path: root/drivers/net
2011-05-16Merge branch 'wireless-next-2.6' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-2.6
2011-05-16mwifiex: use ieee80211_amsdu_to_8023s routineYogesh Ashok Powar
mwifiex was using its own implementation of converting 802.11n AMSDU to 802.3s. This patch removes mwifiex specific implementation and uses existing ieee80211_amsdu_to_8023s routine. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16cfg80211: make stripping of 802.11 header optional from AMSDUYogesh Ashok Powar
Currently the devices that have already stripped IEEE 802.11 header from the AMSDU SKB can not use ieee80211_amsdu_to_8023s routine. This patch enhances ieee80211_amsdu_to_8023s() API by changing mandatory removing of IEEE 802.11 header from AMSDU to optional. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k: make npending frames check as boolMohammed Shafi Shajakhan
we are not doing anything by tracking the number of pending frames. bail out when we first find a pending frame in any one of the 10 queues. Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k: make sure main_rssi is positiveMohammed Shafi Shajakhan
some times the rssi control descriptor for the main antenna may be negative like that of alternate antenna, hence before incrementing packet counts/rssi of main/alternate antenna make sure both main_rssi and alt_rssi are positive only. this avoids wrong selection of antenna due to diversity Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k: configure fast_div_bias based on diversity groupMohammed Shafi Shajakhan
configure fast diversity bias based on the antenna diversity group and based on main/alt LNA configurations. also configure main antenna and alternate antenna to gain-table 0 for diversity group 2(AR9485) Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k: Implement an API to swap main/ALT LNA'sMohammed Shafi Shajakhan
for the diversity group 2(AR9485) we swap the LNA's of main/ALT antenna based on alternate antenna's rssi average in comparision with main antenna's rssi, while for AR9285(antenna diversity group 0)we still follow the older method of looking at the packet count in alternate antenna Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: define antenna diversity groupMohammed Shafi Shajakhan
AR9285 belongs to diversity group 0 and AR9485 belongs to diversity group 2. Based on the diversity group we configure certain antenna diversity paramaters such as lna1_lna2_delta and fast diversity bias values. For AR9485 we have some gain table parameter which selects the gain table 0/1 for main and alternate antenna Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: define modules to get/set Antenna diversity paramatersMohammed Shafi Shajakhan
these are the two important modules that will be called by the antenna diversity algorithm module in the rx. this will continuosly configure the hardware based on the current diversity status obtained from the algorithm Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: config diversity based on eeprom contentsMohammed Shafi Shajakhan
* enable LNA-diversity, fast-diversity for AR9485 based on the value read from EEPROM content * if antenna diversity/combining is supported, set LNA1 for the main antenna and LNA2 for the alternate antenna based on the new diversity algorithm Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Cc: Luis Rodriguez <Luis.Rodriguez@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: define registers/macros to support Antenna diversityMohammed Shafi Shajakhan
define few registers and macros to configure/enable Antenna diversity parameters in AR9485 Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: enable Antenna diversity for AR9485Mohammed Shafi Shajakhan
read antenna diversity and combining information from the EEPROM. Enable antenna diversity/combining feature only when both LNA diversity and fast diversity are supported Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Tested-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16ath9k_hw: make antenna diversity modules chip specificMohammed Shafi Shajakhan
this is necessary to support Antenna diversity and combining in new chip sets such as AR9485, previously Antenna diversity support is available only in AR9285 Cc: Gabriel Tseng <Gabriel.Tseng@Atheros.com> Cc: Senthilkumar Balasubramanian <Senthilkumar.Balasubramanian@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16iwlwifi: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warningStephen Boyd
Enabling DEBUG_STRICT_USER_COPY_CHECKS causes the following warning: In file included from arch/x86/include/asm/uaccess.h:573, from include/net/checksum.h:25, from include/linux/skbuff.h:28, from drivers/net/wireless/iwlwifi/iwl-agn-rs.c:28: In function 'copy_from_user', inlined from 'rs_sta_dbgfs_scale_table_write' at drivers/net/wireless/iwlwifi/iwl-agn-rs.c:3099: arch/x86/include/asm/uaccess_64.h:65: warning: call to 'copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct presumably due to buf_size being signed causing GCC to fail to see that buf_size can't become negative. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16iwlegacy: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warningStephen Boyd
Enabling DEBUG_STRICT_USER_COPY_CHECKS causes the following warning: In file included from arch/x86/include/asm/uaccess.h:573, from include/net/checksum.h:25, from include/linux/skbuff.h:28, from drivers/net/wireless/iwlegacy/iwl-4965-rs.c:28: In function 'copy_from_user', inlined from 'iwl4965_rs_sta_dbgfs_scale_table_write' at drivers/net/wireless/iwlegacy/iwl-4965-rs.c:2616: arch/x86/include/asm/uaccess_64.h:65: warning: call to 'copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct presumably due to buf_size being signed causing GCC to fail to see that buf_size can't become negative. Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-13iwlagn: remove unused old_assoc parameterWey-Yi Guy
old_assoc not used, remove it Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: change default beacon intervalJohannes Berg
When the PAN context is active, but unused, it may still block scans that take more dwell time than its beacon interval (which is odd). Work around this problem by using a default beacon interval of 200 so scans will fit between. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: remove set but unused varsJohannes Berg
gcc is warning that a few variables in rate scaling are set but never otherwise used. This pointed out a few simplifications. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: alwasy send RXON with disassociate falge before associateWey-Yi Guy
Before send the RXON command with associated flag set, always do disassociate first to make sure uCode is in the correct state. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: clear STATUS_HCMD_ACTIVE bit if fail enqueueWey-Yi Guy
If fail to enqueue host command, clear the STATUS_hcmD_ACTIVE bit Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: add testmode set fixed rate commandWey-Yi Guy
Add support in testmode for setting fixed rate Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: add eeprom command to testmodeWey-Yi Guy
Add the capability to dump eeprom through testmode request Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: add testmode trace commandWey-Yi Guy
Adding testmode trace/debug capability Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: more ucode error log infoWey-Yi Guy
No functional changes, just logging more information when uCode crash, also change change the format. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: support multiple TBs per commandJohannes Berg
The current "huge" command handling is a bit confusing, and very limited since only one command may be huge at a time. Additionally, we often copy data around quite pointlessly since we could instead map the existing scan buffer for example and use it directly. This patch makes that possible. The first change is that multiple buffers may be given to each command (this change was prepared earlier so callsites don't need to change). Each of those can be mapped attached to a TB in the TFD, and the command header can use a TB (the first one) in the TFD as well. Doing this allows getting rid of huge commands in favour of mapping existing buffers. The beacon transmission is also optimised to not copy the SKB at all but use multiple TBs. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: remove unused pad argumentJohannes Berg
The pad argument to iwlagn_txq_free_tfd isn't used, remove it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: clean up TXQ indirectionJohannes Berg
All of these functions no longer need to be accessed indirectly since they're shared in all AGN devices. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: prepare for multi-TB commandsJohannes Berg
In a subsequent patch, I want to make commands use multiple TBs in a TFD. This is a simple change to prepare the data structures for this, with as of now still just a single TB supported. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13wl12xx: enter/exit psm on wowlan suspend/resumeEliad Peller
When operating as station, enter psm before suspending the device into wowlan state. Add a new completion event to signal when psm was entered successfully. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx_sdio: declare support for NL80211_WOW_TRIGGER_ANYTHING triggerEliad Peller
Since wowlan requires the ability to stay awake while the host is suspended, declare support for NL80211_WOW_TRIGGER_ANYTHING if the MMC_PM_KEEP_POWER capability is being supported. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: prevent scheduling while suspending (WoW enabled)Eliad Peller
When WoW is enabled, the interface will stay up and the chip will be powered on, so we have to flush/cancel any remaining work, and prevent the irq handler from scheduling a new work until the system is resumed. Add 2 new flags: * WL1271_FLAG_SUSPENDED - the system is (about to be) suspended. * WL1271_FLAG_PENDING_WORK - there is a pending irq work which should be scheduled when the system is being resumed. In order to wake-up the system while getting an irq, we initialize the device as wakeup device, and calling pm_wakeup_event() upon getting the interrupt (while the system is about to be suspended) Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx_sdio: set MMC_PM_KEEP_POWER flag on suspendEliad Peller
if a wow trigger was configured, set the MMC_PM_KEEP_POWER flag on suspend, so our power will be kept while the system is suspended. We needed to set this flag on each suspend attempt (when we want to keep power) Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: declare suspend/resume callbacks (for wowlan)Eliad Peller
Additionally, add wow_enabled field to wl, to indicate whether wowlan was configured. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx_sdio: set interrupt as wake_up interruptEliad Peller
set the sdio interrupt as wake_up interrupt, so we will be able to wake up the suspended system (Wake-On-Wireless) Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: remove unused flag WL1271_FLAG_IDLE_REQUESTEDLuciano Coelho
This flag is not used anymore, remove it from the list. Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: prevent sched_scan when not idle or not in station modeLuciano Coelho
The current firmware only supports scheduled scan in station mode and when idle. To prevent the firmware from crashing, return -EOPNOTSUPP when sched_scan start is called in an invalid state. Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: export scheduled scan state in debugfsLuciano Coelho
Add the sched_scanning value to the driver_status debugfs entry. Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: implement scheduled scan driver operations and reportingLuciano Coelho
This patch adds the mac80211 operations for scheduled scan and the scheduled scan results reporting. Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: add scheduled scan structures and commandsLuciano Coelho
Add firmware command structures, definitions and code to to configure, start and stop scheduled scans. Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: listen to scheduled scan eventsLuciano Coelho
Subscribe and listen to PERIODIC_SCAN_REPORT_EVENT_ID and PERIODIC_SCAN_COMPLETE_EVENT_ID in preparation for the scheduled scan implementation. Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: add configuration values for scheduled scanLuciano Coelho
Add the structures and values for driver-configured scheduled scan parameters. Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: add IEEE80211_HW_SPECTRUM_MGMT bit to the hw flagsShahar Levi
Set the spectrum management bit in the hw flags so that mac80211 will set the WLAN_CAPABILITY_SPECTRUM_MGMT bit in association requests (which in practice means that we support 802.11h spectrum management). [Reworded the commit log -- Luca.] Signed-off-by: Shahar Levi <shahar_levi@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: Don't filter beacons that include changed HT IEsShahar Levi
This patch adds a beacon filter rule to pass up the beacons that contain changed HT information elements. These beacons need to be passed to mac80211 so that it can act on such changes. [Reworded commit log -- Luca.] Signed-off-by: Shahar Levi <shahar_levi@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-13wl12xx: simplify wl1271_ssid_set()Eliad Peller
Simplify wl1271_ssid_set by re-using cfg80211_find_ie instead of reimplementing it. Additionally, add a length check to prevent a potential buffer overflow. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-05-12ath9k_hw: Fix STA connection issues with AR9380 (XB113).Senthil Balasubramanian
XB113 (AR9380) 3x3 SB 5G only cards were failing to connect to APs due to incorrect xpabiaslevel configuration. fix it. Cc: stable@kernel.org Cc: Ray Li <ray.li@greenwavereality.com> Cc: Kathy Giori <kathy.giori@atheros.com> Cc: Aeolus Yang <aeolus.yang@atheros.com> Cc: compat@orbit-lab.org Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-12mwifiex: remove mwifiex_recv_complete functionAmitkumar Karwar
The function - increments dropped rx_packet count if status code passed to it is "-1". - frees SKB buffer. But currently the function is being called with "0" status code. This patch replaces above function by dev_kfree_skb_any() call. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-12ath9k_hw: fix dual band assumption for XB113Luis R. Rodriguez
The XB113 cards are single band, 5 GHz-only, but the default settings were configured to assume it was dual band. Users of these cards then would see 2.4 GHz channels but you would never get any scan results from these channels given that the radio is not present. Cc: stable@kernel.org Cc: Fiona Cain <Fiona.Cain@atheros.com> Cc: Ray Li <ray.li@greenwavereality.com> Cc: Kathy Giori <kathy.giori@atheros.com> Cc: Aeolus Yang <aeolus.yang@atheros.com> Cc: Dan Friedman <dan.friedman@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-11libertas: Add libertas_disablemesh module parameter to disable mesh interfaceSascha Silbe
This allows individual users and deployments to disable mesh support at runtime, i.e. without having to build and maintain a custom kernel. Based on a patch by Paul Fox <pgf@laptop.org>. Signed-off-by: Sascha Silbe <silbe@activitycentral.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-11mwifiex: cleanup ioctl.hBing Zhao
Some structures and macros in ioctl.h are redundant or no longer used. Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-11mwifiex: remove redundant local structuresAmitkumar Karwar
Avoid use of local structure in the function if the structure is already allocated by the caller and the structure pointer is passed. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
