path: root/drivers/net
2006-03-27[PATCH] bcm43xx: reduce the size of bcm43xx_private by removing unneeded ↵Michael Buesch
members. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: add functions bcm43xx_dma_read/write, ↵Michael Buesch
bcm43xx_dma_tx_suspend/resume. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: receive TX status on MMIO or DMA unconditionally regarding ↵Michael Buesch
the 80211 core rev. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: fix some stuff, add a few missing mmiowb(), remove dead code.Michael Buesch
This may workaround the XMIT ERRORs some people are getting. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: Remove the mmio access printing facility overhead.Michael Buesch
2006-03-27[PATCH] bcm43xx: Abstract the locking mechanism.Michael Buesch
This is the starting point to make the driver out-of-order-MMIO-stores safe. There are more mmiowb() needed. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: Set both, the DMAmask and the coherent DMAmask.Michael Buesch
This has a potential to fix the >1G bug. But I can not test that, yet. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: fix DMA TX skb freeing in case of fragmented packets.Pete Zaitcev
It seems to me that the today's wireless-2.6 git contains bcm43xx which does not free txb's correctly, if I understand it right. Consider a situation where a txb with two skb's is sent down. The dma_tx_fragment will save the pointer to meta->txb of the first fragment. If fragments are freed in order, ieee80211_txb_free frees both skb's when the first fragment is processed. This may result in reuse of the second skb's memory. This danger is rather remote, but it seems to me that the patch below not only fixes the problem, but also makes the code simpler, which is good, right? Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: Add sysfs attributes for device specific tunables.Michael Buesch
2006-03-27[PATCH] bcm43xx: Move TX/RX related functions to its own file. Add basic ↵Michael Buesch
RTS/CTS code. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: add assert(bcm->initialized) to periodic_tasks_setup().Michael Buesch
2006-03-27[PATCH] bcm43xx: move initialized = 1 to the end of init_board.Michael Buesch
Note that the periodic work has to be started with initialized==1 Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: Workaround init_board vs IRQ race.Michael Buesch
The proper fix for this is to move IRQ enabling to the end of init_board. But this is nontrivial and needs to be done with care. Stay with this cheap workaround for now. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: Fix Kconfig typo (transfer mode default)Michael Buesch
2006-03-27[PATCH] bcm43xx: remove old unused struct.Michael Buesch
2006-03-27[PATCH] bcm43xx: split the channel helper functions, so that they can be ↵Michael Buesch
used without a valid running core. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: make bcm43xx_sprom_crc() static.Michael Buesch
2006-03-27[PATCH] bcm43xx: Move sprom lowlevel reading/writing to its own functions.Michael Buesch
2006-03-27[PATCH] bcm43xx: Code cleanups. This removes various "inline" statements and ↵Michael Buesch
reduces codesize. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: rewrite and simplify the periodic task handling.Michael Buesch
2006-03-27[PATCH] bcm43xx: fix LED code.Michael Buesch
2006-03-27[PATCH] Apple Airport: Add Kconfig note that the bcm43xx driver has to be ↵Michael Buesch
used for Airport Extreme cards. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: add a note that not all devices support PIO.Michael Buesch
2006-03-27[PATCH] bcm43xx: Partially fix PIO code. Add Kconfig option for PIO or DMA ↵Michael Buesch
mode (or both). Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: remove WX debugging.Michael Buesch
2006-03-27[PATCH] bcm43xx: fix compiletime warning (phy_xmitpower)Michael Buesch
2006-03-27[PATCH] bcm43xx: heavily increase mac_suspend timeout.Michael Buesch
2006-03-27[PATCH] bcm43xx: enable SPROM writing.Michael Buesch
2006-03-27[PATCH] bcm43xx: fix txpower reporting in WE.Michael Buesch
2006-03-27[PATCH] Sync bcm43xx_phy_initb6() with specsDanny van Dyk
2006-03-27[PATCH] bcm43xx: Wireless Ext updateMichael Buesch
Wireless Ext update: update we_version_source set enc_capa Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: basic ethtool supportMichael Buesch
This patch contains the beginnings of ethtool support for bcm43xx. It only implements get_drvinfo and get_link, but that's enough for ifplugd to use ethtool to know whether we're associated or not and then start or stop dhcp as necessary. Signed-off-by: Jason Lunz <lunz@falooley.org> Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: Remove function bcm43xx_channel_is_allowed()Michael Buesch
Geographical restriction should become part of the 80211 stack, so every driver does not have to duplicate it. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: Add more initvals sanity checks and error out, if one ↵Michael Buesch
sanity check fails. Signed-off-by: Michael Buesch <mbuesch@freenet.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] bcm43xx: Fix makefile. Remove all the "out-of-tree" stuff.Michael Buesch
2006-03-27[PATCH] bcm43xx: add DEBUG Kconfig option. Also fix indention.Michael Buesch
2006-03-27[PATCH] bcm43xx: remove redundant COPYING file.Michael Buesch
2006-03-27[PATCH] bcm43xx: Move README file to Documentation directory.Michael Buesch
2006-03-27[PATCH] bcm43xx: remove linux version compatibility code.Michael Buesch
2006-03-27[PATCH] bcm43xx: sync with svn.berlios.deMichael Buesch
2006-03-27[PATCH] bcm43xx: patch Kconfig and wireless/Makefile for importJohn W. Linville
Patch Kconfig and wireless/Makefile to merge bcm43xx 'properly' Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-27[PATCH] wireless: import bcm43xx sourcesJohn W. Linville
Import the bcm43xx driver from the upstream sources here: ftp://ftp.berlios.de/pub/bcm43xx/snapshots/bcm43xx/bcm43xx-20060123.tar.bz2 Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-26[PATCH] more s/fucn/func/ typo fixesAkinobu Mita
s/fucntion/function/ typo fixes Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: minor cleanupsSteffen Klassert
Remove some whitespaces and codingstyle issues. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: remove per-driver versioningSteffen Klassert
Remove per-driver versioning. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: use ethtool_op_get_linkSteffen Klassert
Use ethtool_op_get_link instead of vortex_get_link. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: carriercheck for forced mediaSteffen Klassert
Handle netif_carrier_{on,of} also if media is forced to 10baseT/100baseTx. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: decrease polling intervalSteffen Klassert
Set the polling interval for media changes to 5 seconds if link is down and 60 seconds if link is up. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] 3c59x: use mii_check_mediaSteffen Klassert
Check for media changes and netif_carrier by using mii_check_media() if mii is used. Signed-off-by: Steffen Klassert <klassert@mathematik.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: misc static one-file mutexesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jens Axboe <axboe@suse.de> Cc: Neil Brown <neilb@cse.unsw.edu.au> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: Greg KH <greg@kroah.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
