RFC for WL1251 idle mode support brought a few issues that are worth to
update before adding the idle mode support.
Since the idle mode can reuse the code that is now used in Power Save Mode
(PSM), the flag psm in struct wl1251 is changed to variable station_mode
to be able to distinguish between PSM and idle modes.
As the station mode is different than the power power save mode command
that is sent to chip, the enum wl1251_cmd_ps_mod values are used only when
communicating with the chip and new enum wl1251_station_mode values are used
inside the driver.
Confusing comment about psm and elp relation is removed since the PSM is
actually activated by putting the chip into Entreme Low Power (ELP) mode.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Kalle Valo <kvalo@adurom.com>
Implement connection quality monitoring similar to the wl1271 driver.
It triggers ieee80211_cqm_rssi_notify with the corresponding event when
RSSI drops blow RSSI threshold or rises again above the RSSI threshold.
It should be noted that wl1251 doesn't support RSSI hysteresis, instead it
uses RSSI averageing and delays events until a certain count of frames
proved RSSI change.
Signed-off-by: David Gnedt <david.gnedt@davizone.at>
wl1271 driver is under heavy development but on the other hand the older
wl1251 driver is currently considered more as a legacy driver. To make it
easier to develop wl1271 features move wl1251 to it's own directory,
drivers/net/wireless/wl1251.
There are no functional changes, only moving of files. One regression
is that Kconfig won't be updated automatically and user needs to enable
wl1251 manually with an older config file.
Signed-off-by: Kalle Valo <kvalo@adurom.com>
