Now that a new mac80211-based driver for Realtek devices has been submitted,
it is time to reorganize the directories. Rather than having directories
rtlwifi and rtl818x be in drivers/net/wireless/, they will now be in
drivers/net/wireless/realtek/. This change simplifies the directory
structure, but does not result in any configuration changes that are
visable to the user.
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
packet.
rtl8192cu can't connect to AP after physical reconnect.
according to dmesg, that problem's cause was DHCP timeout.
rtl_is_special_data function checks packet type for adjusting rate.
when that function is called from _rtl_rc_get_highest_rix, it can not
calculate offset correctly. so i add argument is_encn in rtl_is_special_data.
is_enc variable mean that iv header is added in skb parameter.
i test only rtl8192cu chipset. because i doesn't have other rtlwifi chipsets.
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
Addition of the new drivers and the update to a new version for the others
lead to changes in all the core routines.
There's not a single rate control algorithm actually in
a separate module where the module refcount would be
required. Similarly, there's no specific rate control
module.
Therefore, all the module handling code in rate control
is really just dead code, so remove it.
Change the code to allow making all the rate control ops
const, nothing ever needs to change them. Also change all
drivers to make use of this and mark the ops const.
5 and 10 MHz support needs to know the current operating channel width,
add the chandef to the rate control API.
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
For VHT, many more bandwidth changes are possible. As a first
step, stop toggling the IEEE80211_HT_CAP_SUP_WIDTH_20_40 flag
in the HT capabilities and instead introduce a bandwidth field
indicating the currently usable bandwidth to transmit to the
station. Of course, make all drivers use it.
To achieve this, make ieee80211_ht_cap_ie_to_sta_ht_cap() get
the station as an argument, rather than the new capabilities,
so it can set up the new bandwidth field.
If the station is a VHT station and VHT bandwidth is in use,
also set the bandwidth accordingly.
Doing this allows us to get rid of the supports_40mhz flag as
the HT capabilities now reflect the true capability instead of
the current setting.
While at it, also fix ieee80211_ht_cap_ie_to_sta_ht_cap() to not
ignore HT cap overrides when MCS TX isn't supported (not that it
really happens...)
This partially reverts commit 44ba973699b831414c3f8eef68ee5a7fe1208a05.
rate_control_rate_init assumes the rate_init member of
struct rate_control_ops is not NULL therefore not initializing it leads to
an oops as soon the driver succesfully associates to an AP.
The removal of rate_update from 44ba973699b831414c3f8eef68ee5a7fe1208a05
is ok because rate_update is checked for NULL before being
called.
Signed-off-by: Catalin Iacob <iacobcatalin@gmail.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
the new driver
This patch completes the addition of the new driver for the Realtek
RTL8723AE devices by adding the make file and by modifying Kconfig
and Makefile of rtlwifi. Some variable names were shortened to ease
the problem of limiting all lines to 80 characters, thus changes were
made to wifi.h and rtl8192{ce,cu,sw}/hw.c.
Cc: <chaoming_li@realsil.com.cn>
The channel type argument to the rate_update()
callback isn't really the correct way to give
the rate control algorithm about the desired
RX bandwidth of the peer.
Remove this argument, and instead update the
STA capabilities with 20/40 appropriately. The
SMPS update done by this callback works in the
same way, so this makes the callback cleaner.
Consolidate printks to avoid possible message interleaving
and reduce the object size.
Remove unnecessary RT_TRACE parentheses.
Miscellaneous typo and grammar fixes.
Add missing newlines to formats.
Remove duplicate KERN_DEBUG prefixes.
Coalesce formats.
Align arguments.
$ size drivers/net/wireless/rtlwifi/built-in.o*
594841 55333 129680 779854 be64e drivers/net/wireless/rtlwifi/built-in.o.new
607022 55333 138720 801075 c3933 drivers/net/wireless/rtlwifi/built-in.o.old
These are a potential source of confusion, as most C code treats all
non-zero values as true.
Signed-off-by: Mike McCormack <mikem@ring3k.org>
Convert rc routines for addition of RTL8192SE and RTL8192DE code
Signed-off-by: Chaoming_Li <chaoming_li@realsil.com.cn>
Allow drivers or rate control algorithms to specify BlockAck session
timeout when initiating an ADDBA transaction. This is useful in cases
where maintaining persistent BA sessions does not incur any overhead.
The current timeout value of 5000 TUs is retained for all non ath9k/ath9k_htc
drivers.
Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
