This is since my patch:
iwlagn: introduce transport layer and implement rx_init
The IRQ is requested before the locks are initialized, hence the crash.
Initialize the tasklet before we request the IRQ on the way.
Reported-by: Johannes Berg <johannes.berg@intel.com>
Tested-by: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Call iwl_probe with a ready iwl_bus struct. This means that the bus layer
assigns the irq, dev and iwl_bus_ops pointers to iwl_bus before giving it to
iwl_probe.
The device specific struct is allocated together with the common iwl_bus struct
by the bus specific layer. The pointer to the aggregate struct is passed to the
upper layer that holds a pointer to iwl_bus instead of an embedded iw_bus.
The private data given to the PCI subsystem is now iwl_bus and not iwl_priv.
Provide bus_* inliners on the way in order to simplify the syntax.
Rename iwl-pci.h -> iwl-bus.h since it is bus agnostic and represent the
external of the bus layer.
It still holds a pointer to iwl_priv. But hopefully this will disappear at some point.
Also add the multiple inclusion protection to iwl-trans.h that was forgotten.
Move iwl-trans structures to iwl-trans.h
This function is really related to the transport layer - move it.
Basically all the nic_init flow should be in the transport layer.
iwl_prepare_card_hw will move to the transport too in a separate patch.
All the configurations of the HW for AMPDU are now in the transport layer.
kick_nic means to remove the RESET bit from the embedded CPU
Signed-off-by: Wey-Yi Guy <wey-yi.guy@intel.com>
tx start will start the tx queues: basically configure the SCD
Remove the IWLAGN prefix to SCD defines on the way.
Since iwlagn_stop_device was the only caller to the rx_stop / tx_stop,
these two don't need to be API any more.
Also create a new file: iwl-trans-int-pcie.h which will include
the non static functions that are shared among the current pcie transport layer.
Since all the irq / tasklet is now handled in the transport layer, it should
give an API to ensure that all the irq / tasklet have finished running. This
will allow the upper layer to release all its resources.
PCIe doesn't provide any ISR registration API, whereas other buses do.
Hence, we need to move the tasklet and irq to the transport layer to allow this
flexibility.
Split the Tx datapath in two parts:
* the first deals with the Tx cmd composition
* the second attaches the skb + Tx cmd to the queues
This removes the for priv->trans.ops->...
Not needed since the driver split.
Now, there are only two functions to send a host command:
* send_cmd that receives a iwl_host_cmd
* send_cmd_pdu that builds the iwl_host_cmd itself and received flags
The flags CMD_ASYNC / CMD_SYNC / CMD_WANT_SKB are not changed by the API
functions.
Kill the unused flags CMD_SIZE_NORMAL / CMD_NO_SKB on the way.
Code duplication was needed during the move, not needed any more.
Tx stop moves to transport layer.
Rx stop moves to transport layer.
Tx free functions move to the transport layer. Unify the functions that deal with tx queues and cmd queue.
Since the CMD queue is not fully allocated, but uses the q->n_bd / q->window trick, the release flow of TX queue and CMD queue was different.
iwlagn_txq_free_tfd receives now the index of the TFD to be freed, which allows to unify the release flow for all the queues.
These functions allocate all the Tx context. Only the simple tx_init is exported as API.
The transport layer ness to release all rx ressources. This function is an API for it.
The transport layer is responsible for all the queues, DMA rings etc...
This is the beginning of the separation of all the code that is tighly
related to HW design to the aforementioned transport layer.
