we do min() on u8 and small integer constant; cast the latter to u8.
ESSIDs can technically include NULL characters. Drivers should not be
adjusting the length of the ESSID before reporting it in their
SIOCGIWESSID handlers. Breaks stuff like wpa_supplicant. Note that ipw
drivers, which seem to currently be the "most correct", don't have this
problem.
Signed-off-by: Dan Williams <dcbw@redhat.com>
This patch removes almost all inclusions of linux/version.h. The 3
#defines are unused in most of the touched files.
A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is
unfortunatly in linux/version.h.
There are also lots of #ifdef for long obsolete kernels, this was not
touched. In a few places, the linux/version.h include was move to where
the LINUX_VERSION_CODE was used.
quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'`
search pattern:
/UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h
Signed-off-by: Olaf Hering <olh@suse.de>
My patch that adds WE-17 support to the Prism54 driver went
already in the kernel, except for a tiny bit that was dropped on the
way. This is the missing bit....
Tested with 2.6.13 (with real HW).
Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
infrastructure for it.
Let it rip!
