path: root/drivers/net/wireless/rtlwifi/rtl8192cu/phy.c
2011-12-07rtl8192{ce,cu,de,se}: avoid problems because of possible ERFOFF -> ERFSLEEP ↵Philipp Dreimann
transition In drivers rtl8192ce, rtl8192cu, rtl8192se, and rtl8192de, break statements would allow ppsc->rfpwr_state to be changed to ERFSLEEP even though the device is actually in ERFOFF. Signed-off-by: Philipp Dreimann <philipp@dreimann.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Stable <stable@vger.kernel.org> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-03rtlwifi: Remove set_rfpowerstate_inprogressMike McCormack
set_rfpowerstate_inprogress is only set and never read so remove it. Signed-off-by: Mike McCormack <mikem@ring3k.org> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-26rtlwifi: rtl8192ce: rtl8192cu: Fix most sparse warningsLarry Finger
Fix most sparse warnings in rtlwifi, rtl8192ce and rtl8192cu drivers. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-23rtlwifi: rtl8192ce: rtl8192cu: Fix multiple def errors for allyesconfig buildLarry Finger
As noted by Stephan Rothwell, an allyesconfig build fails since rtl8192cu was merged with failures such as: drivers/net/wireless/rtlwifi/rtl8192cu/built-in.o: In function `rtl92c_phy_sw_chnl': (.opd+0xf30): multiple definition of `rtl92c_phy_sw_chnl' drivers/net/wireless/rtlwifi/rtl8192ce/built-in.o:(.opd+0xb70): first defined here drivers/net/wireless/rtlwifi/rtl8192cu/built-in.o: In function `rtl92c_fill_h2c_cmd': (.opd+0x288): multiple definition of `rtl92c_fill_h2c_cmd' drivers/net/wireless/rtlwifi/rtl8192ce/built-in.o:(.opd+0x288): first defined here These are caused because the code shared between rtl8192ce and rtl8192cu is included in both drivers. This has been fixed by creating a new modue that contains the shared code. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-21rtlwifi: rtl8192cu: Add routine phyGeorge
Add the routine rtlwifi/rtl8192cu/phy.c. Most of the code is included from rtlwifi/rtl8192c/phy_common.c. Signed-off-by: George <george0505@realtek.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
