path: root/drivers/net
2011-03-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB: Increase DMA max_segment_size on Mellanox hardware IB/mad: Improve an error message so error code is included RDMA/nes: Don't print success message at level KERN_ERR RDMA/addr: Fix return of uninitialized ret value IB/srp: try to use larger FMR sizes to cover our mappings IB/srp: add support for indirect tables that don't fit in SRP_CMD IB/srp: rework mapping engine to use multiple FMR entries IB/srp: allow sg_tablesize to be set for each target IB/srp: move IB CM setup completion into its own function IB/srp: always avoid non-zero offsets into an FMR
2011-03-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (90 commits) mfd: Push byte swaps out of wm8994 bulk read path mfd: Rename ab8500 gpadc header mfd: Constify WM8994 write path mfd: Push byte swap out of WM8994 bulk I/O mfd: Avoid copying data in WM8994 I2C write mfd: Remove copy from WM831x I2C write function mfd: Staticise WM8994 PM ops regulator: Add a subdriver for TI TPS6105x regulator portions v2 mfd: Add a core driver for TI TPS61050/TPS61052 chips v2 gpio: Add Tunnel Creek support to sch_gpio mfd: Add Tunnel Creek support to lpc_sch pci_ids: Add Intel Tunnel Creek LPC Bridge device ID. regulator: MAX8997/8966 support mfd: Add WM8994 bulk register write operation mfd: Append additional read write on 88pm860x mfd: Adopt mfd_data in 88pm860x input driver mfd: Adopt mfd_data in 88pm860x regulator mfd: Adopt mfd_data in 88pm860x led mfd: Adopt mfd_data in 88pm860x backlight mfd: Fix MAX8997 Kconfig entry typos ...
2011-03-23rapidio: modify subsystem and driver initialization sequenceAlexandre Bounine
Subsystem initialization sequence modified to support presence of multiple RapidIO controllers in the system. The new sequence is compatible with initialization of PCI devices. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rapidio: modify configuration to support PCI-SRIO controllerAlexandre Bounine
1. Add an option to include RapidIO support if the PCI is available. 2. Add FSL_RIO configuration option to enable controller selection. 3. Add RapidIO support option into x86 and MIPS architectures. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23mfd: mfd_cell is now implicitly available to janz driversAndres Salomon
The cell's platform_data is now accessed with a helper function; change clients to use that, and remove the now-unused data_size. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: mfd_cell is now implicitly available to timberdale driversAndres Salomon
The cell's platform_data is now accessed with a helper function; change clients to use that, and remove the now-unused data_size. Note that the mfd's platform_data is marked __devinitdata. This is still correct in all cases except for the timbgpio driver, whose remove hook has been changed to no longer reference the pdata. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-22zlib: slim down zlib_deflate() workspace when possibleJim Keniston
Instead of always creating a huge (268K) deflate_workspace with the maximum compression parameters (windowBits=15, memLevel=8), allow the caller to obtain a smaller workspace by specifying smaller parameter values. For example, when capturing oops and panic reports to a medium with limited capacity, such as NVRAM, compression may be the only way to capture the whole report. In this case, a small workspace (24K works fine) is a win, whether you allocate the workspace when you need it (i.e., during an oops or panic) or at boot time. I've verified that this patch works with all accepted values of windowBits (positive and negative), memLevel, and compression level. Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Miller <davem@davemloft.net> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22IB: Increase DMA max_segment_size on Mellanox hardwareDavid Dillow
By default, each device is assumed to be able only handle 64 KB chunks during DMA. By giving the segment size a larger value, the block layer will coalesce more S/G entries together for SRP, allowing larger requests with the same sg_tablesize setting. The block layer is the only direct user of it, though a few IOMMU drivers reference it as well for their *_map_sg coalescing code. pci-gart_64 on x86, and a smattering on on sparc, powerpc, and ia64. Since other IB protocols could potentially see larger segments with this, let's check those: - iSER is fine, because you limit your maximum request size to 512 KB, so we'll never overrun the page vector in struct iser_page_vec (128 entries currently). It is independent of the DMA segment size, and handles multi-page segments already. - IPoIB is fine, as it maps each page individually, and doesn't use ib_dma_map_sg(). - RDS appears to do the right thing and has no dependencies on DMA segment size, but I don't claim to have done a complete audit. - NFSoRDMA and 9p are OK -- they do not use ib_dma_map_sg(), so they doesn't care about the coalescing. - Lustre's ko2iblnd does not care about coalescing -- it properly walks the returned sg list. This patch ups the value on Mellanox hardware to 1 GB, which matches reported firmware limits on mlx4. Signed-off-by: David Dillow <dillowda@ornl.gov> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits) IPVS: Use global mutex in ip_vs_app.c ipvs: fix a typo in __ip_vs_control_init() veth: Fix the byte counters net ipv6: Fix duplicate /proc/sys/net/ipv6/neigh directory entries. macvlan: Fix use after free of struct macvlan_port. net: fix incorrect spelling in drop monitor protocol can: c_can: Do basic c_can configuration _before_ enabling the interrupts net/appletalk: fix atalk_release use after free ipx: fix ipx_release() snmp: SNMP_UPD_PO_STATS_BH() always called from softirq l2tp: fix possible oops on l2tp_eth module unload xfrm: Fix initialize repl field of struct xfrm_state netfilter: ipt_CLUSTERIP: fix buffer overflow netfilter: xtables: fix reentrancy netfilter: ipset: fix checking the type revision at create command netfilter: ipset: fix address ranges at hash:*port* types niu: Rename NIU parent platform device name to fix conflict. r8169: fix a bug in rtl8169_init_phy() bonding: fix a typo in a comment ftmac100: use resource_size() ...
2011-03-21veth: Fix the byte countersEric W. Biederman
Commit 44540960 "veth: move loopback logic to common location" introduced a bug in the packet counters. I don't understand why that happened as it is not explained in the comments and the mut check in dev_forward_skb retains the assumption that skb->len is the total length of the packet. I just measured this emperically by setting up a veth pair between two noop network namespaces setting and attempting a telnet connection between the two. I saw three packets in each direction and the byte counters were exactly 14*3 = 42 bytes high in each direction. I got the actual packet lengths with tcpdump. So remove the extra ETH_HLEN from the veth byte count totals. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21macvlan: Fix use after free of struct macvlan_port.Eric W. Biederman
When the macvlan driver was extended to call unregisgter_netdevice_queue in 23289a37e2b127dfc4de1313fba15bb4c9f0cd5b, a use after free of struct macvlan_port was introduced. The code in dellink relied on unregister_netdevice actually unregistering the net device so it would be safe to free macvlan_port. Since unregister_netdevice_queue can just queue up the unregister instead of performing the unregiser immediately we free the macvlan_port too soon and then the code in macvlan_stop removes the macaddress for the set of macaddress to listen for and uses memory that has already been freed. To fix this add a reference count to track when it is safe to free the macvlan_port and move the call of macvlan_port_destroy into macvlan_uninit which is guaranteed to be called after the final macvlan_port_close. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21can: c_can: Do basic c_can configuration _before_ enabling the interruptsJan Altenberg
I ran into some trouble while testing the SocketCAN driver for the BOSCH C_CAN controller. The interface is not correctly initialized, if I put some CAN traffic on the line, _while_ the interface is being started (which means: the interface doesn't come up correcty, if there's some RX traffic while doing 'ifconfig can0 up'). The current implementation enables the controller interrupts _before_ doing the basic c_can configuration. I think, this should be done the other way round. The patch below fixes things for me. Signed-off-by: Jan Altenberg <jan@linutronix.de> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-20r8169: fix a bug in rtl8169_init_phy()Eric Dumazet
commit 54405cde7624 (r8169: support control of advertising.) introduced a bug in rtl8169_init_phy() Reported-and-tested-by: Piotr Hosowicz <piotr@hosowicz.com> Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by:: Oliver Neukum <oliver@neukum.org> Cc: Francois Romieu <romieu@fr.zoreil.com> Tested-by: Anca Emanuel <anca.emanuel@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-19niu: Rename NIU parent platform device name to fix conflict.David S. Miller
When the OF device driver bits were converted over to the platform device infrastructure in commit 74888760d40b3ac9054f9c5fa07b566c0676ba2d ("dt/net: Eliminate users of of_platform_{,un}register_driver") we inadvertantly created probing problems in the OF case. The NIU driver creates a dummy platform device to represent the board that contains one or more child NIU devices. Unfortunately we use the same name, "niu", as the OF device driver itself uses. The result is that we try to probe the dummy "niu" parent device we create, and since it has a NULL ofdevice pointer etc. everything explodes: [783019.128243] niu: niu.c:v1.1 (Apr 22, 2010) [783019.128810] Unable to handle kernel NULL pointer dereference [783019.128949] tsk->{mm,active_mm}->context = 000000000000039e [783019.129078] tsk->{mm,active_mm}->pgd = fffff803afc5a000 [783019.129206] \|/ ____ \|/ [783019.129213] "@'/ .. \`@" [783019.129220] /_| \__/ |_\ [783019.129226] \__U_/ [783019.129378] modprobe(2004): Oops [#1] [783019.129423] TSTATE: 0000000011001602 TPC: 0000000010052ff8 TNPC: 000000000061bbb4 Y: 00000000 Not tainted [783019.129542] TPC: <niu_of_probe+0x3c/0x2dc [niu]> [783019.129624] g0: 8080000000000000 g1: 0000000000000000 g2: 0000000010056000 g3: 0000000000000002 [783019.129733] g4: fffff803fc1da0c0 g5: fffff800441e2000 g6: fffff803fba84000 g7: 0000000000000000 [783019.129842] o0: fffff803fe7df010 o1: 0000000010055700 o2: 0000000000000000 o3: fffff803fbacaca0 [783019.129951] o4: 0000000000000080 o5: 0000000000777908 sp: fffff803fba866e1 ret_pc: 0000000010052ff4 [783019.130083] RPC: <niu_of_probe+0x38/0x2dc [niu]> [783019.130165] l0: fffff803fe7df010 l1: fffff803fbacafc0 l2: fffff803fbacaca0 l3: ffffffffffffffed [783019.130273] l4: 0000000000000000 l5: 000000007fffffff l6: fffff803fba86f40 l7: 0000000000000001 [783019.130382] i0: fffff803fe7df000 i1: fffff803fc20aba0 i2: 0000000000000000 i3: 0000000000000001 [783019.130490] i4: 0000000000000000 i5: 0000000000000000 i6: fffff803fba867a1 i7: 000000000062038c [783019.130614] I7: <platform_drv_probe+0xc/0x20> Fix by simply renaming the parent device to "niu-board". Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-19r8169: fix a bug in rtl8169_init_phy()Eric Dumazet
commit 54405cde7624 (r8169: support control of advertising.) introduced a bug in rtl8169_init_phy() Reported-by: Piotr Hosowicz <piotr@hosowicz.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Oliver Neukum <oliver@neukum.org> Cc: Francois Romieu <romieu@fr.zoreil.com> Tested-by: Anca Emanuel <anca.emanuel@gmail.com> Tested-by: Piotr Hosowicz <piotr@hosowicz.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-19bonding: fix a typo in a commentNicolas de Pesloüan
Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18ftmac100: use resource_size()Dan Carpenter
The calculation is off-by-one. It should be "end - start + 1". This patch fixes it to use resource_size() instead. Oddly, the code already uses resource size correctly a couple lines earlier when it calls request_mem_region() for this memory. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18gianfar: Fall back to software tcp/udp checksum on older controllersAlex Dubov
As specified by errata eTSEC49 of MPC8548 and errata eTSEC12 of MPC83xx, older revisions of gianfar controllers will be unable to calculate a TCP/UDP packet checksum for some alignments of the appropriate FCB. This patch checks for FCB alignment on such controllers and falls back to software checksumming if the alignment is known to be bad. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (27 commits) arch/tile: support newer binutils assembler shift semantics arch/tile: fix deadlock bugs in rwlock implementation drivers/edac: provide support for tile architecture tile on-chip network driver: sync up with latest fixes arch/tile: support 4KB page size as well as 64KB arch/tile: add some more VMSPLIT options and use consistent naming arch/tile: fix some comments and whitespace arch/tile: export some additional module symbols arch/tile: enhance existing finv_buffer_remote() routine arch/tile: fix two bugs in the backtracer code arch/tile: use extended assembly to inline __mb_incoherent() arch/tile: use a cleaner technique to enable interrupt for cpu_idle() arch/tile: sync up with <arch/sim.h> and <arch/sim_def.h> changes arch/tile: fix reversed test of strict_strtol() return value arch/tile: avoid a simulator warning during bootup arch/tile: export <asm/hardwall.h> to userspace arch/tile: warn and retry if an IPI is not accepted by the target cpu arch/tile: stop disabling INTCTRL_1 interrupts during hypervisor downcalls arch/tile: fix __ndelay etc to work better arch/tile: bug fix: exec'ed task thought it was still single-stepping ... Fix up trivial conflict in arch/tile/kernel/vmlinux.lds.S (percpu alignment vs section naming convention fix)
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-17Merge tag 'v2.6.38' of ↵Chris Metcalf
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus
2011-03-17net: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-16Merge branch 'remove' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'remove' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6629/2: aaec2000: remove support for mach-aaec2000 ARM: lh7a40x: remove unmaintained platform support Fix up trivial conflicts in - arch/arm/mach-{aaec2000,lh7a40x}/include/mach/memory.h (removed) - drivers/usb/gadget/Kconfig (USB_[GADGET_]LH7A40X removed, others added)
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-16Merge branch 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: BKL: That's all, folks fs/locks.c: Remove stale FIXME left over from BKL conversion ipx: remove the BKL appletalk: remove the BKL x25: remove the BKL ufs: remove the BKL hpfs: remove the BKL drivers: remove extraneous includes of smp_lock.h tracing: don't trace the BKL adfs: remove the big kernel lock
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-16bonding: enable netpoll without checking link statusAndy Gospodarek
Only slaves that are up should transmit netpoll frames, so there is no need to check to see if a slave is up before enabling netpoll on it. This resolves a reported failure on active-backup bonds where a slave interface is down when netpoll was enabled. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Tested-by: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16net: introduce rx_handler results and logic around thatJiri Pirko
This patch allows rx_handlers to better signalize what to do next to it's caller. That makes skb->deliver_no_wcard no longer needed. kernel-doc for rx_handler_result is taken from Nicolas' patch. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flagJiri Pirko
Since bond-related code was moved from net/core/dev.c into bonding, IFF_SLAVE_INACTIVE is no longer needed. Replace is with flag "inactive" stored in slave structure Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16bonding: wrap slave state workJiri Pirko
transfers slave->state into slave->backup (that it's going to transfer into bitfield. Introduce wrapper inlines to do the work with it. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16net: get rid of multiple bond-related netdevice->priv_flagsJiri Pirko
Now when bond-related code is moved from net/core/dev.c into bonding code, multiple priv_flags are not needed anymore. So let them rot. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16bonding: register slave pointer for rx_handlerJiri Pirko
Register slave pointer as rx_handler data. That would eventually prevent need to loop over slave devices to find the right slave. Use synchronize_net to ensure that bond_handle_frame does not get slave structure freed when working with that. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16be2net: Bump up the version numberAjit Khaparde
Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16be2net: Copyright notice change. Update to Emulex instead of ServerEnginesAjit Khaparde
2011-03-16e1000e: fix kconfig for crc32 dependencyEric Dumazet
ERROR: "crc32_le" [drivers/net/e1000e/e1000e.ko] undefined! Reported-by: Frank Peters <frank.peters@comcast.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Bruce Allan <bruce.w.allan@intel.com> Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: (21 commits) PM / Hibernate: Reduce autotuned default image size PM / Core: Introduce struct syscore_ops for core subsystems PM PM QoS: Make pm_qos settings readable PM / OPP: opp_find_freq_exact() documentation fix PM: Documentation/power/states.txt: fix repetition PM: Make system-wide PM and runtime PM treat subsystems consistently PM: Simplify kernel/power/Kconfig PM: Add support for device power domains PM: Drop pm_flags that is not necessary PM: Allow pm_runtime_suspend() to succeed during system suspend PM: Clean up PM_TRACE dependencies and drop unnecessary Kconfig option PM: Remove CONFIG_PM_OPS PM: Reorder power management Kconfig options PM: Make CONFIG_PM depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) PM / ACPI: Remove references to pm_flags from bus.c PM: Do not create wakeup sysfs files for devices that cannot wake up USB / Hub: Do not call device_set_wakeup_capable() under spinlock PM: Use appropriate printk() priority level in trace.c PM / Wakeup: Don't update events_check_enabled in pm_get_wakeup_count() PM / Wakeup: Make pm_save_wakeup_count() work as documented ...
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cma: Replace global lock in rdma_destroy_id() with id-specific one IB/cm: Cancel pending LAP message when exiting IB_CM_ESTABLISH state IB/cm: Bump reference count on cm_id before invoking callback RDMA/cma: Fix crash in request handlers IB/ipath: Don't reset disabled devices IB/qib: Fix M_Key field in SubnGet and SubnGetResp MADs IB/qib: Set default LE2 value for active cables to 0 RDMA/cxgb4: Debugfs dump_qp() updates RDMA/cxgb4: Dispatch FATAL event on EEH errors RDMA/cxgb4: Use ULP_MODE_TCPDDP RDMA/cxgb4: Enable on-chip SQ support by default RDMA/cxgb4: Do CIDX_INC updates every 1/16 CQ depth CQE reaps RDMA/cxgb4: Remove db_drop_task RDMA/cxgb4: Turn on delayed ACK IB/qib: Return correct MAD when setting link width to 255
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-15xen network backend driverIan Campbell
netback is the host side counterpart to the frontend driver in drivers/net/xen-netfront.c. The PV protocol is also implemented by frontend drivers in other OSes too, such as the BSDs and even Windows. The patch is based on the driver from the xen.git pvops kernel tree but has been put through the checkpatch.pl wringer plus several manual cleanup passes and review iterations. The driver has been moved from drivers/xen/netback to drivers/net/xen-netback. One major change from xen.git is that the guest transmit path (i.e. what looks like receive to netback) has been significantly reworked to remove the dependency on the out of tree PageForeign page flag (a core kernel patch which enables a per page destructor callback on the final put_page). This page flag was used in order to implement a grant map based transmit path (where guest pages are mapped directly into SKB frags). Instead this version of netback uses grant copy operations into regular memory belonging to the backend domain. Reinstating the grant map functionality is something which I would like to revisit in the future. Note that this driver depends on 2e820f58f7ad "xen/irq: implement bind_interdomain_evtchn_to_irqhandler for backend drivers" which is in linux next via the "xen-two" tree and is intended for the 2.6.39 merge window: git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen.git stable/backends this branch has only that single commit since 2.6.38-rc2 and is safe for cross merging into the net branch. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15bonding: Improve syslog message at device creation timePhil Oester
When the bonding module is loaded, it creates bond0 by default. Then, when attempting to create bond0, the following messages are printed to syslog: kernel: bonding: bond0 is being created... kernel: bonding: Bond creation failed. Which seems to indicate a problem, when in reality there is no problem. Since the actual error code is passed down from bond_create, make use of it to print a bit less ominous message: kernel: bonding: bond0 is being created... kernel: bond0 already exists. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15bonding: Call netif_carrier_off after register_netdevicePhil Oester
Bringing up a bond interface with all network cables disconnected does not properly set the interface as DOWN because the call to netif_carrier_off occurs too early in bond_init. The call needs to occur after register_netdevice has set dev->reg_state to NETREG_REGISTERED, so that netif_carrier_off will trigger the call to linkwatch_fire_event. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15bonding: Incorrect TX queue offsetPhil Oester
When packets come in from a device with >= 16 receive queues headed out a bonding interface, syslog gets filled with this: kernel: bond0 selects TX queue 16, but real number of TX queues is 16 because queue_mapping is offset by 1. Adjust return value to account for the offset. This is a revision of my earlier patch (which did not use the skb_rx_queue_* helpers - thanks to Ben for the suggestion). Andy submitted a similar patch which emits a pr_warning on invalid queue selection, but I believe the log spew is not useful. We can revisit that question in the future, but in the interim I believe fixing the core problem is worthwhile. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15Merge branch 'master' of ↵David S. Miller
2011-03-15be2net: Fix UDP packet detected status in RX complPadmanabh Ratnakar
Status of UDP packet detection not getting populated in RX completion structure. This is required in csum_passed() routine. Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15netxen: support for GbE port settingsSony Chacko
o Enable setting speed and auto negotiation parameters for GbE ports. o Hardware do not support half duplex setting currently. David Miller: Amit please update your patch to silently reject link setting attempts that are unsupported by the device. Signed-off-by: Sony Chacko <sony.chacko@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
