Part of reorganising wireless drivers directory and Kconfig.
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Even if we mark PS on, device still worked in normal mode. Patch
corrects that and now we send proper powertable command to device,
which put it in sleep mode when PS is on.
Reported-and-tested-by: Tino Keitel <tino.keitel@tikei.de>
Tested-by: Pedro Francisco <pedrogfrancisco@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
mac80211 and the Intel drivers all define crypto
constants, move them to ieee80211.h instead.
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This patch is based on "iwlwifi: report A-MPDU status".
(12bf6f45d1703858)
Since the firmware will give us an A-MPDU bit and
only a single PHY information packet for all the
subframes in an A-MPDU, we can easily report the
minimal A-MPDU information for radiotap.
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
This patch is based on "iwlwifi: fix antenna bitmask".
(362b0563b28506d53)
Like the new iwlagn devices, the old 4965N device only
supports a maximum of three antennas. Hence only three
bits are used, the fourth bit is likely the A-MPDU
indicator.
Process iwlegacy source files using:
indent -npro -l500 -nhnl
indent -npro -kr -i8 -ts8 -sob -l80 -nbbo -ss -ncs -cp1 -il0 -psl
Plus manual compilation fixes.
On the way remove also not needed iwl-fh.h include.
