We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: linux-wireless@vger.kernel.org
CC: Ivo van Doorn <IvDoorn@gmail.com>
CC: Gertjan van Wingerde <gwingerde@gmail.com>
CC: Helmut Schaa <helmut.schaa@googlemail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Use the module_pci_driver() macro to make the code simpler
by eliminating module_init and module_exit calls.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
The PCI and SoC specific drivers are using separate
code now so it is not reasonable to use the same
module for both drivers anymore.
The 'rt2800pci_hwcrypt_disabled' function is the
only PCI specific callback which is used by the
SoC driver. Create a clone of that to get rid of
the dependency.
Even though the two functions are using the same
variable, but the SoC specific code will be moved
into a separate module which will have its own
'modparam_nohwcrypt' variable.
Move the function into the rt2800mmio module, in order
to make it usable from other modules.
The function is called for PCI and SoC devices
however the MCU related part of the function
has no effect on SoC devices. Move the common
part of the function into a separate helper and
use that for the SoC devices.
The function contain code for SoC devices only.
Rename the function to 'rt2800soc_disable_radio'
and move it to the SoC specific section. Use
the renamed function in the SoC specific code
only and remove the 'if rt2x00_is_soc(rt2x00dev)'
condition from the function body.
The 'rt2800pci_set_state' function uses MCU commands
to set the device state, however these have no effect
on SoC devices. Use a different set_state callback
which does not use the MCU fcuntions.
Use empty firmware callbacks for SoC devices because those
don't require firmware.
Rename the 'rt2800pci_read_eeprom_soc function' to
'rt2800soc_read_eeprom' and use that directly in the
SoC specific 'rt2800_ops' structure. Also move the
'rt2800pci_eeprom_read' function into an 'ifdef PCI'
section and remove the 'rt2800pci_read_eeprom_soc'
call from that.
Additionally, remove the dummy inline eeprom functions.
Those are not used anymore.
This makes it possible to use different callback
functions for PCI and SoC devices which will allow
to move the SoC driver into a separate module.
Move the functions into a separate module, in order
to make those usable from other modules.
The functions are used for devices with memory
mapped I/O and contain no PCI specific code at
all. Use rt2800mmio prefix instead of rt2800pci
in the function names to reflect that.
The patch contains no functional changes.
to make those usable from other modules. Also move
the queue register offset macros from rt2800pci.h
into rt2800mmio.h.
the RX descriptor related defines from rt2800pci.h
into rt2800mmio.h
the TX descriptor related defines from rt2800pci.h
into rt2800mmio.h.
The 2011_1007_RT5390_RT5392_Linux_STA_V2.5.0.3_DPO
driver enables PCIe wakeup for these chips as well.
Do the same in rt2x00.
References:
rt28xx_init in common/rtmp_init_intf.c
RTMPInitPCIeLinkCtrlValue in os/linux/rt_rbus_pci_drv.c
The rt2800pci driver uses the same [RT]XWI size
for all chipsets, however some chips requires
different values.
The size of the [RT]XWI structures is a constant
value for a given chipset and it does not depend
on the underlying interface. Add a helper function
which returns the correct values for the actual
chipset and use the new helper both in the rt2800usb
and in the rt2800pci drivers. This ensures that both
drivers are using the correct values.
Use common names instead of chip specific ones.
The patch contains no functional changes, but
it makes it easier to add support for further
descriptor sizes.
Acked-by: Stanislaw Gruszka <stf_xl@wp.pl>
Different chipsets may use different TXWI descriptor
size. Instead of using a hardcoded value, use the
'queue->winfo_size' which holds the correct value for
a given device.
The extra_tx_headroom field of struct rt2x00_ops
indicates the extra TX headroom size required for
a given device. This data is redundant, the value
can be computed from the desc_size and winfo_size
fields of the TX queues.
Move the extra_tx_headroom field to struct rt2x00_dev,
compute its value in the probe routine and use the
cached value in the rest of the code.
Acked-by: Stanislaw Gruszka <sgruszka@redhat.com>
The generic rt2x00 code has been changed to allow the
drivers toimplement dynamic data_queue initialization.
Remove the static data queue descriptor structures
and implement the queue_init callback instead.
The TX data queue is initialized already when
the rt2800pci_txstatus_interrupt() function is
called.
Fetch the number of the queue entries from that
instead of using the entry_num field of the data
queue descriptor.
The two values are the same, and the use of the
rt2x00dev->tx->limit value allows us to get rid
of a superfluous pointer dereference.
Reduce object space ~2% using more current logging styles.
Neaten and simplify logging macros.
Use wiphy_<level> where appropriate.
Coalesce formats.
Convert ERROR/WARNING/INFO macros to rt2x00_<level>
Convert EEPROM to rt2x00_eeprom_dbg
Convert PROBE_ERROR to rt2x00_probe_err
Convert DEBUG to rt2x00_dbg
$ size drivers/net/wireless/rt2x00/built-in.o*
245639 71696 69584 386919 5e767 drivers/net/wireless/rt2x00/built-in.o.new
240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.nodyndbg
240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.no_rt2x00_debug
249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old
249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old.nodyndbg
244222 70096 69712 384030 5dc1e drivers/net/wireless/rt2x00/built-in.o.old.no_rt2x00_debug
On new 2800 hardware sizes of TXWI & RXIW can be different than TXD
& RXD sizes, so we need to difference between them. Let's define
winfo_size as size of in buffer descriptor (TXWI & RXWI), and desc_size
of as size of additional descriptor - in separate DMA coherent buffer
for PCI hardware (TXD & RXD) and yet another in buffer descriptor for
USB hardware (TXINFO & RXINFO).
Change is rt2x00 wild, but should affect only 2800 driver.
Patch also fix beaconing for 5592usb AP mode.
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
Use the recently introduced rt2x00mmio_* routines
instead of the rt2x00pci_* variants.
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
drivers/net/wireless/rt2x00/rt2x00pci.c
The rt2800pci driver supports the built-in wireless
MAC of the Ralink RT3x5x SoCs. However building the
driver for these SoCs leads to the following error:
LD init/built-in.o
drivers/built-in.o: In function `rt2800pci_rxdone_tasklet':
<...>/drivers/net/wireless/rt2x00/rt2800pci.c:1012: undefined reference to `rt2x00pci_rxdone'
drivers/built-in.o:(.rodata+0x4780): undefined reference to `rt2x00pci_initialize'
drivers/built-in.o:(.rodata+0x4784): undefined reference to `rt2x00pci_uninitialize'
drivers/built-in.o:(.rodata+0x47bc): undefined reference to `rt2x00pci_flush_queue'
drivers/built-in.o:(.rodata+0x4818): undefined reference to `rt2x00pci_regbusy_read'
make[5]: *** [vmlinux] Error 1
The missing functions are provided by the rt2x00pci
module. This module is only selected by the rt2800pci
driver if PCI support is enabled in the kernel, because
some parts of the rt2x00pci code depends on PCI support.
PCI support is not available on the RT3x5x SoCs because
those have no PCI host controller at all.
Move the non PCI specific code from rt2x00pci into a
separate module. This makes it possible to use that
code even if PCI support is disabled. The affected
functions are used by all of the rt2x00 PCI drivers
so select the new module for those drivers.
Based on:
TXWI_STRUC
RXWI_STRUC
DPO_RT5572_LinuxSTA_2.6.1.3_20121022/include/chip/rtmp_mac.h
Tested-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
rt2800 hardware sometimes reorders tx frames when transmitting to
multiple BA enabled STAs concurrently.
For example a tx queue
[ STA1 | STA2 | STA1 | STA2 ]
can result in the tx status reports
[ STA1 | STA1 | STA2 | STA2 ]
when the hw decides to put the frames for STA1 in one AMPDU.
To mitigate this effect associate the currently processed tx status
to the first frame in the tx queue with a matching wcid.
This patch fixes several problems related to incorrect tx status
reporting. Furthermore the tx rate selection is much more stable when
communicating with multiple STAs.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Since v3.9-rc1 the kernel has basic support for Ralink WiSoC. The config symbols
are named slightly different than before. Fix the rt2x00 to match the new
symbols.
The commit causing this breakage is:
commit ae2b5bb6570481b50a7175c64176b82da0a81836
Author: John Crispin <blogic@openwrt.org>
Date: Sun Jan 20 22:05:30 2013 +0100
MIPS: ralink: adds Kbuild files
Signed-off-by: John Crispin <blogic@openwrt.org>
0x1814,0x359f is a RT3592 802.11a/b/g/n 2x2 WiFi Adapter
support added by 872834dfb38edc6f72cfc783a5ce78f2a9f36ec5
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: users@rt2x00.serialmonkey.com
Cc: linux-wireless@vger.kernel.org
Signed-off-by: Xose Vazquez Perez <xose.vazquez@gmail.com>
Both the rtt2x00usb_eeprom_read and the ioremap
functions are allowed to fail, however their
return values are not checked in the read_eeprom
functions in the rt2800{pci,usb} drivers.
The patch adds the missing checks, and converts
all read_eeprom functions to return an int value,
so the error values can be propagated up to the
'rt2800_validate_eeprom' function.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: users@rt2x00.serialmonkey.com (moderated for non-subscribers)
All drivers set this value to 1, so there is no need (currently) to let
drivers set this.
Therefor, remove the field; we can always add it back when it is needed.
Inspired by an earlier patch from Paul Fertser.
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Paul Fertser <fercerpav@gmail.com>
Refactor the probe_hw code so that more code can be shared between
rt2800pci and rt2800usb.
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
The various rt2x00 drivers use different methods to name the different
GPIO register fields indicating the GPIO pin value and the fields
indicating the direction.
Start using a unified naming scheme for the GPIO register fields:
- <csr>_VAL<x> for fields indicating the GPIO pin value.
- <csr>_DIR<x> for fields indicating the GPIO pin direction.
Acked-by: Ivo Van Doorn <ivdoorn@gmail.com>
We need to program the rfkill switch GPIO pin direction to input at
device initialization time, not only when the interface is brought up.
Doing this only when the interface is brought up could lead to rfkill
detecting the switch is turned on erroneously and inability to create
the interface and bringing it up.
Reported-and-tested-by: Andreas Messer <andi@bastelmap.de>
Cc: <stable@vger.kernel.org>
This patch is going to fix the resuming failed from S3/S4
for rt3290 chip.
Signed-off-by: Woody Hung <Woody.Hung@mediatek.com>
Cc: Kevin Chou <kevin.chou@mediatek.com>
Signed-off-by: Chen, Chien-Chia <machen@suse.com>
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
Fix indention and remove unnecessary brackets and compares.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
This patch support the new chipset rt3290 wifi implementation in rt2x00.
It initailize the related mac, bbp and rf register in startup phase.
And this patch modify the efuse read/write method for the different efuse data offset of rt3290.
This chip is used at least by the D-Link DWA-525 adapter.
Signed-off-by: Alex Villac<ED>s Lasso <a_villacis@palosanto.com>
Signed-off-by: Zero.Lin <Zero.Lin@mediatek.com>
RT539x devices:
(0x1814, 0x5362)
(0x1814, 0x5392)
Taken from ralink driver 2011_0406_RT5390_RT5392_Linux_STA_V2.5.0.3_DPO
