path: root/drivers/net/wireless/rtlwifi
2012-02-09rtlwifi: Modify rtl_pci_init to return 0 on successSimon Graham
Fixes problem where caller would think routine succeeded when it failed leading to divide by zero panic. Signed-off-by: Simon Graham <simon.graham@virtualcomputer.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-12Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2012-01-10rtl8192se: Fix BUG caused by failure to check skb allocationLarry Finger
When downloading firmware into the device, the driver fails to check the return when allocating an skb. When the allocation fails, a BUG can be generated, as seen in https://bugzilla.redhat.com/show_bug.cgi?id=771656. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-07Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits) arm: fix up some samsung merge sysdev conversion problems firmware: Fix an oops on reading fw_priv->fw in sysfs loading file Drivers:hv: Fix a bug in vmbus_driver_unregister() driver core: remove __must_check from device_create_file debugfs: add missing #ifdef HAS_IOMEM arm: time.h: remove device.h #include driver-core: remove sysdev.h usage. clockevents: remove sysdev.h arm: convert sysdev_class to a regular subsystem arm: leds: convert sysdev_class to a regular subsystem kobject: remove kset_find_obj_hinted() m86k: gpio - convert sysdev_class to a regular subsystem mips: txx9_sram - convert sysdev_class to a regular subsystem mips: 7segled - convert sysdev_class to a regular subsystem sh: dma - convert sysdev_class to a regular subsystem sh: intc - convert sysdev_class to a regular subsystem power: suspend - convert sysdev_class to a regular subsystem power: qe_ic - convert sysdev_class to a regular subsystem power: cmm - convert sysdev_class to a regular subsystem s390: time - convert sysdev_class to a regular subsystem ... Fix up conflicts with 'struct sysdev' removal from various platform drivers that got changed: - arch/arm/mach-exynos/cpu.c - arch/arm/mach-exynos/irq-eint.c - arch/arm/mach-s3c64xx/common.c - arch/arm/mach-s3c64xx/cpu.c - arch/arm/mach-s5p64x0/cpu.c - arch/arm/mach-s5pv210/common.c - arch/arm/plat-samsung/include/plat/cpu.h - arch/powerpc/kernel/sysfs.c and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
2012-01-06Merge branch 'driver-core-next' into Linux 3.2Greg Kroah-Hartman
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file, and it fixes the build error in the arch/x86/kernel/microcode_core.c file, that the merge did not catch. The microcode_core.c patch was provided by Stephen Rothwell <sfr@canb.auug.org.au> who was invaluable in the merge issues involved with the large sysdev removal process in the driver-core tree. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-03Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/b43/dma.c drivers/net/wireless/brcm80211/brcmfmac/dhd_linux.c
2011-12-19module_param: make bool parameters really bool (net & drivers/net)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. (Thanks to Joe Perches for suggesting coccinelle for 0/1 -> true/false). Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19net: fix assignment of 0/1 to bool variables.Rusty Russell
DaveM said: Please, this kind of stuff rots forever and not using bool properly drives me crazy. Joe Perches <joe@perches.com> gave me the spatch script: @@ bool b; @@ -b = 0 +b = false @@ bool b; @@ -b = 1 +b = true I merely installed coccinelle, read the documentation and took credit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19rtlwifi: Fix locking problem introduces with commit 6539306bLarry Finger
When I tested commit 6539306, I did not notice that loading an out-of-tree module turns off lockdep testing in kernel 3.2. For that reason, I missed the kernel WARNING shown below: The solution fixes the warning by partially reverting commit 6539306. [ 84.168146] ------------[ cut here ]------------ [ 84.168155] WARNING: at kernel/mutex.c:198 mutex_lock_nested+0x309/0x310() [ 84.168158] Hardware name: HP Pavilion dv2700 Notebook PC [ 84.168161] Modules linked in: nfs lockd auth_rpcgss nfs_acl sunrpc af_packet cpufreq_conservative cpufreq_userspace cpufreq_powersave powernow_k8 mperf e xt3 jbd ide_cd_mod cdrom snd_hda_codec_conexant arc4 rtl8192ce ide_pci_generic rtl8192c_common rtlwifi snd_hda_intel mac80211 snd_hda_codec snd_pcm snd_timer amd74xx ide_core cfg80211 k8temp snd joydev soundcore hwmon battery forcedeth i2c_nforce2 sg rfkill ac serio_raw snd_page_alloc button video i2c_core ipv6 a utofs4 ext4 mbcache jbd2 crc16 sd_mod ahci ohci_hcd libahci libata scsi_mod ehci_hcd usbcore usb_common fan processor thermal [ 84.168231] Pid: 1218, comm: kworker/u:2 Not tainted 3.2.0-rc5-wl+ #155 [ 84.168234] Call Trace: [ 84.168240] [<ffffffff81048aaa>] warn_slowpath_common+0x7a/0xb0 [ 84.168245] [<ffffffff81048af5>] warn_slowpath_null+0x15/0x20 [ 84.168249] [<ffffffff813811f9>] mutex_lock_nested+0x309/0x310 [ 84.168269] [<ffffffffa00793f9>] ? rtl_ips_nic_on+0x49/0xb0 [rtlwifi] [ 84.168277] [<ffffffffa00793f9>] rtl_ips_nic_on+0x49/0xb0 [rtlwifi] [ 84.168284] [<ffffffffa007ab85>] rtl_pci_tx+0x1b5/0x560 [rtlwifi] [ 84.168291] [<ffffffffa007635a>] rtl_op_tx+0x9a/0xa0 [rtlwifi] [ 84.168359] [<ffffffffa043cf51>] __ieee80211_tx+0x181/0x2b0 [mac80211] [ 84.168375] [<ffffffffa043ef06>] ieee80211_tx+0xf6/0x120 [mac80211] [ 84.168391] [<ffffffffa043ee49>] ? ieee80211_tx+0x39/0x120 [mac80211] [ 84.168408] [<ffffffffa043f80b>] ieee80211_xmit+0xdb/0x100 [mac80211] [ 84.168425] [<ffffffffa043f730>] ? ieee80211_skb_resize.isra.26+0xb0/0xb0 [mac80211] [ 84.168441] [<ffffffffa0440b2a>] ieee80211_tx_skb_tid+0x5a/0x70 [mac80211] [ 84.168458] [<ffffffffa0443da2>] ieee80211_send_auth+0x152/0x1b0 [mac80211] [ 84.168474] [<ffffffffa042e169>] ieee80211_work_work+0x1049/0x1860 [mac80211] [ 84.168489] [<ffffffffa042d120>] ? free_work+0x20/0x20 [mac80211] [ 84.168504] [<ffffffffa042d120>] ? free_work+0x20/0x20 [mac80211] [ 84.168510] [<ffffffff81065ffc>] process_one_work+0x17c/0x530 [ 84.168514] [<ffffffff81065f92>] ? process_one_work+0x112/0x530 [ 84.168519] [<ffffffff81066994>] worker_thread+0x164/0x350 [ 84.168524] [<ffffffff8108420d>] ? trace_hardirqs_on+0xd/0x10 [ 84.168528] [<ffffffff81066830>] ? manage_workers.isra.28+0x220/0x220 [ 84.168533] [<ffffffff8106bc17>] kthread+0x87/0x90 [ 84.168539] [<ffffffff813854b4>] kernel_thread_helper+0x4/0x10 [ 84.168543] [<ffffffff81382bdd>] ? retint_restore_args+0xe/0xe [ 84.168547] [<ffffffff8106bb90>] ? __init_kthread_worker+0x70/0x70 [ 84.168552] [<ffffffff813854b0>] ? gs_change+0xb/0xb [ 84.168554] ---[ end trace f25a4fdc768c028f ]--- Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stanislaw Gruska <sgruszka@redhat.com> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-14Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/iwlwifi/iwl-agn.c
2011-12-13rtlwifi: merge ips,lps spinlocks into one mutexStanislaw Gruszka
With previous patch "rtlwifi: use work for lps" we can now use mutex for protecting ps mode changing critical sections. This fixes running system with interrupts disabled for long time. Merge ips_lock and lps_lock as they seems to protect the same data structures (accessed in rtl_ps_set_rf_state() function). Reported-by: Philipp Dreimann <philipp@dreimann.net> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Mike McCormack <mikem@ring3k.org> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-13rtlwifi: use work for lpsStanislaw Gruszka
Leaving leisure power save mode can take some time, so it's better to perform that action in process context with interrupts enabled. This patch changes lps_leave tasklet to work. Reported-by: Philipp Dreimann <philipp@dreimann.net> Tested-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Mike McCormack <mikem@ring3k.org> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2011-12-07rtl8192{ce,cu,de,se}: avoid problems because of possible ERFOFF -> ERFSLEEP ↵Philipp Dreimann
transition In drivers rtl8192ce, rtl8192cu, rtl8192se, and rtl8192de, break statements would allow ppsc->rfpwr_state to be changed to ERFSLEEP even though the device is actually in ERFOFF. Signed-off-by: Philipp Dreimann <philipp@dreimann.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-06rtl8192c: Do not log firmware load message unless actually doneLarry Finger
A previous commit fixed a problem whereby the rtl8192c driver loaded the firmware from disk many times; however, the log message was not moved. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-02Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/iwlwifi/iwl-agn.c drivers/net/wireless/libertas/cfg.c
2011-12-02treewide: Fix typos in various parts of the kernel, and fix some comments.Justin P. Mattock
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments. Please let me know if I missed anything, and I will try to get it changed and resent. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-30Merge branch 'master' of ↵John W. Linville
2011-11-28rtlwifi: Fix incorrect return of IRQ_HANDLEDLarry Finger
The recent discussion regarding an incorrect return of IRQ_HANDLED from rt2800pci caused me to look at this PCI interrupt routine. I discovered that changes were needed. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28rtlwifi: fix lps_lock deadlockStanislaw Gruszka
rtl_lps_leave can be called from interrupt context, so we have to disable interrupts when taking lps_lock. Below is full lockdep info about deadlock: [ 93.815269] ================================= [ 93.815390] [ INFO: inconsistent lock state ] [ 93.815472] 2.6.41.1-3.offch.fc15.x86_64.debug #1 [ 93.815556] --------------------------------- [ 93.815635] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage. [ 93.815743] swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes: [ 93.815832] (&(&rtlpriv->locks.lps_lock)->rlock){+.?...}, at: [<ffffffffa025dad6>] rtl_lps_leave+0x26/0x103 [rtlwifi] [ 93.815947] {SOFTIRQ-ON-W} state was registered at: [ 93.815947] [<ffffffff8108e10d>] __lock_acquire+0x369/0xd0c [ 93.815947] [<ffffffff8108efb3>] lock_acquire+0xf3/0x13e [ 93.815947] [<ffffffff814e981d>] _raw_spin_lock+0x45/0x79 [ 93.815947] [<ffffffffa025de34>] rtl_swlps_rf_awake+0x5a/0x76 [rtlwifi] [ 93.815947] [<ffffffffa025aec0>] rtl_op_config+0x12a/0x32a [rtlwifi] [ 93.815947] [<ffffffffa01d614b>] ieee80211_hw_config+0x124/0x129 [mac80211] [ 93.815947] [<ffffffffa01e0af3>] ieee80211_dynamic_ps_disable_work+0x32/0x47 [mac80211] [ 93.815947] [<ffffffff81075aa5>] process_one_work+0x205/0x3e7 [ 93.815947] [<ffffffff81076753>] worker_thread+0xda/0x15d [ 93.815947] [<ffffffff8107a119>] kthread+0xa8/0xb0 [ 93.815947] [<ffffffff814f3184>] kernel_thread_helper+0x4/0x10 [ 93.815947] irq event stamp: 547822 [ 93.815947] hardirqs last enabled at (547822): [<ffffffff814ea1a7>] _raw_spin_unlock_irqrestore+0x45/0x61 [ 93.815947] hardirqs last disabled at (547821): [<ffffffff814e9987>] _raw_spin_lock_irqsave+0x22/0x8e [ 93.815947] softirqs last enabled at (547790): [<ffffffff810623ed>] _local_bh_enable+0x13/0x15 [ 93.815947] softirqs last disabled at (547791): [<ffffffff814f327c>] call_softirq+0x1c/0x30 [ 93.815947] [ 93.815947] other info that might help us debug this: [ 93.815947] Possible unsafe locking scenario: [ 93.815947] [ 93.815947] CPU0 [ 93.815947] ---- [ 93.815947] lock(&(&rtlpriv->locks.lps_lock)->rlock); [ 93.815947] <Interrupt> [ 93.815947] lock(&(&rtlpriv->locks.lps_lock)->rlock); [ 93.815947] [ 93.815947] *** DEADLOCK *** [ 93.815947] [ 93.815947] no locks held by swapper/0. [ 93.815947] [ 93.815947] stack backtrace: [ 93.815947] Pid: 0, comm: swapper Not tainted 2.6.41.1-3.offch.fc15.x86_64.debug #1 [ 93.815947] Call Trace: [ 93.815947] <IRQ> [<ffffffff814dfd00>] print_usage_bug+0x1e7/0x1f8 [ 93.815947] [<ffffffff8101a849>] ? save_stack_trace+0x2c/0x49 [ 93.815947] [<ffffffff8108d55c>] ? print_irq_inversion_bug.part.18+0x1a0/0x1a0 [ 93.815947] [<ffffffff8108dc8a>] mark_lock+0x106/0x220 [ 93.815947] [<ffffffff8108e099>] __lock_acquire+0x2f5/0xd0c [ 93.815947] [<ffffffff810152af>] ? native_sched_clock+0x34/0x36 [ 93.830125] [<ffffffff810152ba>] ? sched_clock+0x9/0xd [ 93.830125] [<ffffffff81080181>] ? sched_clock_local+0x12/0x75 [ 93.830125] [<ffffffffa025dad6>] ? rtl_lps_leave+0x26/0x103 [rtlwifi] [ 93.830125] [<ffffffff8108efb3>] lock_acquire+0xf3/0x13e [ 93.830125] [<ffffffffa025dad6>] ? rtl_lps_leave+0x26/0x103 [rtlwifi] [ 93.830125] [<ffffffff814e981d>] _raw_spin_lock+0x45/0x79 [ 93.830125] [<ffffffffa025dad6>] ? rtl_lps_leave+0x26/0x103 [rtlwifi] [ 93.830125] [<ffffffff81422467>] ? skb_dequeue+0x62/0x6d [ 93.830125] [<ffffffffa025dad6>] rtl_lps_leave+0x26/0x103 [rtlwifi] [ 93.830125] [<ffffffffa025f677>] _rtl_pci_ips_leave_tasklet+0xe/0x10 [rtlwifi] [ 93.830125] [<ffffffff8106281f>] tasklet_action+0x8d/0xee [ 93.830125] [<ffffffff810629ce>] __do_softirq+0x112/0x25a [ 93.830125] [<ffffffff814f327c>] call_softirq+0x1c/0x30 [ 93.830125] [<ffffffff81010bf6>] do_softirq+0x4b/0xa1 [ 93.830125] [<ffffffff81062d7d>] irq_exit+0x5d/0xcf [ 93.830125] [<ffffffff814f3b7e>] do_IRQ+0x8e/0xa5 [ 93.830125] [<ffffffff814ea533>] common_interrupt+0x73/0x73 [ 93.830125] <EOI> [<ffffffff8108b825>] ? trace_hardirqs_off+0xd/0xf [ 93.830125] [<ffffffff812bb6d5>] ? intel_idle+0xe5/0x10c [ 93.830125] [<ffffffff812bb6d1>] ? intel_idle+0xe1/0x10c [ 93.830125] [<ffffffff813f8d5e>] cpuidle_idle_call+0x11c/0x1fe [ 93.830125] [<ffffffff8100e2ef>] cpu_idle+0xab/0x101 [ 93.830125] [<ffffffff814c6373>] rest_init+0xd7/0xde [ 93.830125] [<ffffffff814c629c>] ? csum_partial_copy_generic+0x16c/0x16c [ 93.830125] [<ffffffff81d4bbb0>] start_kernel+0x3dd/0x3ea [ 93.830125] [<ffffffff81d4b2c4>] x86_64_start_reservations+0xaf/0xb3 [ 93.830125] [<ffffffff81d4b140>] ? early_idt_handlers+0x140/0x140 [ 93.830125] [<ffffffff81d4b3ca>] x86_64_start_kernel+0x102/0x111 Resolves: https://bugzilla.redhat.com/show_bug.cgi?id=755154 Reported-by: vjain02@students.poly.edu Reported-and-tested-by: Oliver Paukstadt <pstadt@sourcentral.org> Cc: stable@vger.kernel.org Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-22rtlwifi: squash warning in _usb_read_syncJohn W. Linville
drivers/net/wireless/rtlwifi/usb.c: In function ‘_usb_read_sync’: drivers/net/wireless/rtlwifi/usb.c:102:6: warning: ‘status’ may be used uninitialized in this function drivers/net/wireless/rtlwifi/usb.c:102:6: note: ‘status’ was declared here My compiler is dumb, but better to eliminate the warning than to have anyone waste time evaluating this again... Signed-off-by: John W. Linville <linville@tuxdriver.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
2011-11-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux Conflicts: drivers/net/wireless/iwlegacy/iwl-debugfs.c drivers/net/wireless/iwlegacy/iwl-rx.c drivers/net/wireless/iwlegacy/iwl-scan.c drivers/net/wireless/iwlegacy/iwl-tx.c include/net/bluetooth/bluetooth.h
2011-11-21rtlwifi: Remove redundant code from PCI interruptLarry Finger
The interrupt routine for PCI devices has a special exit that executes the same instructions as does the normal exit. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21rtlwifi: rtl8192cu: Fix endianian issuesLarry Finger
Driver rtlwifi fails on a big-endian host. These changes have been tested on a Mac PowerBook G4, which has a PPC processor. Although this patch touches some of the code that will affect endian issues on PCI hardware through drivers rtl8192ce, rtl8192se, and rtl8192de, these have not been tested due to lack of suitable hardware. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21rtlwifi: rtl8192cu: Change firmware upload to use block writesLarry Finger
Driver rtl8192cu writes the firmware with 32-bit asynchronous writes. This design is OK for USB 2.0 adapters, but the current implementation of xhcu-hcd has a limited ring size, which is exceeded. By converting to synchronous block writes, this error is avoided. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-21rtlwifi: rtl8192cu: Allow retries for USB I/OGeorge
The USB driver does not retry reads - allow 10 tries. Signed-off-by: George <george0505@realtek.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-18USB: convert drivers/net/* to use module_usb_driver()Greg Kroah-Hartman
This converts the drivers in drivers/net/* to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Oliver Neukum <oliver@neukum.name> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Petko Manolov <petkan@users.sourceforge.net> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Dan Williams <dcbw@redhat.com> Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Gertjan van Wingerde <gwingerde@gmail.com> Cc: Helmut Schaa <helmut.schaa@googlemail.com> Cc: Herton Ronaldo Krzesinski <herton@canonical.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jiri Pirko <jpirko@redhat.com> Cc: Pavel Roskin <proski@gnu.org> Cc: Yoann DI-RUZZA <y.diruzza@lim.eu> Cc: George <george0505@realtek.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-09Merge branch 'master' of ↵John W. Linville
2011-11-08rtl8192cu: Add new device IDsLarry Finger
The latest vendor (non-mac80211) driver of 9/22/2011 shows some new device IDs for rtl8192cu. In addition, some typos in the table are fixed and one duplicate is removed. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-02Merge branch 'for-linus' of git://github.com/richardweinberger/linuxLinus Torvalds
* 'for-linus' of git://github.com/richardweinberger/linux: (90 commits) um: fix ubd cow size um: Fix kmalloc argument order in um/vdso/vma.c um: switch to use of drivers/Kconfig UserModeLinux-HOWTO.txt: fix a typo UserModeLinux-HOWTO.txt: remove ^H characters um: we need sys/user.h only on i386 um: merge delay_{32,64}.c um: distribute exports to where exported stuff is defined um: kill system-um.h um: generic ftrace.h will do... um: segment.h is x86-only and needed only there um: asm/pda.h is not needed anymore um: hw_irq.h can go generic as well um: switch to generic-y um: clean Kconfig up a bit um: a couple of missing dependencies... um: kill useless argument of free_chan() and free_one_chan() um: unify ptrace_user.h um: unify KSTK_... um: fix gcov build breakage ...
2011-11-02um: a couple of missing dependencies...Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-10-31drivers/net: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These were getting the macros from an implicit module.h include via device.h, but we are planning to clean that up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> drivers/net: Add export.h to wireless/brcm80211/brcmfmac/bcmsdh.c This relatively recently added file uses EXPORT_SYMBOL and hence needs export.h included so that it is compatible with the module.h split up work. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/net: Add module.h to drivers who were implicitly using itPaul Gortmaker
The device.h header was including module.h, making it present for most of these drivers. But we want to clean that up. Call out the include of module.h in the modular network drivers. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
2011-10-14rtlwifi: rtl8192de: Updates from latest Reaktek driver - Part IIIChaoming Li
This patch incorporate the differences between the 06/20/2011 and 08/16/2011 Realtek releases of the rtl8192de driver. The changes include: 1. Update for new chip versions Signed-off-by: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14rtlwifi: rtl8192se: Updates from latest Realtek driver version - Part IIChaoming Li
This patch incorporate the differences between the 06/20/2011 and 08/16/2011 Realtek releases of the rtl8192se driver. The changes include: 1. Fixing some typos in register usage. 2. A change in the handling of decryption status for 802.11w packets. Signed-off-by: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14rtlwifi: rtl8192ce: Add new chip revisionsChaoming Li
This patch incorporate the differences between the 06/20/2011 and 08/16/2011 Realtek releases of the rtlwifi driver. The changes include: 1. Adding new chip revisions including new firmware. Signed-off-by: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14rtlwifi: Update to new Realtek version - Part IChaoming Li
This patch incorporate the differences between the 06/20/2011 and 08/16/2011 Realtek releases of the rtlwifi driver. The changes include: 1. Handling of IEEE80211_HW_CONNECTION_MONITOR. 2. Fix typo to get proper response to nullfunc frames. Signed-off-by: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14rtlwifi: Change PCI drivers to use the new PM frameworkLarry Finger
2011-10-11rtlwifi: Change debug parameter to apply to individual driversLarry Finger
The current debug parameter is applied to rtlwifi, which means that all loaded drivers have the same level of debugging applied. In addition, the previous method requires a two-step load process to enable debugging. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-03mac80211: pass vif param to conf_tx() callbackEliad Peller
tx params should be configured per interface. add ieee80211_vif param to the conf_tx callback, and change all the drivers that use this callback. The following spatch was used: @rule1@ struct ieee80211_ops ops; identifier conf_tx_op; @@ ops.conf_tx = conf_tx_op; @rule2@ identifier rule1.conf_tx_op; identifier hw, queue, params; @@ conf_tx_op ( - struct ieee80211_hw *hw, + struct ieee80211_hw *hw, struct ieee80211_vif *vif, u16 queue, const struct ieee80211_tx_queue_params *params) {...} Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30rtlwifi: Remove unused _usb_nbytes_read_write and _usb_writeN_syncLarry Finger
2011-09-30rtlwifi: Remove unused routine _usb_readN_syncLarry Finger
2011-09-28Merge branch 'master' of git://git.infradead.org/users/linville/wirelessJohn W. Linville
Conflicts: drivers/net/wireless/iwlwifi/iwl-scan.c net/wireless/nl80211.c
2011-09-27mac80211: add ieee80211_vif param to tsf functionsEliad Peller
TSF can be kept per vif. Add ieee80211_vif param to set/get/reset_tsf, and move the debugfs entries to the per-vif directory. Update all the drivers that implement these callbacks. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-26rtlwifi: rtl8192cu: Fix unitialized structLarry Finger
Driver rtl8192cu assigns a new struct rtl_tcb_desc object, but fails to clear it. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@kernel.org> [2.6.39+] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-20rtlwifi: Combine instances of RTL_HAL_IS_CCK_RATE macros.Larry Finger
Three drivers, rtl8192ce, rtl8192cu and rtl8192de, use the same macro to check if a particular rate is in the CCK set. This common code is relocated to a common header file. A distinct macro used by rtl8192se with the same name is renamed. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
