path: root/drivers/net/wireless/iwlegacy/common.c
2015-11-18iwlegacy: move under intel directoryKalle Valo
Part of reorganising wireless drivers directory and Kconfig. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-03-03wireless: Use eth_<foo>_addr instead of memsetJoe Perches
Use the built-in function instead of memset. Miscellanea: Add #include <linux/etherdevice.h> where appropriate Use ETH_ALEN instead of 6 Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-31iwlegacy: use correct structure type name in sizeofJulia Lawall
Correct typo in the name of the type given to sizeof. Because it is the size of a pointer that is wanted, the typo has no impact on compilation or execution. This problem was found using Coccinelle (http://coccinelle.lip6.fr/). The semantic patch used can be found in message 0 of this patch series. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-06-25mac80211: support more than one band in scan requestDavid Spinadel
Some drivers (such as iwlmvm) can handle multiple bands in a single HW scan request. Add a HW flag to indicate that the driver support this. To hold the required data, create a separate structure for HW scan request that holds cfg scan request and data about different parts of the scan IEs. As this changes the mac80211 API, update all drivers using it to use the correct new function type/argument. Signed-off-by: David Spinadel <david.spinadel@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-04-09mac80211: add vif to flush callEmmanuel Grumbach
This will allow the low level driver to make decision based on the vif such as queues etc... Since the vif might be NULL, we can't add it to the tracing functions. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> [fix staging rtl8821ae driver] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-24iwlegacy: properly enable power savingStanislaw Gruszka
Even if we mark PS on, device still worked in normal mode. Patch corrects that and now we send proper powertable command to device, which put it in sleep mode when PS is on. Reported-and-tested-by: Tino Keitel <tino.keitel@tikei.de> Tested-by: Pedro Francisco <pedrogfrancisco@gmail.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-01-03wireless: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Christian Lamparter <chunkeey@googlemail.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-01-03iwlegacy: use ether_addr_equal_64bitsJulia Lawall
Ether_addr_equal_64bits is more efficient than ether_addr_equal, and can be used when each argument is an array within a structure that contains at least two bytes of data beyond the array. The structures involved are: ieee80211_hdr defined in include/linux/ieee80211.h, il_priv defined in drivers/net/wireless/iwlegacy/common.h and il_rxon_cmd defined in drivers/net/wireless/iwlegacy/commands.h This was done using Coccinelle (http://coccinelle.lip6.fr/). Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-11-25cfg80211: consolidate passive-scan and no-ibss flagsLuis R. Rodriguez
These two flags are used for the same purpose, just combine them into a no-ir flag to annotate no initiating radiation is allowed. Old userspace sending either flag will have it treated as the no-ir flag. To be considerate to older userspace we also send both the no-ir flag and the old no-ibss flags. Newer userspace will have to be aware of older kernels. Update all places in the tree using these flags with the following semantic patch: @@ @@ -NL80211_RRF_PASSIVE_SCAN +NL80211_RRF_NO_IR @@ @@ -NL80211_RRF_NO_IBSS +NL80211_RRF_NO_IR @@ @@ -IEEE80211_CHAN_PASSIVE_SCAN +IEEE80211_CHAN_NO_IR @@ @@ -IEEE80211_CHAN_NO_IBSS +IEEE80211_CHAN_NO_IR @@ @@ -NL80211_RRF_NO_IR | NL80211_RRF_NO_IR +NL80211_RRF_NO_IR @@ @@ -IEEE80211_CHAN_NO_IR | IEEE80211_CHAN_NO_IR +IEEE80211_CHAN_NO_IR @@ @@ -(NL80211_RRF_NO_IR) +NL80211_RRF_NO_IR @@ @@ -(IEEE80211_CHAN_NO_IR) +IEEE80211_CHAN_NO_IR Along with some hand-optimisations in documentation, to remove duplicates and to fix some indentation. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> [do all the driver updates in one go] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-08-02iwl4965: reset firmware after rfkill offStanislaw Gruszka
Using rfkill switch can make firmware unstable, what cause various Microcode errors and kernel warnings. Reseting firmware just after rfkill off (radio on) helped with that. Resolve: https://bugzilla.redhat.com/show_bug.cgi?id=977053 Reported-and-tested-by: Justin Pearce <whitefox@guardianfox.net> Cc: stable@vger.kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-06-12iwl4965: workaround for firmware frame tx rejectionStanislaw Gruszka
Firmware can reject to transmit frame on passive channel, when it did not yet received any frame with valid CRC on that channel. Workaround this problem in the driver. Tested-by: Jake Edge <jake@lwn.net> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-05-17iwlegacy: remove inline marking of EXPORT_SYMBOL functionsDenis Efremov
EXPORT_SYMBOL and inline directives are contradictory to each other. The patch fixes this inconsistency. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Denis Efremov <yefremov.denis@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-04-24Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2013-04-10Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next Conflicts: drivers/net/wireless/ath/carl9170/debug.c drivers/net/wireless/ath/carl9170/main.c net/mac80211/ieee80211_i.h
2013-04-10Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/rt2x00/rt2x00pci.c net/mac80211/sta_info.c net/wireless/core.h
2013-03-26net: wireless: iwlegacy: add CONFIG_PM_SLEEP to suspend/resume functionsJingoo Han
Add CONFIG_PM_SLEEP to suspend/resume functions to fix the following build warning when CONFIG_PM_SLEEP is not selected. This is because sleep PM callbacks defined by SIMPLE_DEV_PM_OPS are only used when the CONFIG_PM_SLEEP is enabled. drivers/net/wireless/iwlegacy/common.c:4894:1: warning: 'il_pci_suspend' defined but not used [-Wunused-function] drivers/net/wireless/iwlegacy/common.c:4912:1: warning: 'il_pci_resume' defined but not used [-Wunused-function] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-25Merge branch 'for-john' of ↵John W. Linville
2013-03-25mac80211: Use a cfg80211_chan_def in ieee80211_hw_conf_chanKarl Beldan
Drivers that don't use chanctxes cannot perform VHT association because they still use a "backward compatibility" pair of {ieee80211_channel, nl80211_channel_type} in ieee80211_conf and ieee80211_local. Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com> [fix kernel-doc] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-20Merge branch 'master' of ↵John W. Linville
2013-03-18mac80211: pass queue bitmap to flush operationJohannes Berg
There are a number of situations in which mac80211 only really needs to flush queues for one virtual interface, and in fact during this frames might be transmitted on other virtual interfaces. Calculate and pass a queue bitmap to the driver so it knows which queues to flush. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-17drivers:net: dma_alloc_coherent: use __GFP_ZERO instead of memset(, 0)Joe Perches
Reduce the number of calls required to alloc a zeroed block of memory. Trivially reduces overall object size. Other changes around these removals o Neaten call argument alignment o Remove an unnecessary OOM message after dma_alloc_coherent failure o Remove unnecessary gfp_t stack variable Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-15drivers:net: Remove dma_alloc_coherent OOM messagesJoe Perches
I believe these error messages are already logged on allocation failure by warn_alloc_failed and so get a dump_stack on OOM. Remove the unnecessary additional error logging. Around these deletions: o Alignment neatening. o Remove unnecessary casts of dma_alloc_coherent. o Hoist assigns from ifs. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-11iwlegacy: fix sparse warningsStephen Hemminger
Make local functions and tables static. Make ops table Mark 3945 ops as read_mostly. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-02-15Merge branch 'for-john' of ↵John W. Linville
2013-02-15mac80211: stop modifying HT SMPS capabilityJohannes Berg
Instead of modifying the HT SMPS capability field for stations, track the SMPS mode explicitly in a new field in the station struct and use it in the drivers that care about it. This simplifies the code using it. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-14iwlegacy: more checks for dma mapping errorsStanislaw Gruszka
This patch check output of pci_map_single() calls. I missed them on my previous patch "iwlegacy: check for dma mapping errors", which fixed only pci_map_page() calls. To handle remaining possible dma mappings errors, we need to rearrange ilXXXX_tx_skb() and il_enqueue_hcmd() functions. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-28Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/ath/ath9k/main.c drivers/net/wireless/iwlwifi/dvm/tx.c
2013-01-22iwlegacy: fix IBSS cleanupStanislaw Gruszka
We do not correctly change interface type when switching from IBSS mode to STA mode, that results in microcode errors. Resolves: https://bugzilla.redhat.com/show_bug.cgi?id=886946 Reported-by: Jaroslav Skarvada <jskarvad@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-07iwlegacy: add flush callbackStanislaw Gruszka
Dump implementation of flush, which just wait until all TX queues become empty. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-07iwlegacy: Use standard #defines for PCIe Capability ASPM fieldsBjorn Helgaas
Use the standard #defines rather than creating local definitions for PCIe Capability ASPM fields. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Stanislaw Gruszka <sgruszka@redhat.com>
2012-12-07iwlegacy: collapse wrapper for pcie_capability_read_word()Bjorn Helgaas
il_pcie_link_ctl() has only one call site and no longer provides any useful abstraction, so collapse it into the caller. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Stanislaw Gruszka <sgruszka@redhat.com>
2012-09-24iwlegacy: use eth_broadcast_addrJohannes Berg
Instead of copying from a constant array (which is still needed for other purposes) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-08-10iwlegacy: clean up suspend/resumeJohannes Berg
There's no need to export the il_pci_suspend and il_pci_resume functions since they're only referenced from il_pm_ops. The latter can also be defined using SIMPLE_DEV_PM_OPS instead of open-coding it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-12Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next Conflicts: drivers/net/wireless/iwmc3200wifi/cfg80211.c drivers/net/wireless/mwifiex/cfg80211.c
2012-07-12mac80211: add time synchronisation with BSS for assocJohannes Berg
Some drivers (iwlegacy, iwlwifi and rt2x00) today use the bss_conf.last_tsf value. By itself though that value is completely worthless since it may be ancient. What really is needed is synchronisation between some device time and the TSF. To clarify this, rename bss_conf.last_tsf to sync_tsf and add sync_device_ts which is obtained from rx_status which gets a new field device_timestamp for this purpose. This is intentionally not using the mactime field since that is used for other things and in IBSS is expected to sync with the IBSS's TSF which isn't necessarily true for the device timestamp. Also, since we have the information and it's useful even before the connection has been established, give all the timing details to the driver before authenticating. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: net/mac80211/mlme.c
2012-07-09iwlegacy: always monitor for stuck queuesStanislaw Gruszka
This is iwlegacy version of: commit 342bbf3fee2fa9a18147e74b2e3c4229a4564912 Author: Johannes Berg <johannes.berg@intel.com> Date: Sun Mar 4 08:50:46 2012 -0800 iwlwifi: always monitor for stuck queues If we only monitor while associated, the following can happen: - we're associated, and the queue stuck check runs, setting the queue "touch" time to X - we disassociate, stopping the monitoring, which leaves the time set to X - almost 2s later, we associate, and enqueue a frame - before the frame is transmitted, we monitor for stuck queues, and find the time set to X, although it is now later than X + 2000ms, so we decide that the queue is stuck and erroneously restart the device Cc: stable@vger.kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-28iwlegacy: print how long queue was actually stuckPaul Bolle
Every now and then, after resuming from suspend, the iwlegacy driver prints iwl4965 0000:03:00.0: Queue 2 stuck for 2000 ms. iwl4965 0000:03:00.0: On demand firmware reload I have no idea what causes these errors. But the code currently uses wd_timeout in the first error. wd_timeout will generally be set at IL_DEF_WD_TIMEOUT (ie, 2000). Perhaps printing for how long the queue was actually stuck can clarify the cause of these errors. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-10drivers/net: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-26iwlegacy: fix BSSID settingStanislaw Gruszka
Current commit 0775f9f90cdaf40fbf69b3192b3dddb2b3436f45 "mac80211: remove spurious BSSID change flag" exposed bug on iwlegacy, that we do not set BSSID address correctly and then device was not able to receive frames after successful associate. On the way fix scan canceling comment. Apparently ->post_associate() do cancel scan itself, but scan cancel on BSS_CHANGED_BSSID is needed. I'm not sure why, but when I removed it, I had frequent auth failures: wlan4: send auth to 54:e6:fc:98:63:fe (try 1/3) wlan4: send auth to 54:e6:fc:98:63:fe (try 2/3) wlan4: send auth to 54:e6:fc:98:63:fe (try 3/3) wlan4: authentication with 54:e6:fc:98:63:fe timed out Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-26iwlegacy: do not nulify il->vif on resetStanislaw Gruszka
This il->vif is dereferenced in different part of iwlegacy code, so do not nullify it. This should fix random crashes observed in companion with microcode errors i.e. crash in il3945_config_ap(). Additionally this should address also WARNING: at drivers/net/wireless/iwlegacy/common.c:4656 il_mac_remove_interface at least one of the possible reasons of that warning. Cc: stable@vger.kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-13mac80211: rename bss_conf timestamp to last_tsfJohannes Berg
This value is not really very useful by itself, yet some drivers (including iwlwifi until I can figure out what it should do) use it. At least rename it to "last_tsf" to indicate the meaning and add a note that it may be really old. I suspect the value may become useful combined with the rx_status->mactime, but we don't (yet) store that value and pass it to the driver. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-22iwlegacy: s/il_txq_mem/il_free_txq_mem/gStanislaw Gruszka
Previous name was confusing. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-22iwlegacy: s/S_RF_KILL_HW/S_RFKILL/gStanislaw Gruszka
2012-02-22iwlegacy: small queue initializations cleanupStanislaw Gruszka
2012-02-22iwlegacy: check correct il_poll_bit error valueStanislaw Gruszka
2012-02-22iwlegacy: do not grab nic access if rfkillStanislaw Gruszka
If rfkill is on il_grab_nic_access() fail and we can not write to the various registers during stop procedure. Write to those registers unconditionally instead. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-22iwlegacy: improve mac operation debuggability a bitStanislaw Gruszka
2012-02-22iwlegacy: get rid of tx/rx traffic logStanislaw Gruszka
The same data can be gathered using monitor mode. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-22iwlegacy: merge all ops structures into oneStanislaw Gruszka
