Part of reorganising wireless drivers directory and Kconfig.
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Previously, each bus type was responsible for freeing the firmware
structure, but some did that badly. Move responsibility for freeing
firmware into firmware.c so that it's done once and correctly, instead
of happening in multiple places in bus-specific code.
This fixes a use-after-free bug found by Dr. H. Nikolaus Schaller where
the SDIO code forgot to NULL priv->helper_fw after freeing it.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Switch over to using olpc-ec.h in multiple steps, so as not to break builds.
This covers every driver that calls olpc_ec_cmd().
Signed-off-by: Andres Salomon <dilinger@queued.net>
Acked-by: Paul Fox <pgf@laptop.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
We found a deadlock in the handling of command failures/reset conditions.
For example:
1. Two commands are in the queue.
2. The first command is sent, but causes a timeout, which kicks off an
asynchronous device reset
3. The second command is queued (but not yet sent to the hardware)
4. The device reset kicks in, causing the if_usb disconnect handler to
set the "surprise removed" flag to be set as the device disappears
from the bus. This causes lbs_thread to stop processing things
("adapter removed; waiting to die"), not processing any further
commands, leaving the second queued command "in the air", causing a
deadlock.
Fix this by removing the surpriseremoved flag setting in if_usb. I can't
see any reason why this needs to be done so early. lbs_remove_card will set
this flag at an appropriate time - i.e. after all pending commands have
been completed or cancelled, avoiding this deadlock.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Adding casts of objects to the same type is unnecessary
and confusing for a human reader.
For example, this cast:
int y;
int *p = (int *)&y;
I used the coccinelle script below to find and remove these
unnecessary casts. I manually removed the conversions this
script produces of casts with __force, __iomem and __user.
type T;
T *p;
- (T *)p
+ p
Neatened the mwifiex_deauthenticate_infra function which
was doing odd things with array pointers and not using
is_zero_ether_addr.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB 3.5-rc1 changes from Greg Kroah-Hartman:
"Here is the big USB 3.5-rc1 pull request for the 3.5-rc1 merge window.
It's touches a lot of different parts of the kernel, all USB drivers,
due to some API cleanups (getting rid of the ancient err() macro) and
some changes that are needed for USB 3.0 power management updates.
There are also lots of new drivers, pimarily gadget, but others as
well. We deleted a staging driver, which was nice, and finally
dropped the obsolete usbfs code, which will make Al happy to never
have to touch that again.
There were some build errors in the tree that linux-next found a few
days ago, but those were fixed by the most recent changes (all were
due to us not building with CONFIG_PM disabled.)
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (477 commits)
xhci: Fix DIV_ROUND_UP compile error.
xhci: Fix compile with CONFIG_USB_SUSPEND=n
USB: Fix core compile with CONFIG_USB_SUSPEND=n
brcm80211: Fix compile error for .disable_hub_initiated_lpm.
Revert "USB: EHCI: work around bug in the Philips ISP1562 controller"
MAINTAINERS: Add myself as maintainer to the USB PHY Layer
USB: EHCI: fix command register configuration lost problem
USB: Remove races in devio.c
USB: ehci-platform: remove update_device
USB: Disable hub-initiated LPM for comms devices.
xhci: Add Intel U1/U2 timeout policy.
xhci: Add infrastructure for host-specific LPM policies.
USB: Add macros for interrupt endpoint types.
xhci: Reserve one command for USB3 LPM disable.
xhci: Some Evaluate Context commands must succeed.
USB: Disable USB 3.0 LPM in critical sections.
USB: Add support to enable/disable USB3 link states.
USB: Allow drivers to disable hub-initiated LPM.
USB: Calculate USB 3.0 exit latencies for LPM.
USB: Refactor code to set LPM support flag.
arch/arm/mach-exynos/mach-nuri.c
arch/arm/mach-exynos/mach-universal_c210.c
drivers/net/wireless/ath/ath6kl/usb.c
Hub-initiated LPM is not good for USB communications devices. Comms
devices should be able to tell when their link can go into a lower power
state, because they know when an incoming transmission is finished.
Ideally, these devices would slam their links into a lower power state,
using the device-initiated LPM, after finishing the last packet of their
data transfer.
If we enable the idle timeouts for the parent hubs to enable
hub-initiated LPM, we will get a lot of useless LPM packets on the bus
as the devices reject LPM transitions when they're in the middle of
receiving data. Worse, some devices might blindly accept the
hub-initiated LPM and power down their radios while they're in the
middle of receiving a transmission.
The Intel Windows folks are disabling hub-initiated LPM for all USB
communications devices under a xHCI USB 3.0 host. In order to keep
the Linux behavior as close as possible to Windows, we need to do the
same in Linux.
Set the disable_hub_initiated_lpm flag for for all USB communications
drivers. I know there aren't currently any USB 3.0 devices that
implement these class specifications, but we should be ready if they do.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: Hansjoerg Lipp <hjlipp@web.de>
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Jan Dumon <j.dumon@option.com>
Cc: Petko Manolov <petkan@users.sourceforge.net>
Cc: Steve Glendinning <steve.glendinning@smsc.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Kalle Valo <kvalo@qca.qualcomm.com>
Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com>
Cc: Jouni Malinen <jouni@qca.qualcomm.com>
Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com>
Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com>
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: Brett Rudley <brudley@broadcom.com>
Cc: Roland Vossen <rvossen@broadcom.com>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: "Franky (Zhenhui) Lin" <frankyl@broadcom.com>
Cc: Kan Yan <kanyan@broadcom.com>
Cc: Dan Williams <dcbw@redhat.com>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: Herton Ronaldo Krzesinski <herton@canonical.com>
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
Cc: Daniel Drake <dsd@gentoo.org>
Cc: Ulrich Kunitz <kune@deine-taler.de>
Acked-by: Dan Williams <dcbw@redhat.com>
Remove the ability to pass module parameters with firmware filenames
for USB and SDIO interfaces.
Remove the ability to pass custom "user" filenames to lbs_get_firmware().
Remove the ability to reprogram internal device memory with a different
firmware from the USB driver (we don't know of any users), and simplify
the OLPC firmware loading quirk to simply placing the OLPC firmware
at the top of the list (we don't know of any users other than OLPC).
Move lbs_get_firmware() into its own file.
These simplifications should have no real-life effect but make the
upcoming transition to asynchronous firmware loading considerably less
painful.
Add a corresponding leave call on error failure.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
alloc failures use dump_stack so emitting an additional
out-of-memory message is an unnecessary duplication.
Remove the allocation failure messages.
This converts the drivers in drivers/net/* to use the
module_usb_driver() macro which makes the code smaller and a bit
simpler.
Added bonus is that it removes some unneeded kernel log messages about
drivers loading and/or unloading.
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Pavel Roskin <proski@gnu.org>
Cc: Yoann DI-RUZZA <y.diruzza@lim.eu>
Cc: George <george0505@realtek.com>
Normally, the v9 firmware will be loaded if it's available. However, on
OLPC XO-1 machines, the olpc-specific firmware supports extra functionality.
This makes the libertas driver attempt to load the custom firmware first
if the machine is an OLPC machine; if that fails (or it's not an OLPC
machine), fall back to attempting to load the other firmwares.
usb8388_olpc.bin is currently found in the linux-firmware repository.
Modify the driver so that it does not function when the interface is
down, in preparation for runtime power management.
No commands can be run while the interface is down, so the ndo_dev_stop
routine now directly does all necessary work (including asking the device
to disconnect from the network and disabling multicast functionality)
directly.
power_save and power_restore hooks are added meaning that card drivers
can take steps to turn the device off when the interface is down.
The MAC address can now only be changed when all interfaces are down;
the new address will be programmed when an interface gets brought up.
This matches mac80211 behaviour.
Also, some small cleanups/simplifications were made in the surrounding
device handling logic.
OLPC power management code has recently gone upstream. This piece
completes the puzzle for libertas_usb, which now programs the OLPC EC
for wlan wakeups when they have been requested.
Currently, "udevadm info -a -p /sys/class/net/wlan0" doesn't mention
the usb8xxx or libertas driver anywhere. This makes writing udev rules
a bit uncomfortable.
Using the USB interface as the parent device corrects the hierarchy.
Using the more descriptive logging styles gives a bit
more information about the device being operated on.
Makes the object trivially smaller too.
$ size drivers/net/wireless/libertas/built-in.o.*
187730 2973 38488 229191 37f47 drivers/net/wireless/libertas/built-in.o.new
188195 2973 38488 229656 38118 drivers/net/wireless/libertas/built-in.o.old
Use the standard pr_<level> functions eases grep a bit.
Added a few missing terminating newlines to messages.
Coalesced long formats.
Convert all libertas/ files to use kernel-doc notation instead
of whatever it was (doxygen?).
Add or fix function parameters in several places.
Use expected style for multi-line comments in lots of places.
Remove erroneous /** in multiple places.
Certain firmware versions, particularly the 8388 found on the XO-1,
do not support the EHS_REMOVE_WAKEUP command that is used to disable
WOL. Sending this command to the card will return a failure that
would get propagated up the stack and cause suspend to fail.
Instead, fall back to an all-zero wakeup mask.
This fixes http://dev.laptop.org/ticket/9967
Signed-off-by: Deepak Saxena <dsaxena@laptop.org>
[includes fixups by Paul Fox]
This hunk added by commit 66fceb69b72f seems erroneous. We don't want to
prevent suspend of the whole system if no wakeup params are set.
In the case of the usb8388 we do want to keep the card powered up even
if there are no wakeup params. This is because it will continue acting
as a mesh node.
If the mesh is disabled, it would indeed make more sense to power down
the card during suspend, as the equivalent hunk does for the SD interface.
But that's a separate task; for now just restore the previous behaviour.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
The return code was being overwritten with -1.
Useful for debugging.
Signed-off-by: Paul Fox <pgf@laptop.org>
drivers/net/wireless/libertas/if_sdio.c
Look for firmware where the linux-firmware tree actually puts it, but
fall back to original firmware name & location when the new location
doesn't exist.
Since the writing to sysfs can free the old one, we need to block that
when we access the charp variables.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Jing Huang <huangj@brocade.com>
Cc: James E.J. Bottomley <James.Bottomley@suse.de>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: libertas-dev@lists.infradead.org
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: linux-scsi@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Powersave looks like it got broken at some point but we'll fix that up
when the command submission stuff is more understandable, which this
series helps to do. That said, this patch should not further break
powersave.
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression from,to,size,flag;
statement S;
- to = \(kmalloc\|kzalloc\)(size,flag);
+ to = kmemdup(from,size,flag);
if (to==NULL || ...) S
- memcpy(to, from, size);
// </smpl>
In suspend() host sleep is activated using already configured
host sleep parameters through wol command, and in resume() host
sleep is cancelled. Earlier priv->fw_ready flag used to reset and
set in suspend and resume handler respectively. Since after suspend
only host goes into sleep state and firmware is always ready, those
changes in flag state are removed.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
drivers/net/usb/cdc_ether.c
All CDC ethernet devices of type USB_CLASS_COMM need to use
'&mbm_info'.
On a 64-bit kernel, skb->tail is an offset, not a pointer. The libertas
usb driver passes it to usb_fill_bulk_urb() anyway, causing interesting
crashes. Fix that by using skb->data instead.
This highlights a problem with usb_fill_bulk_urb(). It doesn't notice
when dma_map_single() fails and return the error to its caller as it
should. In fact it _can't_ currently return the error, since it returns
void.
So this problem was showing up only at unmap time, after we'd already
suffered memory corruption by doing DMA to a bogus address.
Cc: stable@kernel.org
Add timer based auto deep sleep feature in libertas driver which can be
configured using iwconfig command. This is tested on SD8688, SD8686 cards
with firmware versions 10.38.1.p25, 9.70.4.p0 respectively on 32-bit and 64-bit
platforms. Tests have been done for USB/CS cards to make sure that the patch
won't break USB/CS code. We didn't test the if_spi driver.
Signed-off-by: Bing Zhao <bzhao@marvell.com>
Power save support depends on the firmware capabilities rather than the
card's hardware interface. Use the FW_CAPINFO_PS bit in the firmware
capabilities mask throughout the driver in place of the redundant
ps_supported flag and don't make decisions about PS support in the
interface drivers (with the exception of a special case in the USB
driver).
V2: put the USB special case in the right place.
Signed-off-by: Andrey Yurovsky <andrey@cozybit.com>
We're going to remove the FIRMWARE_NAME_MAX definition in order to avoid any
firmware name length restriction.
This patch eplaces the shared FIRMWARE_NAME_MAX definition with a libertas
local one.
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
The mesh and radiotap interfaces need to use the same private data as
the main wifi interface. If the main wifi interface uses netdev_priv(),
but the other interfaces ->ml_priv, there's no way to figure out where
the private data actually is in the WEXT handlers and netdevice
callbacks. So make everything use ->ml_priv.
Fixes botched netdev_priv() conversion introduced by "netdevice
libertas: Fix directly reference of netdev->priv", though admittedly
libertas' use of ->priv was somewhat "special".
Signed-off-by: Kiran Divekar <dkiran@marvell.com>
Tested-by: Chris Ball <cjb@laptop.org>
Simply replace netdev->priv with netdev_priv().
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
Based on a patch from Shailendra Govardhan <shailen@marvell.com>.
This patch allows implementation of more specific wake-on-lan rules than those
of ethtool.
Please note that only firmware 5.110.22.p20 and above supports this feature.
This patch only implements the driver/firmware interface, not the
userspace/driver interface.
Signed-off-by: Anna Neal <anna@cozybit.com>
Signed-off-by: Javier Cardona <javier@cozybit.com>
The generic reset command is unused. Each interface type needs to
handle the reset command differently since after reset, the firmware is
dead and interface-specific mechanisms must be used to reinitialize the
card.
To use these features, copy the boot2 and firmware images to /lib/firmware and:
echo <boot2_image_name> > /sys/class/net/ethX/lbs_flash_boot2
echo <firmware_image_name> > /sys/class/net/ethX/lbs_flash_fw
Signed-off-by: Brian Cavagnolo <brian@cozybit.com>
Add locking and non-locking versions of if_usb_prog_firmware to support
programming firmware after and before driver bring-up respectively. Add more
suitable error codes for firmware programming process. Add capability checks
for persistent features before attempting to use them.
Based on patches from Brajesh Dave and Priyank Singh.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/powerpc/booting-without-of.txt
drivers/atm/Makefile
drivers/net/fs_enet/fs_enet-main.c
drivers/pci/pci-acpi.c
net/8021q/vlan.c
net/iucv/iucv.c
Documentation/feature-removal-schedule.txt
drivers/net/wan/hdlc_fr.c
drivers/net/wireless/iwlwifi/iwl-4965.c
drivers/net/wireless/iwlwifi/iwl3945-base.c
Handle .reset_resume() so that libertas can survive suspend/resume without
reloading the firmware.
Acked-by: Deepak Saxena <dsaxena@laptop.org>
