drivers/net/ethernet/emulex/benet/be.h
drivers/net/netconsole.c
net/bridge/br_private.h
Three mostly trivial conflicts.
The net/bridge/br_private.h conflict was a function signature (argument
addition) change overlapping with the extern removals from Joe Perches.
In drivers/net/netconsole.c we had one change adjusting a printk message
whilst another changed "printk(KERN_INFO" into "pr_info(".
Lastly, the emulex change was a new inline function addition overlapping
with Joe Perches's extern removals.
time_after_eq() only works if the delta is < MAX_ULONG/2.
For a 32bit Dom0, if netfront sends packets at a very low rate, the time
between subsequent calls to tx_credit_exceeded() may exceed MAX_ULONG/2
and the test for timer_after_eq() will be incorrect. Credit will not be
replenished and the guest may become unable to send packets (e.g., if
prior to the long gap, all credit was exhausted).
Use jiffies_64 variant to mitigate this problem for 32bit Dom0.
Suggested-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Jason Luan <jianhai.luan@oracle.com>
This patch adds code to handle SKB_GSO_TCPV6 skbs and construct appropriate
extra or prefix segments to pass the large packet to the frontend. New
xenstore flags, feature-gso-tcpv6 and feature-gso-tcpv6-prefix, are sampled
to determine if the frontend is capable of handling such packets.
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
Cc: Wei Liu <wei.liu2@citrix.com>
Cc: David Vrabel <david.vrabel@citrix.com>
There is no mechanism to insist that a guest always generates a packet
with good checksum (at least for IPv4) so we must handle checksum
offloading from the guest and hence should set NETIF_F_RXCSUM.
Check xenstore flag feature-ipv6-csum-offload to determine if a
guest is happy to accept IPv6 packets with only partial checksum.
Without this patch, if a frontend cycles through states Closing
and Closed (which Windows frontends need to do) then the netdev
will be destroyed and requires re-invocation of hotplug scripts
to restore state before the frontend can move to Connected. Thus
when udev is not in use the backend gets stuck in InitWait.
With this patch, the netdev is left alone whilst the backend is
still online and is only de-registered and freed just prior to
destroying the vif (which is also nicely symmetrical with the
netdev allocation and registration being done during probe) so
no re-invocation of hotplug scripts is required.
Acked-by: Wei Liu <wei.liu2@citrix.com>
This makes sure a format string cannot accidentally leak into the
kthread_run() call.
Acked-by: Ian Campbell <ian.campbell@citrix.com>
As we move to 1:1 model and melt xen_netbk and xenvif together, it would
be better to use single prefix for all functions in xen-netback.
This patch implements 1:1 model netback. NAPI and kthread are utilized
to do the weight-lifting job:
- NAPI is used for guest side TX (host side RX)
- kthread is used for guest side RX (host side TX)
Xenvif and xen_netbk are made into one structure to reduce code size.
This model provides better scheduling fairness among vifs. It is also
prerequisite for implementing multiqueue for Xen netback.
Netback and netfront only use one event channel to do TX / RX notification,
which may cause unnecessary wake-up of processing routines. This patch adds a
new feature called feature-split-event-channels to netback, enabling it to
handle TX and RX events separately.
Netback will use tx_irq to notify guest for TX completion, rx_irq for RX
notification.
If frontend doesn't support this feature, tx_irq equals to rx_irq.
This patch enables user to unload netback module, which is useful when user
wants to upgrade to a newer netback module without rebooting the host.
Netfront cannot handle netback removal event. As we cannot fix all possible
frontends we add module get / put along with vif get / put to avoid
mis-unloading of netback. To unload netback module, user needs to shutdown all
VMs or migrate them to another host or unplug all vifs before hand.
Acked-by: Ian Campbell <ian.campbell@citrix.com>¬
Pull in 'net' to take in the bug fixes that didn't make it into
3.8-final.
Also, deal with the semantic conflict of the change made to
net/ipv6/xfrm6_policy.c A missing rt6->n neighbour release
was added to 'net', but in 'net-next' we no longer cache the
neighbour entries in the ipv6 routes so that change is not
appropriate there.
If the credit timer is left armed after calling
xen_netbk_remove_xenvif(), then it may fire and attempt to schedule
the vif which will then oops as vif->netbk == NULL.
This may happen both in the fatal error path and during normal
disconnection from the front end.
The sequencing during shutdown is critical to ensure that: a)
vif->netbk doesn't become unexpectedly NULL; and b) the net device/vif
is not freed.
1. Mark as unschedulable (netif_carrier_off()).
2. Synchronously cancel the timer.
3. Remove the vif from the schedule list.
4. Remove it from it netback thread group.
5. Wait for vif->refcnt to become 0.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reported-by: Christopher S. Aker <caker@theshore.net>
Synchronize with 'net' in order to sort out some l2tp, wireless, and
ipv6 GRE fixes that will be built on top of in 'net-next'.
A buggy or malicious frontend should not be able to confuse netback.
If we spot anything which is not as it should be then shutdown the
device and don't try to continue with the ring in a potentially
hostile state. Well behaved and non-hostile frontends will not be
penalised.
As well as making the existing checks for such errors fatal also add a
new check that ensures that there isn't an insane number of requests
on the ring (i.e. more than would fit in the ring). If the ring
contains garbage then previously is was possible to loop over this
insane number, getting an error each time and therefore not generating
any more pending requests and therefore not exiting the loop in
xen_netbk_tx_build_gops for an externded period.
Also turn various netdev_dbg calls which no precipitate a fatal error
into netdev_err, they are rate limited because the device is shutdown
afterwards.
This fixes at least one known DoS/softlockup of the backend domain.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Jan Beulich <JBeulich@suse.com>
Sometimes it is useful to be able to change the MAC address of the
interface for netback devices. For example, when using ebtables it may
be useful to be able to distinguish traffic from different interfaces
without depending on the interface name.
Reported-by: Nikita Borzykh <sample.n@gmail.com>
Reported-by: Paul Harvey <stockingpaul@hotmail.com>
Cc: netdev@vger.kernel.org
Cc: xen-devel@lists.xen.org
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Matt Wilson <msw@amazon.com>
All tables of function pointers should be const to make hacks
more difficult. Compile tested only.
v2: add couple missing conversions in drivers
split unexporting netdev_fix_features()
implemented %pNF
convert sock::sk_route_(no?)caps
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
If a VM is saved and restored (or migrated) the netback driver will no
longer process any Tx packets from the frontend. xenvif_up() does not
schedule the processing of any pending Tx requests from the front end
because the carrier is off. Without this initial kick the frontend
just adds Tx requests to the ring without raising an event (until the
ring is full).
This was caused by 47103041e91794acdbc6165da0ae288d844c820b (net:
xen-netback: convert to hw_features) which reordered the calls to
xenvif_up() and netif_carrier_on() in xenvif_connect().
netback is the host side counterpart to the frontend driver in
drivers/net/xen-netfront.c. The PV protocol is also implemented by
frontend drivers in other OSes too, such as the BSDs and even Windows.
The patch is based on the driver from the xen.git pvops kernel tree but
has been put through the checkpatch.pl wringer plus several manual
cleanup passes and review iterations. The driver has been moved from
drivers/xen/netback to drivers/net/xen-netback.
One major change from xen.git is that the guest transmit path (i.e. what
looks like receive to netback) has been significantly reworked to remove
the dependency on the out of tree PageForeign page flag (a core kernel
patch which enables a per page destructor callback on the final
put_page). This page flag was used in order to implement a grant map
based transmit path (where guest pages are mapped directly into SKB
frags). Instead this version of netback uses grant copy operations into
regular memory belonging to the backend domain. Reinstating the grant
map functionality is something which I would like to revisit in the
future.
Note that this driver depends on 2e820f58f7ad "xen/irq: implement
bind_interdomain_evtchn_to_irqhandler for backend drivers" which is in
linux next via the "xen-two" tree and is intended for the 2.6.39 merge
window:
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen.git stable/backends
this branch has only that single commit since 2.6.38-rc2 and is safe for
cross merging into the net branch.
Reviewed-by: Ben Hutchings <bhutchings@solarflare.com>
