path: root/drivers/net/wireless/rt2x00/rt2x00leds.c
2013-12-11rt2x00: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: linux-wireless@vger.kernel.org CC: Ivo van Doorn <IvDoorn@gmail.com> CC: Gertjan van Wingerde <gwingerde@gmail.com> CC: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-04-22rt2x00: Use more current logging styles, shrink object sizeJoe Perches
Reduce object space ~2% using more current logging styles. Neaten and simplify logging macros. Use wiphy_<level> where appropriate. Coalesce formats. Convert ERROR/WARNING/INFO macros to rt2x00_<level> Convert EEPROM to rt2x00_eeprom_dbg Convert PROBE_ERROR to rt2x00_probe_err Convert DEBUG to rt2x00_dbg Convert EEPROM to rt2x00_eeprom_dbg $ size drivers/net/wireless/rt2x00/built-in.o* text data bss dec hex filename 245639 71696 69584 386919 5e767 drivers/net/wireless/rt2x00/built-in.o.new 240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.nodyndbg 240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.no_rt2x00_debug 249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old 249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old.nodyndbg 244222 70096 69712 384030 5dc1e drivers/net/wireless/rt2x00/built-in.o.old.no_rt2x00_debug Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-09rt2x00: increase led's name buffer lengthJakub Kicinski
With 9-letter driver names phy's number was truncated to two characters, which caused warnings when creating sysfs entries for leds on systems with multiple devices. Signed-off-by: Jakub Kicinski <kubakici@wp.pl> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-11rt2x00: Update copyright statements.Gertjan van Wingerde
As mentioned on the linux-wireless mailing list, the current copyright statements in the rt2x00 are meaningless, as the rt2x00 project is not even a formal legal entity. Therefore it is better to replace the existing copyright statements with copyright statements for the people that actually wrote the code. Note: Updated to the best of my knowledge with respect to who contributed considerable amounts of code. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> CC: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-09rt2x00: fix led namingDanny Kukawka
Fixed led device naming for the rt2x00 driver. Due to the documentation of the led subsystem/class the naming should be "devicename:colour:function" while not applying sections should be left blank. This should lead to e.g. "%s::radio" instead of "%s:radio". Signed-off-by: Danny Kukawka <dkukawka@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29rt2x00: Update copyright year to 2009Ivo van Doorn
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-12rt2x00: Fix radio LED type checkAndrew Price
Since "rt2x00: Fix LED state handling", rt2x00leds_led_radio wrongly checks that the LED type is LED_TYPE_ASSOC. This patch makes it check for LED_TYPE_RADIO once again. Signed-off-by: Andrew Price <andy@andrewprice.me.uk> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-26rt2x00: Don't switch off LED on initializationIvo van Doorn
When we switch off the LEDS during initialization we kill rt73usb from proper functioning. The immediate result after the first LED command are MCU failures and a complete breakdown of TX/RX. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-21rt2x00: Fix LED state handlingIvo van Doorn
For every global LED state change (register/unregister, suspend/resume) we should force the LEDS to turn off. This makes sure that the LEDS will always be in a sane state after the state switch. Note that when unregister is called but the LED class wasn't resumed yet, we shouldn't change the LED state since we might not have access to the device (device was unplugged while suspended). Also remove the checks in the activity, assoc and radio LEDS which blocked calls to brightness_set() when the state hasn't changed. Some of those LEDS could be enabled by themselves when something happens in the hardware (e.g. firmware is loaded). We already did called rt2x00leds to switch the LED off, but those calls were blocked. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-01rt2x00: Fix quality/activity led handlingIvo van Doorn
There was an obvious typo in LED structure initialization which caused the radio and quality/activity leds to be incorrectly initialized which resulted in the leds not being enabled. Additionally add the rt2x00led_led_activity() handler that will enable TX/RX activity leds when the radio is being enabled. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-01rt2x00: Remove MAC80211_LEDS dependencyIvo van Doorn
Implement triggers inside rt2x00 itself based on input from mac80211. This replaces the method of using the mac80211 trigger events which do not work for USB drivers due to the scheduling requirement. After this patch RT2500USB_LEDS and RT73USB_LEDS no longer need to be tagged as broken since they now support LED handling again without having to check for in_atomic(). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13rt2x00: Make rt2x00leds_register return voidIvo van Doorn
rt2x00dev isn't interested in the rt2x00leds_register() value anyway. So lets make it return void to even prevent people from assuming there is anybody interested in the returnvalue. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Enable LED class support for rt2500usb/rt73usbIvo van Doorn
Add kerneldoc for vendor request functions in rt2x00usb. Add asynchroneous vendor request function in rt2x00usb. With the availability of the asynchroneuous vendor request we can now enable LED class support for rt2500usb and rt73usb. Since LED handling is not important, it doesn't really matter if a register call fails (This solution is better then no LED class support at all). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
