path: root/drivers/net/wireless/mwl8k.c
2010-02-22mwl8k: convert to new station add/remove callbacksJohannes Berg
This converts mwl8k to use the new station add/remove callbacks instead of using the old sta_notify callback. The new callbacks can sleep, so a lot of code can be removed now. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-16mwl8k: disable softirqs when accessing sta_notify_listPavel Roskin
Use spin_[un]lock_bh in mwl8k_sta_notify(). The sta_notify handler is required to be atomic, yet it can be called in process context, so make sure one call won't preempt another. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-08mwl8k: remove get_tx_stats() mac80211 opKalle Valo
get_tx_stats() will be removed from mac80211. mwl8k used struct ieee80211_tx_queue_stats internally to track the queue lenght. Replace struct ieee80211_tx_queue_stats with a simple len field in struct mwl8k_tx_queue. Limit and count fields seemed to be unused. Compile-tested only. Cc: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-26mac80211: wait for beacon before enabling powersaveJohannes Berg
Because DTIM information is required for powersave but is only conveyed in beacons, wait for a beacon before enabling powersave, and change the way the information is conveyed to the driver accordingly. mwl8k doesn't currently seem to implement PS but requires the DTIM period in a different way; after talking to Lennert we agreed to just have mwl8k do the parsing itself in the finalize_join work. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: update version number (to 0.12) and copyrightLennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: enable multi-BSS AP operationLennert Buytenhek
As follows: - GET_HW_SPEC is now responsible for setting priv->{ap,sta}_macids_supported, which are bitmasks of supported macids for AP and STA mode. (Typically, STA firmware images will support only one macid, #0, in STA mode, and AP firmware images will support macids #0-7, in AP mode.) - Our wiphy ->interfaces_modes is now set based on the non-zero-ness of these two bitmasks. - We main priv->macids_used, a bitmask of which macids are currently in use. ->add_interface() will assign the lowest free macid for this interface type as it is created, or bail out if there are no more free macids to assign. ->delete_interface() will mark the macid as being free again. This enables the multi-BSS code added in the previous commits. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: post per-vif firmware commands as per-vif commandsLennert Buytenhek
SET_BEACON, SET_MAC_ADDR, BSS_START and SET_NEW_STN are the currently supported firmware commands that are actually per-vif commands. Use mwl8k_post_pervif_cmd() for these commands, so that the macid of the vif they operate on gets passed down into the firmware. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: prepare for posting per-vif firmware commandsLennert Buytenhek
One of the bytes in the mwl8k firmware command header is the 'macid' byte, which for per-vif commands indicates which of the BSSes this command is intended for. (For commands that are not per-vif commands, this byte can just be 0.) This patch adds mwl8k_post_pervif_cmd(), which will take the macid assigned to this interface (to be done in ->add_interface()), copy it into the command packet macid field, and post the command as usual. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: convert the priv->vif pointer to a list of vifsLennert Buytenhek
To prepare for adding multi-BSS support. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: use firmware capability field to decide which bands to registerLennert Buytenhek
Make the decision about whether to register the 2.4 and 5 GHz bands with mac80211 by looking at the capability field in GET_HW_SPEC (STA firmware only for now). This enables 5 GHz STA operation. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: allow selecting 5 GHz channelsLennert Buytenhek
2010-01-12mwl8k: handle 5 GHz legacy rate bitmaps in firmware commandsLennert Buytenhek
Whenever mac80211 gives us a legacy rate bitmap in the context of the 5 GHz band, we need to remember to shift the bitmap left by 5 positions before giving it to the firmware, as the firmware follows the bitmap bit assignment of the 2.4 GHz rate table even if we're on the 5 GHz band, and the 2.4 GHz rate table includes five non-OFDM rates at the start that are not valid in the 5 GHz band. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: properly set receive status rate index on 5 GHz receiveLennert Buytenhek
The mwl8k firmware uses indices into the 2.4 GHz band rate table for the receive descriptor channel field even if the packet was received on a 5 GHz channel, while mac80211 expects an index into the 5 GHz band rate table when packets are received on the 5 GHz band, which presents a mismatch as the 5 GHz band rate table lacks the five non-OFDM rates that the 2.4 GHz rate table starts with. To handle this properly, we need to substract 5 from the rate index field if the packet was received on a 5 GHz channel (and was not received at an MCS rate). Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: add 5 GHz band channels and ratesLennert Buytenhek
2010-01-12mwl8k: move responsibility for initialising wiphy bands to GET_HW_SPECLennert Buytenhek
So that we can make 2.4 GHz and 5 GHz band registration conditional on the capability bitmask returned by the firmware. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: rename 2.4 GHz band/channels/rates related variables from FOO to FOO_24Lennert Buytenhek
To prepare for adding 5 GHz band/channels/rates. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: add another 88w8366 PCI IDLennert Buytenhek
0x2a43 is a single-band (2.4GHz only) 88w8366 mini-PCIe card. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: simplify sequence number assignmentLennert Buytenhek
By storing the sequence counter in << 4 format, like other drivers do. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: don't call SET_AID if we're not associatedLennert Buytenhek
2010-01-12mwl8k: remove (mostly) write-only variable priv->current_channelLennert Buytenhek
2010-01-12mwl8k: update MODULE_FIRMWARE tagsLennert Buytenhek
Add MODULE_FIRMWARE tags for the mwl8k firmware images that don't have them yet, and move them to where the firmware image names are declared. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: move receive processing to taskletLennert Buytenhek
Like how TX reclaim is done in a tasklet, move receive processing to tasklet context as well. This can have nice benefits for CPU utilisation and throughput, especially at 3-stream rates. (Use the same CLEAR_SEL trick as the TX reclaim tasklet does, to avoid having to touch the interrupt mask registers.) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: keep TX_DONE interrupt masked while transmit reclaim is runningLennert Buytenhek
By making use of the CLEAR_SEL feature of the mwl8k host interface interrupt controller, we can keep the TX_DONE interrupt source masked while the transmit reclaim tasklet is running (NAPI style) without having to touch the interrupt controller's interrupt mask register when entering or exiting polling mode, and without having to do any more register reads/writes than we do now. When CLEAR_SEL is enabled on the TX_DONE interrupt source, reading the interrupt status register will clear the TX_DONE status bit if it was set, allowing it to be set again if a new TX_DONE event arrives while we are running the TX reclaim tasklet, but such a new event will then not trigger another PCI interrupt until a zero is written to the TX_DONE interrupt status register bit. I.e., if we write a zero to the TX_DONE interrupt source bit in the interrupt status register when the TX reclaim tasklet thinks it's done, a PCI interrupt will be triggered if a new TX_DONE event arrived from the hardware between us deciding that there is no more work to do and re-enabling the TX_DONE interrupt source, thereby avoiding the classic NAPI poll mode exit race that would otherwise occur. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: allow limiting the amount of transmit reclaim doneLennert Buytenhek
Add a limit argument to mwl8k_txq_reclaim(), to allow limiting the number of packets that it will reclaim, and make it return the number of packets that it reclaimed. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: basic AP interface supportLennert Buytenhek
Add support for creating AP interfaces, and enabling beaconing. This allows running a basic AP (11b/g mode only for now). Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: correctly set the mac_type field for AP SET_MAC_ADDRLennert Buytenhek
2010-01-12mwl8k: implement AP firmware station database maintenanceLennert Buytenhek
STA firmware uses UPDATE_STADB to manipulate the hardware station database, whereas AP firmware uses SET_NEW_STN -- this implements the latter, and hooks it into mwl8k_sta_notify(), to be used if we're running on AP firmware. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: add the AP version of USE_FIXED_RATELennert Buytenhek
As with the STA version, unicast will use auto rate adaptation, but the AP version allows setting the rates to be used for management and multicast transmissions, which can be set based on the BSS basic rate set. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: simplify mwl8k_cmd_use_fixed_rate()Lennert Buytenhek
As we always use the auto rate adaptation feature and never pass in a rate table, USE_FIXED_RATE can be simplified somewhat. While we're at it, rename it to *_sta, as this is the STA version of the command. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: bump the transmit wait timeout to 5 secondsLennert Buytenhek
While it is reasonable to expect that at least one transmit ring entry will be processed per second while we are waiting for the transmit rings to drain, the firmware can end up doing batching of transmit ring status writeback, which means that the transmit rings can appear stuck for more than a second at a time. Bump the TX drain wait timeout up from 1 to 5 seconds to account for this. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: undo transmit queue 0/1 swapping in mwl8k_cmd_set_edca_params()Lennert Buytenhek
The comment and code in mwl8k_cmd_set_edca_params() suggest that the mapping between SET_EDCA_PARAMS queue numbers and transmit rings isn't actually 1:1, while tests show that the mapping is in fact 1:1. So, get rid of the transmit queue 0/1 swapping. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mwl8k: minor cleanupsLennert Buytenhek
2010-01-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6John W. Linville
Conflicts: net/mac80211/iface.c
2010-01-05mwl8k: pass GET_HW_SPEC capability bitmask up the stackLennert Buytenhek
This enables HT association and AMPDU in the receive direction for STA firmware images on hardware that supports it. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05mwl8k: trivial rx-only ampdu implementationLennert Buytenhek
AMPDU receive doesn't need any special handling, so let's enable this before tackling the transmit side. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05mwl8k: pass in HT capabilities and rates when associatingLennert Buytenhek
Pass the AP's MCS rate mask to SET_RATE when associating, and make UPDATE_STADB pass in the peer's HT caps and rates when adding a new hardware station database entry. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05mwl8k: allow setting HT channelsLennert Buytenhek
2010-01-05mwl8k: add support for 88w8363 in STA modeLennert Buytenhek
2010-01-05mwl8k: fix changed flags handling in mwl8k_bss_info_changed()Lennert Buytenhek
Previously, mwl8k_bss_info_changed() would refuse to do anything if the 'changed' argument indicated that the association status hadn't changed. Fix this up so that it will allow changing things like the preamble type, the slot time and the CTS-to-self protection method without having to reassociate. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05mwl8k: honor peer rate setLennert Buytenhek
When calling SET_RATE, SET_AID, or when creating a station database entry for our AP, pass in the AP's rate set instead of just blindly enabling all legacy rates, so as to end up doing the right thing when talking to 11b-only APs. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05mwl8k: move ->peer_id from mwl8k_vif to mwl8k_staLennert Buytenhek
For STA firmware, move the per-peer hardware station ID to the driver-private part of struct ieee80211_sta, where it belongs. (Since issuing a hardware station database maintenance command sleeps, we can't hold a reference to the ieee80211_sta * across the command, and since we won't know the station ID until after the command completes, we need to re-lookup the sta when the command is done to write the returned station ID back to its driver-private part.) Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05mwl8k: remove mwl8k_vif::bssid, which is now uselessLennert Buytenhek
2010-01-05mwl8k: handle station database update for AP's sta entry via ->sta_notify()Lennert Buytenhek
Inserting and removing a hardware station database entry for the AP when we are in managed mode is currently done in ->bss_info_changed(). To prepare for adding AP mode support, implement the ->sta_notify() driver method, and let that handle inserting and removing the hardware station database entry for our AP instead. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05mwl8k: move struct peer_capability_info to its only userLennert Buytenhek
2010-01-05mwl8k: make the tx ring drain status messages somewhat more friendlyLennert Buytenhek
Old: > phy0: timeout waiting for tx rings to drain (9 -> 5 pkts), retrying > phy0: timeout waiting for tx rings to drain (5 -> 2 pkts), retrying > phy0: tx rings drained New: > phy0: waiting for tx rings to drain (9 -> 5 pkts) > phy0: waiting for tx rings to drain (5 -> 2 pkts) > phy0: tx rings drained Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-05mwl8k: prevent freeing free IRQ if ieee80211_register_hw() failsLennert Buytenhek
2010-01-05mwl8k: bail out if there is no AP firmware image support for this chipLennert Buytenhek
2010-01-05mwl8k: update version number to 0.11Lennert Buytenhek
2010-01-04mwl8k: fix configure_filter() memory leak on errorLennert Buytenhek
If there was an error acquiring the firmware lock in mwl8k_configure_filter(), we would end up leaking the multicast command packet prepared by mwl8k_prepare_multicast(). Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28mac80211: remove struct ieee80211_if_init_confJohannes Berg
All its members (vif, mac_addr, type) are now available in the vif struct directly, so we can pass that instead of the conf struct. I generated this patch (except the mac80211 and header file changes) with this semantic patch: @@ identifier conf, fn, hw; type tp; @@ tp fn(struct ieee80211_hw *hw, -struct ieee80211_if_init_conf *conf) +struct ieee80211_vif *vif) { <... ( -conf->type +vif->type | -conf->mac_addr +vif->addr | -conf->vif +vif ) ...> } Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
