path: root/drivers/net/wireless/p54
2011-04-11Merge branch 'master' of ↵David S. Miller
2011-04-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) net: Add support for SMSC LAN9530, LAN9730 and LAN89530 mlx4_en: Restoring RX buffer pointer in case of failure mlx4: Sensing link type at device initialization ipv4: Fix "Set rt->rt_iif more sanely on output routes." MAINTAINERS: add entry for Xen network backend be2net: Fix suspend/resume operation be2net: Rename some struct members for clarity pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev dsa/mv88e6131: add support for mv88e6085 switch ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2) be2net: Fix a potential crash during shutdown. bna: Fix for handling firmware heartbeat failure can: mcp251x: Allow pass IRQ flags through platform data. smsc911x: fix mac_lock acquision before calling smsc911x_mac_read iwlwifi: accept EEPROM version 0x423 for iwl6000 rt2x00: fix cancelling uninitialized work rtlwifi: Fix some warnings/bugs p54usb: IDs for two new devices wl12xx: fix potential buffer overflow in testmode nvs push zd1211rw: reset rx idle timer from tasklet ...
2011-04-08p54: Initialize extra_len in p54_tx_80211Jason Conti
This patch fixes a very serious off-by-one bug in the driver, which could leave the device in an unresponsive state. The problem was that the extra_len variable [used to reserve extra scratch buffer space for the firmware] was left uninitialized. Because p54_assign_address later needs the value to reserve additional space, the resulting frame could be to big for the small device's memory window and everything would immediately come to a grinding halt. Reference: https://bugs.launchpad.net/bugs/722185 Cc: <stable@kernel.org> Acked-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Jason Conti <jason.conti@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-04p54usb: IDs for two new devicesChristian Lamparter
Cc: <stable@kernel.org> Reported-by: Mark Davis [via p54/devices wiki] Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-11Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-03-07p54spi: Update kconfig help textMichael Buesch
This updates the p54spi Kconfig help text. The driver works well on n8x0, so remove the words "experimental" and "untested". Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-04Merge branch 'for-davem' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-02-28p54: fix a NULL pointer dereference bugFelix Fietkau
If the RSSI calibration table was not found or not parsed properly, priv->rssi_db will be NULL, p54_rssi_find needs to be able to deal with that. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Acked-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-28p54usb: add Senao NUB-350 usbidChristian Lamparter
Reported-by: Mark Davis Cc: <stable@kernel.org> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-25mac80211: make tx() operation return voidJohannes Berg
The return value of the tx operation is commonly misused by drivers, leading to errors. All drivers will drop frames if they fail to TX the frame, and they must also properly manage the queues (if they didn't, mac80211 would already warn). Removing the ability for drivers to return a BUSY value also allows significant cleanups of the TX TX handling code in mac80211. Note that this also fixes a bug in ath9k_htc, the old "return -1" there was wrong. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> [ath5k] Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> [rt2x00] Acked-by: Larry Finger <Larry.Finger@lwfinger.net> [b43, rtl8187, rtlwifi] Acked-by: Luciano Coelho <coelho@ti.com> [wl12xx] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-25p54: implement set_coverage_classChristian Lamparter
The callback sets slot time as specified in IEEE 802.11-2007 section 17.3.8.6 and raises round trip delay accordingly. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-23mac80211: rename RX_FLAG_TSFTJohannes Berg
The flag isn't very descriptive -- the intention is that the driver provides a TSF timestamp at the beginning of the MPDU -- make that clearer by renaming the flag to RX_FLAG_MACTIME_MPDU. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-21p54pci: update receive dma buffers before and after processingChristian Lamparter
Documentation/DMA-API-HOWTO.txt states: "DMA transfers need to be synced properly in order for the cpu and device to see the most uptodate and correct copy of the DMA buffer." Cc: <stable@kernel.org> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-18p54: implement flush callbackChristian Lamparter
2011-02-18p54: Fix compile warningLarry Finger
If any of the p54-based drivers are built with CONFIG_P54_LEDS not defined, the following warning is generated: CC [M] drivers/net/wireless/p54/main.o drivers/net/wireless/p54/main.c: In function ‘p54_register_common’: drivers/net/wireless/p54/main.c:614:21: warning: unused variable ‘priv’ Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-14p54spi: update sample eepromChristian Lamparter
Commit: "p54: enhance rssi->dBm database import" changed the way how the driver deals with the rssical data. A new data format was necessary and hence this patch. NOTE: (for users with a custom eeprom binary) I spent some time updating p54tools to support the new format too: => (git available from) http://git.kernel.org/?p=linux/kernel/git/chr/p54tools.git It now comes with a simplistic script "n800_rssi2v2.sh" which can be used to automate the conversion. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-14p54: enhance rssi->dBm database importChristian Lamparter
This patch fixes several shortcomings of the previous implementation. Features of the rewrite include: * handles undocumented "0x0000" word at the start of the frequency table. (Affected some early? DELL 1450 USB devices and my Symbol 5GHz miniPCI card.) * supports more than just one reference point per band. (Also needed for the Symbol card.) * ships with default values in case the eeprom data is damaged, absent or unsupported. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-14p54: p54_generate_band cleanupChristian Lamparter
2011-02-14p54: sort channel list by frequency instead of channel indexChristian Lamparter
Some channel indices of the low 5GHz band clash with those of the 2.4GHz band. Therefore we should go with the channel's center frequency. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-10p54: fix sequence no. accounting off-by-one errorChristian Lamparter
P54_HDR_FLAG_DATA_OUT_SEQNR is meant to tell the firmware that "the frame's sequence number has already been set by the application." Whereas IEEE80211_TX_CTL_ASSIGN_SEQ is set for frames which lack a valid sequence number and either the driver or firmware has to assign one. Yup, it's the exact opposite! Cc: <stable@kernel.org> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h drivers/net/wireless/iwlwifi/iwl-1000.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-core.h drivers/vhost/vhost.c
2010-12-14p54usb: New USB ID for Gemtek WUBI-100GWEduardo Costa
This USB ID is for the WUBI-100GW 802.11g Wireless LAN USB Device that uses p54usb. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Eduardo Costa <ecosta.tmp@gmail.com> Cc: Stable <stable@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-13p54usb: add 5 more USBIDsChristian Lamparter
This patch adds five more USBIDs to the table. Source: http://www.linuxant.com/pipermail/driverloader/2005q3/002307.html http://wireless.kernel.org/en/users/Drivers/p54/devices (by M. Davis) Cc: <stable@kernel.org> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-02wireless: Remove unnecessary casts of usb_get_intfdataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-15drivers/net/wireless/p54/eeprom.c: Return -ENOMEM on memory allocation failureJulia Lawall
In this code, 0 is returned on memory allocation failure, even though other failures return -ENOMEM or other similar values. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression ret; expression x,e1,e2,e3; @@ ret = 0 ... when != ret = e1 *x = \(kmalloc\|kcalloc\|kzalloc\)(...) ... when != ret = e2 if (x == NULL) { ... when != ret = e3 return ret; } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: <stable@kernel.org> Acked-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-05p54usb: add five more USBIDsChristian Lamparter
Source: http://www.wikidevi.com/wiki/Intersil/p54/usb/windows Cc: <stable@kernel.org> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-24Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/ath/ath5k/base.c net/mac80211/main.c
2010-09-07p54spi: Add error message for eeprom failureMichael Büsch
This adds an error message for the eeprom request failure case. This way it's easier for the user to figure out what went wrong. Signed-off-by: Michael Büsch <mb@bu3sch.de> Acked-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-30p54: fix tx feedback status flag checkChristian Lamparter
Michael reported that p54* never really entered power save mode, even tough it was enabled. It turned out that upon a power save mode change the firmware will set a special flag onto the last outgoing frame tx status (which in this case is almost always the designated PSM nullfunc frame). This flag confused the driver; It erroneously reported transmission failures to the stack, which then generated the next nullfunc. and so on... Cc: <stable@kernel.org> Reported-by: Michael Buesch <mb@bu3sch.de> Tested-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-25p54: better rssi->dbm conversion for longbow physChristian Lamparter
This patch should fix the dodgy signal and noise value reports for most longbow (p54spi) users: e.g.: (an older tcpdump extract) > 2.0 Mb/s 2437 MHz (0x00a0) -49dB signal -41dB noise > 1.0 Mb/s 2437 MHz (0x00a0) 4dB signal -41dB noise The formula is taken from stlc45xx: http://gitorious.org/stlc45xx/mainline/blobs/master/stlc45xx.c#line1199 Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-25p54usb: fix off-by-one on !CONFIG_PMChristian Lamparter
The ISL3887 chip needs a USB reset, whenever the usb-frontend module "p54usb" is reloaded. This patch fixes an off-by-one bug, if the user is running a kernel without the CONFIG_PM option set and for some reason (e.g.: compat-wireless) wants to switch between different p54usb modules. Cc: <stable@kernel.org> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-25p54spi: Kconfig option for config blobChristian Lamparter
This patch adds an Kconfig option, which allows the user to select, whenever he/she wants to include a 4k blob for generic calibration and interface values into the driver, or cut the module size by about 15 to 20%. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-24Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/iwlwifi/iwl-core.h
2010-08-24p54: improve eeprom parserChristian Lamparter
Like other vendors, p54* devices have a checksum for the EEPROM descriptor data. This patch enhances the parser code to generate and verify the data fields, before initializing the radio-chip on the card. Note: If you have to bootstrap an alternative EEPROM image for your device and you don't know how to generate a valid crc ccitt checksum, you should take a look at: http://git.kernel.org/?p=linux/kernel/git/chr/p54tools.git The "checksum" utility loads a binary p54 EEPROM blob (use the -f switch, to skip the check) and applies the correct crc automatically. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-24p54spi: fix eeprom checksumChristian Lamparter
This patch corrects the bogus descriptor checksum of our Nokia N8XX EEPROM blob. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-18drivers/net/wireless: Restore upper case words in wiphy_<level> messagesJoe Perches
Commit c96c31e499b70964cfc88744046c998bb710e4b8 "(drivers/net/wireless: Use wiphy_<level>)" inadvertently changed some upper case words to lower case. Restore the original case. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-16mac80211: use cipher suite selectorsJohannes Berg
Currently, mac80211 translates the cfg80211 cipher suite selectors into ALG_* values. That isn't all too useful, and some drivers benefit from the distinction between WEP40 and WEP104 as well. Therefore, convert it all to use the cipher suite selectors. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-16Merge branch 'master' of ↵John W. Linville
2010-08-16p54: update fw version info in wiphy structJohn W. Linville
This makes the information available through ethtool... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-09Revert "p54pci: Add PCI ID for SMC2802W"John W. Linville
This reverts commit 5f7aebd845a9d2ed42f36b7333579ec3534b4713. Apparently, that PCI ID data was incorrectly taken from the subsystem information. The actual ID matches another already known ID. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-04p54pci: Add PCI ID for SMC2802WLarry Finger
The SMC2802W appears to work with p54pci. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Tested-by: David Cozatt <olbrannon@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-27drivers/net/wireless: Use wiphy_<level>Joe Perches
Standardize the logging macros used. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-27p54: Added get_survey callback in order to get channel noiseJohn W. Linville
2010-06-17Merge branch 'master' of ↵David S. Miller
2010-06-17Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: net/mac80211/mlme.c
