Use the built-in function instead of memset.
Miscellanea:
Add #include <linux/etherdevice.h> where appropriate
Use ETH_ALEN instead of 6
All of the survey data is (currently) per channel anyway,
so having the word "channel" in the name does nothing. In
the next patch I'll introduce global data to the survey,
where the word "channel" is actually confusing.
Allow drivers to support NL80211_SCAN_FLAG_RANDOM_ADDR with software
based scanning and generate a random MAC address for them for every
scan request with the flag.
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Remove the now unnecessary memset too.
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: "John W. Linville" <linville@tuxdriver.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
It fixes following sparse check warning
>#make C=1 CF=-D__CHECK_ENDIAN__ drivers/net/wireless/mwl8k.o
>drivers/net/wireless/mwl8k.c:3089:6: warning: symbol 'mwl8k_update_survey' was not declared. Should it be static?
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Nishant Sarmukadam <nishants@marvell.com>
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
It fixes couple of sparse check
>drivers/net/wireless/mwl8k.c:3104:19: warning: cast to restricted __le32
>drivers/net/wireless/mwl8k.c:3108:18: warning: cast to restricted __le32
Survey stats such as channel busy time, rx busy time
and noise are collected when sw_scan starts for every
switched new channel. This happens till sw_scan stops.
All the collected stats are shared up when get_survey()
is called.
This implements support for ACS feature from Hostapd.
Implement sw_scan start and stop callbacks.
Reset BBP registers for channel, RX busy and
average noise stats which clear on read.
Adding AP firmware command to access BBP
regs. This will be used for retrieving
different counters CCA/RX needed for ACS
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
This value is no longer used by mac80211, and practically no
driver ever set it to a correct value anyway, so remove it.
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be
used when each argument is an array within a structure that contains at
least two bytes of data beyond the array.
The structures involved are:
ieee80211_hdr defined in include/linux/ieee80211.h and
mwl8k_priv defined in drivers/net/wireless/mwl8k.c
This was done using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
The driver core clears the driver data to NULL after device_release
or on probe failure. Thus, it is not needed to manually clear the
device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
The firmware hang issue is not seen very often,
though it is still seen sometimes (once in 12
hours in local tests). The changes in the driver
,to interrupt the firmware, are needed when we
detect that firmware is stuck and when the host
queues are full and we begin to drop packets.
This is to ensure that the firmware does not
miss any PPA_RDY interrupts to cause the firmware
restart dont miss PPA_READY interrupt for SC2
This rate causes an overflow in the extended rates IE's data rate field,
with the overflowing bit setting the Basic Rate Set membership. This
results in a bogus 8 Mpbs basic rate, making clients checking them refuse
association.
Since the rate is likely unused anyway (HT will yield better rates between
supporting chips), we can just remove it.
This fixes association from wpa_supplicant and Android 4.x and newer.
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
drivers/net/wireless/ath/carl9170/debug.c
drivers/net/wireless/ath/carl9170/main.c
net/mac80211/ieee80211_i.h
Fix settings not being applied when the device is idle and the firmware
gets reloaded (because of changing from STA to AP mode). This caused
the device using the wrong channel (and likely band), e.g. a 5 GHz only
card still defaulted to channel 6 in the 2.4 GHz band when left
unconfigured.
This issue was always present, but only made visible with "mwl8k: Do not
call mwl8k_cmd_set_rf_channel unconditionally" (0f4316b9), since before
that the channel was (re-)configured at the next _config call even when
it did not change from the mac80211 perspective.
Drivers that don't use chanctxes cannot perform VHT association because
they still use a "backward compatibility" pair of {ieee80211_channel,
nl80211_channel_type} in ieee80211_conf and ieee80211_local.
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
[fix kernel-doc]
Currently the caps are parsed on every firmware reload, causing any
channel flags to be cleared.
When there is a firmware to interface mode mismatch, the triggered
firmware reload causes a reset of the regulatory settings, causing all
channels to become available:
root@openrouter:/# iw phy phy0 info
Wiphy phy0
Band 1:
Frequencies:
* 2412 MHz [1] (0.0 dBm)
* 2417 MHz [2] (0.0 dBm)
* 2422 MHz [3] (0.0 dBm)
* 2427 MHz [4] (0.0 dBm)
* 2432 MHz [5] (0.0 dBm)
* 2437 MHz [6] (0.0 dBm)
* 2442 MHz [7] (0.0 dBm)
* 2447 MHz [8] (0.0 dBm)
* 2452 MHz [9] (0.0 dBm)
* 2457 MHz [10] (0.0 dBm)
* 2462 MHz [11] (0.0 dBm)
* 2467 MHz [12] (0.0 dBm)
* 2472 MHz [13] (0.0 dBm)
* 2484 MHz [14] (0.0 dBm)
To prevent this, only parse the caps on the first firmware load during
hardware probe, and store them locally to know we have already parsed
them.
This differs from legacy chips i.e.
a 8764 loads firmware image without a helper image
b Check interrupt status register for download
complete indication.
The patch does the following:-
a Add entry in the PCIe table
b Add firmware support with API versioning
c Reuse most of the 8366 code
d Make 8764 specific changes where 8764 differs
from 8366 e.g. structure definitions.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
drivers/net/wireless/iwlwifi/dvm/tx.c
The band field for the supported channels were left unpopulated, making
them default to 0 == IEEE80211_BAND_2GHZ, even for the 5GHz channels.
This resulted in null pointer accesses if anything tries to access
wiphy->bands[channel->band] of a 5GHz channel on 5GHz only cards, since
wiphy->bands[2GHZ] is NULL for them (e.g. cfg80211_chandef_usable does).
Example kernel OOPS:
[ 665.669993] Unable to handle kernel NULL pointer dereference at virtual address 00000016
[ 665.678194] pgd = c6d58000
[ 665.680941] [00000016] *pgd=06f8a831, *pte=00000000, *ppte=00000000
[ 665.687303] Internal error: Oops: 17 [#1]
[ 666.116373] Backtrace:
[ 666.118866] [<bf0368dc>] (cfg80211_chandef_usable+0x0/0x1bc [cfg80211]) from [<bf025e64>] (nl80211_leave_mesh+0x244/0x264 [cfg80211])
[ 666.130919] r7:c6d12100 r6:0000143c r5:c0611c48 r4:c0611b98
[ 666.136668] [<bf025d84>] (nl80211_leave_mesh+0x164/0x264 [cfg80211]) from [<bf02634c>] (nl80211_remain_on_channel+0x2a0/0x358 [cfg80211])
[ 666.149074] r7:c6d12000 r6:c6d12000 r5:c6f4f368 r4:00000003
[ 666.154814] [<bf0262ec>] (nl80211_remain_on_channel+0x240/0x358 [cfg80211]) from [<bf02ddb0>] (nl80211_set_wiphy+0x264/0x560 [cfg80211])
[ 666.167150] [<bf02db4c>] (nl80211_set_wiphy+0x0/0x560 [cfg80211]) from [<c01f94e0>] (genl_rcv_msg+0x1b8/0x1f8)
[ 666.177205] [<c01f9328>] (genl_rcv_msg+0x0/0x1f8) from [<c01f89a0>] (netlink_rcv_skb+0x58/0xb4)
[ 666.185949] [<c01f8948>] (netlink_rcv_skb+0x0/0xb4) from [<c01f931c>] (genl_rcv+0x20/0x2c)
[ 666.194251] r6:c6f70780 r5:0000002c r4:c6f70780 r3:00000001
[ 666.199973] [<c01f92fc>] (genl_rcv+0x0/0x2c) from [<c01f8418>] (netlink_unicast+0x154/0x1f4)
[ 666.208449] r4:c785ea00 r3:c01f92fc
[ 666.212057] [<c01f82c4>] (netlink_unicast+0x0/0x1f4) from [<c01f8790>] (netlink_sendmsg+0x230/0x2b0)
[ 666.221240] [<c01f8560>] (netlink_sendmsg+0x0/0x2b0) from [<c01cccf8>] (sock_sendmsg+0x90/0xa4)
[ 666.229986] [<c01ccc68>] (sock_sendmsg+0x0/0xa4) from [<c01cdcb0>] (__sys_sendmsg+0x290/0x298)
[ 666.238637] r9:00000000 r8:c0611ec8 r6:0000002c r5:c0610000 r4:c0611f64
[ 666.245411] [<c01cda20>] (__sys_sendmsg+0x0/0x298) from [<c01cf52c>] (sys_sendmsg+0x44/0x6c)
[ 666.253897] [<c01cf4e8>] (sys_sendmsg+0x0/0x6c) from [<c00090a0>] (ret_fast_syscall+0x0/0x2c)
[ 666.262460] r6:00000000 r5:beeff96c r4:00000005
alloc failures already get standardized OOM
messages and a dump_stack.
Add PCI deviceIDs for single band versions of 88W8366, found e.g. in
simultaneous dual band routers based on kirkwood.
While using STA mode in the AP firmware, avoid
calling some firmware commands which are not
supported by the AP firmware.
Choose interface specific function calls
based on interface type instead of
firmware types.
Add and delete self entry in the firmware sta database
for AP interface only. We do not need such an entry for
STA interface.
Firmware supports hardware encryption feature
for the station interface running on AP
firmware.
Set mac type for station interface on AP firmware
as secondary. This allows the firmware to set specific
characteristics for the STA interface.
When user wants to add a station interface when
AP firmware is loaded & in-use, allow creating
it and also notify user about the same.
Allow adding max one STA interface for AP fw.
Specify the STA support in iface_limit and
in wihpy->interface_modes
This avoids calling mwl8k_cmd_rf_antenna functions every
time mwl8k_config function is called.
Avoid calling mwl8k_cmd_set_rf_channel unconditionally
by checking IEEE80211_CONF_CHANGE_CHANNEL.
For the commands, that might change the hw characteristics
of the PHY device, stop the running bsses and resume them
once command is complete.
drivers/net/wireless/ath/ath9k/main.c
If pci_iomap() fails in mwl8k_probe(), it breaks off initialization,
deallocates all resources, but returns zero.
There is a similar issue when priv->rxd_ops is NULL in mwl8k_probe_hw().
The patch adds proper error code return values.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
If queues are stopped in mwl8k_stop,
these should be started in mwl8k_start
Signed-off-by: Yogesh Powar <yogeshp@marvell.com>
When a station deauths, we do not delete the streams with state
AMPDU_STREAM_NEW and these remain created forever. Fix this issue by
removing such streams in the driver
Whenever TX ring is drained, priv->tx_wait still points
to a valid completion. Making sure that it points to
NULL before returning from the mwl8k_tx_wait_empty
check.
New firmware is required to support
a) Add support for additional ampdu streams
b) Handle corresponding watchdog events to destroy ampdu streams
Bumping firmware API version by one.
Currently, command path waits till all the tx host queues
are empty. Whenever watchdog event is raised, firmware
expects driver to destroy ampdu queues immediately.
This requires corresponding commands i.e.
mwl8k_cmd_get_watchdog_bitmap and mwl8k_destroy_ba to be
sent without waiting for the tx queues to be completely
empty.
Use "watchdog_event_pending" to ensure the above mentioned
two commands are sent down immediately.
With more ampdu streams, we need to handle watchdog
events for the new ampdu streams. Handle these
events appropriately.
Earlier mwl8k_cmd_get_watchdog_bitmap used to return
only one stream index and hence bitwise operations
on the return value were not required. Now the function
returns a bitmap with different bits are mapped with
different stream indices.
Currently, mwl8k_ampdu_stream is passed as one of the
argument to the function mwl8k_destroy_ba. Instead of
this pass only the stream index. This will be helpful
during watchdog event handling when bitmap of stream
indices are received.
Currently, we have 2 ampdu streams that can be created
simultaneously. Firmware is capable of supporting
additional streams. Add support to use these streams.
Set ACK policy to NORMAL when its not going to
be an AMPDU packet.
Ampdu stream index can be derived from stream->idx.
So we no longer need stream->txq_idx, hence removing it.
