path: root/drivers/net
2009-10-24sfc: Merge sfe4001.c into falcon_boards.cBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24sfc: Rename Falcon-specific board code and typesBen Hutchings
Siena will require entirely different board code. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24sfc: Remove redundant hardware initialisationBen Hutchings
2009-10-24sfc: Remove redundant header gmii.hBen Hutchings
2009-10-22sfc: 10Xpress: Report support for pause framesBen Hutchings
Commits 27fbc7d 'mdio: Expose pause frame advertising flags to ethtool' and c634263 'sfc: 10Xpress: Initialise pause advertising flags' added to our reported advertising flags. efx_mdio_set_settings() requires that all advertising flags are also present in the supported flags, so make sure that is true. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-21qlge: Add ethtool register dump function.Ron Mercer
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-21qlge: Add ethtool wake on LAN function.Ron Mercer
2009-10-21qlge: Add ethtool blink function.Ron Mercer
2009-10-21qlge: Add ethtool get/set pause parameter.Ron Mercer
2009-10-20can: provide library functions for skb allocationWolfgang Grandegger
This patch makes the private functions alloc_can_skb() and alloc_can_err_skb() of the at91_can driver public and adapts all drivers to use these. While making the patch I realized, that the skb's are *not* setup consistently. It's now done as shown below: skb->protocol = htons(ETH_P_CAN); skb->pkt_type = PACKET_BROADCAST; skb->ip_summed = CHECKSUM_UNNECESSARY; *cf = (struct can_frame *)skb_put(skb, sizeof(struct can_frame)); memset(*cf, 0, sizeof(struct can_frame)); The frame is zeroed out to avoid uninitialized data to be passed to user space. Some drivers or library code did not set "pkt_type" or "ip_summed". Also, "__constant_htons()" should not be used for runtime invocations, as pointed out by David Miller. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-19i2400m-sdio: select IWMC3200TOP in KconfigTomas Winkler
i2400m-sdio requires iwmc3200top for its operation Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-19iwmc3200wifi: select IWMC3200TOP in KconfigTomas Winkler
iwmc3200wifi requires iwmc3200top for its operation Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-19qlge: Size RX buffers based on MTU.Ron Mercer
Change RX large buffer size based on MTU. If pages are larger than the MTU the page is divided up into multiple chunks and passed to the hardware. When pages are smaller than MTU each RX buffer can contain be comprised of up to 2 pages. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18cosa: Kill off the use of the old ioctl pathAlan Cox
Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17cxgb3: No need to wake queue in xmit handlerKrishna Kumar
The xmit handler doesn't need to wake the queue after stopping it temporarily (some other drivers are doing the same). Patch on net-next-2.6, multiple netperf sessions tested. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17netxen; update version to 4.0.62Dhananjay Phadke
Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17netxen: sysfs control for auto firmware recoveryNarender Kumar
Firmware hang detection and recovery (reset) need to be disabled for diagnostic tools, which can run some disruptive tests. This adds a driver level control to turn off this feature by diag tools. Signed-off-by: Narender Kumar <narender.kumar@qlogic.com> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17netxen: fix error codes in for tools accessDhananjay Phadke
Use -EIO or -EINVAL as error codes, these can get passed up to applications (tools). Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17netxen: onchip memory access changeAmit Kumar Salecha
Add support for different windowing scheme for on chip memory in future chip revisions. This is required by diagnostic tools. Signed-off-by: Amit Kumar Salecha <amit@netxen.com> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17netxen: reset sequence changesAmit Kumar Salecha
Future revisions need different chip reset sequence and firmware initialization. Also clean up some never used debug code. Signed-off-by: Amit Kumar Salecha <amit@netxen.com> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17netxen: 128 memory controller supportAmit Kumar Salecha
Future revisions of the chip have 128 bit memory transactions. Require drivers to implement rmw in case of sub-128 bit accesses by driver. This is mostly used by diagnostic tools. Signed-off-by: Amit Kumar Salecha <amit@netxen.com> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17netxen: defines for next revisionAmit Kumar Salecha
2009-10-16be2net: Add support for next generation of BladeEngine device.Ajit Khaparde
Add new PCI ids to support next generation of BladeEngine device. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Update to version 1.52.1-1Eilon Greenstein
Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Report the maximal available BW as link speedEilon Greenstein
The device is limited to the maximal BW allocation, so it should be displayed as the link speed to notify the user. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Do not call load/unload functionality from DCCEilon Greenstein
There is really no need to clear the MAC or the FW filtering rules - it was added for completion, but caused race conditions with load/unload. Removing this redundant code Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Adding FW mailbox mutexEilon Greenstein
DCC commands are not protected with the RTNL lock, so a mutex should be added Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Changing the Disabled state to a flagEilon Greenstein
When working with DCC, a function can be disabled or enabled (virtual link down or up). Using the function state introduced some race conditions with the load/unload flow. Using a separate flag to indicate that the function is disabled. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Allowing 0 as initial fairness valueEilon Greenstein
Value of zero was used to disable the fairness mechanism. Though the code (driver and FW) allowed changing the value at run time, it did not allow to do that if the mechanism was disabled to begin with. Fixed the FW to allow turning on and off the mechanism at run time. Fixed the code to read the value from the chip at the right sequence. Without this fix, if the initial value was set to zero, traffic could not run on the interface. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14hamradio: Fix bit test correctly.Thomas Sailer
Signed-off-by: Thomas Sailer <t.sailer@alumni.ethz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14net: Remove BKL from tunThomas Gleixner
The lock_kernel/unlock_kernel() in cycle_kernel_lock() which is called in tun_chr_open() is not serializing against anything and safe to remove. tun_chr_fasync() is serialized by get/put_tun() and fasync_helper() has no dependency on BKL. The modification of tun->flags is racy with and without the BKL so removing it does not make it worse. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13Merge branch 'master' of ↵David S. Miller
2009-10-13TI DaVinci EMAC: Clear statistics register properly.Sriram
The mechanism to clear the statistics register is dependent on the status of GMIIEN bit in MAC control register. If the GMIIEN bit is set, the stats registers are write to decrement. If the GMIIEN bit is cleared, the stats registers are plain read/write registers. The stats register clearing operation must take into account the current state of GMIIEN as it can be cleared when the interface is brought down. With existing implementation logic, querying for interface stats when the interface is down, can corrupt the statistics counters. This patch examines the GMIIEN bit status in MAC_CONTROL register before choosing an appropriate mask for clearing stats registers. Signed-off-by: Sriramakrishnan <srk@ti.com> Acked-by: Chaithrika U S <chaithrika@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13r8169: partial support and phy init for the 8168dfrançois romieu
Extracted from Realtek's 8.012.00 r8168 driver. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Tested-by: Simon Farnsworth <simon.farnsworth@onelan.com> Cc: Edward Hsu <edward_hsu@realtek.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: smsc911x: allow platform_data to specify mac addressManuel Lauss
Extend the driver to accept a MAC address specified in platform_data. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: enable smsc911x on MIPSManuel Lauss
2009-10-13ixgb: Fix erroneous display of stats by ethtool -SAjit Khaparde
Commit 5675f221 overlooked the way offsets for netdev stats were considered. Because of this some of the stats shown by ethtool -S were wrong. This patch fixes it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13igb: Fix erroneous display of stats by ethtool -SAjit Khaparde
Commit 337e067d overlooked the way offsets for netdev stats were considered. Because of this some of the stats shown by ethtool -S were wrong. This patch fixes it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13e1000: Fix erroneous display of stats by ethtool -SAjit Khaparde
Commit 23d26497 overlooked the way offsets for netdev stats were considered. Because of this some of the stats shown by ethtool -S were wrong. This patch fixes it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13e1000e: Fix erroneous display of stats by ethtool -SAjit Khaparde
Commit fd8235bb overlooked the way offsets for netdev stats were considered. Because of this some of the stats shown by ethtool -S were wrong. This patch fixes it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13ixgbe: Fix erroneous display of stats by ethtool -SAjit Khaparde
Commit 59aa3cc4 overlooked the way offsets for netdev stats were considered. Because of this some of the stats shown by ethtool -S were wrong. This patch fixes it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13netxen: add sysfs entries for diag toolsDhananjay Phadke
Add sysfs entries to enable register and memory access for diagnostic tools. Signed-off-by: Narender Kumar <narender.kumar@qlogic.com> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13netxen: separate register and memory access lockDhananjay Phadke
Since register and onboard memory access has separate window registers, they need not be kept under same lock. Also, memory is always accessed from process context (mostly for firmware init and diagnostic tools). Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13netxen: annotate register windowing codeDhananjay Phadke
Use common variables crb_win, ocm_win for all revisions of chip. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13netxen: add access to on chip memory for toolsDhananjay Phadke
Add access to on chip memory, this is used by debug and diagnostic tools only. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13netxen: remove sub 64-bit mem accessesAmit Kumar Salecha
Sub 64-bit / unaligned access to oncard memory was only used by old diagnostic tools, causes some intermittent issues when memory controller agent is used. The new access method was added by commit ea6828b8aa3a8ebae8d7740f32f212ba1d2f0742 ("netxen: improve pci memory access"). Firmware init anyway uses 8-byte strides. This also fixes address/offset calculation for NX2031 context memory (SIU). For NX3031, SIU uses same register offsets as packet memory (MIU). Signed-off-by: Amit Kumar Salecha <amit@netxen.com> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
2009-10-13sb1250-mac: duplicate setting of bit V_MAC_RX_PL_THRSH(4) in ↵roel kluin
sbmac_channel_start() The bit V_MAC_RX_PL_THRSH(4) was already set a few lines higher. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
