path: root/drivers/net/wireless
2010-01-05rt2x00: Properly request tx headroom for alignment operations.Gertjan van Wingerde
Current rt2x00 drivers may result in a "ieee80211_tx_status: headroom too small" error message when a frame needs to be properly aligned before transmitting it. This is because the space needed to ensure proper alignment isn't requested from mac80211. Fix this by adding sufficient amount of alignment space to the amount of headroom requested for TX frames. Reported-by: David Ellingsworth <david@identd.dyndns.org> Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <ivdoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05rt2x00: Fix LED configuration setting for rt2800.Gertjan van Wingerde
rt2800_blink_set uses an illegal value to set the LED_CFG_G_LED_MODE field of the LED_CFG register. This field is only 2 bits large, so should be initialized with value that fits. Use default value from the vendor driver. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05rt2x00: use correct headroom for transmissionPavel Roskin
Use rt2x00dev->ops->extra_tx_headroom, not rt2x00dev->hw->extra_tx_headroom in the tx code, as the later may include other headroom not to be used in the chipset driver. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-04ath5k: Fix eeprom checksum check for custom sized eepromsLuis R. Rodriguez
Commit 8bf3d79bc401ca417ccf9fc076d3295d1a71dbf5 enabled EEPROM checksum checks to avoid bogus bug reports but failed to address updating the code to consider devices with custom EEPROM sizes. Devices with custom sized EEPROMs have the upper limit size stuffed in the EEPROM. Use this as the upper limit instead of the static default size. In case of a checksum error also provide back the max size and whether or not this was the default size or a custom one. If the EEPROM is busted we add a failsafe check to ensure we don't loop forever or try to read bogus areas of hardware. This closes bug 14874 http://bugzilla.kernel.org/show_bug.cgi?id=14874 Cc: stable@kernel.org Cc: David Quan <david.quan@atheros.com> Cc: Stephen Beahm <stephenbeahm@comcast.net> Reported-by: Joshua Covington <joshuacov@googlemail.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-04zd1211rw: Fix multicast filtering.Benoit Papillault
If multicast parameter (as returned by zd_op_prepare_multicast) has changed, no bit in changed_flags is set. To handle this situation, we do not return if changed_flags is 0. If we do so, we will have some issue with IPv6 which uses multicast for link layer address resolution. Signed-off-by: Benoit Papillault <benoit.papillault@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-04iwl: off by one bugDan Carpenter
tid is used as an array offset. agg = &priv->stations[sta_id].tid[tid].agg; iwl4965_tx_status_reply_tx(priv, agg, tx_resp, txq_id, index); It should be limitted to MAX_TID_COUNT - 1; struct iwl_tid_data tid[MAX_TID_COUNT]; regards, dan carpenter Signed-off-by: Dan Carpenter <error27@gmail.com> CC: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-04mwl8k: fix configure_filter() memory leak on errorLennert Buytenhek
If there was an error acquiring the firmware lock in mwl8k_configure_filter(), we would end up leaking the multicast command packet prepared by mwl8k_prepare_multicast(). Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-04ath9k: fix ito64Ming Lei
The unit of sizeof() is byte instead of bit, so fix it. The patch can fix debug output of some dma_addr_t variables. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-04ath9k: Fix Kconfig depends for ATH9K_DEBUGFSDominik Geyer
Add missing DEBUG_FS dependency for ATH9K_DEBUGFS in ath9k's Kconfig. Signed-off-by: Dominik D. Geyer <dominik.geyer@gmx.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-29Revert "b43: Enforce DMA descriptor memory constraints"John W. Linville
This reverts commit 9bd568a50c446433038dec2a5186c5c57c3dbd23. That commit is shown to cause allocation failures during initialization on some machines. http://bugzilla.kernel.org/show_bug.cgi?id=14844 Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28iwmc3200wifi: fix array out-of-boundary accessZhu Yi
Allocate priv->rx_packets[IWM_RX_ID_HASH + 1] because the max array index is IWM_RX_ID_HASH according to IWM_RX_ID_GET_HASH(). Cc: stable@kernel.org Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28wl1251: timeout one too soon in wl1251_boot_run_firmware()Roel Kluin
`loop' reaches INIT_LOOP + 1 after the loop. so if ACX_INTR_INIT_COMPLETE occurs in the last iteration the write occurs but also the error out as if a timeout occurred. This is probably very unlikely to ever occur. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28ath9k: fix missed error codes in the tx status checkFelix Fietkau
My previous change added in: commit 815833e7ecf0b9a017315cae6aef4d7cd9517681 ath9k: fix tx status reporting was not checking all possible tx error conditions. This could possibly lead to throughput issues due to slow rate control adaption or missed retransmissions of failed A-MPDU frames. This patch adds a mask for all possible error conditions and uses it in the xmit ok check. Cc: stable@kernel.org Reported-by: Björn Smedman <bjorn.smedman@venatech.se> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28ath9k: wake hardware during AMPDU TX actionsLuis R. Rodriguez
AMDPDU actions poke hardware for TX operation, as such we want to turn hardware on for these actions. AMDPU RX operations do not require hardware on as nothing is done in hardware for those actions. Without this we cannot guarantee hardware has been programmed correctly for each AMPDU TX action. Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28ath9k: wake hardware for interface IBSS/AP/Mesh removalLuis R. Rodriguez
When we remove a IBSS/AP/Mesh interface we stop DMA but to do this we should ensure hardware is on. Awaken the device prior to these calls. This should ensure DMA is stopped upon suspend and plain device removal. Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28ath9k: fix suspend by waking device prior to stopSujith
Ensure the device is awake prior to trying to tell hardware to stop it. Impact of not doing this is we can likely leave the device in an undefined state likely causing issues with suspend and resume. This patch ensures harware is where it should be prior to suspend. Cc: stable@kernel.org Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28wl1271_cmd.c: cleanup char => u8Dan Carpenter
This is just a clean up and doesn't make a functional difference. It keeps the lint checkers happy. Signed-off-by: Dan Carpenter <error27@gmail.com> Reviewed-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28iwlwifi: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28ath9k: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28wireless: remove remaining qual codeJohannes Berg
This removes the remaining users of the rx status 'qual' field and the field itself. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28rt2x00: Add USB ID for Linksys WUSB 600N rev 2.Gertjan van Wingerde
This is a rt2870 based device. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28ath5k: fix SWI calibration interrupt stormBob Copeland
The calibration period is now invoked by triggering a software interrupt from within the ISR by ath5k_hw_calibration_poll() instead of via a timer. However, the calibration interval isn't initialized before interrupts are enabled, so we can have a situation where an interrupt occurs before the interval is assigned, so the interval is actually negative. As a result, the ISR will arm a software interrupt to schedule the tasklet, and then rearm it when the SWI is processed, and so on, leading to a softlockup at modprobe time. Move the initialization order around so the calibration interval is set before interrupts are active. Another possible fix is to schedule the tasklet directly from the poll routine, but I think there are additional plans for the SWI. Signed-off-by: Bob Copeland <me@bobcopeland.com> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28libertas: Remove carrier signaling from the scan codeSamuel Ortiz
There is no reason to signal a carrier off when doing a 802.11 scan. Cc: Holger Schurig <holgerschurig@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28orinoco: fix GFP_KERNEL in orinoco_set_key with interrupts disabledAndrey Borzenkov
orinoco_set_key is called from two places both with interrupts disabled (under orinoco_lock). Use GFP_ATOMIC instead of GFP_KERNEL. Fixes following warning: [ 77.254109] WARNING: at /home/bor/src/linux-git/kernel/lockdep.c:2465 lockdep_trace_alloc+0x9a/0xa0() [ 77.254109] Hardware name: PORTEGE 4000 [ 77.254109] Modules linked in: af_packet irnet ppp_generic slhc ircomm_tty ircomm binfmt_misc dm_mirror dm_region_hash dm_log dm_round_robin dm_multipath dm_mod loop nvram toshiba cryptomgr aead pcompress crypto_blkcipher michael_mic crypto_hash crypto_algapi orinoco_cs orinoco cfg80211 smsc_ircc2 pcmcia irda toshiba_acpi yenta_socket video i2c_ali1535 backlight rsrc_nonstatic ali_agp pcmcia_core psmouse output crc_ccitt i2c_core alim1535_wdt rfkill sg evdev ohci_hcd agpgart usbcore pata_ali libata reiserfs [last unloaded: scsi_wait_scan] [ 77.254109] Pid: 2296, comm: wpa_supplicant Not tainted 2.6.32-1avb #1 [ 77.254109] Call Trace: [ 77.254109] [<c011f0ad>] warn_slowpath_common+0x6d/0xa0 [ 77.254109] [<c014206a>] ? lockdep_trace_alloc+0x9a/0xa0 [ 77.254109] [<c014206a>] ? lockdep_trace_alloc+0x9a/0xa0 [ 77.254109] [<c011f0f5>] warn_slowpath_null+0x15/0x20 [ 77.254109] [<c014206a>] lockdep_trace_alloc+0x9a/0xa0 [ 77.254109] [<c018d296>] __kmalloc+0x36/0x130 [ 77.254109] [<dffcb6a8>] ? orinoco_set_key+0x48/0x1c0 [orinoco] [ 77.254109] [<dffcb6a8>] orinoco_set_key+0x48/0x1c0 [orinoco] [ 77.254109] [<dffcb9fc>] orinoco_ioctl_set_encodeext+0x1dc/0x2d0 [orinoco] [ 77.254109] [<c035b117>] ioctl_standard_call+0x207/0x3b0 [ 77.254109] [<dffcb820>] ? orinoco_ioctl_set_encodeext+0x0/0x2d0 [orinoco] [ 77.254109] [<c0307f1f>] ? rtnl_lock+0xf/0x20 [ 77.254109] [<c0307f1f>] ? rtnl_lock+0xf/0x20 [ 77.254109] [<c02fb115>] ? __dev_get_by_name+0x85/0xb0 [ 77.254109] [<c035b616>] wext_handle_ioctl+0x176/0x200 [ 77.254109] [<dffcb820>] ? orinoco_ioctl_set_encodeext+0x0/0x2d0 [orinoco] [ 77.254109] [<c030020f>] dev_ioctl+0x6af/0x730 [ 77.254109] [<c02eec65>] ? move_addr_to_kernel+0x55/0x60 [ 77.254109] [<c02eed59>] ? sys_sendto+0xe9/0x130 [ 77.254109] [<c02ed77e>] sock_ioctl+0x7e/0x250 [ 77.254109] [<c02ed700>] ? sock_ioctl+0x0/0x250 [ 77.254109] [<c019cf4c>] vfs_ioctl+0x1c/0x70 [ 77.254109] [<c019d1fa>] do_vfs_ioctl+0x6a/0x590 [ 77.254109] [<c0178e50>] ? might_fault+0x90/0xa0 [ 77.254109] [<c0178e0a>] ? might_fault+0x4a/0xa0 [ 77.254109] [<c02ef90e>] ? sys_socketcall+0x17e/0x280 [ 77.254109] [<c019d759>] sys_ioctl+0x39/0x60 [ 77.254109] [<c0102e3b>] sysenter_do_call+0x12/0x32 [ 77.254109] ---[ end trace 95ef563548d21efd ]--- Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21mac80211: fix peer HT capabilitiesJohannes Berg
I noticed yesterday, because Jeff had noticed a speed regression, cf. bug http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2138 that the SM PS settings for peers were wrong. Instead of overwriting the SM PS settings with the local bits, we need to keep the remote bits. The bug was part of the original HT code from over two years ago, but unfortunately nobody noticed that it makes no sense -- we shouldn't be overwriting the peer's setting with our own but rather keep it intact when masking the peer capabilities with our own. While fixing that, I noticed that the masking of capabilities is completely useless for most of the bits, so also fix those other bits. Finally, I also noticed that PSMP_SUPPORT no longer exists in the final 802.11n version, so also remove that. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwmc3200wifi: Fix test of unsigned in iwm_ntf_stop_resume_tx()Roel Kluin
`queue' was unsigned so the test did not work. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Reviewed-by: Pavel Roskin <proski@gnu.org> Acked-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21Libertas: fix buffer overflow in lbs_get_essid()Daniel Mack
The libertas driver copies the SSID buffer back to the wireless core and appends a trailing NULL character for termination. This is a) unnecessary because the buffer is allocated with kzalloc and is hence already NULLed when this function is called, and b) for priv->curbssparams.ssid_len == 32, it writes back one byte too much which causes memory corruptions. Fix this by removing the extra write. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Maithili Hinge <maithili@marvell.com> Cc: Kiran Divekar <dkiran@marvell.com> Cc: Michael Hirsch <m.hirsch@raumfeld.com> Cc: netdev@vger.kernel.org Cc: libertas-dev@lists.infradead.org Cc: linux-wireless@lists.infradead.org Cc: stable@kernel.org Acked-by: Holger Schurig <holgerschurig@gmail.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21drivers/net/wireless/iwlwifi/iwl-tx.c: fix gcc-3.4.5 warningakpm@linux-foundation.org
drivers/net/wireless/iwlwifi/iwl-tx.c: In function `iwl_hw_txq_ctx_free': drivers/net/wireless/iwlwifi/iwl-tx.c:410: warning: suggest explicit braces to avoid ambiguous `else' Cc: Zhu Yi <yi.zhu@intel.com> Cc: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21ath9k: Stop ANI when doing a resetSujith
The MIB counters are disabled when doing a chip reset. Since ANI depends on the MIB registers for its operation, relying on the contents of said registers during HW reset results in sub-optimal performance. Cc: stable@kernel.org Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21ath9k: Fix TX queue drainingSujith
When TX DMA termination has failed, the HW has to be reset completely. Doing a fast channel change in this case is insufficient. Also, change the debug level of a couple of messages to FATAL. Cc: stable@kernel.org Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21ath9k: Fix bug in assigning sequence numberSujith
The internal, driver-specific maintenance of sequence numbers is applicable only for HT frames. Also, remove comments that are not relevant anymore. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21rt2x00: Fix calculation of rt2800 iveiv entry offset.Gertjan van Wingerde
Fix typo. The index should be multiplied by the entry size, not 'and'-ed. Found via code-inspection. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: fix 40MHz operation setting on cards that do not allow itReinette Chatre
Some devices have 40MHz operation disabled entirely. Ensure that driver do not enable 40MHz operation if a channel does not allow this. This fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2135 Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> CC: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwl3945: fix panic in iwl3945 driverZhu Yi
3945 updated write_ptr without regard to read_ptr on the Tx path. This messes up our TFD on high load and result in the following: <1>[ 7290.414172] IP: [<ffffffffa0dd53a1>] iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <4>[ 7290.414205] PGD 0 <1>[ 7290.414214] Thread overran stack, or stack corrupted <0>[ 7290.414229] Oops: 0002 [#1] PREEMPT SMP <0>[ 7290.414246] last sysfs file: /sys/devices/platform/coretemp.1/temp1_input <4>[ 7290.414265] CPU 0 <4>[ 7290.414274] Modules linked in: af_packet nfsd usb_storage usb_libusual cpufreq_powersave exportfs cpufreq_conservative iwl3945 nfs cpufreq_userspace snd_hda_codec_realtek acpi_cpufreq uvcvideo lockd iwlcore snd_hda_intel joydev coretemp nfs_acl videodev snd_hda_codec mac80211 v4l1_compat snd_hwdep sbp2 v4l2_compat_ioctl32 uhci_hcd psmouse auth_rpcgss ohci1394 cfg80211 ehci_hcd video ieee1394 snd_pcm serio_raw battery ac nvidia(P) usbcore output sunrpc evdev lirc_ene0100 snd_page_alloc rfkill tg3 libphy fuse lzo lzo_decompress lzo_compress <6>[ 7290.414486] Pid: 0, comm: swapper Tainted: P 2.6.32-rc8-wl #213 Aspire 5720 <6>[ 7290.414507] RIP: 0010:[<ffffffffa0dd53a1>] [<ffffffffa0dd53a1>] iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <6>[ 7290.414541] RSP: 0018:ffff880002203d60 EFLAGS: 00010246 <6>[ 7290.414557] RAX: 000000000000004f RBX: ffff880064c11600 RCX: 0000000000000013 <6>[ 7290.414576] RDX: ffffffffa0ddcf20 RSI: ffff8800512b7008 RDI: 0000000000000038 <6>[ 7290.414596] RBP: ffff880002203dd0 R08: 0000000000000000 R09: 0000000000000100 <6>[ 7290.414616] R10: 0000000000000001 R11: 0000000000000000 R12: 00000000000000a0 <6>[ 7290.414635] R13: 0000000000000002 R14: 0000000000000013 R15: 0000000000020201 <6>[ 7290.414655] FS: 0000000000000000(0000) GS:ffff880002200000(0000) knlGS:0000000000000000 <6>[ 7290.414677] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b <6>[ 7290.414693] CR2: 0000000000000041 CR3: 0000000001001000 CR4: 00000000000006f0 <6>[ 7290.414712] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 <6>[ 7290.414732] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 <4>[ 7290.414752] Process swapper (pid: 0, threadinfo ffffffff81524000, task ffffffff81528b60) <0>[ 7290.414772] Stack: <4>[ 7290.414780] ffff880002203da0 0000000000000046 0000000000000000 0000000000000046 <4>[ 7290.414804] <0> 0000000000000282 0000000000000282 0000000000000282 ffff880064c12010 <4>[ 7290.414830] <0> ffff880002203db0 ffff880064c11600 ffff880064c12e50 ffff8800512b7000 <0>[ 7290.414858] Call Trace: <0>[ 7290.414867] <IRQ> <4>[ 7290.414884] [<ffffffffa0dc8c47>] iwl3945_irq_tasklet+0x657/0x1740 [iwl3945] <4>[ 7290.414910] [<ffffffff8138fc60>] ? _spin_unlock+0x30/0x60 <4>[ 7290.414931] [<ffffffff81049a21>] tasklet_action+0x101/0x110 <4>[ 7290.414950] [<ffffffff8104a3d0>] __do_softirq+0xc0/0x160 <4>[ 7290.414968] [<ffffffff8100d01c>] call_softirq+0x1c/0x30 <4>[ 7290.414986] [<ffffffff8100eff5>] do_softirq+0x75/0xb0 <4>[ 7290.415003] [<ffffffff81049ee5>] irq_exit+0x95/0xa0 <4>[ 7290.415020] [<ffffffff8100e547>] do_IRQ+0x77/0xf0 <4>[ 7290.415038] [<ffffffff8100c7d3>] ret_from_intr+0x0/0xf <0>[ 7290.415052] <EOI> <4>[ 7290.415067] [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415087] [<ffffffff81234f04>] ? acpi_idle_enter_bm+0x27a/0x2a5 <4>[ 7290.415107] [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415130] [<ffffffff812c11f3>] ? cpuidle_idle_call+0x93/0xf0 <4>[ 7290.415149] [<ffffffff8100b0d7>] ? cpu_idle+0xa7/0x110 <4>[ 7290.415168] [<ffffffff8137b3d5>] ? rest_init+0x75/0x80 <4>[ 7290.415187] [<ffffffff8158cd0a>] ? start_kernel+0x3a7/0x3b3 <4>[ 7290.415206] [<ffffffff8158c315>] ? x86_64_start_reservations+0x125/0x129 <4>[ 7290.415227] [<ffffffff8158c3fd>] ? x86_64_start_kernel+0xe4/0xeb <0>[ 7290.415243] Code: 00 41 39 ce 0f 8d e8 01 00 00 48 8b 47 40 48 63 d2 48 69 d2 98 00 00 00 4c 8b 04 02 48 c7 c2 20 cf dd a0 49 8d 78 38 49 8d 40 4f <c6> 47 09 00 c6 47 0c 00 c6 47 0f 00 c6 47 12 00 c6 47 15 00 49 <1>[ 7290.415382] RIP [<ffffffffa0dd53a1>] iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <4>[ 7290.415410] RSP <ffff880002203d60> <0>[ 7290.415421] CR2: 0000000000000041 <4>[ 7290.415436] ---[ end trace ec46807277caa515 ]--- <0>[ 7290.415450] Kernel panic - not syncing: Fatal exception in interrupt <4>[ 7290.415468] Pid: 0, comm: swapper Tainted: P D 2.6.32-rc8-wl #213 <4>[ 7290.415486] Call Trace: <4>[ 7290.415495] <IRQ> [<ffffffff8138c040>] panic+0x7d/0x13a <4>[ 7290.415519] [<ffffffff8101071a>] oops_end+0xda/0xe0 <4>[ 7290.415538] [<ffffffff8102e1ea>] no_context+0xea/0x250 <4>[ 7290.415557] [<ffffffff81038991>] ? select_task_rq_fair+0x511/0x780 <4>[ 7290.415578] [<ffffffff8102e475>] __bad_area_nosemaphore+0x125/0x1e0 <4>[ 7290.415597] [<ffffffff81038d0c>] ? __enqueue_entity+0x7c/0x80 <4>[ 7290.415616] [<ffffffff81039201>] ? enqueue_task_fair+0x111/0x150 <4>[ 7290.415636] [<ffffffff8102e53e>] bad_area_nosemaphore+0xe/0x10 <4>[ 7290.415656] [<ffffffff8102e8fa>] do_page_fault+0x26a/0x320 <4>[ 7290.415674] [<ffffffff813905df>] page_fault+0x1f/0x30 <4>[ 7290.415697] [<ffffffffa0dd53a1>] ? iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <4>[ 7290.415723] [<ffffffffa0dc8c47>] iwl3945_irq_tasklet+0x657/0x1740 [iwl3945] <4>[ 7290.415746] [<ffffffff8138fc60>] ? _spin_unlock+0x30/0x60 <4>[ 7290.415764] [<ffffffff81049a21>] tasklet_action+0x101/0x110 <4>[ 7290.415783] [<ffffffff8104a3d0>] __do_softirq+0xc0/0x160 <4>[ 7290.415801] [<ffffffff8100d01c>] call_softirq+0x1c/0x30 <4>[ 7290.415818] [<ffffffff8100eff5>] do_softirq+0x75/0xb0 <4>[ 7290.415835] [<ffffffff81049ee5>] irq_exit+0x95/0xa0 <4>[ 7290.415852] [<ffffffff8100e547>] do_IRQ+0x77/0xf0 <4>[ 7290.415869] [<ffffffff8100c7d3>] ret_from_intr+0x0/0xf <4>[ 7290.415883] <EOI> [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415911] [<ffffffff81234f04>] ? acpi_idle_enter_bm+0x27a/0x2a5 <4>[ 7290.415931] [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415952] [<ffffffff812c11f3>] ? cpuidle_idle_call+0x93/0xf0 <4>[ 7290.415971] [<ffffffff8100b0d7>] ? cpu_idle+0xa7/0x110 <4>[ 7290.415989] [<ffffffff8137b3d5>] ? rest_init+0x75/0x80 <4>[ 7290.416007] [<ffffffff8158cd0a>] ? start_kernel+0x3a7/0x3b3 <4>[ 7290.416026] [<ffffffff8158c315>] ? x86_64_start_reservations+0x125/0x129 <4>[ 7290.416047] [<ffffffff8158c3fd>] ? x86_64_start_kernel+0xe4/0xeb Reported-by: Maxim Levitsky <maximlevitsky@gmail.com> Tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> CC: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: initialize spinlock before useReinette Chatre
Recent powersaving work resulted in power management ops being called during EEPROM initialization. The lock used by these functions is not initialized at this time. Ensure lock is initialized before it is used. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwl3945: disable power saveReinette Chatre
we see from http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2125 that power saving does not work well on 3945. Since then power saving has also been connected with association problems where an AP deathenticates a 3945 after it is unable to transmit data to it - this happens when 3945 enters power savings mode. Disable power save support until issues are resolved. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> CC: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: fix more eeprom endian bugsJohannes Berg
I've also for a long time had a problem with the temperature calculation code, which I had fixed by byte-swapping the values, and now it turns out that was the correct fix after all. Also, any use of iwl_eeprom_query_addr() that is for more than a u8 must be cast to little endian, and some structs as well. Fix all this. Again, no real impact on platforms that already are little endian. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: fix EEPROM/OTP reading endian annotations and a bugJohannes Berg
The construct "le16_to_cpu((__force __le16)(r >> 16))" has always bothered me when looking through the iwlwifi code, it shouldn't be necessary to __force anything, and before this code, "r" was obtained with an ioread32, which swaps each of the two u16 values in it properly when swapping the entire u32 value. I've had arguments about this code with people before, but always conceded they were right because removing it only made things not work at all on big endian platforms. However, analysing a failure of the OTP reading code, I now finally figured out what is going on, and why my intuition about that code being wrong was right all along. It turns out that the 'priv->eeprom' u8 array really wants to have the data in it in little endian. So the force code above and all really converts *to* little endian, not from it. Cf., for instance, the function iwl_eeprom_query16() -- it reads two u8 values and combines them into a u16, in a little-endian way. And considering it more, it makes sense to have the eeprom array as on the device, after all not all values really are 16-bit values, the MAC address for instance is not. Now, what this really means is that all the annotations are completely wrong. The eeprom reading code should fill the priv->eeprom array as a __le16 array, with __le16 values. This also means that iwl_read_otp_word() should really have a __le16 pointer as the data argument, since it should be filling that in a format suitable for priv->eeprom. Propagating these changes throughout, iwl_find_otp_image() is found to be, now obviously visible, defective -- it uses the data returned by iwl_read_otp_word() directly as if it was CPU endianness. Fixing that, which is this hunk of the patch: - next_link_addr = link_value * sizeof(u16); + next_link_addr = le16_to_cpu(link_value) * sizeof(u16); is the only real change of this patch. Everything else is just fixing the sparse annotations. Also, the bug only shows up on big endian platforms with a 1000 series card. 5000 and previous series do not use OTP, and 6000 series has shadow RAM support which means we don't ever use the defective code on any cards but 1000. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21rt2x00: Disable powersaving for rt61pci and rt2800pci.Gertjan van Wingerde
We've had many reports of rt61pci failures with powersaving enabled. Therefore, as a stop-gap measure, disable powersaving of the rt61pci until we have found a proper solution. Also disable powersaving on rt2800pci as it most probably will show the same problem. Cc: stable@kernel.org Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21drivers/net/wireless: Correct code taking the size of a pointerJulia Lawall
sizeof(iv16) and sizeof(iv32) are the sizes of pointers. Change them to the size of the copied data. Furthermore, iveiv_entry is a local structure that has just been initialized and is not visible outside this function. Thus, there would seem to be no point to copy data into it. The order of the arguments is thus changed to copy the data into the parameters, which are provided as pointers, suggesting in this case that they should be used to return values. A simplified version of the semantic patch that finds the first problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression *x; expression f; type T; @@ *f(...,(T)x,...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21ath9k: Last fix for TX software padding.Benoit Papillault
First, we copy/paste the padding stuff from ath9k_tx to ath_tx_cabq since it needs to same kind of padding, but for internally generated beacons. Next, software padding done on TX needs to be removed before calling ieee80211_tx_status. The code was already there in ath_tx_complete but it was wrong. Fix it by using ath9k_cmn_padpos. This later code has been tested by sending packets to a monitor interface and reading packets from the same interface. Signed-off-by: Benoit PAPILLAULT <benoit.papillault@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: fix syslog message for event log dump sizeWey-Yi Guy
When trigger event log dumping from debugfs, the entire event log should be dumped and the size should match the number of events being dump. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: power up all devices for EEPROM readReinette Chatre
Recent commits "iwlwifi: remove power-wasting calls to apm_ops.init()" and "iwlagn: power up device before initializing EEPROM" had the goal of reducing device power consumption from the time the module is loaded until the interface is brought up and the device's power saving mechanisms kick in. The idea is that once the module is loaded there is no need for the device to consume power until the interface is brought up. With the current solution the device is only powered up during EEPROM read, and then so also only if the EEPROM type is OTP. We have found that on certain platforms even non-OTP devices require power to be up during EEPROM read. On these platforms the driver never loads and the system log contains the following: iwlagn 0000:03:00.0: MAC is in deep sleep!. CSR_GP_CNTRL = 0x080403D8 We thus now power up all devices during EEPROM read. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: allocated rx page accounting cleanupZhu Yi
In iwlwifi, priv->alloc_rxb_page is used to keep track of the Rx pages allocated by the driver. This cleans up the page free routines by introducing __iwl_free_pages/iwl_free_pages so that the accounting is more accurate and less error prone. This also fixes two instances where the counter was not updated. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-14rt2x00: Fix rt2800usb detection in rt2800lib.Gertjan van Wingerde
rt2800lib incorrectly detected whether RT2800USB was enabled because it didn't account for a modularized RT2800USB driver. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-10b43: Remove reset after fatal DMA errorLarry Finger
As shown in Kernel Bugzilla #14761, doing a controller restart after a fatal DMA error does not accomplish anything other than consume the CPU on an affected system. Accordingly, substitute a meaningful message for the restart. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> [2.6.32] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-10rtl8187: add radio led and fix warnings on suspendHerton Ronaldo Krzesinski
Michael Buesch reports that his rtl8187 gives warnings on suspend ("queueing ieee80211 work while going to suspend" warnings), as rtl8187 can call ieee80211_queue_delayed_work after mac80211 is suspended. This change enhances rtl8187 led code so we can avoid queuing work after mac80211 is suspended: now we register a radio led and make additional checks to ensure led is off/on properly as mac80211 wants. Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-10ath5k: enable EEPROM checksum checkLuis R. Rodriguez
Without this we have no gaurantee of the integrity of the EEPROM and are likely to encounter a lot of bogus bug reports due to actual issues on the EEPROM. With the EEPROM checksum check in place we can easily rule those issues out. If you run patch during a revert *you* have a card with a busted EEPROM and only older kernel will support that concoction. This patch is a trade off between not accepitng bogus EEPROMs and avoiding bogus bug reports allowing developers to focus instead on real concrete issues. If stable keeps bogus bug reports because of a possibly busted EEPROM feel free to apply this there too. Tested on an AR5414 Cc: stable@kernel.org Cc: jirislaby@gmail.com Cc: akpm@linux-foundation.org Cc: rjw@sisk.pl Cc: me@bobcopeland.com Cc: david.quan@atheros.com Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-07ath5k: add support for Dell Vostro A860 LEDShahar Or
Adds support for the WiFi activity LED on the Dell Vostro A860 laptop. Signed-off-by: Shahar Or <shahar@shahar-or.co.il> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-07orinoco: remove spare KERN_DEBUGDavid Kilroy
A KERN_DEBUG didn't get removed when transitioning from printk to pr_debug Signed-off-by: David Kilroy <kilroyd@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
