path: root/drivers/net/wireless/iwlegacy/commands.h
2015-11-18iwlegacy: move under intel directoryKalle Valo
Part of reorganising wireless drivers directory and Kconfig. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2014-02-24iwlegacy: properly enable power savingStanislaw Gruszka
Even if we mark PS on, device still worked in normal mode. Patch corrects that and now we send proper powertable command to device, which put it in sleep mode when PS is on. Reported-and-tested-by: Tino Keitel <tino.keitel@tikei.de> Tested-by: Pedro Francisco <pedrogfrancisco@gmail.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-05-16wireless: move crypto constants to ieee80211.hJohannes Berg
mac80211 and the Intel drivers all define crypto constants, move them to ieee80211.h instead. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-01iwl4965: report A-MPDU statusChristian Lamparter
This patch is based on "iwlwifi: report A-MPDU status". (12bf6f45d1703858) Since the firmware will give us an A-MPDU bit and only a single PHY information packet for all the subframes in an A-MPDU, we can easily report the minimal A-MPDU information for radiotap. Cc: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-30iwlegacy: fix antenna bitmaskChristian Lamparter
This patch is based on "iwlwifi: fix antenna bitmask". (362b0563b28506d53) Like the new iwlagn devices, the old 4965N device only supports a maximum of three antennas. Hence only three bits are used, the fourth bit is likely the A-MPDU indicator. Cc: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-15iwlegacy: indentions and whitespacesStanislaw Gruszka
Process iwlegacy source files using: indent -npro -l500 -nhnl indent -npro -kr -i8 -ts8 -sob -l80 -nbbo -ss -ncs -cp1 -il0 -psl Plus manual compilation fixes. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
2011-11-15iwlegacy: merge iwl-power.h into common.hStanislaw Gruszka
2011-11-15iwlegacy: merge common header filesStanislaw Gruszka
2011-11-15iwlegacy: rename iwl-commands.h to commands.hStanislaw Gruszka
On the way remove also not needed iwl-fh.h include. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
