Merge iwl-{tx,rx,sta,scan,power,eeprom,led,hcmd}.c into common.c .
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
We do not support many contexts.
Also rename config names IWLWIFI_LEGACY to IWLEGACY
More renaming to make code shorter.
Make code shorter.
iwl_legacy prefix result in long function names, what cause that we
have frequent line split and not readable code. Also iwl_foo symbols
are duplicated in iwlwifi driver, what is annoying when editing
kernel tree with cscope.
We do not reset radio anymore, hence don't need that code too.
drivers/net/wireless/iwlegacy/built-in.o:(.rodata+0x29f0): multiple definition of `iwl_rates'
drivers/net/wireless/iwlwifi/built-in.o:(.rodata+0xa68): first defined here
powerpc64-linux-ld: Warning: size of symbol `iwl_rates' changed from 143 in drivers/net/wireless/iwlwifi/built-in.o to 130 in drivers/net/wireless/iwlegacy/built-in.o
drivers/net/wireless/iwlegacy/built-in.o:(.data+0x0): multiple definition of `bt_coex_active'
drivers/net/wireless/iwlwifi/built-in.o:(.data+0x668): first defined here
drivers/net/wireless/iwlegacy/built-in.o:(.rodata+0x750): multiple definition of `iwl_eeprom_band_1'
drivers/net/wireless/iwlwifi/built-in.o:(.rodata+0x27d0): first defined here
drivers/net/wireless/iwlegacy/built-in.o:(.rodata+0x3f0): multiple definition of `iwl_bcast_addr'
drivers/net/wireless/iwlwifi/built-in.o:(.rodata+0x24f8): first defined here
drivers/net/wireless/iwlegacy/built-in.o:(.bss+0x3d48): multiple definition of `iwl_debug_level'
drivers/net/wireless/iwlwifi/built-in.o:(.bss+0x21950): first defined here
Intel WiFi devices 3945 and 4965 now have their own driver in the folder
Add support to build these drivers independently of the driver for
AGN devices. Selecting the 3945 builds iwl3945.ko and iwl_legacy.ko,
and selecting the 4965 builds iwl4965.ko and iwl_legacy.ko. iwl-legacy.ko
contains code shared between both devices.
The 3945 is an ABG/BG device, with no support for 802.11n. The 4965 is a 2x3
ABGN device.
Signed-off-by: Meenakshi Venkataraman <meenakshi.venkataraman@intel.com>
Acked-by: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
