path: root/drivers/net
2010-08-05Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (63 commits) of/platform: Register of_platform_drivers with an "of:" prefix of/address: Clean up function declarations of/spi: call of_register_spi_devices() from spi core code of: Provide default of_node_to_nid() implementation. of/device: Make of_device_make_bus_id() usable by other code. of/irq: Fix endian issues in parsing interrupt specifiers of: Fix phandle endian issues of/flattree: fix of_flat_dt_is_compatible() to match the full compatible string of: remove of_default_bus_ids of: make of_find_device_by_node generic microblaze: remove references to of_device and to_of_device sparc: remove references to of_device and to_of_device powerpc: remove references to of_device and to_of_device of/device: Replace of_device with platform_device in includes and core code of/device: Protect against binding of_platform_drivers to non-OF devices of: remove asm/of_device.h of: remove asm/of_platform.h of/platform: remove all of_bus_type and of_platform_bus_type references of: Merge of_platform_bus_type with platform_bus_type drivercore/of: Add OF style matching to platform bus ... Fix up trivial conflicts in arch/microblaze/kernel/Makefile due to just some obj-y removals by the devicetree branch, while the microblaze updates added a new file.
2010-08-05Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (79 commits) powerpc/8xx: Add support for the MPC8xx based boards from TQC powerpc/85xx: Introduce support for the Freescale P1022DS reference board powerpc/85xx: Adding DTS for the STx GP3-SSA MPC8555 board powerpc/85xx: Change deprecated binding for 85xx-based boards powerpc/tqm85xx: add a quirk for ti1520 PCMCIA bridge powerpc/tqm85xx: update PCI interrupt-map attribute powerpc/mpc8308rdb: support for MPC8308RDB board from Freescale powerpc/fsl_pci: add quirk for mpc8308 pcie bridge powerpc/85xx: Cleanup QE initialization for MPC85xxMDS boards powerpc/85xx: Fix booting for P1021MDS boards powerpc/85xx: Fix SWIOTLB initalization for MPC85xxMDS boards powerpc/85xx: kexec for SMP 85xx BookE systems powerpc/5200/i2c: improve i2c bus error recovery of/xilinxfb: update tft compatible versions powerpc/fsl-diu-fb: Support setting display mode using EDID powerpc/5121: doc/dts-bindings: update doc of FSL DIU bindings powerpc/5121: shared DIU framebuffer support powerpc/5121: move fsl-diu-fb.h to include/linux powerpc/5121: fsl-diu-fb: fix issue with re-enabling DIU area descriptor powerpc/512x: add clock structure for Video-IN (VIU) unit ...
2010-08-05Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (150 commits) MIPS: PowerTV: Separate PowerTV USB support from non-USB code MIPS: strip the un-needed sections of vmlinuz MIPS: Clean up the calculation of VMLINUZ_LOAD_ADDRESS MIPS: Clean up arch/mips/boot/compressed/decompress.c MIPS: Clean up arch/mips/boot/compressed/ld.script MIPS: Unify the suffix of compressed vmlinux.bin MIPS: PowerTV: Add Gaia platform definitions. MIPS: BCM47xx: Fix nvram_getenv return value. MIPS: Octeon: Allow more than 3.75GB of memory with PCIe MIPS: Clean up notify_die() usage. MIPS: Remove unused task_struct.trap_no field. Documentation: Mention that KProbes is supported on MIPS SAMPLES: kprobe_example: Make it print something on MIPS. MIPS: kprobe: Add support. MIPS: Add instrunction format for BREAK and SYSCALL MIPS: kprobes: Define regs_return_value() MIPS: Ritually kill stupid printk. MIPS: Octeon: Disallow MSI-X interrupt and fall back to MSI interrupts. MIPS: Octeon: Support 256 MSI on PCIe MIPS: Decode core number for R2 CPUs. ...
2010-08-05MIPS: au1000_eth: Get ethernet address from platform_dataManuel Lauss
au1000_eth uses firmware calls to get a valid MAC address, and changes it depending on platform device id. This patch moves this logic out of the driver into the platform device registration part, where boards with supported chips can use whatever firmware interface they need; the default implementation maintains compatibility with existing, YAMON-based firmware. Tested-by: Wolfgang Grandegger <wg@denx.de> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Cc: netdev@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1481/ Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Alchemy: remove SOC_AU1X00 in favor of MIPS_ALCHEMYManuel Lauss
Remove the CONFIG_SOC_AU1X00 Kconfig symbol since its job can also be done by MACH_ALCHEMY, now renamed to MIPS_ALCHEMY. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/1461/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-08-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Runtime: Add runtime PM statistics (v3) PM / Runtime: Make runtime_status attribute not debug-only (v. 2) PM: Do not use dynamically allocated objects in pm_wakeup_event() PM / Suspend: Fix ordering of calls in suspend error paths PM / Hibernate: Fix snapshot error code path PM / Hibernate: Fix hibernation_platform_enter() pm_qos: Get rid of the allocation in pm_qos_add_request() pm_qos: Reimplement using plists plist: Add plist_last PM: Make it possible to avoid races between wakeup and system sleep PNPACPI: Add support for remote wakeup PM: describe kernel policy regarding wakeup defaults (v. 2) PM / Hibernate: Fix typos in comments in kernel/power/swap.c
2010-08-04Merge branch 'master' into for-nextJiri Kosina
2010-08-04hostap:hostap_hw.c Fix typo in commentJustin P. Mattock
The patch below fixes a typo in a comment. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-04Fix spelling contorller -> controller in commentsStefan Weil
Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-03phy/marvell: add 88ec048 supportCyril Chemparathy
Marvell 88ec048 is a derivative of its 88e1121r device. From the programmer's perspective, the one major difference is the addition of an additional control bit in Page 2 Register 16 - used to control the padding of odd nibble preambles. This patch adds support for this new device, while inheriting as much code as possible from the existing 88e1121r implementation. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-04Merge commit 'gcl/next' into nextBenjamin Herrenschmidt
2010-08-03igb: Program MDICNFG register prior to PHY initAlexander Duyck
This patch addresses an issue seen on 82580 in which the MDICNFG register will be reset during a single function reset and as a result we will be unable to communicate with the PHY. To correct the issue, added a call to reset_mdicnfg just prior to the first access of the MDICNFG register in sgnii_uses_mdio. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-03e1000e: correct MAC-PHY interconnect register offset for 82579Bruce Allan
The MAC-PHY interconnect register set on ICH/PCH parts is accessed through a peephole mechanism by writing an offset to a CSR register. The offset for the interconnect's half-duplex control register (which is used in a jumbo frame workaround for 82579) is incorrect. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-03hso: Add new product IDFilip Aben
This patch adds a new product ID to the hso driver. Signed-off-by: Filip Aben <f.aben@option.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-03can: Add driver for esd CAN-USB/2 deviceMatthias Fuchs
This patch adds a driver for esd's USB high speed CAN interface. The driver supports devices with multiple CAN interfaces. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000e/hw.h net/bridge/br_device.c net/bridge/br_input.c
2010-08-02phy/marvell: add 88e1121 interface mode supportCyril Chemparathy
This patch adds support for RGMII RX/TX delay configuration on marvell 88e1121 and derivatives. With this patch, PHY_INTERFACE_MODE_RGMII_*ID modes are now supported on these devices. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02net: Fix a typo from "dev" to "ndev"Henrique Camargo
The typo was causing compilation errors since "dev" was not defined. Signed-off-by: Henrique Camargo <henrique.camargo@ensitec.com.br> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02igb: Use irq_synchronize per vector when using MSI-XEmil Tantilov
Synchronize all IRQs when using MSI-X. Similar to ixgbe. Issue was reported on e1000e, but the patch is also valid for igb. CC: Jean Delvare <jdelvare@suse.de> Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02ixgbevf: fix null pointer dereference due to filter being set for VLAN 0Alexander Duyck
This change corrects an issue that resulted in a null pointer dereference for the addition of VLAN 0 without any VLANs being registered. Also this code removes some unnecessary checks for defines and the unnecessary setting of VLAN flags since that is now handled within the kernel via the vlan_features. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02e1000e: Fix irq_synchronize in MSI-X caseJeff Kirsher
Based on original patch/work from Jean Delvare <jdelvare@suse.de> Synchronize all IRQs when in MSI-X IRQ mode. Jean's original patch hard coded the sync with the 3 possible vectors, this patch incorporates more flexibility for the future and aligns with how igb stores the number of vectors into the adapter structure. CC: Jean Delvare <jdelvare@suse.de> Cc: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Acked-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02e1000e: register pm_qos request on hardware activationFlorian Mickler
The pm_qos_add_request call has to register the pm_qos request with the pm_qos susbsystem before first use of the pm_qos request via pm_qos_update_request. As pm_qos changed to use plists there is no benefit in registering and unregistering the pm_qos request on ifup/ifdown and thus we move the registering into e1000_open and the unregistering in e1000_close. This fixes the following warning: [ 1.786060] WARNING: at kernel/pm_qos_params.c:264 pm_qos_update_request+0x28/0x54() [ 1.786088] Hardware name: Latitude E6500 [ 1.787045] pm_qos_update_request() called for unknown object [ 1.787966] Modules linked in: [ 1.788940] Pid: 1, comm: swapper Not tainted 2.6.35-rc5-mmotm0719 #1 [ 1.790035] Call Trace: [ 1.791121] [<ffffffff81037335>] warn_slowpath_common+0x80/0x98 [ 1.792205] [<ffffffff810373e1>] warn_slowpath_fmt+0x41/0x43 [ 1.793279] [<ffffffff81057c14>] pm_qos_update_request+0x28/0x54 [ 1.794347] [<ffffffff8134889e>] e1000_configure+0x421/0x459 [ 1.795393] [<ffffffff8134afbd>] e1000_open+0xbd/0x37c [ 1.796436] [<ffffffff8105743a>] ? raw_notifier_call_chain+0xf/0x11 [ 1.797491] [<ffffffff8145f948>] __dev_open+0xae/0xe2 [ 1.798547] [<ffffffff8145f997>] dev_open+0x1b/0x49 [ 1.799612] [<ffffffff8146e36e>] netpoll_setup+0x84/0x259 [ 1.800685] [<ffffffff81b5037c>] init_netconsole+0xbc/0x21f [ 1.801744] [<ffffffff81b5026c>] ? sir_wq_init+0x0/0x35 [ 1.802793] [<ffffffff81b502c0>] ? init_netconsole+0x0/0x21f [ 1.803845] [<ffffffff810002ff>] do_one_initcall+0x7a/0x12f [ 1.804885] [<ffffffff81b2ccae>] kernel_init+0x138/0x1c2 [ 1.805915] [<ffffffff81003554>] kernel_thread_helper+0x4/0x10 [ 1.806937] [<ffffffff81590e00>] ? restore_args+0x0/0x30 [ 1.807955] [<ffffffff81b2cb76>] ? kernel_init+0x0/0x1c2 [ 1.808958] [<ffffffff81003550>] ? kernel_thread_helper+0x0/0x10 [ 1.809958] ---[ end trace 84b562a00a60539e ]--- Signed-off-by: Florian Mickler <florian@mickler.org> Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02cxgb4: update driver versionDimitris Michailidis
Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02cxgb4: add new PCI IDsDimitris Michailidis
2010-08-02cxgb4: fix wrong shift directionDimitris Michailidis
2010-08-02cxgb4: support running the driver on PCI functions besides 0Dimitris Michailidis
Add support for running the driver on any PCI function. Mostly this entails replacing a constant 0 in a number of calls with the variable function number. Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02cxgb4: advertise NETIF_F_TSO_ECNDimitris Michailidis
The device supports TSO+ECN. Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02cxgb4: get on-chip queue info from FW and create a memory window for themDimitris Michailidis
Get info about the availability of Tx on-chip queues from FW and if they are supported set up a memory window for them. iw_cxgb4 will be using them. Move the existing window setup later in the init sequence, after we have collected the new info. Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02cxgb4: fix TSO descriptorsDimitris Michailidis
Commit 1704d74894912b8ecc3e95cecd7bde336a0b1bf2 ("cxgb4vf: small changes to message processing structures/macros") was incomplete and causes cxgb4 to write bad TSO descriptors. Fix that up by reverting the offending part of that commit and adjusting field accesses now that they are one level deeper. Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02cxgb4: don't offload Rx checksums for IPv6 fragmentsDimitris Michailidis
The checksum provided by the device doesn't include the L3 headers, as IPv6 expects. Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02cxgb4: disable an interrupt that is neither used nor servicedDimitris Michailidis
2010-08-02hp100: unmap memory on error pathDan Carpenter
There was an error path where "mem_ptr_virt" didn't get unmapped. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02Tulip: don't initialize SBE xT3E3 WAN ports.Krzysztof Hałasa
SBE 2T3E3 cards use DECchips 21143 but they need a different driver. Don't even try to use a normal tulip driver with them. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02drivers/net/wan/farsync.c: Use standard pr_<level>Joe Perches
Remove locally defined equivalents Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Update version to 3.113Matt Carlson
This patch updates the tg3 version to 3.113. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Migrate tg3_flags to phy_flagsMatt Carlson
This patch moves most of the phy related flag definitions over to the phyflags member and changes the code accordingly. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Create phy_flags and migrate phy_is_low_powerMatt Carlson
This patch deletes the link_config.phy_is_low_power flag and creates a new phy_flags device member to store all phy related settings. All the code is converted accordingly. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Add phy-related preprocessor constantsMatt Carlson
This patch replaces some instances of hardcoded phy register values with preprocessor equivalents. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Add error reporting to tg3_phydsp_write()Matt Carlson
This patch adds error reporting to the tg3_phydsp_write() function and converts a few more locations to use this function over the inlined equivalent. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Improve small packet performanceMatt Carlson
smp_mb() inside tg3_tx_avail() is used twice in the normal tg3_start_xmit() path (see illustration below). The full memory barrier is only necessary during race conditions with tx completion. We can speed up the tx path by replacing smp_mb() in tg3_tx_avail() with a compiler barrier. The compiler barrier is to force the compiler to fetch the tx_prod and tx_cons from memory. In the race condition between tg3_start_xmit() and tg3_tx(), we have the following situation: tg3_start_xmit() tg3_tx() if (!tg3_tx_avail()) BUG(); ... if (!tg3_tx_avail()) netif_tx_stop_queue(); update_tx_index(); smp_mb(); smp_mb(); if (tg3_tx_avail()) if (netif_tx_queue_stopped() && netif_tx_wake_queue(); tg3_tx_avail()) With smp_mb() removed from tg3_tx_avail(), we need to add smp_mb() to tg3_start_xmit() as shown above to properly order netif_tx_stop_queue() and tg3_tx_avail() to check the ring index. If it is not strictly ordered, the tx queue can be stopped forever. This improves performance by about 3% with 2 ports running bi-directional 64-byte packets. Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Remove 5720, 5750, and 5750MMatt Carlson
These devices were never released to the public. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Detect APE firmware typesMatt Carlson
This patch adds code to determine the APE firmware type and report this along with the firmware version. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Restrict ASPM workaround devlistMatt Carlson
The ASPM workaround setting obtained from NVRAM only works with devices older than 5717. This patch enforces the restriction. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Manage gphy power for CPMU-less devs onlyMatt Carlson
This patch changes the code to only manage the PCIe gphy power for CPMU-less devices only. The CPMU takes over management for newer chips. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Don't access phy test ctrl reg for 5717+Matt Carlson
The phy test register location has been repurposed for 5717+ devices. This patch changes the code to avoid this location for these devices. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Create TG3_FLG3_5717_PLUS flagMatt Carlson
This patch creates a TG3_FLG3_5717_PLUS flag to collectively describe the set of changes in the ASIC that will apply to all future chip revisions. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Disable TSS also during tg3_close()Matt Carlson
The TSS flag needs to be turned off during tg3_close(). If the device fails to allocate more than one MSI-X vector the next time the device is brought up, transmits will fail. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02tg3: Add 5784 ASIC rev to earlier PCIe MPS fixMatt Carlson
tg3 commit e7126997342560533317d8467e8516119ebcbd21 entitled "tg3: Preserve PCIe MPS setting for new devs" attempted to ensure the PCIe link negotiated Maximum Payload Size (MPS) setting was 128 bytes for all devices that didn't support higher speeds. The 5784 device was mistakenly added to this list when it shouldn't have. This patch removes the 5784 ASIC rev devices from that list. Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
