net/mac80211/main.c
Replace sizeof(bnx2x_parity_mask)/(sizeof(bnx2x_parity_mask[0]) with
ARRAY_SIZE(bnx2x_parity_mask) in drivers/net/bnx2x/bnx2x_main.c
Signed-off-by: Nikitas Angelinas <nikitasangelinas@gmail.com>
The 'wwan' devtype is meant for devices that require preconfiguration
and *every* time setup before the ethernet interface can be used, like
cellular modems which require a series of setup commands on serial ports
or other mechanisms before the ethernet interface will handle packets.
As ipheth only requires one-per-hotplug pairing setup with no
preconfiguration (like APN, phone #, etc) and the network interface is
usable at any time after that initial setup, remove the incorrect
devtype wwan.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Remove all the volatile keywords where they were used, switch to using the
proper readl/writel accessors.
Replace asm/io.h and asm/cpu.h wih linux/io.h and linux/cpu.h
Use pr_(info|err) and pr_cont where required instead of calls to printk.
Add missing pr_fmt to the driver.
One line has not been changed because it would not improve readability.
This patch fixes the following checkpatch.pl warnings:
- spaces after tabs
- space between function and arguments
- one-line statement braces
- tabs instead of spaces
Use the net_device provided net_device_stats structure.
Remove ixgbevf_get_stats() now its not needed.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Use netdev_alloc_skb_ip_align() helper and do correct allocation
Tested-by: Abraham Arce <x0066660@ti.com>
Signed-off-by: Abraham Arce <x0066660@ti.com>
Acked-by: Chris Snook <chris.snook@gmail.com>
The VF has no flash and can only do memory mapped I/O.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Reduce indentation in a couple of places
Add static function ixgbe_psum
Add temporary for adapter->stats
Did not add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
because no printk in this module used message prefixing.
Whitespace cleanups.
Move inline keyword after function type declarations.
The ordering of operations was messed up in the init and as a result when
VMDQ was enabled we were trying to enable TX rings before setting the VFTE
bits. This resulted in a ring that appeared to fail to enable when in fact
it was blocked because the VFTE bits were cleared after the reset.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Several users report issues with 32-bit adapters when plugged
into PCI slots in machines with >= 4GB ram. In particular AMD
systems with HyperTransport to PCI bridges seem to trigger the
issue, but it isn't limited to only them.
This issue is not easily reproducible here, yet still continues
to occur in the field. For e1000 on PCI devices, just disable DMA
addresses over the 4GB boundary when in PCI (not PCI-X) mode, to
prevent the issue from continuing to pop up. The performance
impact for this is negligible.
The code was refactored to move the init of the hw struct to its
own function. This allows the init to be called very early in
probe, which then allows using hw-> members for this fix.
A slight refactor to the DMA mask code was done for minor
correctness based on the instructions in DMA-API-HOWTO.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
niu_get_ethtool_tcam_all() assumes that its output buffer is the right
size, and warns before returning if it is not. However, the output
buffer size is under user control and ETHTOOL_GRXCLSRLALL is an
unprivileged ethtool command. Therefore this is at least a local
denial-of-service vulnerability.
Change it to check before writing each entry and to return an error if
the buffer is already full.
Compile-tested only.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
This patch introduces cx82310_eth driver - driver for USB ethernet port of
ADSL routers based on Conexant CX82310 chips. Such routers usually have
ethernet port(s) too which are bridged together with the USB ethernet port,
allowing the USB-connected machine to communicate to the network (and also
internet through the ADSL, of course).
This is my first driver, so please check thoroughly. As there's no protocol
documentation, it was done with usbsnoop dumps from Windows driver, some
parts (the commands) inspired by cxacru driver and also other usbnet drivers.
The driver passed my testing - some real work and also pings sized from 0 to
65507 B.
The only problem I found is the ifconfig error counter. When I return 0 (or 1
but empty skb) from rx_fixup(), usbnet increases the error counter although
it's not an error condition (because packets can cross URB boundaries). Maybe
the usbnet should be fixed to allow rx_fixup() to return empty skbs (or some
other value, e.g. 2)?
The USB ID of my device is 0x0572:0xcb01 which conflicts with some ADSL modems
using cxacru driver (they probably use the same chipset but simpler
firmware). The modems seem to use bDeviceClass 0 and iProduct "ADSL USB
MODEM", my router uses bDeviceClass 255 and iProduct "USB NET CARD". The
driver matches only devices with class 255 and checks for the iProduct string
during init. I already posted a patch for the cxacru driver to ignore these
devices.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits)
pkt_sched: Fix lockdep warning on est_tree_lock in gen_estimator
ipvs: avoid oops for passive FTP
Revert "sky2: don't do GRO on second port"
gro: fix different skb headrooms
bridge: Clear INET control block of SKBs passed into ip_fragment().
3c59x: Remove incorrect locking; correct documented lock hierarchy
ipv4: minor fix about RPF in help of Kconfig
xfrm_user: avoid a warning with some compiler
net/sched/sch_hfsc.c: initialize parent's cl_cfmin properly in init_vf()
pxa168_eth: fix a mdiobus leak
net sched: fix kernel leak in act_police
vhost: stop worker only if created
MAINTAINERS: Add ehea driver as Supported
ath9k_hw: fix parsing of HT40 5 GHz CTLs
ath9k_hw: Fix EEPROM uncompress block reading on AR9003
wireless: register wiphy rfkill w/o holding cfg80211_mutex
netlink: Make NETLINK_USERSOCK work again.
irda: Correctly clean up self->ias_obj on irda_bind() failure.
wireless extensions: fix kernel heap content leak
It causes all kinds of DMA API debugging assertions and
all straight-forward attempts to fix it have failed.
So turn off SG, and we'll tackle making this work
properly in net-next-2.6
Reported-by: Dave Jones <davej@redhat.com>
Tested-by: Dave Jones <davej@redhat.com>
This patch is a simplified version of the original patch from James Courtier-Dutton.
>From: James Courtier-Dutton
>Subject: [PATCH] Fix b44 RX FIFO overflow recovery.
>Date: Wednesday, June 30, 2010 - 1:11 pm
>This patch improves the recovery after a RX FIFO overflow on the b44
>Ethernet NIC.
>Before it would do a complete chip reset, resulting is loss of link
>for a few seconds.
>This patch improves this to do recovery in about 20ms without loss of link.
>Signed off by: James@superbug.co.uk
Signed-off-by: Mark Lord <mlord@pobox.com>
This fixes a bug introduced in commit
de847272149365363a6043a963a6f42fb91566e2
"3c59x: Use fine-grained locks for MII and windowed register access".
vortex_interrupt() holds vp->window_lock over multiple register
accesses to reduce locking overhead. However it also needs to call
vortex_error() sometimes, and that uses the regular functions for
access to windowed registers, which will try to acquire window_lock
again.
Therefore, drop window_lock around the call to vortex_error() and set
the window afterward reacquiring the lock. Since vortex_error() may
call vortex_rx(), which *does* require its caller to hold window_lock,
lift that call up into vortex_interrupt(). This also removes the
potential for calling vortex_rx() on a later-generation NIC.
Reported-and-tested-by: Jens Schüßler <jgs@trash.net> [in Debian's 2.6.32]
The time_before_eq()/time_after_eq() functions operate on unsigned
long and only work if the difference between the two compared values
is smaller than half the range of unsigned long (31 bits on i386).
Some of the variables (slave->jiffies, dev->trans_start, dev->last_rx)
used by bonding store a copy of jiffies and may not be updated for a
long time. With HZ=1000, time_before_eq()/time_after_eq() will start
giving bad results after ~25 days.
jiffies will never be before slave->jiffies, dev->trans_start,
dev->last_rx by more than possibly a couple ticks caused by preemption
of this code. This allows us to detect/prevent these overflows by
replacing time_before_eq()/time_after_eq() with time_in_range().
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
We cannot use spinlock when kmalloc is invoked with
GFP_KERNEL flag because it can sleep.
So this patch reviews the usage of spinlock within the
stmmac_resume function avoing this bug.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Reported-by: Jiri Slaby <jirislaby@gmail.com>
- Use napi_gro_receive() and vlan_gro_receive()
- Enable GRO by default
Tested on a RTL8111/8168 adapter
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
Note that the date format was fixed.
Signed-off-by: Yaniv Rosner <yanivr@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Change LED scheme for dual-media
Add required changes in order to support dual-media boards.
Group all PHY specific functions together to have an organized code
Make the needed changes for the new scheme especially around PHY
initialization, and link detection.
- The get_emac_base function was changed to enable setting different MAC
access setting for each PHY based of external configuration.
- As a part of the dual-media preparation, the save_spirom_version was
modified to accept a PHY specific version address to be saved in the
shmem. This will enable to save more than single spirom version in
different locations.
- The test_link function was changed also as a preparation for the
dual-media upcoming changes
- Duplicate initialization logic was removed from the
link_setting_status and link_initialize functions
Move all PHY specific logic from bnx2x_main into bnx2x_link.
Flow control implementation is split to be done in each PHY function.
In previous patch, common PHY functions were split in simple way to
allow easy diff. This patch comes to align code in the new functions.
In addition, the non-production BCM8072 PHY was removed.
Move the code into PHY oriented functions, and for that a new structure
is defines for each PHY which contain PHY properties and its own
functions. This also enables to encapsulate all PHY specific operations
into the PHY functions. During initialization, the PHYs will be probed
by the "bnx2x_phy_probe" function to detect which PHYs exist on-board,
and configure them accordingly. Note that the ext_phy_reset
implementation was incorporated in the ext_phy_init since it is actually
part of the PHY initialization procedure.
Start building the infrastructure for dual media by adding new component
of PHY which will be used all along the function. Modify function to
work with this component instead of the link_params.
The values didn't match the title after removing the LRO
statistics in commit fa37a9586f92051de03a13e55e5ec3880bb6783e
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
If failed to get skb frags using napi_get_frags(),
the packet is dropped.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
The CHELSIO_T1_1G ifdef isn't necessary at this point, because it is
checked in an outer ifdef level already and has no effect here.
Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de>
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Convert jeprintk to pr_err
Remove jeprintk macro define
Remove periods from end of logging messages
Coalesce format strings
bnad_set_rx_mode omit to unlock bna_lock on one fail path. Fix that.
Cc: Debashis Dutt <ddutt@brocade.com>
Cc: Rasesh Mody <rmody@brocade.com>
In this case, a device_node structure is stored in another structure that
is then freed without first decrementing the reference count of the
device_node structure.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
expression x;
identifier f;
position p1,p2;
x@p1->f = \(of_find_node_by_path\|of_find_node_by_name\|of_find_node_by_phandle\|of_get_parent\|of_get_next_parent\|of_get_next_child\|of_find_compatible_node\|of_match_node\|of_find_node_by_type\|of_find_node_with_property\|of_find_matching_node\|of_parse_phandle\|of_node_get\)(...);
... when != of_node_put(x)
kfree@p2(x)
@script:python@
p1 << r.p1;
p2 << r.p2;
cocci.print_main("call",p1)
cocci.print_secs("free",p2)
// </smpl>
Add an entry to the MAINTAINERS file for ibmveth, clean up the copyright
and add all authors. Change the name of the module to reflect the product name
over the last number of years.
Considering all the changes we have made, bump the driver version.
Signed-off-by: Santiago Leon <santil@linux.vnet.ibm.com>
These files probably came across from the skeleton driver. Remove them.
We had a driver specific assert function which wasn't enabled most of the
time. Convert them to BUG_ON and enable them all the time.
We had a few cases where we returned success on error.
Fix most of the kernel coding style issues in ibmveth.
