path: root/drivers/net/wireless/ipw2200.h
2008-03-25ipw2200 annotations and fixesAl Viro
a) a bunch of printks in error-handling assums that ->status is big-endian. b) bitfields trouble c) missing annotations NB: a bunch of structs is declared packed for no good reason, AFAICS. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28ipw2200: do not byteswap struct ipw_associateAl Viro
keep it little-endian, update places that use its members Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28ipw2200 trivial annotationsAl Viro
2008-01-28eliminate byteswapping in struct ieee80211_qos_parametersAl Viro
Make it match the on-the-wire endianness, eliminate byteswapping. The only driver that used this sucker (ipw2200) updated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] ipw2200: batch non-user-requested scan result notificationsDan Williams
ipw2200 makes extensive use of background scanning when unassociated or down. Unfortunately, the firmware sends scan completed events many times per second, which the driver pushes directly up to userspace. This needlessly wakes up processes listening for wireless events many times per second. Batch together scan completed events for non-user-requested scans and send them up to userspace every 4 seconds. Scan completed events resulting from an SIOCSIWSCAN call are pushed up without delay. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10Clean up duplicate includes in drivers/net/Jesper Juhl
This patch cleans up duplicate includes in drivers/net/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-08-29[PATCH] ipw2200: enable wireless extension passive scanZhu Yi
This patch enables the ipw2200 driver to support passive scanning as offered by the wireless extensions. For this, I enhanced the ipw_wx_set_scan function in such a way that it differentiates between a passive and an active scan request. Additionally, I added a new function called ipw_request_passive_scan that is similiar to the ipw_request_scan function to perform passive scans. Last but not least, I added a field (in fact it is a work_struct struct) called request_passive_scan to the ipw_priv struct. Signed-off-by: Thomas King <king@informatik.uni-mannheim.de> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-29[PATCH] ipw2200: Fix kernel Oops if cmdlog debug is enabledZhu Yi
When command error log debug is enabled, we write every host command and parameters into a buffer. But we didn't alloc the parameter buffer for this case. The patch adds struct cmdlog_host_cmd so that the buffer is allocated from the stack. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-29[PATCH] ipw2200: remove unused struct ipw_rx_bufferZhu Yi
2006-08-29[PATCH] ipw2200: always enable frequently used debugging codeZhu Yi
Moving part of the debugging code from IPW_DEBUG to IPW_LL_DEBUG (low level debugging) and make IPW_DEBUG be always enabled. IPW_LL_DEBUG still needs to be enabled by selecting CONFIG_IPW2200_DEBUG. But it is highly deprecated for normal users since it adds higher debug verbosity in driver hot paths. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-06-15[PATCH] ipw2200 locking fixZhu Yi
Well, this is not 100% if when the card fires two consecutive interrupts. Though unlikely, it's better to protect early than seeing some "weird" bugs one day. I proposed attached patch. If you can help to test, that will be appreciated (I cannot see the lockdep warning on my box somehow). Cc: Frederik Deweerdt <deweerdt@free.fr> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-04-24[PATCH] ipw2200: rename CONFIG_IEEE80211_RADIOTAP to CONFIG_IPW2200_RADIOTAPZhu Yi
2006-04-24[PATCH] ipw2200: Enable rtap interface for RF promiscuous mode while associatedZhu Yi
With this patch, a new promiscuous mode is enabled. If the module is loaded with the rtap_iface=1 module parameter, two interfaces will be created (instead of just one). The second interface is prefixed 'rtap' and provides received 802.11 frames on the current channel to user space in a radiotap header format. Example usage: % modprobe ipw2200 rtap_iface=1 % iwconfig eth1 essid MyNetwork % dhcpcd eth1 % tcpdump -i rtap0 If you do not specify 'rtap_iface=1' then the rtap interface will not be created and you will need to turn it on via: % echo 1 > /sys/bus/pci/drivers/ipw2200/*/rtap_iface You can filter out what type of information is passed to user space via the rtap_filter sysfs entry. Currently you can tell the driver to transmit just the headers (which will provide the RADIOTAP and IEEE 802.11 header but not the payload), to filter based on frame control type (Management, Control, or Data), and whether to report transmitted frames, received frames, or both. The transmit frame reporting is based on a patch by Stefan Rompf. Filters can be get and set via a sysfs interface. For example, set the filter to only send headers (0x7), don't report Tx'd frames (0x10), and don't report data frames (0x100): % echo 0x117 > /sys/bus/pci/drivers/ipw2200/*/rtap_filter All your packets are belong to us: % tethereal -n -i rtap0 Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-04-24[PATCH] ipw2200: Exponential averaging for signal and noise LevelZhu Yi
This patch replaces sliding averaging by exponential averaging for reporting the wireless statistics for signal and noise level for ipw2200. See details from: http://www.ces.clemson.edu/linux/ipw2200_averages.shtml Signed-off-by: Bill Moss <bmoss@clemson.edu> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-17[PATCH] ipw2x00: expend Copyright to 2006Zhu Yi
2006-03-17[PATCH] ipw2200: wireless extension sensitivity threshold supportOlivier Hochreutiner
The patch allows the user to set the handover threshold, i.e. the number of consecutively missed beacons that will trigger a roaming attempt. The disassociation threshold is set to 3 times the handover threshold. Signed-off-by: Olivier Hochreutiner <olivier.hochreutiner@epfl.ch> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-17[PATCH] ipw2200: Enables the "slow diversity" algorithmCahill, Ben M
This forces one antenna or the other, if the background noise is significantly quieter in one than the other. It favors the quieter antenna, and won't kick in unless the difference is significant. Signed-off-by: Cahill, Ben M <ben.m.cahill@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-17[PATCH] ipw2200: Set a meaningful silence threshold valueCahill, Ben M
Set a meaningful silence threshold value (replacing our previous "0" default), which gets rid of the gratuitous "Link deterioration" notifications that we've been receiving from firmware. This notification feature tells the driver information to help it determine when to pre-emptively restart the firmware/ucode in anticipation of firmware errors! But since setting this new threshold, I haven't seen any such notifications. At least it keeps the logs a little less busy. Signed-off-by: Cahill, Ben M <ben.m.cahill@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-17[PATCH] ipw2200: use generic ieee80211_get_hdrlen() to get packet lengthZhu Yi
replace ipw2200 specific frame_hdr_len() with generic ieee80211 routine ieee80211_get_hdrlen() Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-30[PATCH] ipw2200: Semaphore to mutexes conversionZhu Yi
The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Ronald Bultje <rbultje@ronald.bitfreak.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Yi Zhu <yi.zhu@intel.com> Cc: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-30[PATCH] ipw2200: remove white space and better format the codeZhu Yi
2006-01-30[PATCH] ipw2200: stack reductionZhu Yi
Checking the stack usage of my kernel, showed that ipw2200 had a few bad offenders. This is on i386 32-bit: 0x00002876 ipw_send_associate: 544 0x000028ee ipw_send_associate: 544 0x000027dc ipw_send_scan_request_ext: 520 0x00002864 ipw_set_sensitivity: 520 0x00005eac ipw_set_rsn_capa: 520 The reason is the host_cmd structure is large (500 bytes). All other functions currently using ipw_send_cmd() suffer from the same problem. This patch introduces ipw_send_cmd_simple() for commands with no data transfer, and ipw_send_cmd_pdu() for commands with a data payload and makes the payload a pointer to the buffer passed in from the caller. As an added bonus, the diffstat looks like this: ipw2200.c | 260 +++++++++++++++++++++----------------------------------------- ipw2200.h | 2 2 files changed, 92 insertions(+), 170 deletions(-) and it shrinks the module a lot as well: Before: text data bss dec hex filename 75177 2472 44 77693 12f7d drivers/net/wireless/ipw2200.ko After: text data bss dec hex filename 61363 2488 44 63895 f997 drivers/net/wireless/ipw2200.ko So about a ~18% reduction in module size. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-30[PATCH] ipw2200: use jiffies_to_msec() wherever possibleZhu Yi
This substitutes Linux jiffies_to_msec() wherever there is a computation for determining milliseconds from jiffies, following lead from ieee80211 code. And it does a little cleanup. "it's" == "it is" ... "its" == possessive "it". Indulge me. ;-) Signed-off-by: Cahill, Ben M <ben.m.cahill@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-30[PATCH] ipw2200: Bluetooth coexistence supportZhu Yi
I've added a new module param "bt_coexist" which defaults to OFF. This does not seem to fix the firmware restarts, but it does do "the right thing" and disables something that we were enabling by default: signaling the Bluetooth h/w which channel we're on (whether or not the BT h/w was out there). Signed-off-by: Ben M Cahill <ben.m.cahill@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-30[PATCH] ipw2200: Add LEAP authentication algorithm supportZhu Yi
Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-30[PATCH] ipw2200: Fix indirect SRAM/register 8/16-bit write routinesZhu Yi
The indirect SRAM/register 8/16-bit write routines are broken for non-dword-aligned destination addresses. Fortunately, these routines are, so far, not used for non-dword-aligned destinations, but here's a patch that fixes them, anyway. The attached patch also adds comments for all direct/indirect I/O routine variations. Signed-off-by: Ben M Cahill <ben.m.cahill@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-30[PATCH] drivers/net/wireless/ipw2200: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global functions static - "extern inline" -> "static inline" - #if 0 the unused global function ipw_led_activity_on() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-12-01[PATCH] Duplicate IPW_DEBUG option for ipw2100 and 2200Brice Goglin
There are currently two IPW_DEBUG options in drivers/net/wireless/Kconfig (one for ipw2100 and one for ipw2200). The attached patch splits it into IPW2100_DEBUG and IPW2200_DEBUG. Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Cc: "James P. Ketrenos" <ipw2100-admin@linux.intel.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-09Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07Fixes missed beacon logic in relation to on-network AP roaming.Ben Cahill
2005-11-07Fix 'Driver using old /proc/net/wireless support, please fix driver !' message.Benoit Boissinot
Wireless extensions moved the get_wireless_stats handler from being in net_device into wireless_handler. Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Adds radiotap support to ipw2200 in monitor mode..Mike Kershaw
Signed-off-by: Mike Kershaw <dragorn@kismetwireless.net> Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Added wait_state wakeup on scan completion.James Ketrenos
Fixed copyright date in ipw2200.h Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Added cmdlog in non-debug systems.James Ketrenos
You can now specify via the module parameter 'cmdlog' to allocate a ring buffer for caching host commands sent to the firmware. They can then be dumped at any time via the sysfs entry 'cmd_log' Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Switched firmware error dumping so that it will capture a log availableJames Ketrenos
via sysfs even if debugging disabled. When a firmware error is captured, it will be dumped to the kernel log (if debug enabled) and captured in memory to be retrieved via sysfs. If an error has already been captured, subsequent errors will be dropped. The existing error can be cleared by writing to the error log entry. Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Changed default # of missed beacons to miss before disassociation to 24James Ketrenos
(vs. 9 which is too low in most environments) Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07[bug 667] Fix the notorious "No space for Tx" bug.Zhu Yi
We send SYSTEM_CONFIG command after the TGI_KEY command if hardware encryption is enabled. It sometimes causes a firmware stall (firmware doesn't respond to any request) and finally bungs up the Tx send queue. The solution is to send SYSTEM_CONFIG command in the post association stage from a workqueue. Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Catch ipw2200 up to equivelancy with v1.0.5James Ketrenos
* Fixed #452 problem with setting retry limit (thanks to Hong Liu) * Fixed #592 race condition during association causing firmware errors * Fixed #602 problem with building in 64-bit environment * Fixed #625 problem with SCAN_REQUEST_EXT sometimes failing * Fixed #645 problem with bit rate not decreasing when moving laptop farther from AP * Fixed #656 problem with 'iwconfig eth1 mode auto' and 'modprobe' locking the system * Fixed #667 problem with "No space for Tx" for hwcrypto=1 * Fixed #685 kernel panic in rmmod caused by led work is still queued * Fixed #695 problem with network doesn't reassociate after suspend/resume * Fixed #701 problem with 'iwprvi sw_reset' not resetting the card from monitor mode * Fixed #710 problem with monitor mode being used after a WEP key has been configured * Fixed network->mode vs. priv->ieee->iw_mode checking (thanks to Ben Cahill) * Fixed "Unknown management packet %d" warning * Fixed setting channels multiple times in monitor mode causes scan stopped * Fixed ipw_wx_sw_reset doesn't switch firmware if mode is changed. * Add duplicate packet checking code (kill ping DUP! and TKIP replay warning) * Fix hardware encryption (both WEP and AES) doesn't work with fragmentation. Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Catch ipw2200 up to equivelancy with v1.0.4James Ketrenos
* Fixed #627 problem with open APs not working with wpa_supplicant * Fixed #632 problem with 'txpower auto' setting power incorrectly (thanks to Kai Groner) * Fixed #634 problem with 'iwconfig eth1 frag 0' hanging the shell * Fixed problem with adapter not fully powering off during suspend to RAM or when module unloaded. * Fixed #645 problem with turning fixed rates off not taking effect until you reload the driver * Fixed problem with firmware restart if wpa_supplicant was used to set a key that wasn't exactly 5 or 13 bytes in length. * Fixed #623 Added iwpriv sw_reset extension to reset sw parameters * Added managment frame export to user space with frame statistics * Fixed #652 Modified the driver to load the EEPROM data even if RF KILL is active during driver load * Global s:CX2_:IPW_:g to make code more consistent * Fixed #572 problem with setting txpower to auto * Fixed #656 problem with kernel oops if mode auto; modprobe -r ipw2200 * Added QoS (CONFIG_IPW_QOS) support. This is being actively developed but is the first step in getting WMM support into the driver and the kernel. * Fixed some race conditions with channel changes, association, and scan abort that could periodically cause a firmware restart. * Added some extensions to export scan and network statistics to user space (exposed through speed_scan and net_stats sysfs entries) * Fixed a few bugs in how monitor mode was supported (scan lists weren't quite right) * Updated the firmware requirement from 2.2 to 2.3 which supports monitor mode. Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Catch ipw2200 up to equivelancy with v1.0.3James Ketrenos
* Fix #616 problem with OOPS on module load (thanks to Yi Zhu) * Fixed problem with led module parameter being described as 'auto_create' * Added support to merge between adhoc networks (thanks to Mohamed Abbas) * Added semaphore lock at the driver's entry points to protect against re-entry (thanks to Mohamed Abbas) * Added semaphore lock to background scheduled driver actions (thanks to Mohamed Abbas) * Changed how signal quality is reported for scan output (thanks to Peter Jones) * Fixed how high/low clamp values of signal quality are reported so a more consistent ramp is provided (thanks to Bill Moss) * Fix #624 problem with duplicate addresses (again) (thanks to Bernard Blackham) * Fix #385 problem with fragmentation and certain sized packets (thanks to Mohamed Abbas) * Modified iwconfig network name if RF kill is enabled to say 'radio off' * Fix #382 problem with driver not responding to probe requests in Ad-Hoc mode (thanks to Mohamed Abbas) Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Catch ipw2200 up to equivelancy with v1.0.2James Ketrenos
Removed unneeded parenthesis around numeric constant defines Added support for iwspy Put in fix for Ad-Hoc mode not passing through all packets (thanks to KKH) Put in fix for fragmentation not working for fragment sizes between 441-464 bytes (thanks to Mohamed Abbas) Fixed #592 problem of CONFIG_IEEE80211_WPA_MODULE not including WPA support into the driver -- fixed as a result of no longer limiting WPAs inclusion Fixed #594 problem with user rates mask causing lack of association if AP mandatory rate is masked out. We now add back in as a supported rate any mandatory rate. Fixed #597 kernel oops due to calling dev_kfree_skb on an skb multiple times. Added code to control LEDs that can be controlled through the wireless NIC (vs. non-wireless HW interfaces) -- this is currently disabled by default due to reports by some users of it hanging their laptop. Added some more debug messages around fragmentation logic Added locking around STATUS_HCMD_ACTIVE to prevent re-entry race conditions Moved ipw_adapter_restart to only execute on the priv->workqueue to keep keyboard errors from occuring during adapter restart Added CFG_BACKGROUND_SCAN to easily allow people to play with background scanning implementations Modified WPA logic to send WPA IE if one is set (vs. being based on wpa_enabled) Modified scan result logic to report WPA and RSN IEs if set (vs. being based on wpa_enabled) Fixed issues with endianess compatability between the host and wireless adapter (thanks to York Liu and Yi Zhu) Fixed problem with Ad-Hoc network creation causing a firmware error if a scan was actively running (thanks to Mohamed Abbas) Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-11-07Catch ipw2200 up to equivelancy with v1.0.1James Ketrenos
This commit contains the following fixes: Fixed #559: iwconfig rate support (thanks to Florian Hackenberger) Improved link signal quality calculation (thanks to Bill Moss) Fixed a problem with sensitivity threshold during association Added iwpriv for turning forcing long preamble support: % iwpriv eth1 set_preamble 1|0 Fixed #542 and #377 support for short preamble Fixed locked BSSID reporting channel number (thanks to Pedro Ramalhais) Fixed type-o with scan watchdog timeout message (thanks to Pedro Ramalhais) Changed logic for displaying get_mode output so the code is easier to follow (thanks to Pedro Ramalhais) Added initial support for WPA (thanks to Yi Zhu) -- tested with wpa_supplicant (either tip w/ ipw driver, or with -Dipw2100) with both CCMP and TKIP Fixed problem with CCMP not working due to uninitialized 802.11 header fields (thanks to Pedro Ramalhais) Bug references are to defects stored on http://bughost.org Signed-off-by: James Ketrenos <jketreno@linux.intel.com>
2005-09-21[PATCH] ieee80211: Updated ipw2200 to be compatible with ieee80211_hdr changesJames Ketrenos
tree 9f86c7b4f59249c05c96c360dfaa817995e8a44f parent 9b09701b2c6254f2fddb009004a14eb5a908714f author James Ketrenos <jketreno@linux.intel.com> 1126714305 -0500 committer James Ketrenos <jketreno@linux.intel.com> 1127316074 -0500 Updated ipw2200 to be compatible with ieee80211_hdr changes. Signed-off-by: James Ketrenos <jketreno@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-07[wireless ieee80211,ipw2200] Lindent source codeJeff Garzik
No code changes, just Lindent + manual fixups. This prepares us for updating to the latest Intel driver code, plus gives the source code a nice facelift.
2005-09-06Merge branch 'upstream' of ↵Linus Torvalds
2005-09-05[IPW2200]: ipw2200.h needs linux/dma-mapping.hDavid S. Miller
2005-09-05[PATCH] (6/7) missing include (ipw2200)viro@ftp.linux.org.uk
added missing include of dma-mapping.h Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
