When uCode HW/SW error detected, dumping important CSR (Control and Status
Registers) values.
Also add "csr" debugfs file to dump the current values of CSR defined in
CSR table to syslog.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
Change name from RF_CARD_DISABLED to CT_CARD_DISABLED to match the
indication from uCode, also log the debug message when the condition
detected in iwl_rx_card_state_notif()
When building rtl8180, the following warning occurs:
CC [M] drivers/net/wireless/rtl818x/rtl8180_dev.o
drivers/net/wireless/rtl818x/rtl8180_dev.c: In function ‘rtl8180_handle_rx’:
drivers/net/wireless/rtl818x/rtl8180_dev.c:135: warning: ‘qual’ is deprecated
(declared at include/net/mac80211.h:562)
rndis_wlan didn't copy module parameters for bcm4320a to private structure.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Everything is ready now and we can enable WMM in mac80211.
Signed-off-by: Kalle Valo <kalle.valo@nokia.com>
Before transmission when aligning the buffer to 4-byte bounday, tx_hdr
needs to be updated. Otherwise debug logs print false data.
Now that necessary commands for WMM are implemented, implement queue handling
for WMM. But WMM is not enabled yet, only one queue is used.
Reviewed-by: Janne Ylalehto <janne.ylalehto@nokia.com>
Needed for WMM.
Needed for WMM.
RX is handled in a workqueue therefore allocating for GFP_ATOMIC
is overkill and not required.
Based on a patch for wl1271 by Luis R. Rodriguez.
The wakeup time calculation was too complicated, simplify it.
The original TI driver uses 100 ms timeout ELP wakeup timeout, better
to use the same. Otherwise problems with wakeup might get unnoticed.
Not all return values were checked and one exit from function didn't put
firmware sleep after the error.
This debug message was missing and caused incomplete log messages.
Sometimes when debugging the state is good info.
This patch fixes a rather embarrassing typo.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
This patch aggregates a bunch of small random changes
that won't fit really anywhere else properly.
1. move tid-locating macro into a separate function.
2. remove redundant NULL check.
3. add modulation mask definition
The flags in question were once useful for debugging.
Time has passed and now they do nothing more than
duplicating txinfo->flags.
AR9170 has the bad habit of choking when traffic builds up.
Tests have shown that this can partially be attributed to
a huge buildup of backlogged frames.
This patch removes dead infrastructure which was meant
for an out-of-tree rate control algorithm.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
BugLink: https://bugs.launchpad.net/ubuntu/+bug/254837
Spurious shared interrupts or early probing interrupts can cause the
hostap interrupt handler to oops before the driver has fully configured
the IO base port addresses. In some cases the oops can be because
the hardware shares an interrupt line, on other cases it is due to a
race condition between probing for the hardware and configuring
the IO base port. The latter occurs because the probing is required to
determin the hardware port address which is only determined when the probe
can interrupt the hardware (catch 22).
This patch catches this pre-configured condition to avoid the oops.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Acked-by: Tim Gardner <tim.gardner@canonical.com>
Acked-by: Stefan Bader <stefan.bader@canonical.com>
drivers/net/pcmcia/fmvj18x_cs.c
drivers/net/pcmcia/nmclan_cs.c
drivers/net/pcmcia/xirc2ps_cs.c
drivers/net/wireless/ray_cs.c
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (50 commits)
pcmcia: rework the irq_req_t typedef
pcmcia: remove deprecated handle_to_dev() macro
pcmcia: pcmcia_request_window() doesn't need a pointer to a pointer
pcmcia: remove unused "window_t" typedef
pcmcia: move some window-related code to pcmcia_ioctl.c
pcmcia: Change window_handle_t logic to unsigned long
pcmcia: Pass struct pcmcia_socket to pcmcia_get_mem_page()
pcmcia: Pass struct pcmcia_device to pcmcia_map_mem_page()
pcmcia: Pass struct pcmcia_device to pcmcia_release_window()
drivers/pcmcia: remove unnecessary kzalloc
pcmcia: correct handling for Zoomed Video registers in topic.h
pcmcia: fix printk formats
pcmcia: autoload module pcmcia
pcmcia/staging: update comedi drivers
PCMCIA: stop duplicating pci_irq in soc_pcmcia_socket
PCMCIA: ss: allow PCI IRQs > 255
PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socket
PCMCIA: soc_common: constify soc_pcmcia_socket ops member
PCMCIA: sa1111: remove duplicated initializers
PCMCIA: sa1111: wrap soc_pcmcia_socket to contain sa1111 specific data
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
When debugging the wifi firmware, we need to disable the wimax core to gain
some memory space. The default value will keep the wimax core enabled.
Wifi and wimax coexistence mode is set by wifi at boot time. There can be
several modes, defined by priority tables. User space components can decide
which one to select by writing to /sys/module/iwmc3200wifi/parameters/wiwi
with this patch, before bringing the interface up.
When sending the wiwi coexistence priority table, we should not tell the LMAC
that we want a response.
This update follows the firmware engineers recommendations.
The driver version number is a remnant from when there was an out-of-tree
iwlwifi driver. Now that the driver forms part of kernel source we do not
need a separate driver version. Instead, we now use the kernel version as
driver version. We maintain the previous tags used to indicate which
components the driver has been compiled with.
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
error_event_table_ptr is only set upon receipt of REPLY_ALIVE. Until
then both event log and error log will fail. Add information to indicate
which uCode encounter the failure case.
In the process of improving uCode event logging capability, the new
implementation was introduced without removing the existing
implementation. The event log will be dumped to dmesg twice.
Remove the old implementation to only log the event once upon sys
assert or request by user.
My gcc appears to be able to see past the function
boundary and notices that the variable 'behaviour'
could be used uninitialised:
drivers/net/wireless/b43/leds.c: In function ‘b43_leds_register’:
drivers/net/wireless/b43/leds.c:339: warning: ‘behaviour’ may be used uninitialized in this function
drivers/net/wireless/b43/leds.c: In function ‘b43_leds_init’:
drivers/net/wireless/b43/leds.c:262: warning: ‘behaviour’ may be used uninitialized in this function
because b43_led_get_sprominfo() didn't initialise
it in all cases.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Add PCI .shutdown method so that we can disable the device during
shutdown or reboot. Without this, the reboot doesn't work well on
some platforms.
This fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2124
Tested-by: pablo <pablolm2005@gmail.com>
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
When handling IWM_CMD_PMKID_FLUSH command, the bssid and
pmkid in pmksa are all NULL. Check it before memcpy.
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Currently, the 2GHz band is enabled unconditionally, even if the device
does not support it.
Changes-licensed-under: ISC
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
On BigEndian gcc complains:
drivers/net/wireless/airo.c: In function ‘sniffing_mode’:
drivers/net/wireless/airo.c:4809: warning: integer overflow in expression
Fix this by doing the bitwise AND on the host-endian value.
While reviewing the l2pad function to align both the header and the payload
on a DMA-capable boundary a bug was discovered where the payload would not
be properly aligned. The header_align value was used where the payload_align
value should have been used.
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
For PPC architecture with PHY Revision < 3, a read of the register
B43_MMIO_HWENABLED_LO will cause a CPU fault unless b43legacy_status()
returns a value of 2 (B43legacy_STAT_STARTED); however, one finds that
the driver is unable to associate after resuming from hibernation unless
this routine returns 1. To satisfy both conditions, the routine is rewritten
to return TRUE whenever b43legacy_status() returns a value < 2.
This patch fixes the second problem listed in the postings for Red Hat
Bugzilla #538523.
Cc: Stable <stable@vger.org>
The routine b43_is_hw_radio_enabled() has long been a problem.
B43_MMIO_HWENABLED_LO will cause a CPU fault unless b43_status()
returns a value of 2 (B43_STAT_STARTED) (BUG 14181). Fixing that
results in Bug 14538 in which the driver is unable to reassociate
after resuming from hibernation because b43_status() returns 0.
The correct fix would be to determine why the status is 0; however,
I have not yet found why that happens. The correct value is found for
my device, which has PHY revision >= 3.
Returning TRUE when the PHY revision < 3 and b43_status() returns 0 fixes
the regression for 2.6.32.
This patch fixes the problem in Red Hat Bugzilla #538523.
Tested-by: Christian Casteyde <casteyde.christian@free.fr>
This patch adds support for ethtool selftest.
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
This fixes the NULL pointer dereference Oops in the ks8851 snl network
driver during transmission. All socket buffers from the queue are
processed inside the loop, but new workqueues have been scheduled to
run.
Signed-off-by: Tristram Ha <Tristram.Ha@micrel.com>
Provide common routine for the transition of operational state for a leaf
device during a root device transition.
Signed-off-by: Patrick Mullaney <pmullaney@novell.com>
Acked-by: Patrick McHardy <kaber@trash.net>
- Replace magic values with constants
- Simplify length calculation and fix a bug
Based on valuable feedback from Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
when disabling interrupts, driver was writing with IO, this is no
necessary because on ixgbe parts the hardware can "oneshot"
disable and clear the interrupt. So on 82598/82599 use of EIAM
should avoid one posted write per interrupt when in MSI-X mode.
This should improve performance and seems to in my limited
testing, reduce CPU utilization VERY slightly.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
drop variables that had cache lines modified in simultaneous hot paths.
keep some variables modified on hot paths but make their storage per queue.
cache align DMA data buffer start addresses.
cache align (padding) some structures that end within a cacheline.
decrease the memory utilization of the tx / rx queue allocation
by changing the default ring size to 512 (from 1024). At
1024 rx entries of 2KB each (from 4kB slab) with 16 queues
ixgbe was using 64 MB of memory per port, which is not
necessary.
Users can still change queue lengths with ethtool -k.
This removes the Tx queue selection for FCoE traffic from ixgbe_xmit_frame()
and does it in the ndo_select_queue() call, moving all Tx queue selection
into a single routine.
Signed-off-by: Yi Zou <yi.zou@intel.com>
Store the user priority for FCoE and use it directly for outgoing
FCoE traffic when DCB is enabled.
