path: root/drivers/net
2008-04-29proc: remove proc_root_driverAlexey Dobriyan
Use creation by full path: "driver/foo". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (45 commits) [MIPS] Pb1200/DBAu1200: move platform code to its proper place [MIPS] Fix handling of trap and breakpoint instructions [MIPS] Pb1200: do register SMC 91C111 [MIPS] DBAu1200: fix bad SMC 91C111 resource size [NET] Kconfig: Rename MIKROTIK_RB500 -> MIKROTIK_RB532 [MIPS] IP27: Fix build bug due to missing include [MIPS] Fix some sparse warnings on traps.c and irq-msc01.c [MIPS] cevt-gt641xx: Kill unnecessary include [MIPS] DS1287: Add clockevent driver [MIPS] add DECstation I/O ASIC clocksource [MIPS] rbtx4938: minor cleanup [MIPS] Alchemy: kill unused PCI_IRQ_TABLE_LOOKUP macro [MIPS] rbtx4938: misc cleanups [MIPS] jmr3927: use generic txx9 gpio [MIPS] rbhma4500: use generic txx9 gpio [MIPS] generic txx9 gpio support [MIPS] make fallback gpio.h gpiolib-friendly [MIPS] unexport null_perf_irq() and make it static [MIPS] unexport rtc_mips_set_time() [MIPS] unexport copy_from_user_page() ...
2008-04-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: iwlwifi: Allow building iwl3945 without iwl4965. wireless: Fix compile error with wifi & leds tcp: Fix slab corruption with ipv6 and tcp6fuzz ipv4/ipv6 compat: Fix SSM applications on 64bit kernels. [IPSEC]: Use digest_null directly for auth sunrpc: fix missing kernel-doc can: Fix copy_from_user() results interpretation Revert "ipv6: Fix typo in net/ipv6/Kconfig" tipc: endianness annotations ipv6: result of csum_fold() is already 16bit, no need to cast [XFRM] AUDIT: Fix flowlabel text format ambibuity.
2008-04-28[NET] Kconfig: Rename MIKROTIK_RB500 -> MIKROTIK_RB532Ralf Baechle
The platform is actually named routerboard 532 so let's call it this. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Jeff Garzik <jeff@garzik.org>
2008-04-27iwlwifi: Allow building iwl3945 without iwl4965.Jason Riedy
If IWL3945 ever depends on IWLCORE, the silent, user-invisible IWLWIFI option can go away. Signed-off-by: Jason Riedy <jason@acm.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: mlx4_core: Add helper to move QP to ready-to-send mlx4_core: Add HW queues allocation helpers RDMA/nes: Remove volatile qualifier from struct nes_hw_cq.cq_vbase mlx4_core: CQ resizing should pass a 0 opcode modifier to MODIFY_CQ mlx4_core: Move kernel doorbell management into core IB/ehca: Bump version number to 0026 IB/ehca: Make some module parameters bool, update descriptions IB/ehca: Remove mr_largepage parameter IB/ehca: Move high-volume debug output to higher debug levels IB/ehca: Prevent posting of SQ WQEs if QP not in RTS IPoIB: Handle 4K IB MTU for UD (datagram) mode RDMA/nes: Fix adapter reset after PXE boot RDMA/nes: Print IPv4 addresses in a readable format RDMA/nes: Use print_mac() to format ethernet addresses for printing
2008-04-27e1000e triggers sparc32 gcc bugAl Viro
... and isn't possible on sparc32 boxen anyway, unless somebody had done JavaStation with PCIE lately. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25mlx4_core: Add helper to move QP to ready-to-sendYevgeny Petrilin
Avoid duplicating code in ethernet and FC modules. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-25mlx4_core: Add HW queues allocation helpersYevgeny Petrilin
Wrap doorbell, buffer and MTT allocation in helper functions for ethernet and FC modules to use. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-25Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (49 commits) [POWERPC] Add zImage.iseries to arch/powerpc/boot/.gitignore [POWERPC] bootwrapper: fix build error on virtex405-head.S [POWERPC] 4xx: Fix 460GT support to not enable FPU [POWERPC] 4xx: Add NOR FLASH entries to Canyonlands and Glacier dts [POWERPC] Xilinx: of_serial support for Xilinx uart 16550. [POWERPC] Xilinx: boot support for Xilinx uart 16550. [POWERPC] celleb: Add support for PCI Express [POWERPC] celleb: Move miscellaneous files for Beat [POWERPC] celleb: Move a file for SPU on Beat [POWERPC] celleb: Move files for Beat mmu and iommu [POWERPC] celleb: Move files for Beat hvcall interfaces [POWERPC] celleb: Move the SCC related code for celleb [POWERPC] celleb: Move the files for celleb base support [POWERPC] celleb: Consolidate io-workarounds code [POWERPC] cell: Generalize io-workarounds code [POWERPC] Add CONFIG_PPC_PSERIES_DEBUG to enable debugging for platforms/pseries [POWERPC] Convert from DBG() to pr_debug() in platforms/pseries/ [POWERPC] Register udbg console early on pseries LPAR [POWERPC] Mark udbg console as CON_ANYTIME, ie. callable early in boot [POWERPC] Set udbg_console index to 0 ...
2008-04-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-xen-next * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-xen-next: (52 commits) xen: add balloon driver xen: allow compilation with non-flat memory xen: fold xen_sysexit into xen_iret xen: allow set_pte_at on init_mm to be lockless xen: disable preemption during tlb flush xen pvfb: Para-virtual framebuffer, keyboard and pointer driver xen: Add compatibility aliases for frontend drivers xen: Module autoprobing support for frontend drivers xen blkfront: Delay wait for block devices until after the disk is added xen/blkfront: use bdget_disk xen: Make xen-blkfront write its protocol ABI to xenstore xen: import arch generic part of xencomm xen: make grant table arch portable xen: replace callers of alloc_vm_area()/free_vm_area() with xen_ prefixed one xen: make include/xen/page.h portable moving those definitions under asm dir xen: add resend_irq_on_evtchn() definition into events.c Xen: make events.c portable for ia64/xen support xen: move events.c to drivers/xen for IA64/Xen support xen: move features.c from arch/x86/xen/features.c to drivers/xen xen: add missing definitions in include/xen/interface/vcpu.h which ia64/xen needs ...
2008-04-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (48 commits) net: Fix wrong interpretation of some copy_to_user() results. xfrm: alg_key_len & alg_icv_len should be unsigned [netdrvr] tehuti: move ioctl perm check closer to function start ipv6: Fix typo in net/ipv6/Kconfig via-velocity: fix vlan receipt tg3: sparse cleanup forcedeth: realtek phy crossover detection ibm_newemac: Increase MDIO timeouts gianfar: Fix skb allocation strategy netxen: reduce stack usage of netxen_nic_flash_print smc911x: test after postfix decrement fails in smc911x_{reset,drop_pkt} net drivers: fix platform driver hotplug/coldplug forcedeth: new backoff implementation ehea: make things static phylib: Add support for board-level PHY fixups [netdrvr] atlx: code movement: move atl1 parameter parsing atlx: remove flash vendor parameter korina: misc cleanup korina: fix misplaced return statement WAN: Fix confusing insmod error code for C101 too. ...
2008-04-25Merge branch 'upstream-davem' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2008-04-25[netdrvr] tehuti: move ioctl perm check closer to function startJeff Garzik
Noticed by davem. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25via-velocity: fix vlan receiptFrancois Romieu
- vlans were using a single CAM register (see mac_set_vlan_cam) - setting the address filtering registers for vlans is not needed when there is no vlan The non-tagged interface is filtered out as soon as a tagged (!= 0) interface is created. Its traffic appears again when an zero-tagged interface is created. Tested on Via Epia SN (VT6130 chipset) with several vlans whose tag was above or beyond 255. Signed-off-by: Séguier Régis <rseguier@e-teleport.net> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-24tg3: sparse cleanupEric Dumazet
Fix the following sparse warning : drivers/net/tg3.c:4025:3: warning: context imbalance in 'tg3_restart_hw' - unexpected unlock Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25forcedeth: realtek phy crossover detectionAyaz Abdulla
This patch fixes an issue seen with the realtek 8201 phy. This phy has a problem with crossover detection and it needs to be disabled. The problem only arises on certain switches. Therefore, a module parameter has been added to allow enabling crossover detection if needed. The default will be set to disabled. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ibm_newemac: Increase MDIO timeoutsBenjamin Herrenschmidt
This patch doubles the MDIO timeouts in EMAC as there are field cases where they are two short to communicate with some PHYs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25gianfar: Fix skb allocation strategyAndy Fleming
gianfar was unable to handle failed skb allocation for rx buffers, so we were spinning until it succeeded. Actually, it was worse--we were spinning for a long time, and then silently failing. Instead, we take Stephen Hemminger's suggestion to try the allocation earlier, and drop the packet if it failed. We also make a couple of tweaks to how buffer descriptors are set up. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25netxen: reduce stack usage of netxen_nic_flash_printHarvey Harrison
Don't need to keep a struct netxen_new_user_info on the stack when we only are interested in printing the serial_num. Change to only reading the serial_num. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25smc911x: test after postfix decrement fails in smc911x_{reset,drop_pkt}Roel Kluin
When timeout reaches 0 the postfix decrement still subtracts, so the test fails. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25net drivers: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network platform drivers, to re-enable auto loading. NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support. That looks problematic in the first place (it even uses the ancient "struct device_driver" binding scheme for platform_bus!) and I suspect it will vanish soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have needed more thought to sort out. [akpm@linux-foundation.org: fix sgiseeq.c] [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25forcedeth: new backoff implementationAyaz Abdulla
This patch adds support for a new backoff algorithm for half duplex supported in newer hardware. The old method is will be designated as legacy mode. Re-seeding random values for the backoff algorithms are performed when a transmit has failed due to a maximum retry count (1 to 15, where max is considered the wraparound case of 0). Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ehea: make things staticAndrew Morton
ehea_flush_sq() and ehea_purge_sq() should be static. Cc: Jeff Garzik <jeff@garzik.org> Cc: Thomas Klein <osstklei@de.ibm.com> Cc: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25phylib: Add support for board-level PHY fixupsAndy Fleming
Sometimes the specific interaction between the platform and the PHY requires special handling. For instance, to change where the PHY's clock input is, or to add a delay to account for latency issues in the data path. We add a mechanism for registering a callback with the PHY Lib to be called on matching PHYs when they are brought up, or reset. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25[netdrvr] atlx: code movement: move atl1 parameter parsingChris Snook
Move some code from atlx.c to atl1.c to prevent build conflict with the upcoming atl2 code. No changes, just movement. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25atlx: remove flash vendor parameterChris Snook
There's no good reason to manually set the flash vendor in a module parameter, outside of an Atheros hardware lab. Remove it, so nobody accidentally bricks their board using it incorrectly. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25korina: misc cleanupFrancois Romieu
- useless initialization (korina_ope / korina_restart) - use a single variable for the status code in korina_probe and propagate the error status code from below - useless checks in korina_remove : the variables are necessarily set when korina_probe succeeds Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25korina: fix misplaced return statementFrancois Romieu
The driver takes the error unwind path without condition. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25WAN: Fix confusing insmod error code for C101 too.Krzysztof Halasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25Removing dead code in drivers/net/wan/hdlc_fr.cCédric Augonnet
The local variable "prefix" is never used anymore, and the content of this string appears a bit later, directly in a call to "alloc_netdev" after doing exactly the same if/else test. So there seems to be no point keeping those 4 lines anymore. Signed-off-by: Cédric Augonnet <cedric.augonnet@ens-lyon.org> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25tehuti: check register sizeFrancois Romieu
2008-04-25[netdrvr] typhoon: typhoon_resume - remove call to start_queueGrant Grundler
While trying to fix http://bugzilla.kernel.org/show_bug.cgi?id=8952 I looked at a few other drivers to figure out what drivers _should_ be doing for suspend/resume. I noticed typhoon driver is likely doing more than it needs to. Patch below is untested since I don't have the HW. Suspend/resume code across NIC drivers is fairly inconsistent. And I couldn't find any documentation on what the canonical sequence NICs need to do for suspend or resume. Is there any? Barring contrary advice, I'm going model the tulip suspend/resume fixes after tg3.c since a number of "modern" (< 5 years old) laptops have that and I'm silly enough to assume it works. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ibm_newemac: PowerPC 440EP/440GR EMAC PHY clock workaroundValentine Barshak
This patch adds ibm_newemac PHY clock workaround for 440EP/440GR EMAC attached to a PHY which doesn't generate RX clock if there is no link. The code is based on the previous ibm_emac driver stuff. The 440EP/440GR allows controlling each EMAC clock separately as opposed to global clock selection for 440GX. BenH: Made that #ifdef CONFIG_PPC_DCR_NATIVE for now as dcri_* stuff doesn't exist for MMIO type DCRs like Cell. Some future rework & improvements of the DCR infrastructure will make that cleaner but for now, this makes it work. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ibm_newemac: PowerPC 440GX EMAC PHY clock workaroundValentine Barshak
The PowerPC 440GX Taishan board fails to reset EMAC3 (reset timeout error) if there's no link. Because of that it fails to find PHY chip. The older ibm_emac driver had a workaround for that: the EMAC_CLK_INTERNAL/EMAC_CLK_EXTERNAL macros, which toggle the Ethernet Clock Select bit in the SDR0_MFR register. This patch does the same for "ibm,emac-440gx" compatible chips. The workaround forces clock on -all- EMACs, so we select clock under global emac_phy_map_lock. BenH: Made that #ifdef CONFIG_PPC_DCR_NATIVE for now as dcri_* stuff doesn't exist for MMIO type DCRs like Cell. Some future rework & improvements of the DCR infrastructure will make that cleaner but for now, this makes it work. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ibm_newemac Use status property for unused/unwired EMACsJosh Boyer
Convert ibm_newemac to use the of_device_is_available function when checking for unused/unwired EMACs. We leave the current check for an "unused" property to maintain backwards compatibility for older device trees. Newer device trees should simply use the standard "status" property in the EMAC node. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ibm_newemac: Fix section mismatch warningsJosh Boyer
This patch fixes several section mismatch warnings in the ibm_newemac driver similar to: WARNING: vmlinux.o(.devinit.text+0x3a04): Section mismatch in reference from the function emac_probe() to the function .devexit.text:tah_detach() The function __devinit emac_probe() references a function __devexit tah_detach(). Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ibm_newemac: Add support for 460EX/GT-type MAL rx-channel handlingStefan Roese
On some 4xx PPC's (e.g. 460EX/GT), the rx channel number is a multiple of 8 (e.g. 8 for EMAC1, 16 for EMAC2), but enabling in MAL_RXCASR needs the divided by 8 value for the bitmask. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ibm_newemac: Fix problem with jumbo frame support and EMAC V4.patchStefan Roese
This fixes the jumbo frame support on EMAC V4 systems. Now the correct bit is set depending on the EMAC version configured. Tested on Kilauea (405EX) and Canyonlands (460EX). Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25e1000e: Increment version to 0.2.1Jesse Brandeburg
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25igb: save and restore pcie/msi state to support EEH recoveryAuke Kok
To enable EEH support for pci-express network adapters, pcie/msi state needs to be saved and restored for that adapter. [after similar patches for ixgbe and e1000e from Wendy Xiong] Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Cc: Wendy Xiong <wendyx@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25e1000e: save and restore pcie/msi state to support EEH recoveryWendy Xiong
To enable EEH support for pci-express network adapters, pcie/msi state needs to be saved and restored for that adapter. Tested this EEH patch with 2ports and 4ports pci-express e1000e adapters. Signed-off-by: Wendy Xiong <wendyx@us.ibm.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25ixgbe: save and restore pcie/msi state to support EEH recoveryWendy Xiong
To enable EEH support for pci-express network adapters, pcie/msi state needs to be saved and restored for that adapter. Tested this EEH patch with Intel 10G pci-express ixgbe adapter. Signed-off-by: Wendy Xiong <wendyx@us.ibm.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25e1000e: lower ring minimum size to 64Auke Kok
The lower limit of 80 descriptors in the ring is only valid for one older 8254x chipset. All e1000e devices can use as low as 64 descriptors. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25e1000e: Fix HW Error on es2lan, ARP capture issue by BMCDavid Graham
Several components to this complex fix. The es2lan cards occasionally gave a "HW Error" especially when forcing speed. Some users also reported that the BMC stole ARP packets. The fixes include setting the proper SW_FW bits to tell the BMC that we're active and not do any un-initialization at all, so the setup routine is largely changed. Signed-off-by: David Graham <david.graham@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25e1000e: Add interrupt moderation run-time ethtool interfaceAuke Kok
The ethtool -c / -C interface can now be used to modify the irq moderation algorithm. This change does not require an adapter reset and can thus be used at all times. The adapter only supports changing/reading rx-usecs which has special values for 0, 1 and 3: 0 - no irq moderation whatsoever 1 - normal moderation favoring regular mixed traffic (default) 3 - best attempt at low latency possible at cost of CPU For values between 10 and 10000 the rx-usecs defines "the minimum time between successive irqs" in usec, unlike the module parameter. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25e1000e: cleanup several stats issuesBruce Allan
Several stats registers are completely unused and we just waste pci bus time reading them. We also omit using the high 32 bits of the GORC/ GOTC counters. We can just read clear them and only read the low registers. Mii-tool can also break es2lan if it executes a MII PHY register ioctl while the device is in autonegotiation. Unfortunately it seems that several applications and installations still perform this ioctl call periodically and especially in this crucial startup time. We can fool the ioctl by providing fail safe information that mimics the "down" link state and only perform the dangerous PHY reads once after link comes up to fill in the real values. As long as link stays up the information will not change. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25S2io: Removed rx_lock and put_lockSreenivasa Honnur
- Removed rx_lock and put_lock as the buffer replenishment and receive completion is handled serially. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25S2io: Removed receive buffer replenishment taskletSreenivasa Honnur
- Removed receive buffer replenishment tasklet s2io_tasklet and instead allocating the receive buffers in either the interrupt handler (no napi) or the napi handler (napi enabled). Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25S2io: Version update for memory leak fix during free_tx_buffersSreenivasa Honnur
- Updated version number. Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
