path: root/drivers/net
2010-01-26ariadne: Fix build.David S. Miller
References removed HAVE_MULTICAST. Reporeted-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-25net: use helpers to access uc list V2Jiri Pirko
This patch introduces three macros to work with uc list from net drivers. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23ixgbevf: Fix IPv6 GSO type checksJeff Kirsher
Based on patch from Sridhar Samudrala The following patch fixes the check for IPv6 GSO packet in ixgbevf driver to use skb_is_gso_v6(). SKB_GSO_DODGY is also set when packets are forwarded from a guest. CC: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23ixgbevf: Tell network stack to stop tx when the VF detects PF resetGreg Rose
When the VF detects that the PF has reset turn off carrier and stop all tx queues. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23ixgbevf: Fix panics in the VF driverGreg Rose
Fix panics in the VF driver that occur when you bring it down after having already brought the PF down. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23ixgbevf: Take action when the PF notifies the VF it is resetting.Greg Rose
When the VF driver gets a control message from the PF that indicates the PF is about to reset or go down we schedule the watchdog timer so that it will detect the PF has gone offline and take appropriate action. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23ixgbe: Improve reset coordination between the PF and the VFGreg Rose
Inadequate coordination between the PF driver and the VF driver results in tx hangs in the VF driver when you perform certain actions that will lead to a re-init of the PF. Add feature to notify active VFs when the PF is about to re-initialize so that the VFs can take appropriate action. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23ixgbe: Allow the VF driver to be loaded before the PF driverGreg Rose
The PF Reset Done bit should not be set in the extended control register until the PF has actually completed the bring up process. It is a mis- interpretation of the purpose of this bit to assume it should be set when the physical reset of the device is done. Instead it should be used to indicate to the VFs when the PF is ready to provide them with required services. This is not until after the PF is finished coming up and ready to process mailbox events. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23ixgbe: Remove unused emulation MAC storage from the per VF data structure.Greg Rose
This data storage for SW emulated MAC addresses is unlikely to ever be used so pull it. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23ixgbe: Set the correct pool when VLANs are added in SR-IOV mode.Greg Rose
When VFs are allocated (as indicated by adapter->num_vfs is non-zero) then the PF pool is no longer zero. Instead it will be the same as the number of VFs allocated. When setting the VLVF entry for the PF we need to use the correct pool otherwise the PF will get VLAN packets from the wire because the packet will pass VFTA filtering and the PF has the default pool, but it will not get VLAN packets from the VFs because it has not set the correct pool bit in the VLVF entry. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23Merge branch 'master' of ↵David S. Miller
2010-01-22Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-01-21be2net: fix bug in rx page postingSathya Perla
Pages are posted to the rxq in such a way that more than one frag can share the page. The last frag that uses the page unmaps the page. In the case when a page is not fully used (due to lack of space in rxq) the last frag that uses the page is not being set as a "last_page_user"; instead, the next frag in the rxq is incorrectly being set. The fix has also been tested on ppc64 with 64k pages... Signed-off-by: Sathya Perla <sathyap@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-21be2net: Add link test to list of ethtool self tests.Sarveshwar Bandi
Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-21be2net: ethtool self test reorganization.Sarveshwar Bandi
The ddr dma ethtool self test needs to be performed even when ETH_TEST_FL_OFFLINE is not set. Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-21phy: add RTBI mode for m88e1111Liu Yu-B13201
Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-21ucc_geth: update the tbi-phy settingLiu Yu-B13201
Old method only set tbi-phy for eth0. Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Add 57765 phy ID and enable devices.Matt Carlson
This patch rounds out the 57765 asic rev support by adding the 57765 phy ID and entering the 57765 device IDs in the pci table. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Bypass power source switching for 57765Matt Carlson
The 57765 repurposes all the GPIOs normally used to switch power sources when configured as a NIC device. This patch changes the code to avoid touching the GPIOs for this asic rev. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Turn off the debug UART for 57765Matt Carlson
If the debug UART is left enabled, the LEDs will not work properly. This patch disables the debug UART. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Fix tx mailbox initializationMatt Carlson
If a device supports MSI-X interrupts, the driver assumes TSS will be available. This is not true for the 57765. This patch changes the code so that only the default tx mailbox is initialized if TSS is not available. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Supply a nicaddr for 57765 jumbo RCBMatt Carlson
The 57765 needs the driver to supply a nic address to the jumbo RCB, just like all other devices except the 5717. This patch changes the test to single out the 5717 rather than maintain a lengthy whitelist of asic revs. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Fix 5717 and 57765 memory selftestsMatt Carlson
Both the 5717 and the 57765 will fail 'ethtool -t' selftests at the memory selftest portion. The memory map for these two devices differs from the rest of the asic revs and each other. This patch adds a new memory map to use for memory selftests. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Abort phy init for 5717 serdes devicesMatt Carlson
The 5717 serdes devices have a different phy register layout than all other previous serdes devices. This patch aborts the phy init sequence in tg3_phy_reset() if the device is a 5717 serdes. It also aborts the tg3_phy_toggle_apd() operation. Most other operations in the MII_SERDES path are O.K. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Add 5717 serdes phy IDMatt Carlson
The serdes and copper phys of the 5717 asic rev have different phy IDs. This patch adds the serdes phy ID. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Improve internal resource allocationsMatt Carlson
The 5717 and the 57765 have more resources at their disposal internally. This patch tunes the driver to get better performance. The adjustments made here only apply to the 57765 and 5717 asic revs. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20tg3: Enable PLL PD when CLKREQ disabled for 5717A0Matt Carlson
PCIe PLL power down cannot be used if CLKREQ is enabled because data corruption will occur. If CLKREQ is disabled though, enabling PCIE P1 PLL power-down saves some power. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20e1000e: enhance frame fragment detectionJesse Brandeburg
Originally patched by Neil Horman <nhorman@tuxdriver.com> e1000e could with a jumbo frame enabled interface, and packet split disabled, receive a packet that would overflow a single rx buffer. While in practice very hard to craft a packet that could abuse this, it is possible. this is related to CVE-2009-4538 Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> CC: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20e1000: enhance frame fragment detectionJesse Brandeburg
Originally From: Neil Horman <nhorman@tuxdriver.com> Modified by: Jesse Brandeburg <jesse.brandeburg@intel.com> Hey all- A security discussion was recently given: http://events.ccc.de/congress/2009/Fahrplan//events/3596.en.html And a patch that I submitted awhile back was brought up. Apparently some of their testing revealed that they were able to force a buffer fragment in e1000 in which the trailing fragment was greater than 4 bytes. As a result the fragment check I introduced failed to detect the fragement and a partial invalid frame was passed up into the network stack. I've written this patch to correct it. I'm in the process of testing it now, but it makes good logical sense to me. Effectively it maintains a per-adapter state variable which detects a non-EOP frame, and discards it and subsequent non-EOP frames leading up to _and_ _including_ the next positive-EOP frame (as it is by definition the last fragment). This should prevent any and all partial frames from entering the network stack from e1000. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20e1000/e1000e/igb/igbvf/ixgb/ixgbe: Fix tests of unsigned in *_tx_map()Roel Kluin
The variable count and i are unsigned so the (<|>=)0 tests do not work. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19S2io: two branches the same in wait_for_cmd_complete()Ram Vepa
Fix check to verify if a register bit is set. We have not hit this bug because wait_for_cmd_complete() is always called with S2IO_BIT_RESET. Reported by Roel Kluin <roel.kluin@gmail.com>. Signed-off-by: Ram Vepa <ram.vepa@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.h
2010-01-19ppp_generic.c severly whitespace damanged by ↵Lennart Sorensen
9c705260feea6ae329bc6b6d5f6d2ef0227eda0a I was just looking at ppp_generic, and noticed that it fairly recently (as in the last year) got rather mangled with many spaces turned into tabs in places they very much shouldn't have been. I tracked it down to commit 9c705260feea6ae329bc6b6d5f6d2ef0227eda0a (ppp: ppp_mp_explode() redesign). I am amazed if that patch passed the patch checking script. I have no idea what kind of weird editor setting did this, but it has to have been a weird editor setting or a very unfortunate search and replace gone wrong. I only found it trying to apply a patch I was playing with and wondering why it wouldn't apply. Then I found there were tabs in the middle of comments that used to be spaces. Well here is a patch that should fix it up as far as I can tell. Purely whitespace repair. No actual code changes. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19bfin_mac: use the newer CLKBUFOE bit name via asm/dpmc.hMike Frysinger
This driver tweaks VR_CTL, so pull in the header for the bit defines. Also switch to the new define name as the old one has gone away. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19sfc: QT202x: Remove unreliable MMD check at initialisationMatthew Slattery
Checking the PHY XS MMD here is unnecessary and can give false negatives. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19ucc_geth: Fix full TX queue processingJiajun Wu
commit 7583605b6d29f1f7f6fc505b883328089f3485ad ("ucc_geth: Fix empty TX queue processing") fixed empty TX queue mishandling, but didn't account another corner case: when TX queue becomes full. Without this patch the driver will stop transmiting when TX queue becomes full since 'bd == ugeth->txBd[txQ]' actually checks for two things: queue empty or full. Let's better check for NULL skb, which unambiguously signals an empty queue. Signed-off-by: Jiajun Wu <b06378@freescale.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Stable <stable@vger.kernel.org> [2.6.32] Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-19phylib: Move workqueue initialization to a proper placeAnton Vorontsov
commit 541cd3ee00a4fe975b22fac6a3bc846bacef37f7 ("phylib: Fix deadlock on resume") caused TI DaVinci EMAC ethernet driver to oops upon resume: PM: resume of devices complete after 237.098 msecs Restarting tasks ... done. kernel BUG at kernel/workqueue.c:354! Unable to handle kernel NULL pointer dereference at virtual address 00000000 [...] Backtrace: [<c002c598>] (__bug+0x0/0x2c) from [<c0052a54>] (queue_delayed_work_on+0x74/0xf8) [<c00529e0>] (queue_delayed_work_on+0x0/0xf8) from [<c0052b30>] (queue_delayed_work+0x2c/0x30) The oops pops up because TI DaVinci EMAC driver detaches PHY on suspend and attaches it back on resume. Attaching makes phylib call phy_start_machine() that initializes a workqueue. On the other hand, PHY's resume routine will call phy_start_machine() again, and that will cause the oops since we just destroyed the already scheduled workqueue. This patch fixes the issue by moving workqueue initialization to phy_device_create(). p.s. We don't see this oops with ucc_geth and gianfar drivers because they perform a fine-grained suspend, i.e. they just stop the PHYs without detaching. Reported-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Tested-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-18zd1211rw: adding 0409:0248 to supported device listHin-Tak Leung
Yasuhiro ABE <yadiary@gmail.com> reported success in sourceforge zd1211-dev list. The device is a NEC Aterm WL54GU usb wireless stick. The brand and retail product name NEC, Aterm PA-WL54GU The USB ID's (duh) ID 0409:0248 The chip ID string zd1211rw 1-1:1.0: zd1211b chip 0409:0248 v4810 high 00-1b-8b AL2230S_RF pa0 g--N- The FCC ID unknown Signed-off-by: Hin-Tak Leung <htl10@users.sourceforge.net> Signed-off-by: Yasuhiro ABE <yadiary@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-18p54pci: rx frame length checkChristian Lamparter
A long time ago, a user reported several crashes due to data corruptions which are likely the result of a not-100%-supported, or faulty? PCI bridge. ( http://patchwork.kernel.org/patch/53004/ ) This patch fixes entry #1. "1. p54p_check_rx_ring - skb_over_panic: Under a ping flood or just left running for a bit would panic with a skb_over_panic." As described in the mail: The invalid frame length causes skb_put to bailout and trigger a crash. Note: Simply dropping the frame is problematic, because if its content contains a tx feedback we would lose some portion of the device memory space.... And the driver/mac80211 should handle all other invalid data. Reported-by: Quintin Pitts <geek4linux@gmail.com> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-18iwlwifi: add license to tracing filesReinette Chatre
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-18iwlwifi: Fix throughput stall issue in HT mode for 5000Wey-Yi Guy
Similar to 6000 and 1000 series, RTS/CTS is the recommended protection mechanism for 5000 series in HT mode based on the HW design. Using RTS/CTS will better protect the inner exchange from interference, especially in highly-congested environment, it also prevent uCode encounter TX FIFO underrun and other HT mode related performance issues. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> CC: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-18drivers/net: Eliminate useless codeJulia Lawall
The variable qdev is initialized twice to the same (side effect-free) expression. Drop one initialization. A simplified version of the semantic match that finds this problem is: (http://coccinelle.lip6.fr/) // <smpl> @forall@ idexpression *x; identifier f!=ERR_PTR; @@ x = f(...) ... when != x ( x = f(...,<+...x...+>,...) | * x = f(...) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17bnx2: Save statistics during reset.Michael Chan
MTU changes, ring size changes, etc cause the chip to be reset and the statisctics flushed. To keep track of the accumulated statistics, we add code to save the whole statistics block before reset. We also modify the macros and statistics functions to return the sum of the saved and current counters. Based on original patch by Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17bnx2: Refine statistics code.Michael Chan
Refine the statistics macros by passing in just the name of the counter field. This makes it a lot easier and cleaner to add counters saved before the last reset in the next patch. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-16NET: Add Qlogic ethernet driver for CNA devicesAmit Kumar Salecha
o Separate Ethernet driver for Qlogic CNA devices Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-16qlcnic: Qlogic ethernet driver for CNA devicesAmit Kumar Salecha
o 1G/10G Ethernet Driver for Qlgic QLE8240 and QLE8242 CNA devices. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-16macvlan: add GRO bit to features maskPatrick Mullaney
Allow macvlan devices to support GRO. Signed-off-by: Patrick Mullaney <pmullaney@novell.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-16qlge: Add module param to force firmware core dump.Ron Mercer
Default setting is 'off', don't allow force firmware dump. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
