git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (257 commits)
[ARM] Update mach-types
ARM: 5636/1: Move vendor enum to AMBA include
ARM: Fix pfn_valid() for sparse memory
[ARM] orion5x: Add LaCie NAS 2Big Network support
[ARM] pxa/sharpsl_pm: zaurus c3000 aka spitz: fix resume
ARM: 5686/1: at91: Correct AC97 reset line in at91sam9263ek board
ARM: 5640/1: This patch modifies the support of AC97 on the at91sam9263 ek board
ARM: 5689/1: Update default config of HP Jornada 700-series machines
ARM: 5691/1: fix cache aliasing issues between kmap() and kmap_atomic() with highmem
ARM: 5688/1: ks8695_serial: disable_irq() lockup
ARM: 5687/1: fix an oops with highmem
ARM: 5684/1: Add nuc960 platform to w90x900
ARM: 5683/1: Add nuc950 platform to w90x900
ARM: 5682/1: Add cpu.c and dev.c and modify some files of w90p910 platform
ARM: 5626/1: add suspend/resume functions to amba-pl011 serial driver
ARM: 5625/1: fix hard coded 4K resource size in amba bus detection
MMC: MMCI: convert realview MMC to use gpiolib
ARM: 5685/1: Make MMCI driver compile without gpiolib
ARM: implement highpte
ARM: Show FIQ in /proc/interrupts on CONFIG_FIQ
Fix up trivial conflict in arch/arm/kernel/signal.c.
It was due to the TIF_NOTIFY_RESUME addition in commit d0420c83f ("KEYS:
Extend TIF_NOTIFY_RESUME to (almost) all architectures") and follow-ups.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits)
netxen: update copyright
netxen: fix tx timeout recovery
netxen: fix file firmware leak
netxen: improve pci memory access
netxen: change firmware write size
tg3: Fix return ring size breakage
netxen: build fix for INET=n
cdc-phonet: autoconfigure Phonet address
Phonet: back-end for autoconfigured addresses
Phonet: fix netlink address dump error handling
ipv6: Add IFA_F_DADFAILED flag
net: Add DEVTYPE support for Ethernet based devices
mv643xx_eth.c: remove unused txq_set_wrr()
ucc_geth: Fix hangs after switching from full to half duplex
ucc_geth: Rearrange some code to avoid forward declarations
phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs
drivers/net/phy: introduce missing kfree
drivers/net/wan: introduce missing kfree
net: force bridge module(s) to be GPL
Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded
Fixed up trivial conflicts:
- arch/x86/include/asm/socket.h
converted to <asm-generic/socket.h> in the x86 tree. The generic
header has the same new #define's, so that works out fine.
- drivers/net/tun.c
fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that
switched over to using 'tun->socket.sk' instead of the redundantly
available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks
to the TUN driver") which added a new 'tun->sk' use.
Noted in 'next' by Stephen Rothwell.
MAINTAINERS
arch/arm/mm/fault.c
'w90x900' into devel
o Add QLogic copyright, add linux-driver@qlogic.com to
MAINTAINERS.
o Delete old contact information.
Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com>
Redesign tx timeout handling in line with new firmware
reset design that co-ordinates with other PCI function
drivers.
o For NX3031, first try to reset PCI function's own
context before requesting firmware reset.
o For NX2031, since firmware heartbit is not supported
directly request firmware reset.
Signed-off-by: Amit Kumar Salecha <amit@netxen.com>
Release file firmware when no firmware reset is required.
o Access on card memory through memory controller (agent)
rather than moving small pci window around. Clean up the
code for moving windows around.
o Restrict memory accesss to 64 bit, currently only firmware
download uses this.
Use 8 byte strides for firmware download into card
memory since oncard memory controller needs 8 byte
(64 bit) accesses. This avoids unnecessary rmw cycles.
Commit f6eb9b1fc1411d22c073f5264e5630a541d0f7df, "tg3: Add 5717 asic
rev" changed how the rx return ring size operations are done. It
effectively inverts the sense of the previous test, but it failed to
also invert the resulting sizes. This patch corrects that error.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
When CONFIG_INET is disabled, netxen has a build failure:
netxen_nic_main.c:(.text+0x118fd1): undefined reference to `netxen_config_indev_addr'
so make that function just an empty stub when CONFIG_INET=n.
(not "inline" since that conflicts with other declarations of it)
Acked-by: Dhananjay Phadke <dhananjay@netxen.com>
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
The Ethernet framing is used for a lot of devices these days. Most
prominent are WiFi and WiMAX based devices. However for userspace
application it is important to classify these devices correctly and
not only see them as Ethernet devices. The daemons like HAL, DeviceKit
or even NetworkManager with udev support tries to do the classification
in userspace with a lot trickery and extra system calls. This is not
good and actually reaches its limitations. Especially since the kernel
does know the type of the Ethernet device it is pretty stupid.
To solve this problem the underlying device type needs to be set and
then the value will be exported as DEVTYPE via uevents and available
within udev.
# cat /sys/class/net/wlan0/uevent
DEVTYPE=wlan
INTERFACE=wlan0
IFINDEX=5
This is similar to subsystems like USB and SCSI that distinguish
between hosts, devices, disks, partitions etc.
The new SET_NETDEV_DEVTYPE() is a convenience helper to set the actual
device type. All device types are free form, but for convenience the
same strings as used with RFKILL are choosen.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
The txq_set_wrr() function in drivers/net/mv643xx_eth.c is
unused, not even referenced under #if 0 or something like that,
which results in a compile-time warning:
drivers/net/mv643xx_eth.c:1070: warning: 'txq_set_wrr' defined but not used
Fix: remove it.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
MPC8360 QE UCC ethernet controllers hang when changing link duplex
under a load (a bit of NFS activity is enough).
PHY: mdio@e0102120:00 - Link is Up - 1000/Full
sh-3.00# ethtool -s eth0 speed 100 duplex half autoneg off
PHY: mdio@e0102120:00 - Link is Down
PHY: mdio@e0102120:00 - Link is Up - 100/Half
NETDEV WATCHDOG: eth0 (ucc_geth): transmit queue 0 timed out
Badness at c01fcbd0 [verbose debug info unavailable]
NIP: c01fcbd0 LR: c01fcbd0 CTR: c0194e44
The cure is to disable the controller before changing speed/duplex
and enable it afterwards.
Though, disabling the controller might take quite a while, so we
better not grab any spinlocks in adjust_link(). Instead, we quiesce
the driver's activity, and only then disable the controller.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
We'll need ugeth_disable() and ugeth_enable() calls earlier in the
file, so rearrange some code to avoid forward declarations.
The patch doesn't contain any functional changes.
Acked-by: Timur Tabi <timur@freescale.com>
According to specs, when auto-negotiation is disabled, Marvell PHYs need
a software reset after changing speed/duplex forcing bits. Otherwise,
the modified bits have no effect.
Error handling code following a kzalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
Error handling code following a kmalloc should free the allocated data.
// <smpl>
@r exists@
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
if (x == NULL) S
<... when != x
x->f1 = E
f(...,x->f1,...)
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
// </smpl>
And also do a better job of returning proper NET_{RX,XMIT}_ values.
Based on a patch and suggestions by Mark Smith.
This fixes CVE-2009-2903
Reported-by: Mark Smith <lk-netdev@lk-netdev.nosense.org>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (48 commits)
RDMA/iwcm: Reject the connection when the cm_id is destroyed
RDMA/cxgb3: Clean up properly on FW mismatch failures
RDMA/cxgb3: Don't ignore insert_handle() failures
MAINTAINERS: InfiniBand/RDMA mailing list transition to vger
IB/mad: Allow tuning of QP0 and QP1 sizes
IB/mad: Fix possible lock-lock-timer deadlock
RDMA/nes: Map MTU to IB_MTU_* and correctly report link state
RDMA/nes: Rework the disconn routine for terminate and flushing
RDMA/nes: Use the flush code to fill in cqe error
RDMA/nes: Make poll_cq return correct number of wqes during flush
RDMA/nes: Use flush mechanism to set status for wqe in error
RDMA/nes: Implement Terminate Packet
RDMA/nes: Add CQ error handling
RDMA/nes: Clean out CQ completions when QP is destroyed
RDMA/nes: Change memory allocation for cqp request to GFP_ATOMIC
RDMA/nes: Allocate work item for disconnect event handling
RDMA/nes: Update refcnt during disconnect
IB/mthca: Don't allow userspace open while recovering from catastrophic error
IB/mthca: Distinguish multiple devices in /proc/interrupts
IB/mthca: Annotate CQ locking
and 'nes' into for-linus
and convert PXA-based devices to gpio_pwdown where possible.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
The macro res_size in drivers/net/dm9000.c is a copy of resource_size in
linux/ioport.h. Remove the function and use resource_size instead.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
The memory for the private data is allocated using kzalloc in
alloc_etherdev (or alloc_netdev_mq respectively) so there is no need to
set it to 0 again.
Fix the offset of vlan_TCI field in cmd_desc_type0.
Signed-off-by: Amit Kumar Salecha <amit@qlogic.com>
Fix typo in checking dest ip has support before
programming destip addresses.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Oops, a stupid mistake in the original patch which adds coex 3-wire
support. Bluetooth priority gpio needs to be gpio 7.
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
This subsystem id will be used later to turn on the btcoex
support.
The preferred module is p54pci which also supports FullMAC
PCI / Cardbus devices. We schedule removal for 2.6.34. Reason
to remove this is no one really is testing prism54 anymore,
and while it works p54pci provides support for the same hardware.
It should be noted I have been told some FullMAC devices may not
have worked with the SoftMAC driver but to date we have yet to
recieve a single bug report regarding this. If there are users
out there please let us know!
Cc: aquilaver@yahoo.com
Cc: Dan Williams <dcbw@redhat.com>
Cc: Kai Engert <kengert@redhat.com>
Cc: Jean Tourrilhes <jt@hpl.hp.com>
Cc: Tim de Waal<tim.dewaal@yahoo.com>
Cc: Roy Marples <uberlord@gentoo.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Christian Lamparter <chunkeey@web.de>
Cc: Björn Steinbrink <B.Steinbrink@gmx.de>
Cc: Tim Gardner <tim.gardner@canonical.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
This fixes some gcc warnings for switch statements.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
This fixes a sparse warning in the hardware-TKIP code:
drivers/net/wireless/b43/xmit.c:272:18: warning: incorrect type in assignment (different base types)
drivers/net/wireless/b43/xmit.c:272:18: expected unsigned short [unsigned] [short] <noident>
drivers/net/wireless/b43/xmit.c:272:18: got restricted unsigned short [usertype] <noident>
The code should work correctly with and without this patch applied.
Currently, when QoS-disable is requested, we would leave QoS enabled
in firmware, but only queue frames on one queue.
Change that and also tell firmware about disabled QoS, so it
completely ignores all the QoS parameters. Also don't upload the parameters,
if QoS is disabled.
The calculated values for the ACK timeout and ACK
consume time are different then the values as
used by the Legacy drivers.
After testing from James Ledwith it appeared that
the calculated values caused a high amount of TX
failures, and the values from the Legacy drivers
were the most optimal to prevent TX failure due to
excessive retries.
The symptoms of this problem:
- Rate control module always falls back to 1Mbs
- Low throughput when bitrate was fixed
Possible side-effects (not confirmed but highly likely)
- Problems with DHCP
- Broken connections due to lack of probe response
This should fix at least:
Kernel bugzilla reports: [13362], [13009], [9273]
Fedora bugzilla reports: [443203]
but possible some additional bugs as well.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
The function res_size in drivers/net/niu.c is a copy of resource_size in
PCMCIA support works well and is not experimental anymore.
apply the conformance test limits (CTL) stored in the eeprom upon
the values calculated for the tx power (ar->power_*).
This is based on the implementation in the vendor driver
(hal/hpmain.c, line 3700 ff.) with one difference:
If any ctl mode isn't found in the eeprom, we fall back to the "lower",
legacy modes (5GHT20,11A or 2GHT20,11G,11B). Otus only did 5GHT20->11A.
Currently CTL are applied for the FCC group only.
Signed-off-by: Joerg Albert <jal2@gmx.de>
The ar9170 driver needs the defines for conformance test limit groups
and cannot include regd_common.h
Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com>
This removes the SHM spinlock.
SHM is protected by wl->mutex.
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
This removes the PIO RX work. It's not needed anymore, because
we can sleep in the threaded interrupt handler.
This removes the DMA/PIO queue locks. Locking is handled by
wl->mutex now.
This removes the TX spinlock and defers TX to a workqueue to allow
locking wl->mutex instead and to allow sleeping for register accesses.
