path: root/drivers/net
2007-05-11S2IO: Statistics for link up/down and memory allocated/freedSreenivasa Honnur
1. Added statistics for link up/down, last link up/down. 2. Statistics for memory allocated/freed. 3. Changed level of some DBG_PRINTs. Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-11S2IO: statistics for memory allocation failuersSreenivasa Honnur
1. Added code to count the number of memory failures. 2. Added watchdog_timer counter. 3. Changed debug level for some DBG_PRINTS. Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-11S2IO: getringparam ethtool optionSreenivasa Honnur
Adding get_ringparam ethtool option. Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-11Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-ip22Linus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-ip22: Convert SGI IP22 and specific drivers to platform_device.
2007-05-11Convert SGI IP22 and specific drivers to platform_device.Ralf Baechle
2007-05-10[IrDA]: KingSun/DonShine USB IrDA dongle support.Alex Villac�s Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. In addition, it uses interrupt endpoints instead of bulk ones as the rest of USB IrDA dongles supported by Linux (just to be different?) and data reads need to be parsed to extract the valid bytes before being unwrapped (details in the comment at the start of the source). No speed commands have been discovered for this dongle, and I suspect it does not have any at all. On plugin, this dongle reports vendor and device IDs: 0x07c0:0x4200 . The Windows driver that is used normally to control this dongle has a filename of DSIR620.SYS . Signed-off-by: Alex Villac�s Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (24 commits) [POWERPC] Fix compile error with kexec and CONFIG_SMP=n [POWERPC] Split initrd logic out of early_init_dt_scan_chosen() to fix warning [POWERPC] Fix warning in hpte_decode(), and generalize it [POWERPC] Minor pSeries IOMMU debug cleanup [POWERPC] PS3: Fix sys manager build error [POWERPC] Assorted janitorial EEH cleanups [POWERPC] We don't define CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID [POWERPC] pmu_sys_suspended is only defined for PPC32 [POWERPC] Fix incorrect calculation of I/O window addresses [POWERPC] celleb: Update celleb_defconfig [POWERPC] celleb: Fix parsing of machine type hack command line option [POWERPC] celleb: Fix PCI config space accesses to subordinate buses [POWERPC] celleb: Fix support for multiple PCI domains [POWERPC] Wire up sys_utimensat [POWERPC] CPM_UART: Removed __init from cpm_uart_init_portdesc to fix warning [POWERPC] User rheap from arch/powerpc/lib [POWERPC] 83xx: Fix the PCI ranges in the MPC834x_MDS device tree. [POWERPC] 83xx: Fix the PCI ranges in the MPC832x_MDS device tree. [POWERPC] CPM_UART: cpm_uart_set_termios should take ktermios, not termios [POWERPC] Change rheap functions to use ulongs instead of pointers ...
2007-05-10[S390] Kconfig: no wireless on s390.Martin Schwidefsky
Hide the config menues for wireless on s390. Cc: John W. Linville <linville@tuxdriver.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-10[S390] Kconfig: unwanted menus for s390.Martin Schwidefsky
Disable some more menus in the configuration files that are of no interest to a s390 machine. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-10Merge branch 'linux-2.6'Paul Mackerras
2007-05-09[POWERPC] Change rheap functions to use ulongs instead of pointersTimur Tabi
The rheap allocation functions return a pointer, but the actual value is based on how the heap was initialized, and so it can be anything, e.g. an offset into a buffer. A ulong is a better representation of the value returned by the allocation functions. This patch changes all of the relevant rheap functions to use a unsigned long integers instead of a pointer. In case of an error, the value returned is a negative error code that has been cast to an unsigned long. The caller can use the IS_ERR_VALUE() macro to check for this. All code which calls the rheap functions is updated accordingly. Macros IS_MURAM_ERR() and IS_DPERR(), have been deleted in favor of IS_ERR_VALUE(). Also added error checking to rh_attach_region(). Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-05-09Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adapters IB: Put rlimit accounting struct in struct ib_umem IB/uverbs: Export ib_umem_get()/ib_umem_release() to modules
2007-05-09Merge branch 'usb-move' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'usb-move' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: Move USB network drivers to drivers/net/usb.
2007-05-09Move USB network drivers to drivers/net/usb.Jeff Garzik
It is preferable to group drivers by usage (net, scsi, ATA, ...) than by bus. When reviewing drivers, the [PCI|USB|PCMCIA|...] maintainer is probably less qualified on networking issues than a networking maintainer. Also, from a practical standpoint, chips often appear on multiple buses, which is why we do not put drivers into drivers/pci/net. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09atl1: add netconsole supportAlexey Dobriyan
Copied from b44 driver, but it works: netconsole: device eth0 not up yet, forcing it atl1: eth0 link is up 100 Mbps full duplex netconsole: network logging started Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09Fix hang on IBM Token Ring PCMCIA card ejectionPaul Walmsley
Ejecting a PCMCIA IBM Token Ring card that has not had its dev->open() called will reliably trigger an uninitialized spinlock oops when spinlock debugging is enabled. The system then hangs, occasionally softlockup oopsing. Apparently ibmtr.c:tok_interrupt() doesn't expect to be called before tok_open(), but tok_interrupt() gets called anyway when the card is ejected. So, set an already-existing flag which causes tok_interrupt() to bail out early upon card ejection. Tested by inserting and removing the PCMCIA card several times. Signed-off-by: Paul Walmsley <paul@booyaka.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09skge: default WOL should be magic only (rev2)Stephen Hemminger
By default, the skge driver now enables wake on magic and wake on PHY. This is a bad default (bug), wake on PHY means machine will never shutdown if connected to a switch. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>a Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09Merge branch 'upstream' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) sound: convert "sound" subdirectory to UTF-8 MAINTAINERS: Add cxacru website/mailing list include files: convert "include" subdirectory to UTF-8 general: convert "kernel" subdirectory to UTF-8 documentation: convert the Documentation directory to UTF-8 Convert the toplevel files CREDITS and MAINTAINERS to UTF-8. remove broken URLs from net drivers' output Magic number prefix consistency change to Documentation/magic-number.txt trivial: s/i_sem /i_mutex/ fix file specification in comments drivers/base/platform.c: fix small typo in doc misc doc and kconfig typos Remove obsolete fat_cvf help text Fix occurrences of "the the " Fix minor typoes in kernel/module.c Kconfig: Remove reference to external mqueue library Kconfig: A couple of grammatical fixes in arch/i386/Kconfig Correct comments in genrtc.c to refer to correct /proc file. Fix more "deprecated" spellos. Fix "deprecated" typoes. ... Fix trivial comment conflict in kernel/relay.c.
2007-05-09unify flush_work/flush_work_keventd and rename it to cancel_work_syncOleg Nesterov
flush_work(wq, work) doesn't need the first parameter, we can use cwq->wq (this was possible from the very beginnig, I missed this). So we can unify flush_work_keventd and flush_work. Also, rename flush_work() to cancel_work_sync() and fix all callers. Perhaps this is not the best name, but "flush_work" is really bad. (akpm: this is why the earlier patches bypassed maintainers) Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Cc: Auke Kok <auke-jan.h.kok@intel.com>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09phy: use flush_work_keventd()Andrew Morton
(akpm: bypassed maintainers, sorry. There are other patches which depend on this) Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09e1000: use flush_work_keventd()Andrew Morton
Switch e1000 over to flush_work_keventd(). This probably fixes a netdev-close versus linkwatch rtnl_lock() deadlock which nobody knew about. (akpm: bypassed maintainers, sorry. There are other patches which depend on this) Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Acked-by: Auke Kok <auke-jan.h.kok@intel.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09tg3: use flush_work_keventd()Andrew Morton
Convert tg3 over to flush_work_keventd(). Remove nasty now-unneeded deadlock avoidance logic. (akpm: bypassed maintainers, sorry. There are other patches which depend on this) Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Chan <mchan@broadcom.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09remove broken URLs from net drivers' outputMarkus Dahms
Remove broken URLs (www.scyld.com) from network drivers' logging output. URLs in comments and other strings are left intact. Signed-off-by: Markus Dahms <dahms@fh-brandenburg.de> Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Alan Cox <alan@redhat.com> igned-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix "deprecated" typoes.Robert P. J. Day
Fix remaining misspellings of "depreciated" to "deprecated." Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adaptersRoland Dreier
Add an InfiniBand driver for Mellanox ConnectX adapters. Because these adapters can also be used as ethernet NICs and Fibre Channel HBAs, the driver is split into two modules: mlx4_core: Handles low-level things like device initialization and processing firmware commands. Also controls resource allocation so that the InfiniBand, ethernet and FC functions can share a device without stepping on each other. mlx4_ib: Handles InfiniBand-specific things; plugs into the InfiniBand midlayer. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-08Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (40 commits) [netdrvr] atl1: fix build pasemi_mac: Use local-mac-address instead of mac-address if available pasemi_mac: PHY support pasemi_mac: Add msglevel support and "debug" module param pasemi_mac: Logic cleanup / rx performance improvements pasemi_mac: Minor cleanup / define fixes pasemi_mac: Add SKB reuse / copy-break pasemi_mac: Timer and interrupt fixes pasemi_mac: Abstract and fix up interrupt restart routines pasemi_mac: Move the IRQ mapping from the PCI layer to the driver tc35815: Remove unnecessary skb->dev assignment drivers/net/dm9000: Convert to generic boolean AT91RM9200 Ethernet: Fix multicast addressing AT91RM9200 Ethernet: Support additional PHYs PCMCIA-NETDEV : xirc2ps_cs: bugfix of multicast code sky2: re-enable 88E8056 for most motherboards MIPS: Drop unnecessary CONFIG_ISA from RBTX49XX ne: MIPS: Use platform_driver for ne on RBTX49XX ne: Add NEEDS_PORTLIST to control ISA auto-probe ne: Misc fixes for platform driver. ... Fix conflict in drivers/net/pasemi_mac.c (get_property() got renamed to of_get_property()) manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits) [POWERPC] Abolish powerpc_flash_init() [POWERPC] Early serial debug support for PPC44x [POWERPC] Support for the Ebony 440GP reference board in arch/powerpc [POWERPC] Add device tree for Ebony [POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now [POWERPC] MPIC U3/U4 MSI backend [POWERPC] MPIC MSI allocator [POWERPC] Enable MSI mappings for MPIC [POWERPC] Tell Phyp we support MSI [POWERPC] RTAS MSI implementation [POWERPC] PowerPC MSI infrastructure [POWERPC] Rip out the existing powerpc msi stubs [POWERPC] Remove use of 4level-fixup.h for ppc32 [POWERPC] Add powerpc PCI-E reset API implementation [POWERPC] Holly bootwrapper [POWERPC] Holly DTS [POWERPC] Holly defconfig [POWERPC] Add support for 750CL Holly board [POWERPC] Generalize tsi108 PCI setup [POWERPC] Generalize tsi108 PHY types ... Fixed conflict in include/asm-powerpc/kdebug.h manually Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08smsc-ircc2: add PNP supportBjorn Helgaas
Claim devices using PNP, unless the user explicitly specified device addresses. This can be disabled with the "smsc-ircc2.nopnp" option. This removes the need for probing legacy addresses and helps untangle IR devices from serial8250 devices. Sometimes the SMC device is at a legacy COM port address but does not use the legacy COM IRQ. In this case, claiming the device using PNP rather than 8250 legacy probe means we can automatically use the correct IRQ rather than forcing the user to use "setserial" to set the IRQ manually. If the PNP claim doesn't work, make sure you don't have a setserial init script, e.g., /etc/init.d/setserial, configured to poke in legacy COM port resources for the IRDA device. That causes the serial driver to claim resources needed by this driver. Based on this patch by Ville Syrjälä: http://www.hpl.hp.com/personal/Jean_Tourrilhes/IrDA/ir260_smsc_pnp.diff Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Keith Owens <kaos@ocs.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Jean Tourrilhes <jt@hpl.hp.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Russell King <rmk+serial@arm.linux.org.uk> Acked-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08smsc-ircc2: tidy up module parameter checkingBjorn Helgaas
To determine whether the user specified a module parameter, use some #defines instead of checking for bare magic numbers. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Keith Owens <kaos@ocs.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Jean Tourrilhes <jt@hpl.hp.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Russell King <rmk+serial@arm.linux.org.uk> Cc: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08[PATCH] bcm43xx: Remove dead configuration variable CONFIG_947XXLarry Finger
The CONFIG_BCM947XX configuration variable was designed for use by the embedded device used by the OpenWRT project. The device has been shifted to the ssb driver in bcm43xx-mac80211 and will not be used with SoftMAC. Accordingly, this "dead" configuration variable is removed. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-08[PATCH] zd1211rw: Add ID for ZyXEL AG-225H v2Daniel Drake
Tested by davo on IRC zd1211b chip 0586:3413 v4810 full 00-13-49 AL7230B_RF pa0 ----- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-08[PATCH] zd1211rw: Add ID for Sitecom WL-117Matthew Davidson
This is another "driverless" device which first presents itself as a USB CDROM drive. A separate patch has been submitted to make usb-storage ignore that device, so that zd1211rw can eject it. zd1211 chip 0df6:9075 v4916 full 00-0c-f6 AL2230_RF pa0 ---- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-08[PATCH] zd1211rw: Added new USB id for Planex GW-US54ZGLUlrich Kunitz
Alan Tam <Tam at SiuLung dot com> asked for inclusion of this device into the tree. zd1211b chip 0053:5301 v4810 high 00-90-cc AL2230_RF pa0 ---N Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-08[netdrvr] atl1: fix buildJeff Garzik
We need linux/pci.h. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08pasemi_mac: Use local-mac-address instead of mac-address if availableOlof Johansson
Use local-mac-address in the device tree instead. Fall back to mac-address for older firmware. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08pasemi_mac: PHY supportOlof Johansson
PHY support for pasemi_mac. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08pasemi_mac: Add msglevel support and "debug" module paramOlof Johansson
Add msglevel support for pasemi_mac. Move the MODULE_* defines to the top to go together with the variable (similar to tg3). Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08pasemi_mac: Logic cleanup / rx performance improvementsOlof Johansson
Logic cleanup and some performance enhancements to the RX path. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08pasemi_mac: Minor cleanup / define fixesOlof Johansson
* Remove some unused defines * Fix a couple of wrong chip register defines, and add a few more fields that might be used in the near future. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08pasemi_mac: Add SKB reuse / copy-breakOlof Johansson
Add a copy-break and recycle the SKB in the driver for small packets. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08pasemi_mac: Timer and interrupt fixesOlof Johansson
Timer and interrupt fixes: * Be pickier with what kind of interrupts are acked to avoid the device to get out of sync with the driver state * Set RX count threshhold to 1 (for NAPI interrupted mode), TX count threshold to 32. * Set timer thresholds to current max (~16ms). Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08pasemi_mac: Abstract and fix up interrupt restart routinesOlof Johansson
Abstract out (and fix up) the interrupt restart routines, making sure we start out in a consistent state. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08pasemi_mac: Move the IRQ mapping from the PCI layer to the driverOlof Johansson
Fixes for ethernet IRQ mapping, to be done in the driver instead of in the platform setup code. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08tc35815: Remove unnecessary skb->dev assignmentAtsushi Nemoto
Apply changes in commit 4c13eb6657fe9ef7b4dc8f1a405c902e9e5234e0 to newly added piece of code. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08drivers/net/dm9000: Convert to generic booleanRichard Knutsson
Convert to generic boolean. Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08AT91RM9200 Ethernet: Fix multicast addressingAndrew Victor
The order that the two 32-bit words written to the Hash Address (Low, High) Registers for matching of multicast addresses is incorrect. Signed-off-by: Lars Reemts <Lars.Reemts@entwicklung.eq-3.de> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
