__napi_schedule might raise softirq but nothing
causes do_softirq to trigger, so it does not in fact
run. As a result,
the error message "NOHZ: local_softirq_pending 08"
sometimes occurs during boot of a KVM guest when the network service is
started and we are oom:
Bringing up loopback interface: [ OK ]
Bringing up interface eth0:
Determining IP information for eth0...NOHZ: local_softirq_pending 08
done.
[ OK ]
Further, receive queue processing might get delayed
indefinitely until some interrupt triggers:
virtio_net expected napi to be run immediately.
One way to cause do_softirq to be executed is by
invoking local_bh_enable(). As __napi_schedule is
normally called from bh or irq context, this
seems to make sense: disable bh before __napi_schedule
and enable afterwards.
In fact it's a very complicated way of calling do_softirq(),
and works since this function is only used when we are not
in interrupt context. It's not hot at all, in any ideal scenario.
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
Tested-by: Ulrich Obergfell <uobergfe@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
John Linville says:
Here are three more fixes that some of my developers are desperate to
see included in 3.4...
Johan Hedberg went to some length justifyng the inclusion of these two
Bluetooth fixes:
"The device_connected fix should be quite self-explanatory, but it's
actually a wider issue than just for keyboards. All profiles that do
incoming connection authorization (e.g. headsets) will break without it
with specific hardware. The reason it wasn't caught earlier is that it
only occurs with specific Bluetooth adapters.
As for the security level patch, this fixes L2CAP socket based security
level elevation during a connection. The HID profile needs this (for
keyboards) and it is the only way to achieve the security level
elevation when using the management interface to talk to the kernel
(hence the management enabling patch being the one that exposes this"
The rtlwifi fix addresses a regression related to firmware loading,
as described in kernel.org bug 43187. It basically just moves a hunk
of code to a more appropriate place.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
Andy reported pch_gbe triggered "NETDEV WATCHDOG" errors.
May 11 11:06:09 kontron kernel: WARNING: at net/sched/sch_generic.c:261
dev_watchdog+0x1ec/0x200() (Not tainted)
May 11 11:06:09 kontron kernel: Hardware name: N/A
May 11 11:06:09 kontron kernel: NETDEV WATCHDOG: eth0 (pch_gbe):
transmit queue 0 timed out
It seems pch_gbe has a racy tx path (races with TX completion path)
Remove tx_queue_lock lock since it has no purpose, we must use tx_lock
instead.
Reported-by: Andy Cress <andy.cress@us.kontron.com>
Tested-by: Andy Cress <andy.cress@us.kontron.com>
Needs to be tagged with FLAG_WWAN, which since it has generic
descriptors, won't happen if we don't override the generic
driver info.
Cc: Oliver Neukum <oliver@neukum.org>
Cc: stable@vger.kernel.org
Signed-off-by: Dan Williams <dcbw@redhat.com>
Acked-by: Oliver Neukum <oliver@neukum.org>
Commit 4231d47e6fe69f061f96c98c30eaf9fb4c14b96d(net/usbnet: avoid
recursive locking in usbnet_stop()) fixes the recursive locking
problem by releasing the skb queue lock before unlink, but may
cause skb traversing races:
- after URB is unlinked and the queue lock is released,
the refered skb and skb->next may be moved to done queue,
even be released
- in skb_queue_walk_safe, the next skb is still obtained
by next pointer of the last skb
- so maybe trigger oops or other problems
This patch extends the usage of entry->state to describe 'start_unlink'
state, so always holding the queue(rx/tx) lock to change the state if
the referd skb is in rx or tx queue because we need to know if the
refered urb has been started unlinking in unlink_urbs.
The other part of this patch is based on Huajun's patch:
always traverse from head of the tx/rx queue to get skb which is
to be unlinked but not been started unlinking.
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: Oliver Neukum <oneukum@suse.de>
Cc: stable@kernel.org
In commit b0302ab, the rtlwifi family of drivers was converted to use
asynchronous firmware loading. Unfortumately, the implementation was
racy, and the ieee80211 routines could be started before rtl_init_core()
was called to setup the data.
This patch fixes the bug noted in https://bugzilla.kernel.org/show_bug.cgi?id=43187.
Reported-by: Joshua Roys <Joshua.Roys@gtri.gatech.edu>
Tested-by: Neptune Ning <frostyplanet@gmail.com>
Cc: Stable <stable@vger.kernel.org> [3.3]
I applied the wrong version of Jiri's bonding fix in commit
13a8e0c8cdb43982372bd6c65fb26839c8fd8ce9 ("bonding: don't increase
rx_dropped after processing LACPDUs")
I applied v3, which introduces warnings I asked him to fix,
instead of v4 which properly takes care of those issues.
This inter-diffs such that the warnings are now gone.
If a link change interrupt comes in we just clear the interrupt
and continue along without notifying the upper networking layers
that the link has changed. Use the mii_check_link() function to
update the link status whenever a link change interrupt occurs.
Cc: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Ethernet vlan header is not on the packet and kept in the skb->vlan_tci
when it comes from lower dev. This patch inserts vlan header in user
buffer during skb copy on user read.
Signed-off-by: Basil Gor <basil.gor@gmail.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Since commit 3aba891d, bonding processes LACP frames (802.3ad
mode) with bond_handle_frame(). Currently a copy of the skb is
made and the original is left to be processed by other
rx_handlers and the rest of the network stack by returning
RX_HANDLER_ANOTHER. As there is no protocol handler for
PKT_TYPE_LACPDU, the frame is dropped and dev->rx_dropped
increased.
Fix this by making bond_handle_frame() return RX_HANDLER_CONSUMED
if bonding has processed the LACP frame.
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
This reverts commit 8a83a00b0735190384a348156837918271034144.
It causes regressions for S390 devices, because it does an
unconditional DST drop on SKBs for vlans and the QETH device
needs the neighbour entry hung off the DST for certain things
on transmit.
Arnd can't remember exactly why he even needed this change.
drivers/net/macvlan.c
net/8021q/vlan_dev.c
net/core/dev.c
The NEQ interrupt is only triggered when there was no previous pending
interrupt. If we request irq handling after an interrupt has occurred,
we will never get an interrupt until we call H_RESET_EVENTS.
Events seem to be cleared when we first register the NEQ. So, when we
requested irq handling right after registering it, a possible race with
an interrupt was much less likely. Now, there is a chance we may lose
this race and never get any events.
The fix here is to poll and acknowledge any events that might have
happened right after registering the irq handler.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Since the caller (PM resume code) is not the one holding rtnl, when taking the
'else' branch rtnl may be released at any moment, thereby defeating the whole
purpose of this code block.
Signed-off-by: Benjamin Poirier <bpoirier@suse.de>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
The r8169 may get stuck or show bad behaviour after activating TSO :
the net_device is not stopped when it has no more TX descriptors.
This problem comes from TX_BUFS_AVAIL which may reach -1 when all
transmit descriptors are in use. The patch simply tries to keep positive
values.
Tested with 8111d(onboard) on a D510MO, and with 8111e(onboard) on a
Zotac 890GXITX.
Signed-off-by: Julien Ducourthial <jducourt@free.fr>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
If RSS is disabled on the PF (efx->n_rx_channels == 1) we try to set
up the indirection table so that VFs can use it, setting
efx->rss_spread = efx_vf_size(efx). But if SR-IOV was disabled at
compile time, this evaluates to 0 and we end up dividing by zero when
initialising the table.
I considered changing the fallback definition of efx_vf_size() to
return 1, but its value is really meaningless if we are not going to
enable VFs. Therefore add a condition of efx_sriov_wanted(efx) in
efx_probe_interrupts().
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Some RNDIS devices include a bogus CDC Union descriptor pointing
to non-existing interfaces. The RNDIS code is already prepared
to handle devices without a CDC Union descriptor by hardwiring
the driver to use interfaces 0 and 1, which is correct for the
devices with the bogus descriptor as well. So we can reuse the
existing workaround.
Cc: Markus Kolb <linux-201011@tower-net.de>
Cc: Iker Salmón San Millán <shaola@esdebian.org>
Cc: Jonathan Nieder <jrnieder@gmail.com>
Cc: 655387@bugs.debian.org
Signed-off-by: Bjørn Mork <bjorn@mork.no>
This is a bug fix for an "interface fails to load" issue.
The issue occurs when bnx2x driver loads after UNDI driver was previously
loaded over the chip. In such a scenario the UNDI driver is loaded and operates
in the pre-boot kernel, within its own specific host memory address range.
When the pre-boot stage is complete, the real kernel is loaded, in a new and
distinct host memory address range. The transition from pre-boot stage to boot
is asynchronous from UNDI point of view.
A race condition occurs when UNDI driver triggers a DMAE transaction to valid
host addresses in the pre-boot stage, when control is diverted to the real
kernel. This results in access to illegal addresses by our HW as the addresses
which were valid in the preboot stage are no longer considered valid.
Specifically, the 'was_error' bit in the pci glue of our device is set. This
causes all following pci transactions from chip to host to timeout (in
accordance to the pci spec).
Signed-off-by: Ariel Elior <ariele@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Silence sparse warnings shown below:
drivers/net/ethernet/intel/e1000/e1000_main.c:3435:17: warning:
cast to restricted __le64
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
igb and ixgbe incorrectly call netdev_tx_reset_queue() from
i{gb|xgbe}_clean_tx_ring() this sort of works in most cases except
when the number of real tx queues changes. When the number of real
tx queues changes netdev_tx_reset_queue() only gets called on the
new number of queues so when we reduce the number of queues we risk
triggering the watchdog timer and repeated device resets.
So this is not only a cosmetic issue but causes real bugs. For
example enabling/disabling DCB or FCoE in ixgbe will trigger this.
CC: Alexander Duyck <alexander.h.duyck@intel.com>
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Tested-by: John Bishop <johnx.bishop@intel.com>
By default, iwlwifi uses order-1 pages (8 KB) to store incoming frames,
but doesnt say so in skb->truesize.
This makes very possible to exhaust kernel memory since these skb evade
normal socket memory accounting.
As struct ieee80211_hdr is going to be pulled before calling IP stack,
there is no need to use dev_alloc_skb() to reserve NET_SKB_PAD bytes.
alloc_skb() is ok in this driver, allowing more tailroom.
Pull beginning of frame in skb header, in the hope we can reuse order-1
pages in the driver immediately for small frames and reduce their
truesize to the minimum (linear skbs)
Cc: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Neal Cardwell <ncardwell@google.com>
After this commit:
commit aacc1bea190d731755a65cb8ec31dd756f4e263e
Author: Multanen, Eric W <eric.w.multanen@intel.com>
Date: Wed Mar 28 07:49:09 2012 +0000
ixgbe: driver fix for link flap
The BIT_APP_UPCHG bit is no longer set when ixgbe_dcbnl_set_all() is
called. This results in the FCoE app user priority never getting set
and the driver will not configure the tx_rings correctly for FCoE
packets which use the SAN MTU and FCoE offloads.
We resolve this regression by fixing ixgbe_copy_dcb_cfg() to also
check for FCoE application changes. Additionally, we can drop the
IEEE variants of get_dcb_app() because this path is never called
with the IEEE mode enabled.
Tested-by: Ross Brattain <ross.b.brattain@intel.com>
It was possible for shutdown to pull the rug out from other driver entry
points. Now we just grab the rtnl lock before taking everything apart.
Thanks to Hariharan for noticing this tight race condition.
Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com>
Cc: Hariharan Nagarajan <hanagara@cisco.com>
Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com>
WakeOnLan was broken in this driver because gp->asleep_wol is a 1-bit
bitfield and it was being assigned WAKE_MAGIC, which is (1 << 5).
gp->asleep_wol remains 0 and the machine never wakes up. Fixed by casting
gp->wake_on_lan to bool. Tested on an iBook G4.
Signed-off-by: Gerard Lledo <gerard.lledo@gmail.com>
If register_netdev returns failure, the dev->interrupt and
its transfer buffer should be released, so just fix it.
The transfer buffer of dev->interrupt is allocated in .probe path,
but not freed in .disconnet path, so mark the interrupt URB as
URB_FREE_BUFFER to free the buffer when the URB is destroyed.
Acked-by: Oliver Neukum <oneukum@suse.de>
Creating a VLAN interface on top of ucc_geth adds 4 bytes
to the frame and the HW controller is not prepared to
TX a frame bigger than 1518 bytes which is 4 bytes too
small for a full VLAN frame. Add 16 bytes which will handle
the a simple VLAN and leaves 12 bytes for future expansion.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
In a busy network we see ucc_geth is dropping RX pkgs every now
and then. Increase the RX queues HW descriptors from
16 to 32 to deal with this.
This reverts commit a844adfd7bee4edc66d337de6c33b348e83552a8.
The commit a844adfd is degrading rx sensitivity of lower rate in
HT40 mode and it is confirmed that reverting the change is
improving rx sensitivity.
spur_freq_sd (for self-corr in AGC) is defined with respect to the
center of each 20MHz channel while spur_phase_delta (for self-corr
in Rx and spur data filter) is defined with respect to the center
of current RF channel.
So in short, we need to subtract spur_freq_sd (for self-corr in AGC)
by the offset between the center of primary20 and the center of RF
channel in SW. This offset could be +/10 MHz for dynamic 40.
Cc: Madhan Jaganathan <madhanj@qca.qualcomm.com>
Signed-off-by: Kai Shi <kaishi@qca.qualcomm.com>
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
dpc_tl_lock is not acquired in the error handle code for bus down.
But it's unlocked using spin_unlock_irqrestore after finishing task
list walk down. Grab the lock before breaking the loop to avoid a
double unlock.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Franky Lin <frankyl@broadcom.com>
Bug: The VLAN bit of the MAC RX Status Word is unreliable in several older
supported chips. Sometimes the VLAN bit is not set for valid VLAN packets
and also sometimes the VLAN bit is set for non-VLAN packets that came after
a VLAN packet. This results in a receive length error when VLAN hardware
tagging is enabled.
Fix: Variation on original fix proposed by Mirko.
The VLAN information is decoded in the status loop, and can be
applied to the received SKB there. This eliminates the need for the
separate tag field in the interface data structure. The tag has to
be copied and cleared if packet is copied. This version checked out
with vlan and normal traffic.
Note: vlan_tx_tag_present should be renamed vlan_tag_present, but that
is outside scope of this.
Reported-by: Mirko Lindner <mlindner@marvell.com>
When a small packet is received, the driver copies it to a new skb to allow
reusing the full size Rx buffer. The copy was propogating the checksum offload
but not the receive hash information. The bug is impact was mostly harmless
and therefore not observed until reviewing this area of code.
The driver calls cxgb_vlan_mode() from init_one(). This calls into
synchronize_rx(), which locks all the q locks, but the q locks are not
initialized until cxgb_up() -> setup_sge_qsets(). So move the call to
cxgb_vlan_mode() into cxgb_up(), after the call to setup_sge_qsets().
We also move the body of these functions up higher to avoid having to
a forward declaration.
This was found because of the lockdep warning:
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
Pid: 323, comm: work_for_cpu Not tainted 3.4.0-rc5 #28
Call Trace:
[<ffffffff8106e767>] register_lock_class+0x108/0x2d0
[<ffffffff8106ff42>] __lock_acquire+0xd3/0xd06
[<ffffffff81070fd0>] lock_acquire+0xbf/0xfe
[<ffffffff813862a6>] _raw_spin_lock_irq+0x36/0x45
[<ffffffffa01e71aa>] cxgb_vlan_mode+0x96/0xcb [cxgb3]
[<ffffffffa01f90eb>] init_one+0x8c4/0x980 [cxgb3]
[<ffffffff811fcbf0>] local_pci_probe+0x3f/0x70
[<ffffffff81042206>] do_work_for_cpu+0x10/0x22
[<ffffffff810482de>] kthread+0xa1/0xa9
[<ffffffff8138e234>] kernel_thread_helper+0x4/0x10
Contrary to what lockdep says, the code is not fine: we are locking an
uninitialized spinlock.
Signed-off-by: Roland Dreier <roland@purestorage.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net
With the support to bounce buffer added, the skb is coming as nonlinear in the
case of non-DDPed data frames for FCoE, which is mostly ok as the FCoE stack
would take care of that. However, for target mode, we have to set the FC CRC
and FC EOF field to allow the protocol stack to not drop the frame for the last
data frame of that sequence. So fix this by linearizing the skb first before
doing skb_put().
Signed-off-by: Yi Zou <yi.zou@intel.com>
Tested-by: Marcus Dennis <marcusx.e.dennis@intel.com>
The driver was freeing memory in shutdown instead of remove. As a result
we were leaking memory if IEEE DCB was enabled and we loaded/unloaded the
driver. This change moves the freeing of the memory into the remove
routine where it belongs.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Acked-by: John Fastabend <john.r.fastabend@intel.com>
Maybe it's a typo, but it cause that igbvf can't be initialized successfully.
Set perm_addr value using valid dev_addr, although which is equal to hw.mac.addr.
Signed-off-by: Samuel Liao <samuelliao@tencent.com>
Signed-off-by: Shan Wei <davidshan@tencent.com>
This patch sets the automatic speed and duplex detection bits
in MAC_CR to enable the mac to determine its speed automatically
from the phy.
Note this must be done BEFORE the receiver or transmitter is
enabled.
Signed-off-by: Stephane Fillod <fillods@users.sf.net>
Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net>
also explicitly set the phy to advertise 1000 speeds
smsc75xx phy interrupt acknowledge needs an mdio_write to clear
PHY_INT_SRC instead of just a read like in smsc95xx.
fix bug in phy_init loop that was ignoring BMCR reset bit, akin to smsc95xx's d946092000698fd204d82a9d239103c656fb63bf
smsc75xx needs MII_ACCESS_BUSY to be set to correctly trigger mdio I/O. Note smsc75xx is different from smsc95xx in this regard.
changes
This patch fixes the same issue as reported on smsc95xx, where the
usb device is connected with no ethernet cable plugged-in.
Without this patch sysfs reports the cable as present
flag@flag-desktop:~$ cat /sys/class/net/eth0/carrier
1
while it's not:
flag@flag-desktop:~$ sudo mii-tool eth0
eth0: no link
This driver currently leaves elp_work behind when stopping, which
occasionally results in data corruption because work function ends
up accessing freed memory, typical symptoms of this are various
worker_thread crashes. Fix it by cancelling elp_work.
Cc: stable@vger.kernel.org # v2.6.37+
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Currently SDIO glue frees it's own structure before calling
wl1251_free_hw(), which in turn calls ieee80211_unregister_hw().
The later call may result in a need to communicate with the chip
to stop it (as it happens now if the interface is still up before
rmmod), which means calls are made back to the glue, resulting in
freed memory access.
Fix this by freeing glue data last.
