path: root/drivers/net/wireless/iwlwifi/mvm/fw.c
2015-11-18iwlwifi: move under intel vendor directoryKalle Valo
Part of reorganising wireless drivers directory and Kconfig. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/asix_common.c net/ipv4/inet_connection_sock.c net/switchdev/switchdev.c In the inet_connection_sock.c case the request socket hashing scheme is completely different in net-next. The other two conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-05iwlwifi: mvm: support using multiple ACs on single HW queueLiad Kaufman
"DQA" is shorthand for "dynamic queue allocation", with the idea of allocating queues per-RA/TID on-demand rather than using shared queues statically allocated per vif. The goal of this is to enable future features (like GO PM) and to improve performance measurements of TX traffic. When RA/TID streams can't be neatly sorted into different AC queues, DQA allows sharing queues for the same RA. This means that DQA allows different ACs may reach the same HW queue. Update the code to allow such queue sharing by having a mapping between the HW queue and the mac80211 queues using it (as this could be more than one queue). Signed-off-by: Liad Kaufman <liad.kaufman@intel.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
2015-10-05iwlwifi: mvm: init card correctly on ctkill exit checkArik Nemtsov
During the CT-kill exit flow, the card is powered up and partially initialized to check if the temperature is already low enough. Unfortunately the init bails early because the CT-kill flag is set. Make the code bail early only for HW RF-kill, as was intended by the author. CT-kill is self-imposed and is not really RF-kill. Fixes: 31b8b343e019 ("iwlwifi: fix RFkill while calibrating") Cc: <stable@vger.kernel.org> [3.18+] Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
2015-09-21iwlwifi: mvm: remove IWL_UCODE_TLV_API_HDC_PHASE_0 TLV flagEmmanuel Grumbach
All the supported firwmares support the new API. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
2015-08-04iwlwifi: mvm: Add FW paging mechanism for the UMAC on SDIOMatti Gottlieb
Family 8000 products has 2 embedded processors, the first known as LMAC (lower MAC) and implements the functionality from previous products, the second one is known as UMAC (upper MAC) and is used mainly for driver offloads as well as new features. The UMAC is typically “less” real-time than the LMAC and is used for higher level controls. The UMAC's code/data size is estimated to be in the mega-byte arena, taking into account the code it needs to replace in the driver and the set of new features. In order to allow the UMAC to execute code that is bigger than its code memory, we allow the UMAC embedded processor to page out code pages on DRAM. When the device is slave on the bus(SDIO) the driver saves the UMAC's image pages in blocks of 32K in the DRAM and sends the layout of the pages to the FW. When the FW wants load / unload pages, it creates an interrupt, and the driver uploads / downloads the page to an address in the a specific address on the device's memory. The driver can support up to 1 MB of pages. Add paging mechanism for the UMAC on SDIO in order to allow the program to use a larger virtual space while using less physical memory on the device itself. Signed-off-by: Matti Gottlieb <matti.gottlieb@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-08-04iwlwifi: mvm: add the ability to trigger only monitor dumpsOren Givon
Change the FW debug trigger tlv to include a monitor only option. Setting this option to true will cause fw dump triggers to only collect monitor data and skip other dumps such as SMEM, SRAM, CSR, PRPH, etc. This option is used when accessing the different parts of the firmware memory is not wanted and can cause unwanted behavior like when debugging TX latency. Signed-off-by: Oren Givon <oren.givon@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-08-04iwlwifi: mvm: print secboot status registers on alive timeoutDor Shaish
Print the CPU1 and CPU2 secured boot status registers from the NIC to indicate a SYSASSERT during secured engine unlocking process on init/protocol image. Signed-off-by: Dor Shaish <dor.shaish@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-08-04iwlwifi: mvm: Add FW paging mechanism for the UMAC on PCIMatti Gottlieb
Family 8000 products has 2 embedded processors, the first known as LMAC (lower MAC) and implements the functionality from previous products, the second one is known as UMAC (upper MAC) and is used mainly for driver offloads as well as new features. The UMAC is typically “less” real-time than the LMAC and is used for higher level controls. The UMAC's code/data size is estimated to be in the mega-byte arena, taking into account the code it needs to replace in the driver and the set of new features. In order to allow the UMAC to execute code that is bigger than its code memory, we allow the UMAC embedded processor to page out code pages on DRAM. When the device is master on the bus(PCI) the driver saves the UMAC's image pages in blocks of 32K in the DRAM and sends the layout of the pages to the FW. The FW can load / unload the pages on its own. The driver can support up to 1 MB of pages. Add paging mechanism for the UMAC on PCI in order to allow the program to use a larger virtual space while using less physical memory on the device. Signed-off-by: Eran Harary <eran.harary@intel.com> Signed-off-by: Matti Gottlieb <matti.gottlieb@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-08-04iwlwifi: add wide firmware command support for notificationsSara Sharon
Add support for extended command id in notification system. Extended command id header contains group id in addition to command id. Signed-off-by: Sara Sharon <sara.sharon@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-08-04iwlwifi: mvm: Enable Rx Checksum hwAvri Altman
TCP software implementation on the host requires extensive computing power. Offloading even some of the TCP/IP stack to the NIC might save a significant overhead. In order to enable this feature on our hw, we need to configure it first. Once done, we mark this capability, to be advertised later to the OS via ieee80211_register_hw. The driver Rx indications for TCP Checksum is integrated within the standard Rx status. The driver responds to those indications as follows: If the frame was tested by hw and checksum ok report CHECKSUM_UNNECESSARY. Otherwise, report CHECKSUM_NONE. Signed-off-by: Avri Altman <avri.altman@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-08-04iwlwifi: remove command header flags fieldJohannes Berg
The 'flags' field really has been reserved in the firmware API for a very long time, probably since 4965. As a consequence, the field is always 0 and checking for a IWL_CMD_FAILED_MSK flag makes no sense. Rename the field to 'reserved', get rid of IWL_CMD_FAILED_MSK and all the code for it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-08-04iwlwifi: mvm: remove command/return value from RX handlersJohannes Berg
In the mvm driver, neither the old command nor the return value are used, so remove them. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-06-26iwlwifi: deprecate -10.ucode for 3160 / 7260 / 7265Sara Sharon
This firmware is not supported anymore - stop loading this firmware. Remove code handling older versions. Signed-off-by: Sara Sharon <sara.sharon@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-06-03iwlwifi: prepare for higher API/CAPA bitsJohannes Berg
Currently, loading the firmware fails when it has higher API or CAPA bits than the driver supports. That's an issue with integration. At the same time, actually using api[0] and capa[0] will become confusing when we also have api[1] and capa[1], and it's almost certain that we'll mix up the bits and use the bits for api[1] with api[0] by accident. Avoid all this by translating the API/CAPA bits to the regular kernel test_bit() format, and also providing wrapper functions. Also use the __bitwise__ facility of sparse to check that we're testing the right one. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-05-28iwlwifi: mvm: handle device start failure correctlyJohannes Berg
If the device fails to start correctly prior to loading the regular runtime firmware (after having run the INIT firmware), treat that error correctly by actually checking the return value of _iwl_trans_start_hw() and stopping the device again before returning an error. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-04-29iwlwifi: mvm: remove deprecated command IDsDavid Spinadel
Signed-off-by: David Spinadel <david.spinadel@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-04-28iwlwifi: mvm: don't power off the device between INIT and OPER firmwaresEran Harary
Our device needs two different firmwares: the INIT firmware and the operational (OPER) firmware. The first one is run when the driver loads and it returns calibrations results as well as the NVM. The second one implements the WiFi protocol. If the wlan interface is not brought up, the device is put to low power state: no firmware will be running. When the interface is brought up, we would run the OPER firmware only and reuse the results of the run of the INIT firmware when the driver was loaded. This is changing with this patch. We now run the INIT firmware every time mac80211 calls start(). The penalty for that is minimal since the INIT firwmare run fast. I now also avoid to power down the device between the INIT and OPER firmware on certains buses. The motivation for this change is that there are components on the device (MFUART) that are triggered by the INIT firmware and need the device to be powered up in order to keep running. Powering the device down between the INIT and OPER firmware would stop these components and prevent them from running again since they are triggered by the INIT firmware only. The new flow allows this and also allows to trigger these components again when the interface is brought up after it has been brought down. Signed-off-by: Eran Harary <eran.harary@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-04-19iwlwifi: mvm: don't stop the FW monitor too earlyEmmanuel Grumbach
When the delay paramatere is provided, we need to stop the collection only after the delay has elapsed. Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-04-02iwlwifi: mvm: do string formatting in debug triggersJohannes Berg
The current code has a lot of duplicates of printing into a buffer (while having to make sure it's NUL-filled and -terminated) and then passing that to the debug trigger collection. Since that's error-prone, instead make the debug trigger collection function take a format string and format arguments (with compiler validity checking) and handle the buffer internally. This makes one behavioural change -- instead of sending the whole buffer to userspace (clearing is needed to not leak stack data) it just passes the actual string (including NUL-terminator.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-03-12iwlwifi: mvm: don't init MCC during CT-killArik Nemtsov
RTNL is not taken during CT-kill so regulatory APIs cannot be invoked. That's fine, since the HW is only brought up to check the temperature during CT-kill. We don't expect Tx or scanning. Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Reviewed-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-03-12iwlwifi: mvm: init country code on init/recoveryArik Nemtsov
During init queue a regulatory update to retrieve the default regulatory settings from FW. If we're during recovery, only replay the current country code to FW, if it exists. Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-03-02iwlwifi: mvm: restart firmware recording when no configuration is setEmmanuel Grumbach
Sometimes the firmware will have a hard coded configuration. In this case, the driver won't find any configuration in the firmware file, and it will have to re-start recording in case it has been stopped. This can't be done by the configuration host command since there is no such host command configured. Do that with the registers instead. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-03-02iwlwifi: mvm: add the cause of the firmware dump in the dumpEmmanuel Grumbach
Now that the firmware dump can be triggered by events in the code and not only the user or an firmware ASSERT, we need a way to know why the firmware dump was triggered. Add a section in the dump file for that. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-03-02iwlwifi: mvm: add framework for triggers for fw dumpEmmanuel Grumbach
Most of the time, the issues we want to debug with the firmware dump mechanism are transient. It is then very hard to stop the recording on time and get meaningful data. In order to solve this, I add here an infrastucture of triggers. The user will supply a list of triggers that will start / stop the recording. We have two types of triggers: start and stop. Start triggers can start a specific configuration. The stop triggers will be able to kick the collection of the data with the currently running configuration. These triggers are given to the driver by the .ucode file - just like the configuration. In the next patches, I'll add triggers in the code. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-03-01iwlwifi: mvm: new Alive / error table APIEmmanuel Grumbach
The new API slightly changes the layout of the version of the firmware - prepare for that. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-03-01iwlwifi: mvm: don't write to DBGC_OUT_CTRL when stopping the recordingEran Harary
Due to HW bug in the DBGC when driver want to stop the dbg recording it should wait 100us before collecting the data instead of write 0 to DBGC_OUT_CTRL. Signed-off-by: Eran Harary <eran.harary@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-02-02iwlwifi: mvm: don't send a command the firmware doesn't knowEmmanuel Grumbach
-9.ucode doesn't know the command SHARED_MEM_CFG yet. Fixes: 04fd2c28226f ("iwlwifi: mvm: add rxf and txf to dump data") Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-01-22iwlwifi: mvm: add support for new LTR commandEmmanuel Grumbach
This new command will give finer granularity to configure the platform. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-01-22iwlwifi: mvm: add rxf and txf to dump dataLiad Kaufman
When the FW is in error status - try to read the RXF and TXF (all of them) and add them to the dump data. This shouldn't happen in non-error statuses, as we don't want to stop the RXF/TXF while they are running. Signed-off-by: Liad Kaufman <liad.kaufman@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2015-01-22iwlwifi: mvm: allow to collect debug data from non-sleepable contextEmmanuel Grumbach
iwl_mvm_fw_dbg_collect allows to collect debug data from the firmware. Most of the firmware interaction is done in non-sleepable context. It makes little sense to force the caller of iwl_mvm_fw_dbg_collect to sleep. Defer the actual collection to a worker so that this function will be able to be called from any context. Reviewed-by: Eran Harary <eran.harary@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-12-28iwlwifi: mvm: add debugfs to trigger fw debug logs collectionEmmanuel Grumbach
This allows to collect the logs even if the firmware hasn't crashed. Of course, crashing the firmware is an option, but this is easier and nicer. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-12-28iwlwifi: mvm: support LnP 1x1 antenna configurationMoshe Harel
The antenna configuration has to be read also from OTP Currently read only from FW image Guideline: An antenna exists only if appears both in FW image & NVM Signed-off-by: Moshe Harel <moshe.harel@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-12-02iwlwifi: mvm: Ability to work with packed usniffer imageEran Harary
The new ucode package format holds also the usniffer images (in addition to the operational images and the TLVs). The driver can load the usniffer image if debug configuration tells it to. Signed-off-by: Eran Harary <eran.harary@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-12-02iwlwifi: mvm: send dbg config hcmds to fw if set in tlvLiad Kaufman
Send all debug-configuration HCMDs that are set in the TLVs to the FW. This may include HCMDs to configure the FW monitor and FW log level, for example. Signed-off-by: Liad Kaufman <liad.kaufman@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-11-24iwlwifi: mvm: add support to MFUART loading notificationChaya Rachel Ivgy
Add support to MFUART loading notification (print notification data with IWL_DEBUG_INFO) Signed-off-by: Chaya Rachel Ivgy <chaya.rachel.ivgi@intel.com> Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-11-24iwlwifi: mvm: implement mac80211 TDLS channel-switch APIsArik Nemtsov
Maintain a TDLS channel-switch state and update it according to notifications from FW and timeouts. Explicitly check all state transitions are valid. When switching is initiated by mac80211, use a delayed work to periodically reschedule it from iwlwifi. Give the FW mac80211 generated TDLS channel-switch request/response templates. It will change appropriate values (switch timings) and Tx them at appropriate times. Enable the channel switch wiphy capability bit when the FW supports it. Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-11-23iwlwifi: mvm: implement UMAC scan APIDavid Spinadel
This API uses second CPU scan commands, and can support multiple simultaneous scans. Adding the new API, and adding new mechanisms to deal with up to 8 simultaneous scans instead of the old scan status. New scan API requires scan configuration for default scan parameters, adding it in _up flow. Also updating scan configuration after updating valid scan antennas via debugfs. Signed-off-by: David Spinadel <david.spinadel@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-11-23Merge remote-tracking branch 'wireless-next/master' into iwlwifi-nextEmmanuel Grumbach
2014-11-03iwlwifi: mvm: handle error from iwl_trans_update_sfEyal Shapira
iwl_trans_update_sf can fail and this wasn't handled. Fix this. Signed-off-by: Eyal Shapira <eyalx.shapira@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-11-03iwlwifi: fix RFkill while calibratingEmmanuel Grumbach
If the RFkill interrupt fires while we calibrate, it would make the firmware fail and the driver wasn't able to recover. Change the flow so that the driver will kill the firmware in that case. Since we have now two flows that are calling trans_stop_device (the RFkill interrupt and the op_mode_mvm_start function) - we need to better sync this. Use the STATUS_DEVICE_ENABLED in the pcie transport in an atomic way to achieve this. This fixes: https://bugzilla.kernel.org/show_bug.cgi?id=86231 CC: <stable@vger.kernel.org> [3.10+] Reviewed-by: Johannes Berg <johannes.berg@intel.com> Reviewed-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-10-23iwlwifi: configure the LTREmmanuel Grumbach
The LTR is the handshake between the device and the root complex about the latency allowed when the bus exits power save. This configuration was missing and this led to high latency in the link power up. The end user could experience high latency in the network because of this. Cc: <stable@vger.kernel.org> [3.10+] Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-09-14iwlwifi: mvm: don't update quota in firmware too oftenJohannes Berg
When updating quota in the firmware, it has to reset quite a bit of internal state, which apparently can have an adverse impact on its operation. Avoid that by only updating the quota command when there are any signification changes, i.e. added/removed bindings or changes in quota that are bigger than 8 TU within a binding. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-09-03iwlwifi: mvm: clarify stop_count, remove transport_stoppedJohannes Berg
The queue handling is a bit unclear - we have an array for stop_count[IWL_MAX_HW_QUEUES] but indices really are the mac80211 queue numbers. Change the array to be only of the right size for mac80211 queues (IEEE80211_MAX_QUEUES) and rename it to be clearer. While at it, also remove the unused transport queue stop bitmap in mvm. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-09-03iwlwifi: add Intel Mobile Communications copyrightJohannes Berg
Our legal structure changed at some point (see wikipedia), but we forgot to immediately switch over to the new copyright notice. For files that we have modified in the time since the change, add the proper copyright notice now. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-05-14iwlwifi: allow dynamic configuration of internal memoryEran Harary
New transport need to configure internal memory based on the data in the (enlarged) alive notification from the firmware. Add a transport API for this. Signed-off-by: Eran Harary <eran.harary@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-05-13iwlwifi: remove CMD_SYNCEmmanuel Grumbach
CMD_SYNC is really 0 which is confusing: if (cmd.flags & CMD_SYNC) is always false. Fix this by simply removing its definition. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-05-11iwlwifi: 8000: add default NVM file name in family 8000Eran Harary
The 8000 family products need a file on the file system which is used as NVM. This file is a must, if no filename is supplied as module parameter, use a default filename. Signed-off-by: Eran Harary <eran.harary@intel.com> Reviewed-by: Dor Shaish <dor.shaish@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-05-06iwlwifi: mvm: prevent nic to powered up at driver loadEran Harary
A few devices aren't allowed to be powered up at driver load time. Add "power_up_nic_in_init" flag to iwl_cfg structure to customize the load flow according to the device. Signed-off-by: Eran Harary <eran.harary@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
2014-04-13iwlwifi: mvm: BT Coex - send priority tables from iwl_send_bt_init_confEmmanuel Grumbach
Calling iwl_send_bt_init_conf for INIT firmware is not a problem, and calling iwl_send_bt_prio_tbl from iwl_send_bt_init_conf allows us to prepare for new API. Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
