path: root/drivers/net/wireless/iwlwifi/iwl-agn-rs.c
2012-08-19iwlwifi: disable greenfield transmissions as a workaroundJohannes Berg
commit 50e2a30cf6fcaeb2d27360ba614dd169a10041c5 upstream. There's a bug that causes the rate scaling to get stuck when it has to use single-stream rates with a peer that can do GF and SGI; the two are incompatible so we can't use them together, but that causes the algorithm to not work at all, it always rejects updates. Disable greenfield for now to prevent that problem. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Tested-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> [bwh: Backported to 3.2: adjust filename] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-06-10iwlwifi: update BT traffic load states correctlyMeenakshi Venkataraman
commit 882dde8eb0d49ce0f853f8f4084dde56a21fe55f upstream. When BT traffic load changes from its previous state, a new LQ command needs to be sent down to the firmware. This needs to be done only once per change. The state variable that keeps track of this change is last_bt_traffic_load. However, it was not being updated when the change had been handled. Not updating this variable was causing a flood of advanced BT config commands to be sent to the firmware. Fix this. Signed-off-by: Meenakshi Venkataraman <meenakshi.venkataraman@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2011-10-14iwlagn: merge station management functionsWey-Yi Guy
After driver split, no need to separate station management functions in two files, merge it Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-14iwlagn: remove un-necessary stepWey-Yi Guy
No need to copy twice. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30iwlagn: iwl-agn-rs: remove unnecessary null check for sta and lq_staGreg Dietsche
both sta and lq_sta are guaranteed to be not null in the calling function so we don't need to check them here. Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-21iwlagn: remove common station privJohannes Berg
Since the driver split there's no more need for shared/non-shared private station data so remove struct iwl_station_priv_common entirely. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-30iwlwifi: iwl-agn-rs.c: remove old commentGreg Dietsche
this comment refers to some code that was removed. Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-29iwlagn: iwl_tid_data moves to iwl-sharedEmmanuel Grumbach
The rate scaling and the transport need to access the data in iwl_tid_data, hence the move. Note that the only component in the upper layer that needs this data is the rate scaling. Refactoring the rate scaling may help to move iwl_tid_data from the shared area to the transport area. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-29iwlagn: enable 11n aggregation without checking traffic loadWey-Yi Guy
Enable HT aggregation when it reach reasonable traffic without checking traffic load which delay enabling the aggregation and lower the throughput but this behavior can be overwrite by module parameter this address https://bugzilla.kernel.org/show_bug.cgi?id=40042 Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-29iwlagn: priv->lock moves to iwl_sharedEmmanuel Grumbach
Since it is used by all the layers, it needs to move to iwl_shared. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-29iwlagn: workqueue moves to iwl_sharedEmmanuel Grumbach
2011-08-29iwlagn: hw_params moves to iwl_sharedEmmanuel Grumbach
2011-08-08iwlagn: remove wireless extensions inclusionsJohannes Berg
linux/wireless.h and net/iw_handler.h headers are for wireless extensions only, so mac80211 drivers shouldn't be including them. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-21iwlagn: testmode fixed rate available for testmode onlyWey-Yi Guy
Move tm_fixed_rate inside CONFIG_IWLWIFI_DEVICE_SVTOOL and only available when the option is enable. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-07-11iwlagn: separate and enhance the fixed rate fromWey-Yi Guy
For testing purpose, we need better control of msc from user application. Separate the fixed_rate between debugfs and testmode and enforce it. Signed-off-by: Kenny Hsu <kenny.hsu@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01iwlagn: change the logging level for aggregation enable checkWey-Yi Guy
Aggregation will not enable if the traffic is lower than the threshold, this is not an error condition, so change the logging level. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-24iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabledWey-Yi Guy
Fix compiling error when CONFIG_MAC80211_DEBUGFS is not enabled drivers/net/wireless/iwlwifi/iwl-agn-rs.c:351: error: 'struct iwl_lq_sta' has no member named 'dbg_fixed_rate' drivers/net/wireless/iwlwifi/iwl-agn-rs.c:1076: error: 'struct iwl_lq_sta' has no member named 'dbg_fixed_rate' Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16Merge branch 'wireless-next-2.6' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-2.6
2011-05-16iwlwifi: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warningStephen Boyd
Enabling DEBUG_STRICT_USER_COPY_CHECKS causes the following warning: In file included from arch/x86/include/asm/uaccess.h:573, from include/net/checksum.h:25, from include/linux/skbuff.h:28, from drivers/net/wireless/iwlwifi/iwl-agn-rs.c:28: In function 'copy_from_user', inlined from 'rs_sta_dbgfs_scale_table_write' at drivers/net/wireless/iwlwifi/iwl-agn-rs.c:3099: arch/x86/include/asm/uaccess_64.h:65: warning: call to 'copy_from_user_overflow' declared with attribute warning: copy_from_user() buffer size is not provably correct presumably due to buf_size being signed causing GCC to fail to see that buf_size can't become negative. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-13iwlagn: remove set but unused varsJohannes Berg
gcc is warning that a few variables in rate scaling are set but never otherwise used. This pointed out a few simplifications. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-05-13iwlagn: add testmode set fixed rate commandWey-Yi Guy
Add support in testmode for setting fixed rate Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-04-07iwlagn: change Copyright to 2011Wey-Yi Guy
2011-04-07iwlagn: remove pointless return variablesJohannes Berg
A number of places just use a variable to return it right away, which is useless, so let's remove the variables there. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-25iwlwifi: add RATE_MCS_RATE_MSKDaniel Halperin
Throughout the code we use rate_n_flags & 0xff to extract the lower byte of the rate_n_flags u32 that contains the information about the rate. Add a #define and remove the use of the magic number. Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-03-25iwlwifi: limit number of attempts for highest HT rateDaniel Halperin
When filling out its rate scale table, iwlwifi repeats the first HT rate IWL_HT_NUMBER_TRY times. The hardware scheduler will stop using aggregation for any frame that fails LINK_QUAL_AGG_DISABLE_START_DEF times. Currently, both these constants equal 3. If iwlwifi probes a faster rate than the link supports, all frames in a (potentially tens of frames large) batch will fail IWL_HT_NUMBER_TRY times. Because this happens to be as large as LINK_QUAL_AGG_DISABLE_START_DEF, all frames will then be sent individually. This leads to a short, but performance-degrading window where the legacy stop-and-wait MAC takes over. Bounding the initial rate by (LINK_QUAL_AGG_DISABLE_START_DEF-1) attempts makes the third try use a lower rate and hence more be likely to succeed. This somewhat mitigates the above described behavior. Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-01-31iwlwifi: use maximum aggregation sizeJohannes Berg
Use the values from the peer to set up the ucode for the right maximum number of subframes in an aggregate. Since the ucode only tracks this per station, use the minimum across all aggregation sessions with this peer. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-01-31iwlagn: adjust rate tableWey-Yi Guy
Minor adjustment for rate scale table Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-12-16iwlwifi: Fix error: struct iwl_lq_sta has no member named dbg_fixed_rateSedat Dilek
While compiling linux-next (next-20101216) I fell over this breakage: ... drivers/net/wireless/iwlwifi/iwl-agn-rs.c: In function ‘iwl_rs_rate_init’: drivers/net/wireless/iwlwifi/iwl-agn-rs.c:2876:8: error: ‘struct iwl_lq_sta’ has no member named ‘dbg_fixed_rate’ dbg_fixed_rate is only used when CONFIG_MAC80211_DEBUGFS is set: [ drivers/net/wireless/iwlwifi/iwl-agn-rs.h ] ... #ifdef CONFIG_MAC80211_DEBUGFS struct dentry *rs_sta_dbgfs_scale_table_file; struct dentry *rs_sta_dbgfs_stats_table_file; struct dentry *rs_sta_dbgfs_rate_scale_data_file; struct dentry *rs_sta_dbgfs_tx_agg_tid_en_file; u32 dbg_fixed_rate; #endif The issue was introduced by commit a1da077bc36368eb7d6312e7e49260f0a3d92c77: "iwlwifi: clear dbg_fixed_rate during init" Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-15mac80211: Add timeout to BA session start APISujith Manoharan
Allow drivers or rate control algorithms to specify BlockAck session timeout when initiating an ADDBA transaction. This is useful in cases where maintaining persistent BA sessions does not incur any overhead. The current timeout value of 5000 TUs is retained for all non ath9k/ath9k_htc drivers. Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-13iwlwifi: clear dbg_fixed_rate during initShanyu Zhao
This prevent bad fixed_rate keeps crashing uCode in an endless loop. Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-11-16iwlagn: support dynamic aggregation for BT coexWey-Yi Guy
Use dynamic aggregation threshold if bt traffic load is high to reduce the impact on aggregated frame. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-07iwlwifi: remove agn rates info thereJohannes Berg
Code and data related to agn bitrates can be part of the agn module rather than being in the core module. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: move agn specific station code thereJohannes Berg
By duplicating a little bit of code between 3945 and agn, we can move a lot of code into an agn specific station management file and thus reduce the amount of code in core that is dead to 3945. before: text data bss dec hex filename 212886 3872 96 216854 34f16 iwlcore.ko 620542 10448 304 631294 9a1fe iwlagn.ko 314013 3264 196 317473 4d821 iwl3945.ko after: text data bss dec hex filename 202857 3872 92 206821 327e5 iwlcore.ko 629102 10448 308 639858 9c372 iwlagn.ko 314240 3264 196 317700 4d904 iwl3945.ko delta: -10029 iwlcore.ko 8560 iwlagn.ko 227 iwl3945.ko so it's a net win even if you have both loaded, likely because a lot of EXPORT_SYMBOLs go away. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-06iwlagn: reduce redundant parameter definitionsWey-Yi Guy
move paramater definitions to a device paramater structure only leaving the device name, which antennas are used and what firmware file to use in the iwl_cfg structure. this will not completely remove the redundancies but greatly reduce them for devices that only vary by name or antennas. the parameters that are more likely to change within a given device family are left in iwl_cfg. also separate bt param structure added to help reduce more. Signed-off-by: Jay Sternberg <jay.e.sternberg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-08-27iwlwifi: move HT configuration data into contextJohannes Berg
A lot of HT configuration semantically belongs into the context, even if right now it will never be different between contexts. Move it so we're better prepared for future changes in mac80211. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-08-25iwlagn: set traffic load based on multiple factorsWey-Yi Guy
Current BT traffic load should based on the following conditions: 1. BT On/Off status 2. Channel announcement enable/disable 3. Curren traffic load report from uCode Need to modify rate scale to down-grade from MIMO to SISO if detected high BT traffic load. Also need to make sure not using chain "B" with high BT traffic or if it is in "full concurrency" mode. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-25iwlwifi: add bt full concurrency supportWey-Yi Guy
Adding the bluetooth full concurrency support for WiFi/BT combo devices. Driver should configure uCode to operate in "full concurrency" mode (via LUT) if both conditions are met: - Antenna Coupling is more than 35dB - WiFi Channel Inhibition Request is hornored by BT Core Currently, there is no antenna coupling information provided by uCode; use module parameter to specified the antenna coupling in dB. When in "full concurrency" mode, driver need to download different LUT to uCode while sending bt configuration command; also, driver need to configure the device operate in 1x1 while in full concurrency mode. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-25iwlagn: let bluetooth traffic load impact rate scaleJohannes Berg
Depending on the amount of bluetooth traffic, using the shared antenna (antenna B) will have adverse impact on both bluetooth and wireless traffic. Add controls to improve the situation by making rate scaling depend on the BT load. When there's high bluetooth traffic load, there's little point in trying to aggregate as BT traffic would disrupt the aggregated frames all the time, so simply don't start sessions then. When BT traffic returns to lower levels, the rate scaling will come here again automatically when wifi traffic is high enough, and then it will be able to successfully enable aggregation. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-24iwlagn: continue perform rate scale when error detectedWey-Yi Guy
If for some reason, the actual link command not matching neither active nor search table; instead of return and not performing rate scale, by-pass the data collection and continue the rate scale process. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-08-24iwlagn: adjust starting action for rate scaleWey-Yi Guy
During rate scale, reset starting action after making action adjustment to avoid the possibility of break out of loop too early. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-08-24iwlwifi: make aggregation time limit configurableWey-Yi Guy
By default, aggregation time limit is 4000 uSec, add the parameter to .cfg to allow this parameter can be configure per device base if needed. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-08-04iwlagn: Improve aggregation failure error messagesAndy Lutomirski
82ca9341763107615a15da6e59b9535d49eb91c3 added scary looking but harmless error messages. Make them clearer and make the actual failure message show up with the same severity as the harmless one. Signed-off-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-25iwlwifi: turn on RTS/CTS after aggregation become operationalWey-Yi Guy
If RTS/CTS protection is needed for HT, wait until get operational notification from mac80211, then inform uCode to switch to RTS/CTS through RXON command. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-06-03mac80211: clean up ieee80211_stop_tx_ba_sessionJohannes Berg
There's no sense in letting anything but internal mac80211 functions set the initiator to anything but WLAN_BACK_INITIATOR, since WLAN_BACK_RECIPIENT is only valid when we have received a frame from the peer, which we react to directly in mac80211. The debugfs code I recently added got this wrong as well. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas_tf/cmd.c drivers/net/wireless/libertas_tf/main.c
2010-05-04iwlwifi: recalculate average tpt if not currentReinette Chatre
We currently have this check as a BUG_ON, which is being hit by people. Previously it was an error with a recalculation if not current, return that code. The BUG_ON was introduced by: commit 3110bef78cb4282c58245bc8fd6d95d9ccb19749 Author: Guy Cohen <guy.cohen@intel.com> Date: Tue Sep 9 10:54:54 2008 +0800 iwlwifi: Added support for 3 antennas ... the portion adding the BUG_ON is reverted since we are encountering the error and BUG_ON was created with assumption that error is not encountered. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-04-30iwlwifi: set AMPDU status variables correctlyDaniel Halperin
The TX status code is currently abusing the ampdu_ack_map field (a bitmap) to count the number of successfully received frames. The comments in mac80211.h show there are actually three different, relevant variables, of which we are currently using two, both incorrectly. Fix this by making - ampdu_ack_len -> the number of ACKed frames (i.e. successes) - ampdu_ack_map -> the bitmap - ampdu_len -> the total number of frames sent (i.e., attempts) to match the header file (and verified with ath9k's usage) and updating Intel's RS code to match. Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
