path: root/drivers/net/wireless
2011-01-04ath9k_htc: Handle FATAL eventsSujith Manoharan
The device has to be reset when a FATAL event is received. Not doing so would leave the card in a non-working state. Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04ath9k_htc: Move work cancellation outside of mutexSujith Manoharan
There is no need to lock the various work cancellation calls. This will be helpful when handling FATAL events. Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04ath9k_htc: Handle pending URBs properlySujith Manoharan
When doing a channel change, the pending URBs have to be killed properly on calling htc_stop(). This fixes the probe response timeout seen when sending UDP traffic at a high rate and running background scan at the same time. Cc: stable <stable@kernel.org> Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04ath9k: Few clean ups in beacon config parametersMohammed Shafi Shajakhan
Some minor clean ups in assigning values to beacon config parameters Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: Fix comment about removed spinlockHelmut Schaa
The comment doesn't match the code anymore. Fix that. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: Remove unused interface spinlockHelmut Schaa
Since the last user of intf->lock is gone we can safely remove it. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: Simplify intf->delayed_flags lockingHelmut Schaa
Instead of protecting delayed_flags with a spinlock use atomic bitops to make the code more readable. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: Remove superfluous assignment of mpdu_densityHelmut Schaa
The tx desciptor already gets initialized to 0. Hence, there's no need to explicitly assign 0 to mpdu_density here. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: Fix panic on frame padding for rt2800 usb devicesIsmael Luceno
Backtrace: rt2800usb_write_tx_data rt2x00queue_write_tx_frame rt2x00mac_tx invoke_tx_handlers __ieee80211_tx ieee80211_tx virt_to_head_page ieee80211_xmit ieee80211_tx_skb ieee80211_scan_work schedule ieee80211_scan_work process_one_work ... It tried to expand the skb past it's end using skb_put. So I replaced it with a call to skb_padto, which takes the issue into account. Signed-off-by: Ismael Luceno <ismael.luceno@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: Fix pointer errors.Gertjan van Wingerde
Fix some pointer errors in the various calls to memcpy, memset and memmove. Although none of these errors are fatal (the expression used now results in the same pointer value) it is better to use the proper expression. All errors are having to deal with arrays. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: remove intf->mac field.Gertjan van Wingerde
The mac field of the rt2x00_intf structure is written to once and used twice. In both these uses the mac address is available via other means. Remove this field as it does not appear to be necessary. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: Remove intf->bssid field.Gertjan van Wingerde
The bssid field in struct rt2x00_intf is only written to once, and is never read from. Remove this field, as it appears to not be needed. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: allow txstatus_fifo w/o txstatus_taskletJohannes Stezenbach
When DRIVER_REQUIRE_TXSTATUS_FIFO is set, intialize the txstatus_fifo, but initialize rt2x00dev->txstatus_tasklet only when both DRIVER_REQUIRE_TXSTATUS_FIFO and rt2x00dev->ops->lib->txstatus_tasklet are set. This allows the txstatus_fifo to be used by rt2800usb which does not use txstatus_tasklet. Signed-off-by: Johannes Stezenbach <js@sig21.net> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04rt2x00: simplify txstatus_fifo handlingJohannes Stezenbach
2011-01-04carl9170: fix usb pm suspend->resume woesChristian Lamparter
This patch revamps some common code-paths which are shared between (re-)initialization and suspend/resume subroutines. It also adds some helpful comments about quirks and associated difficulties. It's quite big, but it should fix #25382: <https://bugzilla.kernel.org/show_bug.cgi?id=25382> And hopefully the code is robust enough to deal with all possible suspend/resume scenarios without requiring the user to do any sort of manual and possibly dangerous work. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04carl9170: reduce channel change delayChristian Lamparter
By removing two "safety" msleeps (and an echo nop), the channel change delay is effectively halved. Previously, the delay could be as long as 260 ms and the device could not go off-channel without risking to miss the next DTIM beacon [interval ~307 ms]. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04carl9170: add missing return-value checkChristian Lamparter
This patch adds a forgotten bail-out path. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04ath5k: fix cycle counter inconsistent lockingBob Copeland
ath5k_reset is called from process context and takes the cc_lock with plain spin_lock(), but cc_lock can also be taken from tasklets in softirq context. Thus we need to at least use spin_lock_bh. This fixes the following lockdep warning: [ 19.967874] sky2 0000:01:00.0: eth0: enabling interface [ 19.982761] ieee80211 phy0: device now idle [ 20.904809] NET: Registered protocol family 17 [ 21.243857] ieee80211 phy0: device no longer idle - scanning [ 21.404343] [ 21.404346] ================================= [ 21.404450] [ INFO: inconsistent lock state ] [ 21.404518] 2.6.37-rc7-wl+ #242 [ 21.404582] --------------------------------- [ 21.404650] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage. [ 21.404721] kworker/u:4/982 [HC0[0]:SC1[3]:HE1:SE0] takes: [ 21.404792] (&(&common->cc_lock)->rlock){+.?...}, at: [<f8115780>] ath5k_ani_calibration+0x29/0x5d9 [ath5k] [ 21.405011] {SOFTIRQ-ON-W} state was registered at: [ 21.405011] [<c105cadd>] __lock_acquire+0x62f/0x13c1 [ 21.405011] [<c105d944>] lock_acquire+0xd5/0xf1 [ 21.405011] [<c12c978d>] _raw_spin_lock+0x45/0x72 [ 21.405011] [<f8111533>] ath5k_reset+0x2c0/0x349 [ath5k] [ 21.405011] [<f8111a7a>] ath5k_start+0xb8/0x139 [ath5k] [ 21.405011] [<f849c714>] ieee80211_do_open+0x13f/0x819 [mac80211] [ 21.405011] [<f849ce51>] ieee80211_open+0x63/0x66 [mac80211] [ 21.405011] [<c1258b2e>] __dev_open+0x8d/0xb6 [ 21.405011] [<c1255c64>] __dev_change_flags+0x9d/0x114 [ 21.405011] [<c1258a75>] dev_change_flags+0x18/0x44 [ 21.405011] [<c1262990>] do_setlink+0x23f/0x521 [ 21.405011] [<c1262d58>] rtnl_setlink+0xe6/0xea [ 21.405011] [<c126347c>] rtnetlink_rcv_msg+0x18a/0x1a0 [ 21.405011] [<c126d5f0>] netlink_rcv_skb+0x35/0x7b [ 21.405011] [<c12632eb>] rtnetlink_rcv+0x20/0x27 [ 21.405011] [<c126d370>] netlink_unicast+0x1bb/0x21e [ 21.405011] [<c126db21>] netlink_sendmsg+0x23b/0x288 [ 21.405011] [<c124823c>] sock_sendmsg+0xac/0xc4 [ 21.405011] [<c1248680>] sys_sendmsg+0x152/0x1a2 [ 21.405011] [<c1249b0d>] sys_socketcall+0x214/0x275 [ 21.405011] [<c10029d0>] sysenter_do_call+0x12/0x36 [ 21.405011] irq event stamp: 138032 [ 21.405011] hardirqs last enabled at (138032): [<c12ca252>] _raw_spin_unlock_irqrestore+0x3b/0x5e [ 21.405011] hardirqs last disabled at (138031): [<c12c98cc>] _raw_spin_lock_irqsave+0x18/0x7e [ 21.405011] softirqs last enabled at (138024): [<f84a570e>] ieee80211_tx_skb+0x47/0x49 [mac80211] [ 21.405011] softirqs last disabled at (138027): [<c100452b>] do_softirq+0x63/0xb4 [ 21.405011] [ 21.405011] other info that might help us debug this: [ 21.405011] 3 locks held by kworker/u:4/982: [ 21.405011] #0: (name){+.+.+.}, at: [<c1046158>] process_one_work+0x1b8/0x41b [ 21.405011] #1: ((&(&local->scan_work)->work)){+.+.+.}, at: [<c1046158>] process_one_work+0x1b8/0x41b [ 21.405011] #2: (&local->mtx){+.+.+.}, at: [<f84920fb>] ieee80211_scan_work+0x32/0x4a4 [mac80211] [ 21.405011] [ 21.405011] stack backtrace: [ 21.405011] Pid: 982, comm: kworker/u:4 Not tainted 2.6.37-rc7-wl+ #242 [ 21.405011] Call Trace: [ 21.405011] [<c12c6e68>] ? printk+0x1d/0x25 [ 21.405011] [<c105a742>] print_usage_bug+0x181/0x18b [ 21.405011] [<c105b196>] ? check_usage_forwards+0x0/0xb6 [ 21.405011] [<c105a9ec>] mark_lock+0x2a0/0x4aa [ 21.405011] [<c1059f6d>] ? trace_hardirqs_off+0xb/0xd [ 21.405011] [<c105ca68>] __lock_acquire+0x5ba/0x13c1 [ 21.405011] [<c1059eed>] ? trace_hardirqs_off_caller+0x18/0x8d [ 21.405011] [<c1059f6d>] ? trace_hardirqs_off+0xb/0xd [ 21.405011] [<c1050411>] ? local_clock+0x2c/0x4f [ 21.405011] [<c1059e00>] ? save_trace+0x2/0xa0 [ 21.405011] [<c105ac39>] ? mark_held_locks+0x43/0x5b [ 21.405011] [<c12ca252>] ? _raw_spin_unlock_irqrestore+0x3b/0x5e [ 21.405011] [<f8115780>] ? ath5k_ani_calibration+0x29/0x5d9 [ath5k] [ 21.405011] [<c105d944>] lock_acquire+0xd5/0xf1 [ 21.405011] [<f8115780>] ? ath5k_ani_calibration+0x29/0x5d9 [ath5k] [ 21.405011] [<c12c9b1a>] _raw_spin_lock_bh+0x4a/0x77 [ 21.405011] [<f8115780>] ? ath5k_ani_calibration+0x29/0x5d9 [ath5k] [ 21.405011] [<f8115780>] ath5k_ani_calibration+0x29/0x5d9 [ath5k] [ 21.405011] [<c105ac39>] ? mark_held_locks+0x43/0x5b [ 21.405011] [<f8113496>] ath5k_tasklet_ani+0x1d/0x27 [ath5k] [ 21.405011] [<c1037304>] tasklet_action+0x96/0x137 [ 21.405011] [<c10379b5>] __do_softirq+0xde/0x1c3 [ 21.405011] [<c10b0cef>] ? arch_get_unmapped_area_topdown+0x3b/0x127 [ 21.405011] [<c10378d7>] ? __do_softirq+0x0/0x1c3 [ 21.405011] <IRQ> [<c1036dee>] ? irq_exit+0x3d/0x49 [ 21.405011] [<c1003b4f>] ? do_IRQ+0x98/0xac [ 21.405011] [<c1002eee>] ? common_interrupt+0x2e/0x34 [ 21.405011] [<c103007b>] ? sys_unshare+0x57/0x226 [ 21.405011] [<c1047fee>] ? queue_delayed_work+0x1/0x27 [ 21.405011] [<f84a83a0>] ? ieee80211_queue_delayed_work+0x2e/0x33 [mac80211] [ 21.405011] [<f8492528>] ? ieee80211_scan_work+0x45f/0x4a4 [mac80211] [ 21.405011] [<c104620e>] ? process_one_work+0x26e/0x41b [ 21.405011] [<c1046158>] ? process_one_work+0x1b8/0x41b [ 21.405011] [<f84920c9>] ? ieee80211_scan_work+0x0/0x4a4 [mac80211] [ 21.405011] [<c10466b6>] ? worker_thread+0x18a/0x2a5 [ 21.405011] [<c12ca25e>] ? _raw_spin_unlock_irqrestore+0x47/0x5e [ 21.405011] [<c104652c>] ? worker_thread+0x0/0x2a5 [ 21.405011] [<c104abe7>] ? kthread+0x67/0x6c [ 21.405011] [<c104ab80>] ? kthread+0x0/0x6c [ 21.405011] [<c1002efa>] ? kernel_thread_helper+0x6/0x10 Signed-off-by: Bob Copeland <me@bobcopeland.com> Acked-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04ath9k: fix spur mitigation no-spur case for AR9002Brian Prodoehl
For the AR9002, the spur frequency read from the EEPROM is mangled before being compared against AR_NO_SPUR. This results in the driver trying to set up the spur mitigation for bogus spurs, rather than cleanly breaking out. Signed-off-by: Brian Prodoehl <bprodoehl@nomadio.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04airo: use simple_write_to_bufferAkinobu Mita
Simplify write file operation for /proc files by using simple_write_to_buffer(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: linux-wireless@vger.kernel.org Cc: netdev@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04ath9k: spin_lock_bh is not required within tasklet context.Senthil Balasubramanian
Disabling BH is not required while running from a tasklet context and so replace spin_lock_bh with just spin_lock. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04iwlagn: fix scan tx antenna setting on 5Ghz bandStanislaw Gruszka
Looks that we do not set correctly antennas when scanning on 5Ghz band and when bluetooth is enabled, because priv->cfg->scan_tx_antennas[band] is only defined for IEEE80211_BAND_2GHZ. To fix we check band before limiting antennas to first one. This allow to remove hard coded cfg->scan_tx_antennas[band]. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04ath5k: Move mac80211 functions into new fileBruno Randolf
Move mac80211 functions into new file mac80211-ops.c to have a better separation and to make base.c smaller. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04iwlagn: enable only rfkill interrupt when device is downStanislaw Gruszka
Since commit 6cd0b1cb872b3bf9fc5de4536404206ab74bafdd "iwlagn: fix hw-rfkill while the interface is down", we enable interrupts when device is not ready to receive them. However hardware, when it is in some inconsistent state, can generate other than rfkill interrupts and crash the system. I can reproduce crash with "kernel BUG at drivers/net/wireless/iwlwifi/iwl-agn.c:1010!" message, when forcing firmware restarts. To fix only enable rfkill interrupt when down device and after probe. I checked patch on laptop with 5100 device, rfkill change is still passed to user space when device is down. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: stable@kernel.org Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-03wireless: comment typo fix diable -> disable.Justin P. Mattock
The below patch fixes a typo "diable" to "disable". Please let me know if this is correct or not. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-03Fix spelling mistakes in commentsStefan Weil
milisecond -> millisecond meassge -> message Cc: Kalle Valo <kvalo@adurom.com> Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) ipv4: dont create routes on down devices epic100: hamachi: yellowfin: Fix skb allocation size sundance: Fix oopses with corrupted skb_shared_info Revert "ipv4: Allow configuring subnets as local addresses" USB: mcs7830: return negative if auto negotiate fails irda: prevent integer underflow in IRLMP_ENUMDEVICES tcp: fix listening_get_next() atl1c: Do not use legacy PCI power management mac80211: fix mesh forwarding MAINTAINERS: email address change net: Fix range checks in tcf_valid_offset(). net_sched: sch_sfq: fix allot handling hostap: remove netif_stop_queue from init mac80211/rt2x00: add ieee80211_tx_status_ni() typhoon: memory corruption in typhoon_get_drvinfo() net: Add USB PID for new MOSCHIP USB ethernet controller MCS7832 variant net_sched: always clone skbs ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed. netlink: fix gcc -Wconversion compilation warning asix: add USB ID for Logitec LAN-GTJ U2A ...
2010-12-26iwlwifi: remove reference to Gen2Wey-Yi Guy
The correct name should be used for the newer devices, remove reference to Gen2 Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-12-26iwlagn: fix FH errorJohannes Berg
# iw wlan0 interface add moni0 type monitor flags control # ip link set moni0 up causes a continuous spew of FH_ERROR from the device. Fix this by not setting the CTL2HOST filter by itself -- CTL + promisc works fine. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-12-26iwlwifi: remove extra stringWey-Yi Guy
For "led_mode" module parameters, string "led_mode" is duplicated twice, remove one. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-12-23PCI: make pci_restore_state return voidJon Mason
pci_restore_state only ever returns 0, thus there is no benefit in having it return any value. Also, a large majority of the callers do not check the return code of pci_restore_state. Make the pci_restore_state a void return and avoid the overhead. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Jon Mason <jon.mason@exar.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-12-22Merge branch 'master' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6
2010-12-22rtlwifi: Fix large packet issueChaoming Li
An RX buffer is set to 9100 bytes to receive 8K AMSDU; however, an skb of this size fails in the kernel. Signed-off-by: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22ath9k: Reset keycache on resumeMohammed Shafi Shajakhan
It looks like some hardware registers are left into undefined state after suspend/resume. At minimum, this can cause odd issues related to key cache and hardware trying to encrypt/decrypt frames unexpectedly. This seems to happen even when there is no keys configured, i.e., hardware can end up touching TX frames just based of invalid key cache context even if the driver is not asking a specific entry to be used. In addition, RX can likely be affected. This patch fixes this issue. Signed-off-by: Jouni Malinen <Jouni.Malinen@Atheros.com> Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22rtlwifi: rtl8192ce: Fix driver problem when radio switch off at module loadLarry Finger
If the radio enable switch is off when the driver is loaded, it is not possible to get radio output until the driver is unloaded and reloaded with the switch on. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22rndis_wlan: add support for set_power_mgmtJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22rndis_wlan: add support for set_cqm_rssi_configJussi Kivilinna
Device poller already reads current RSSI, so add support for set_cqm_rssi_config there. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22rndis_wlan: remove unused variable from priv structureJussi Kivilinna
2010-12-22rndis_wlan: constify rndis_config_opsJussi Kivilinna
2010-12-22rndis_wlan: turn radio off before interface is bring upJussi Kivilinna
Radio should be off when interface is down. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22rndis_wlan: do not set default_key if not WEP keyJussi Kivilinna
rndis_set_default_key did call add_wep_key to set default key on device, even if key is WPA. This caused rndis_wlan not work with wpa_supplicant in nl80211 mode (causing disconnect from AP). Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22rndis_wlan: scanning, workaround device returning incorrect bssid-list item ↵Jussi Kivilinna
count. Sometimes device returns wrong number of items in bssid-list. Appears that some specific beacons trigger this problem and leads to very poor scanning results. Workaround by ignoring num_items received from device and walkthrough full bssid-list buffer. v2: Fix buffer range checks and reading next item length. Old code read behind buffer on last item but didn't use those values as 'count' would also reach zero. Also fix resizing of buffer if device has larger buffer, old code assumed that BSSID-list OID would return same buffer size when it really can return yet another new larger length. Tested-by: Luís Picciochi <Pitxyoki@gmail.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22b43: N-PHY: enable support for PHYs rev 3 and higherRafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-22b43: N-PHY: update 2056 radio on channel switch on rev3+Rafał Miłecki
2010-12-22b43: N-PHY: use correct channel tables for rev4+Rafał Miłecki
2010-12-22b43: N-PHY: avoid PHY hangs for rev 3 and 4Rafał Miłecki
2010-12-22b43: N-PHY: add init tables for 2056 radioRafał Miłecki
2010-12-22b43: N-PHY: implement radio 2056 init stepsRafał Miłecki
2010-12-22b43: use correct firmware for newer coresRafał Miłecki
