path: root/drivers/net/wireless/mwl8k.c
2011-10-03mac80211: pass vif param to conf_tx() callbackEliad Peller
tx params should be configured per interface. add ieee80211_vif param to the conf_tx callback, and change all the drivers that use this callback. The following spatch was used: @rule1@ struct ieee80211_ops ops; identifier conf_tx_op; @@ ops.conf_tx = conf_tx_op; @rule2@ identifier rule1.conf_tx_op; identifier hw, queue, params; @@ conf_tx_op ( - struct ieee80211_hw *hw, + struct ieee80211_hw *hw, struct ieee80211_vif *vif, u16 queue, const struct ieee80211_tx_queue_params *params) {...} Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13mwl8k: Set hardware flag IEEE80211_HW_AP_LINK_PSYogesh Ashok Powar
This will avoid mac80211 to trigger PS mode for connected station based on the PM bit of incoming frames. AP firmware is capable of handling such frames and buffering TX frames destined to the stations that are in PS mode. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-22mwl8k: Traffic to clients gets affected when one client leaves a cyrpto bssNishant Sarmukadam
When a client disassociates from a crypto enabled bss, data traffic to other clients connected to the bss is stalled. This was due to a boolean variable used to keep track if HW crypto is enabled i.e. if set key has been called to add a key. This flag was being reset every time delete key was called e.g when a station leaves the bss. Once the flag is reset, rx status flags were not being set for connected clients which disrupts traffic to these clients. Fix this issue by not resetting the flag since we do not need to reset this flag during the life time of the bss. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-07-15mwl8k: Fixing sta dereference when ieee80211_tx_info->control.sta is NULLYogesh Ashok Powar
Following oops was seen on SMP machine >BUG: unable to handle kernel NULL pointer dereference at 00000012 >IP: [<f8c56691>] mwl8k_tx+0x20e/0x561 [mwl8k] >*pde = 00000000 >Oops: 0000 [#1] SMP >Modules linked in: mwl8k mac80211 cfg80211 [last unloaded: cfg80211] As ieee80211_tx_info->control.sta may be NULL during ->tx call, avoiding sta dereference in such scenario with the following patch. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-rxon.c drivers/net/wireless/rtlwifi/pci.c net/netfilter/ipvs/ip_vs_core.c
2011-06-15mwl8k: Tell firmware to generate CCMP headerNishant Sarmukadam
Post commit e4eefec73ea0a740bfe8736e3ac30dfe92fe392b, the stack is not generating the CCMP header for us anymore. This broke the CCMP functionality since firmware was not doing this either. Set a flag to tell the firmware to generate the CCMP header Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-05mwl8k: Do not ask mac80211 to generate IV for crypto keysYogesh Ashok Powar
Since firmware is capable of generating IV's for all crypto suits (TKIP, CCMP and WEP), do not ask mac80211 to generate IV when HW crypto is being used. Instead only reserve appropriate space in tx skb's in the driver, so that the firmware can write IV's values. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-05mwl8k: Fix broken WEPYogesh Ashok Powar
The WEP key length was being set to 0 erroneously which broke WEP support. Fix the same by setting the key length appropriately. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-29mwl8k: Reducing extra_tx_headroom for tx optimization in AP modeYogesh Ashok Powar
The tx_headroom required for mwl8k driver is 32 bytes and it can use the space for 802.11 header received from mac80211. mwl8k considers the smallest 802.11 frame (CTS2self of 10 bytes) that can be received from mac80211 to compute the extra_tx_headroom as 22 (32 - 10) bytes. When the wireless interface is part of bridge, this extra_tx_headroom requirement results in a memcpy in mac80211 (in function pskb_expand_head) for all the data frames needing L2 forwarding/bridging, when NET_SKB_PAD is defined as 32. This patch reduces the extra_tx_headroom by 8 bytes so that memcpy of data frames in mac80211 is avoided in this case. The resize will be required in driver for frames with 802.11 header size of less than 18 bytes. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-28mwl8k: replace rateinfo bitfields with mask and shift macrosJohn W. Linville
AFAICT, this driver is claiming that 24 bits of rate info fit into a 16-bit field in the Tx descriptor. Anyway, the use of bitfields is frowned-upon for a variety of well-documented reasons... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-25mwl8k: Enable life time expiry for tx packets in the hardwareNishant Sarmukadam
Tell the firmware to enable the life time expiry of tx packets in the hardware. The hardware will now refer to the timestamp in every tx packet and decide whether the packet needs to be dropped or transmitted. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-25mwl8k: Reserve buffers for tx management framesNishant Sarmukadam
Since queues are not stopped anymore, management frames would be dropped if the corresponding tx queue is full. This can cause issues say when we want to setup an ampdu stream and action frames i.e addba requests keep getting dropped frequently. Fix this by reserving some buffers to allow management frames to go through in queue full conditions. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-25mwl8k: Add timestamp information for tx packetsPradeep Nemavat
Timestamp tx packets using a HW micro-second timer. This timestamp will be compared to the current timestamp in the hardware and if the difference is greater than 500ms, the packet will be dropped. Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-25mwl8k: Do not stop tx queuesPradeep Nemavat
This is in preparation to support life time expiry of packets in the hardware to avoid head-of-line blocking where a slow client can hog a tx queue and affect the traffic to a faster client from the same queue. Time stamp the packets in driver to allow dropping them in the hardware if they are queued for more than 500ms. If queues are stopped, packets will be queued up outside the driver. Since we will be able to timestamp the packets only after they hit the driver, the timestamp will be less accurate since we cannot consider the time the packets spent in queues outside the driver. With this commit, to achieve accurate timestamping, the tx queues will not be stopped in normal conditions. The only scenarios where the queues will be stopped are when firmware commands are executing or if the interface is brought down. Now, we need to be prepared for a situation where packets hit the driver even after the tx queues are full. Drop all such packets in the driver itself. Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-13mwl8k: use traffic threshold to decide when to start ampduBrian Cavagnolo
Currently, ampdu stream is created on the first qos packet to an HT sta. The overhead of setting up the BA session may not be justified if the outgoing packet rate is minimal (e.g., ping). So we only allow ampdu streams after seeing a critical number of packets in an arbitrary one-second interval. Based on work by Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-13mwl8k: interrupt handling changesNishant Sarmukadam
We do not need to enable all the interrupts in mwl8k_probe_hw. We need to enable only MWL8K_A2H_INT_OPC_DONE interrupt for sending commands to the firmware. Keep the other interrupts masked in mwl8k_probe_hw. Also, in mwl8k_start, where we expect other interrupts, enable only those interrupts we are interested in. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-12mwl8k: Fix checkpatch.pl and sparse warnings and errorsYogesh Ashok Powar
Fix checkpatch errors and warnings comprising of indent errors, spaces and __packed warnings. Also fix 'make C = 2' warnings. Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-07Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/rtlwifi/efuse.c drivers/net/wireless/rtlwifi/rtl8192c/fw_common.c net/bluetooth/mgmt.c
2011-04-07mwl8k: Do not configure tx power unconditionallyNishant Sarmukadam
Instead of configuring tx power unconditionally, check for IEEE80211_CONF_CHANGE_POWER and configure it only when stack sets this flag Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-07mwl8k: do not free unrequested irqBrian Cavagnolo
When the mwl8k driver attempts and fails to switch from sta to ap firmware (or vice-versa) in the mwl8k_add_interface routine, the mwl8k_stop routine will be called. This routine must not attempt to free the irq if it was not requested. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: Queue ADDBA requests in respective data queuesNishant Sarmukadam
Queue ADDBA requests in respective data queues to avoid ADDBA requests and the the related data packets (to the same ra/tid) queued in the hardware to be sent out asynchronously. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: Check outgoing rate for a station to decide if ampdu can be createdNishant Sarmukadam
If the outgoing packet rate to a particular HT station is <=6.5 Mbps, do not attempt to create an ampdu. Also, if the outgoing rate is legacy rate, do not create an ampdu. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: Handle the watchdog event from the firmwareNishant Sarmukadam
When an ampdu stream is on, if the firmware rate adaptation logic decides that the outgoing packet rate to the station needs to go below 6.5Mbps (non HT rate), it sends an event indicating that the ampdu stream needs to be destroyed. Handle this event in the driver and destroy the ampdu stream so that the rate can go below 6.5Mbps Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: Initiate BA sessionsNishant Sarmukadam
Specifically, handle ampdu_action and attempt to start a BA session on receiving the first qos packet from mac80211 for transmission to a HT sta. While the BA session is being created, all the packets belonging to that stream will be dropped to prevent sequence number mismatch at the recipient. Contains contributions from: Yogesh Powar <yogeshp@marvell.com> Pradeep Nemavat <pnemavat@marvell.com> Brian Cavagnolo <brian@cozybit.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: add internal API for managing AMPDU streamsBrian Cavagnolo
In particular, we can now add, start, lookup, and remove streams. Based on work by Nishant Sarmukadam <nishants@marvell.com> and Pradeep Nemavat <pnemavat@marvell.com>. Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: differentiate between WMM queues and AMPDU queuesBrian Cavagnolo
We now have two different kinds of queues. And the number of AMPDU queues may vary. So we must be clear about which queues we are dealing with. Note that when we report the number of queues to mac80211, we only report the WMM queues. Based on work by Yogesh Powar <yogeshp@marvell.com>. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: add support for block ack commandsNishant Sarmukadam
Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: update to ap firmware API version 2Brian Cavagnolo
Firmware APIv2 adds the following enhancements: -- capabilities are reported by the firmware -- API supports up to 8 dedicated AMPDU streams -- optional packet timestamping and expiration can be enabled. Specifically, packets that are queued in firmware for longer than 500ms will be dropped if this option is used. Based on work by "Nishant Sarmukadam" <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: refactor in preparation for APIv2 updateBrian Cavagnolo
Specifically, APIv2 will specify a variable number of AMPDU queues in the MWL8K_CMD_GET_HW_SPEC. So init the tx queues after MWL8K_CMD_GET_HW_SPEC for ap fw. Also, we make it safe to deinit queues that have not been init'd. This happens if the mwl8k_get_hw_spec_ap routine fails, for example. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-09mwl8k: use kcalloc instead of kmalloc & memsetShan Wei
Use kcalloc or kzalloc rather than the combination of kmalloc and memset. Thanks coccicheck for detecting this. (http://coccinelle.lip6.fr/) Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-25mac80211: make tx() operation return voidJohannes Berg
The return value of the tx operation is commonly misused by drivers, leading to errors. All drivers will drop frames if they fail to TX the frame, and they must also properly manage the queues (if they didn't, mac80211 would already warn). Removing the ability for drivers to return a BUSY value also allows significant cleanups of the TX TX handling code in mac80211. Note that this also fixes a bug in ath9k_htc, the old "return -1" there was wrong. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> [ath5k] Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> [rt2x00] Acked-by: Larry Finger <Larry.Finger@lwfinger.net> [b43, rtl8187, rtlwifi] Acked-by: Luciano Coelho <coelho@ti.com> [wl12xx] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-23mwl8k: Invert tx queues for set_hw_spec and set_edca_paramsNishant Sarmukadam
mac80211 and mwl8k FW tx queue priorities map inversely to each other. Fix this. Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Tested-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-23mwl8k: Tell mac80211 we have rate adaptation in FWNishant Sarmukadam
All mwl8k parts perform rate control in firmware. Make this known to mac80211 so that it does not launch minstrel. Also, because actual tx rate information is not available from the firmware, invalidate the rate status before returning the skb to mac80211. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-23mwl8k: fix rf_antenna rx argument for APNishant Sarmukadam
When configuring rx antennas using CMD_RF_ANTENNA, the argument input is the number of antennas to be enabled. For AP, we support 3 rx antennas and hence set the field to 3. For tx antennas, value is a bitmap, so 0x7 enables all three. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-21cfg80211: Extend channel to frequency mapping for 802.11jBruno Randolf
Extend channel to frequency mapping for 802.11j Japan 4.9GHz band, according to IEEE802.11 section 17.3.8.3.2 and Annex J. Because there are now overlapping channel numbers in the 2GHz and 5GHz band we can't map from channel to frequency without knowing the band. This is no problem as in most contexts we know the band. In places where we don't know the band (and WEXT compatibility) we assume the 2GHz band for channels below 14. This patch does not implement all channel to frequency mappings defined in 802.11, it's just an extension for 802.11j 20MHz channels. 5MHz and 10MHz channels as well as 802.11y channels have been omitted. The following drivers have been updated to reflect the API changes: iwl-3945, iwl-agn, iwmc3200wifi, libertas, mwl8k, rt2x00, wl1251, wl12xx. The drivers have been compile-tested only. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Brian Prodoehl <bprodoehl@gmail.com> Acked-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-19mac80211: track receiver's aggregation reorder buffer sizeJohannes Berg
The aggregation code currently doesn't implement the buffer size negotiation. It will always request a max buffer size (which is fine, if a little pointless, as the mac80211 code doesn't know and might just use 0 instead), but if the peer requests a smaller size it isn't possible to honour this request. In order to fix this, look at the buffer size in the addBA response frame, keep track of it and pass it to the driver in the ampdu_action callback when called with the IEEE80211_AMPDU_TX_OPERATIONAL action. That way the driver can limit the number of subframes in aggregates appropriately. Note that this doesn't fix any drivers apart from the addition of the new argument -- they all need to be updated separately to use this variable! Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-19mwl8k: Enable HW encryption for AP modeNishant Sarmukadam
set_key callback is defined for mac80211 to install keys for HW crypto in AP mode. Driver currently falls back to SW crypto in STA mode. Add support to configure the keys appropriately in the hardware after the set_key routine is called. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-19mwl8k: Set mac80211 rx status flags appropriately when hw crypto is enabledNishant Sarmukadam
When hw crypto is enabled, set rx status flags appropriately depending on whether hw crypto is enabled for a particular bss. Also report MIC errors to mac80211, so that counter measures can be initiated Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: yogesh powar <yogeshp@marvell.com> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-19mwl8k: Add encapsulation of data packet for cryptoNishant Sarmukadam
Different tail pads will be needed for crypto depending on the crypto mode. Add support to encapsulate the packets with appropriate pad value. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-19mwl8k: Modify add_dma_header to include pad parametersNishant Sarmukadam
Add capability to add_dma_header to support padding at tail of the data packet to be transmitted when crypto is enabled. Padding is required for adding crypto information in data packets for supporting 802.11 security modes. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mwl8k: use const struct fw pointers throughoutBrian Cavagnolo
This eliminates compiler warnings by doing things how the firmware class expects. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mwl8k: make initial firmware load asynchronousBrian Cavagnolo
Introduce a firmware loading state machine to manage the process of loading firmware asynchronously and completing initialization upon success. The state machine attempts to load the preferred firmware image. If that fails, and if an alternative firmware image is available, it will attempt to load that one. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mwl8k: add API version checking for AP firmwareBrian Cavagnolo
The AP firmware specifies an API version in the GET_HW_SPEC command response. Currently, the driver only supports AP firmware for the 8366, and only supports API v1. In the future, if higher API version firmwares emerge (possibly for different chips), different ops can be selected based on the reported API version. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mwl8k: choose proper firmware image as directed by userBrian Cavagnolo
The mwl8k can operate in AP or STA mode, depending on the firmware image that is loaded. By default, STA firmware is loaded. Allow the user to override this default mode at module load time. This saves an unnecessary firmware reload for users only interested in AP mode. Also, the firmware image can be swapped to meet the user's add_interface request. For example, suppose the STA firmware is loaded, no STA interface has been added, and the user adds an AP interface. In this case, the AP firmware will be loaded to meet the request. Based on contributions from Pradeep Nemavat <pnemavat@marvell.com>, Yogesh Powar <yogeshp@marvell.com>, and Lennert Buytenhek <buytenh@wantstofly.org>. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mwl8k: factor out firmware loading and hw init codeBrian Cavagnolo
This is in preparation for supporting different fw images for different interface types, and for supporting asynchronous firmware loading. Based on a patch from Pradeep Nemavat <pnemavat@marvell.com> and Yogesh Powar <yogeshp@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mwl8k: rf_tx_power cmd not supported by AP firmware APIv1Nishant Sarmukadam
APIv1 AP firmware does not support the RF_TX_POWER command. It supports the similar TX_POWER command. Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-16mwl8k: revert unnecessary modification of tx descriptorBrian Cavagnolo
This reverts change 783391c443728febc669e40597193308460e7b4f. The stabilized AP v1 firmware uses the same tx descriptor as the STA firmware. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15mwl8k: force AP mode to use non-AMPDU framesNishant Sarmukadam
AP firmware uses xmitcontrol to differentiate between AMPDU and non-AMPDU frames. As the support for AMPDU is not yet added, set xmitcontrol to non-AMPDU for all tx frames for AP firmware. This field will be set to indicate ampdu/non-ampdu frames when tx AMPDU support is added. Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
