path: root/drivers/net/wireless/libertas/hostcmd.h
2009-10-27libertas: cleanup host.h and hostcmd.hHolger Schurig
Also remove some unused definitions and make tab usage consistent. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-07libertas: correct packing of rxpd structureBob Dunlop
Older Gcc compilers (3.4.5 tested) need additional hints in order to get the packing of the rxpd structure (which contains a 16 bit union) correct on the ARM processor. struct txpd does not need these hints since it contains a 32 bit union that packs naturally. Signed-off-by: R.J.Dunlop <rdunlop@guralp.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03libertas: convert CMD_802_11_ASSOCIATE to a direct commandDan Williams
Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03libertas: convert CMD_802_11_AUTHENTICATE to a direct commandDan Williams
And fix up setting authentication suite for v9+ firmware too. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03libertas: simplify and clean up association/start/join setupDan Williams
Some of the parameters for association/join/start commands aren't used (like the FH and CF IEs for IBSS, and the FH IE for BSS), so get rid of their unions to reduce indirection. Also clean up structure names for kernel style. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22libertas: support mesh for various firmware versionsBing Zhao
CMD_MESH_CONFIG command ID and a couple of structure members in TxPD, RxPD have been changed in firmware version 10.x.y.z and newer. Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29libertas: Update libertas core with GSPI constantsColin McCabe
Add GSPI constants to libertas core. Fix misleading comment in lbs_setup_firmware. Signed-off-by: Colin McCabe <colin@cozybit.com> Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-16libertas: Fix alignment issues in libertas coreAndrey Yurovsky
Data structures that come over the wire from the WLAN firmware must be packed. This fixes alignment problems on the blackfin architecture and, reportedly, on the AVR32. This is a replacement for the previous version of this patch which had also explicitly used get_unaligned_ macros. As Johannes Berg pointed out, these macros were unnecessary. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: Colin McCabe <colin@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-21libertas: Fine grained configuration of wake-on-lan.Anna Neal
Based on a patch from Shailendra Govardhan <shailen@marvell.com>. This patch allows implementation of more specific wake-on-lan rules than those of ethtool. Please note that only firmware 5.110.22.p20 and above supports this feature. This patch only implements the driver/firmware interface, not the userspace/driver interface. Signed-off-by: Anna Neal <anna@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15libertas: convert SNMP_MIB to a direct commandDan Williams
And support setting both long and short retries independently. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15libertas: remove unused generic RESET commandDan Williams
The generic reset command is unused. Each interface type needs to handle the reset command differently since after reset, the firmware is dead and interface-specific mechanisms must be used to reinitialize the card. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11libertas: Improvements on automatic tx power control via SIOCSIWTXPOW.Anna Neal
iwconfig txpower can now be used to set tx power to fixed or auto. If set to auto the default firmware settings are used. The command CMD_802_11_PA_CFG is only sent to older firmware, as Dan Williams noted the command was no longer supported in firmware V9+. Signed-off-by: Anna Neal <anna@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29libertas: convert adhoc operations to direct commandsDan Williams
with fixes for v9 and later firmware too. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29libertas: convert CMD_802_11_DEAUTHENTICATE to a direct commandDan Williams
and remove DISASSOCIATE because it's not in any of the specs and has never been used. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29libertas: convert CMD_802_11_RF_TX_POWER to a direct commandDan Williams
And while we're at it, grab min/max TX power from the firmware and use that to validate incoming TX power requests from WEXT. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03libertas: rate adaptation configuration via iwconfig.Javier Cardona
Implemented rate adaptation support via 'iwconfig rate' API. It is now possible to specify a bit-rate value and append 'auto'. That will configure rate adaptation to use all bit-rates equal or lower than than selected value. Made lbs_cmd_802_11_rate_adapt_rateset a direct command. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21libertas: fix multicast filtering on eth and msh interfacesDavid Woodhouse
We weren't properly handling multicast on the mesh interface. Fix that, which involves setting up the hardware to use the union of dev->mc_list for both eth%d and msh%d devices. This means we can't do it directly from ->set_multicast_list() because we'd need to lock the other device to read its list, and we can't do that because it might deadlock. So punt the actual work to keventd. Also, invoke the same when taking an interface down; for some reason the core calls ->set_multicast_list while IFF_UP is still set in dev->flags when we're taking it down, so its addresses don't get removed then. We also convert MAC_MULTICAST_ADR to a direct command while we're at it, removing one more entry from the big switch statement in the deprecated lbs_prepare_and_send_command() function. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-01libertas: convert sleep/wake config direct commandsHolger Schurig
Confirm sleep event: they come very regularly, eventually several times per second. Therefore we want to send the config command as fast as possible. The old code pre-set the command in priv->lbs_ps_confirm_sleep. However, the byte sequence to be sent to the hardware is the same for all interfaces. So this patch make this an extern structure, initialized at module load time. Config wake event: normal conversion to a direct command. However, I don't know how to trigger a "HOST AWAKE" event from the firmware, so this part is untested. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-01libertas: convert CMD_802_11_EEPROM_ACCESS to a direct commandHolger Schurig
2008-04-01libertas: convert CMD_802_11_MAC_ADDRESS to a direct commandHolger Schurig
* directly call lbs_cmd_with_response() * only overwrite priv->current_addr once the firmware call succeeded Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-27libertas: remove CMD_802_11_PWR_CFGHolger Schurig
This has nowhere been used. Note: in the firmware manual this was documented as CMD_802_11_PA_CFG. If we ever need it, we can/should re-implement it as a direct command. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-25libertas: convert GET_LOG to a direct commandHolger Schurig
Now uses __lbs_cmd() to get the "log" (it's actually more a snapshot of various counters, not a sequential log). Besides the "mechanical" convertion the patch add the following logical changes: * Removes the priv->logmsg variable, it was only used in one place anyway, also don't blindly get the counters when associating. Getting the counters then the user asks via WEXT for them is good enought. * don't set wstats.discard.fragment with log.rxfrag, because the latter is a counter for successfully received packets, not for fragmented packets. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-25libertas: convert CMD_MAC_CONTROL to a direct commandHolger Schurig
convert CMD_MAC_CONTROL to a direct command Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06libertas: convert 802_11_SCAN to a direct commandDavid Woodhouse
2008-03-06libertas: convert KEY_MATERIAL to a direct commandDavid Woodhouse
The struct enc_key probably wants to die too, but that can come later. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: always show firmware releaseHolger Schurig
Always shows the firmware release. Also converts the firmware release into something that is easily comparable. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: convert SUBSCRIBE_EVENT to a direct commandDavid Woodhouse
2008-01-28libertas: convert ENABLE_RSN to a direct commandDavid Woodhouse
2008-01-28libertas: convert SET_WEP to a direct commandDavid Woodhouse
2008-01-28libertas: convert SLEEP_PARAMS to a direct commandDavid Woodhouse
2008-01-28libertas: convert INACTIVITY_TIMEOUT to a direct commandDavid Woodhouse
2008-01-28libertas: convert RADIO_CONTROL to a direct commandDavid Woodhouse
2008-01-28libertas: add SLEEP_PERIOD and FW_WAKE_METHOD command definitionsDavid Woodhouse
2008-01-28libertas: store command result in cmdnode instead of priv->cur_cmd_retcodeDavid Woodhouse
... at least for users of __lbs_cmd(). Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: kill pdata_buf member of struct cmd_ctrl_nodeDavid Woodhouse
We can use the callback_arg for it; that's the way we're heading anyway... Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: kill unused wait_option field in struct cmd_ctrl_nodeDavid Woodhouse
2008-01-28libertas: add lbs_host_sleep_cfg() command functionDavid Woodhouse
2008-01-28libertas: add lbs_mesh sysfs attribute for enabling meshDavid Woodhouse
2008-01-28libertas: convert RF_CHANNEL to a direct commandDan Williams
Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: convert DATA_RATE to a direct commandDan Williams
2008-01-28libertas: convert CMD_MESH_ACCESS to a direct commandDavid Woodhouse
2008-01-28libertas: rename and re-type bufvirtualaddr to cmdbufDan Williams
Make it a struct cmd_header, since that's what it is, and clean up the places that it's used. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: convert GET_HW_SPEC to a direct commandDan Williams
2008-01-28libertas: clean up direct command handlingDan Williams
Move direct command handling through __lbs_cmd() over to using the header as the first member of the command structure, and only define the __lbs_cmd() callback in one place rather than 3. Convert boot2 version command to new usage. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: add opaque extra argument to cmd callback functionDavid Woodhouse
This will be useful for letting callbacks do stuff like copying the response into a buffer provided by the caller of lbs_cmd() Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: switch lbs_cmd() to take a callback function pointerDavid Woodhouse
All existing code which sends commands is set up to have some function called with the results, not to get data back. It's more versatile this way, and providing it with a callback function which involves memcpy() is hardly difficult. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: endianness fixesHolger Schurig
Recently I found that that sparse by default doesn't endianness checks. So I changed my compilation habit to be make modules C=1 SUBDIRS=drivers/net/wireless/libertas CHECKFLAGS="-D__CHECK_ENDIAN__" so that I get the little-endian checks from sparse as well. That showed up a good bunch of problems. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: Switch to using a callback function pointer for commandsDavid Woodhouse
2008-01-28libertas: handy function to call firmware commandsHolger Schurig
Using an arbitrary firmware command was actually very painful. One had to change big switch() statements in cmd.c, cmdresp.c, add structs to the big union in "struct cmd_ds_command" and add the define for the CMD_802_11_xxx to the proper place. With this function, this is now much easier. For now, it implements a blocking (a.k.a. CMD_OPTION_WAITFORRSP) way where one deals directly with command requests and response buffers. You can do everything in one place: Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28libertas: remove cmd_ctrl_node->statusHolger Schurig
There was no code that ever did set this variable. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
