page tables in the user PGDs
avr32: Store virtual addresses in the PGD
avr32: Remove useless zeroing of swapper_pg_dir at startup
avr32: Clean up and optimize the TLB operations
avr32: Rename at32ap.c -> pdc.c
avr32: Move setup_platform() into chip-specific file
avr32: Kill special exception handler sections
avr32: Kill unneeded #include <asm/pgalloc.h> from asm/mmu_context.h
avr32: Clean up time.c #includes
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (37 commits)
splice: fix generic_file_splice_read() race with page invalidation
ramfs: enable splice write
drivers/block/pktcdvd.c: avoid useless memset
cdrom: revert commit 22a9189 (cdrom: use kmalloced buffers instead of buffers on stack)
scsi: sr avoids useless buffer allocation
block: blk_rq_map_kern uses the bounce buffers for stack buffers
block: add blk_queue_update_dma_pad
DAC960: push down BKL
pktcdvd: push BKL down into driver
paride: push ioctl down into driver
block: use get_unaligned_* helpers
block: extend queue_flag bitops
block: request_module(): use format string
Add bvec_merge_data to handle stacked devices and ->merge_bvec()
block: integrity flags can't use bit ops on unsigned short
cmdfilter: extend default read filter
sg: fix odd style (extra parenthesis) introduced by cmd filter patch
block: add bounce support to blk_rq_map_user_iov
cfq-iosched: get rid of enable_idle being unused warning
allow userspace to modify scsi command filter on per device basis
According to the legacy drivers the LED association status
must be reset after the firmware has been uploaded to the
hardware.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
This is a small fix to change the idx type from int to unsigned.
Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com>
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
The patch fixes LEDs problem for 3945.
