These drivers pass full mactime information to the stack, make them
indicate this via the new RX_FLAG_TSFT to get mac80211 to show this
information in monitor mode.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Introduce scan capabilities to WEXT so that userspace can do intelligent
things with scan behavior such as handling hidden SSIDs more gracefully.
If the driver reports a specific scan capability, the driver must
respect the options specified in the iw_scan_req structure when handling
the SIOCSIWSCAN call, unless it's mode or state does not allow it to do
so, in which case it must return an error.
This version switches to Dave Kilroy's suggestion of claiming unused
padding space for the scan_capa field.
Signed-off-by: Dan Williams <dcbw@redhat.com>
PPP synchronous tty channel driver: convert the semaphore dead_sem to a
completion
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
Change bnx2_init_napi() to void.
Warning was noted by DaveM.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Enable new tx ring and add new MSIX handler and NAPI poll function
for the new tx ring. Enable MSIX when the hardware supports it.
To separate TX IRQs into a different MSIX vector, we need to
support a new tx ring. The original tx ring will still be used
when not using MSIX.
Change bnx2_napi struct into an array and add code to manage multiple
IRQs. MSIX hardware structures and new registers are also added.
Rx related fields used in NAPI polling are moved from the main
bnx2 struct to the bnx2_napi struct.
Tx related fields used in NAPI polling are moved from the main
Introduce a bnx2_napi structure that will hold a napi_struct and
other fields to handle NAPI polling for the napi_struct. Various tx
and rx indexes and status block pointers will be moved from the main
bnx2 structure to this bnx2_napi structure.
Most NAPI path functions are modified to be passed this bnx2_napi
struct pointer.
Add a table to keep track of multiple IRQs and restructure the IRQ
request and free functions so that they can be easily expanded to
handle multiple IRQs.
This makes the code cleaner and easier to support different tx rings.
If the MTU requires more than 1 page for the SKB, enable the page ring
and calculate the size of the page ring. This will guarantee order-0
allocation regardless of the MTU size.
Fixup loopback test packet size so that we don't deal with the pages
during loopback test.
Add function to reuse a page in case of allocation or other errors.
Add code to construct the completed SKB with the additional data in
the pages.
Add new fields to keep track of the pages and the page rings.
Add functions to allocate and free pages.
Factor out the common functions that will be used to initialize the
normal RX rings and the page rings.
Change the copybreak constant RX_COPY_THRESH to 128. This same
constant will be used for the max. size of the linear SKB when pages
are used. Copybreak will be turned off when pages are used.
Add a new function to handle new SKB allocation and to prepare the
completed SKB. This makes it easier to add support for non-linear
SKB.
Define the various ring constants to make the code cleaner.
The LOOPBACK_OVERHEAD is not used in this file at all.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
X86_32 was the last user of the FASTCALL macro, now that it
uses regparm(3) by default, this macro expands to nothing.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Schedule bcm43xx for for removal in the 2.6.26 development window.
Use iov_length() instead of tun's homemade iov_total().
Only devices that are UP are in the hash, so macvlan_broadcast() doesn't
need to check for IFF_UP.
The local_mac is managed by the network device, no need to keep a
spare copy and all the management problems that could cause.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This patch adds the virtual CAN bus (vcan) network driver.
The vcan device is just a loopback device for CAN frames, no
real CAN hardware is involved.
Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de>
Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de>
* pxa-plat: (53 commits)
[ARM] 4762/1: Basic support for Toradex Colibri module
[ARM] pxa: fix mci_init functions returning -1
[ARM] 4737/1: Refactor corgi_lcd to improve readability + bugfix
[ARM] 4747/1: pcm027: support for pcm990 baseboard for phyCORE-PXA270
[ARM] 4746/1: pcm027: network support for phyCORE-PXA270
[ARM] 4745/1: pcm027: default configuration
[ARM] 4744/1: pcm027: add support for phyCORE-PXA270 CPU module
[NET] smc91x: Make smc91x use IRQ resource trigger flags
[ARM] pxa: add default config for littleton
[ARM] pxa: add basic support for Littleton (PXA3xx Form Factor Platform)
[ARM] 4664/1: Add basic support for HTC Magician PDA phones
[ARM] 4649/1: Base support for pxa-based Toshiba e-series PDAs.
[ARM] pxa: skip registers saving/restoring if entering standby mode
[ARM] pxa: fix PXA27x resume
[ARM] pxa: Avoid fiddling with CKEN register on suspend
[ARM] pxa: Add PXA3 standby code hooked into the IRQ wake scheme
[ARM] pxa: Add zylonite MFP wakeup configurations
[ARM] pxa: program MFPs for low power mode when suspending
[ARM] pxa: make MFP configuration processor independent
[ARM] pxa: remove un-used pxa3xx_mfp_set_xxx() functions
arch/arm/mach-pxa/ssp.c
This patch adds support for Toradex' PXA27x based Colibri module.
It's kept as simple as possible to only provide basic functionality.
A default config is also included.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
This patch adds SMC91x support for the phyCORE-PXA270 CPU module (aka PCM-027).
Signed-off-by: Juergen Beisert <j.beisert@pengutronix.de>
smc91x is shared between many different platforms. Each platform needs
to specify the interrupt type, and in some cases the irq type depends
on more than just the build configuration - it depends on runtime
checks.
Rather than throwing this code into the SMC_IRQ_FLAGS definition, provide
a way for these flags to be passed via the IRQ resource itself.
Note that IRQF_TRIGGER_* constants are intentionally defined to correspond
with the IORESOURCE_IRQ_* interrupt type flags, in much the same way that
the low bits of PCI iomem resources correspond with the BAR flag bits.
Also provide a way to configure smc91x to read the IRQ flags from the
resource. Once all platforms have been converted over (signified
by all definitions of SMC_IRQ_FLAGS being -1) SMC_IRQ_FLAGS should
be removed.
Acked-by: Nicolas Pitre <nico@cam.org>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Add support for Atmel's AT91CAP9 Customizable Microcontroller family.
<http://www.atmel.com/products/AT91CAP/Default.asp>
Signed-off-by: Stelian Pop <stelian@popies.net>
Signed-off-by: Andrew Victor <linux@maxim.org.za>
log_max_eqs is a 4-bit field, not a 3-bit field in the response to the
QUERY_DEV_CAP FW command, so we should mask with 0xf instead of 0x7
when reading it.
Found by Yossi Leybovitch of Mellanox.
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
There is no need for kobject_unregister() anymore, thanks to Kay's
kobject cleanup changes, so replace all instances of it with
kobject_put().
Cc: Kay Sievers <kay.sievers@vrfy.org>
Now that the old kobject_init() function is gone, rename
kobject_init_ng() to kobject_init() to clean up the namespace.
Now that the old kobject_add() function is gone, rename kobject_add_ng()
to kobject_add() to clean up the namespace.
The iseries driver wants to hang kobjects off of its driver, so, to
preserve backwards compatibility, we need to add a call to the driver
core to allow future changes to work properly.
Hopefully no one uses this function in the future and the iseries_veth
driver authors come to their senses so I can remove this hack...
Cc: Dave Larson <larson1@us.ibm.com>
Cc: Santiago Leon <santil@us.ibm.com>
This converts the code to use the new kobject functions, cleaning up the
logic in doing so.
Cc: Kyle A. Lucke <klucke@us.ibm.com>
Cc: David Gibson <dwg@au1.ibm.com>
Stop using kobject_register, as this way we can control the sending of
the uevent properly, after everything is properly initialized.
struct class_device is going away, this converts the code to use struct
device instead.
Signed-off-by: Tony Jones <tonyj@suse.de>
Cc: Jan "Yenya" Kasprzak <kas@fi.muni.cz>
sis190_tx_timeout
-> sis190_hw_start
-> sis190_soft_reset
-> msleep *splat*
PCI transactions are correctly flushed here.
The msleep() is probably useless.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: K.M. Liu <kmliu@sis.com.tw>
i ranges from 0 to 100 in the 'for' loop a few lines above.
Reported by davem.
It is already done in sis190_init_one.
More work is needed to handle correctly the PHY of the new devices
when connected to a 10Mb link but this change already helps some
users as is.
Fix for:
http://bugzilla.kernel.org/show_bug.cgi?id=9467
Cc: J. Gleacher <jgleacher@yahoo.com>
Cc: Alexandre Penasso Teixeira <alexandre@keepsoftware.com>
Cc: Arliton Rocha <arliton@gmail.com>
Cc: Juan Jose Pablos <juanjo@apertus.es>
Cc: Wipat Srutiprom <wipat.s@psu.ac.th>
