Calculate a score for each 1000 IRQs:
- TX completions are worth 1 point
- RX completions are worth 4 if merged using LRO or 2 otherwise
Reduce moderation if the score is less than 10000, down to a minimum
of 5 us. Increase moderation if the score is more than 20000, up to
the specified maximum.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
The bug this function works around only applies to the first set of
page-mapped registers; other pages can be written without locking.
In rare cases, reading the legacy interrupt status register can
acknowledge an event queue whose attention flag has not yet been set
in the register. Until we service this event queue it will not
generate any more interrupts. Therefore, as a secondary check, poll
the next slot in each active event queue whose flag is not set.
The packet parser used in the TX data path for locating checksum
fields can lose synchronisation with the TX queue manager when
handling packets that look like IPv4 but are too short (17-32 bytes).
Work around this by padding to 33 bytes.
The igb driver was using map_single to map the skbs and then unmap_page to
unmap them. This update changes that so instead uses skb_dma_map and
skb_dma_unmap.
In addition the next_to_watch member of the buffer_info struct was being
set uneccesarily. I removed the spots where it was set without being needed.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Currently if there are no multicast addresses programmed into the PF then
the VFs cannot have their multicast filters reset. This change makes it so
the code path that updates vf multicast is always called along with the pf
updates.
igb was previously setting up all of the timer members itself. It is
easier to just call setup_timer and reduce the calls to one line.
This patch removes IGB_DESC_UNUSED and replaces it with a function call
instead in order to cleanup some of the ugliness introduced by the macro.
When the 82575 is fed 802.1q packets, it chokes with
an error of the form:
igb 0000:08:00.1 partial checksum but proto=81!
As the logic there was not smart enough to look into
the vlan header to pick out the encapsulated protocol.
There are times when we'd like to send these packets
out without having to configure a vlan on the interface.
Here we check for the vlan tag and allow the packet to
go out with the correct hardware checksum.
Thanks to Kand Ly <kand@riverbed.com> for discovering the
issue and the coming up with a solution. This patch is
based upon his work.
Signed-off-by: Arthur Jones <ajones@riverbed.com>
Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com>
IBM EMAC driver performs device reset (drivers/net/ibm_newemac/core.c:
emac_probe() -> emac_init_phy() -> emac_reset()) before registering
appropriate net_device (emac_probe() -> register_netdev()), so
net_device name contains raw format string during EMAC reset ("eth%d").
If the case of reset timeout, emac_report_timeout_error() function is
called to report an error. The problem is this function uses net_device
name to report device related, which is not correct, as a result in the
kernel log buffer we see:
eth%d: reset timeout
The solution is to print device_node full_name instead. After applying
the patch proposed, error string is like the following:
/plb/opb/ethernet@ef600e00: reset timeout
Signed-off-by: Mikhail Zolotaryov <lebon@lebon.org.ua>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Convert ixgbe to use net_device_ops properly.
Rather than changing the select_queue function pointer
just check the flag.
Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
commit 1577ecef766650a57fceb171acee2b13cbfaf1d3 ("netdev: Merge UCC
and gianfar MDIO bus drivers") broke the TSEC TBI PHY support: the
driver now refuses to probe TBI MDIO buses as it doesn't know about
"fsl,gianfar-tbi" compatible entry, and thus _probe() fails with
-ENODEV status.
Fix this by adding "fsl,gianfar-tbi" to the list of known Gianfar
MDIO buses.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Andy Fleming <afleming@freescale.com>
commit 4826857f1bf07f9c0f1495e9b05d125552c88a85 ("gianfar: pass the
proper dev to DMA ops") introduced this build breakage:
CC drivers/net/gianfar.o
drivers/net/gianfar.c: In function 'gfar_suspend':
drivers/net/gianfar.c:552: error: 'struct gfar_private' has no member named 'dev'
drivers/net/gianfar.c: In function 'gfar_resume':
drivers/net/gianfar.c:601: error: 'struct gfar_private' has no member named 'dev'
make[2]: *** [drivers/net/gianfar.o] Error 1
Fix this by converting suspend and resume routines to use
gfar_private->ndev.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
This patch enables support for the new Intel 82552 adapter (new PHY paired
with the existing MAC in the ICH7 chipset). No new features are added to
the driver, however there are minor changes due to updated registers and a
few workarounds for hardware errata.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
When merging into Jeff's tree:
commit 5f66f208064f083aab5e55935d0575892e033b59
Author: Arthur Jones <ajones@riverbed.com>
Date: Thu Mar 19 01:13:08 2009 +0000
e1000e: allow tx of pre-formatted vlan tagged packets
We lost one line, this fixes that missing
piece...
drivers/net/virtio_net.c
Removed duplicated #include in drivers/net/dnet.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
The watchdog will schedule an interrupt to help make sure queues are
cleaned in the case when an interrupt is missed, most likely due to very
high load. On 82599, there are extra interrupt registers to account for
the larger number of MSI-X vectors (64 total for 82599 vs. 18 total for
82598). These must be taken into account when performing this operation in
the watchdog.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
ethtool isn't reporting the support level of WoL for 82599 KX4 devices.
While the device does support WoL, ethtool was never updated to properly
report the level of support, nor will it allow ethtool to modify the type
of packets to listen for.
82598's PCI bus reporting on driver load was broken after 82599 merged.
This results in incorrect reporting, and an erroneous warning message
that the 82598 is in a PCIe slot that isn't fast enough to run 10GbE.
This code updates ixgb so that it can use the skb_dma_map/unmap functions
to map the buffers. In addition it also updates the tx hang logic to use
time_stamp instead of dma to determine if it has detected a tx hang.
As with igb, when the e1000e driver is fed 802.1q
packets with hardware checksum on, it chokes with an
error of the form:
checksum_partial proto=81!
go out wiht the correct hardware checksum.
Fixups from Stephen Hemminger <shemminger@vyatta.com> and
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Alexander Duyck <alexander.h.duyck@intel.com>
There were a few issues I noticed in e1000e. These include a double free
of the skb if mapping fails, and the fact that context descriptors appear
to be left in the descriptor ring after the failure.
Add device ID and related support for 82583 mac.
Acked-by: Radheka Godse <radheka.godse@intel.com>
Acked-by: Bruce Allan <bruce.w.allan@intel.com>
The cpu_to_le16 here looks suspicious to me, I don't think we need it
because put_unaligned_le16 also does this.
I don't currently have any big endian hardware with a PCI bus available
to test on, so I haven't been able to verify this.
Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com>
This patch replaces the generic eth_mac_addr function with one that
also updates the hardware mac address registers. It also renames the
existing smsc911x_set_mac_address function to
smsc911x_hw_set_mac_address for clarity.
Newer LAN911x and all LAN921x devices also support changing the mac
address while the device is running, which is useful for some bonding
modes.
The vast majority of bit constants in this driver are defined in the
header file, but TX and RX status word bits are not. This patch (which
should make no functional change) defines these, to make the driver
slightly more readable.
smsc911x_phy_adjust_link is called periodically by the phy layer (as
it's run in polling mode), and it only updates the hardware when it sees
a change in duplex or carrier. This patch clears the last known values
every time the interface is brought up, instead of only when the module
is loaded.
Without this patch the adjust_link function never updates the hardware
after an ifconfig down; ifconfig up. On a full duplex link this causes
the tx error counter to increment, even though packets are correctly
transmitted, as the default MAC_CR register setting is for half duplex.
The tx errors are "no carrier" errors, which should be ignored in
full-duplex mode. When MAC_CR is set to "full duplex" mode they are
correctly ignored by the hardware.
Note that even with this patch the tx error counter can increment if
packets are transmitted between "ifconfig up" and the first phy poll
interval. An improved solution would use the phy interrupt with phylib,
but I haven't managed to make this work 100% robustly yet.
