commit 2fc68eb122c7ea6cd5be1fe7d6650c0beb2f4f40 upstream.
Support for firmware rev 508+ was added years ago, but we never noticed
it reports channel in a different way for G-PHY devices. Instead of
offset from 2400 MHz it simply passes channel id (AKA hw_value).
So far it was (most probably) affecting monitor mode users only, but
the following recent commit made it noticeable for quite everybody:
commit 3afc2167f60a327a2c1e1e2600ef209a3c2b75b7
Author: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Date: Tue Mar 4 16:50:13 2014 +0200
cfg80211/mac80211: ignore signal if the frame was heard on wrong channel
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit 12cd43c6ed6da7bf7c5afbd74da6959cda6d056b upstream.
Register B43_MMIO_PSM_PHY_HDR is 16 bit one, so accessing it with 32b
functions isn't safe. On my machine it causes delayed (!) CPU exception:
Disabling lock debugging due to kernel taint
mce: [Hardware Error]: CPU 0: Machine Check Exception: 4 Bank 4: b200000000070f0f
mce: [Hardware Error]: TSC 164083803dc
mce: [Hardware Error]: PROCESSOR 2:20fc2 TIME 1396650505 SOCKET 0 APIC 0 microcode 0
mce: [Hardware Error]: Run the above through 'mcelog --ascii'
mce: [Hardware Error]: Machine check: Processor context corrupt
Kernel panic - not syncing: Fatal machine check on current CPU
Kernel Offset: 0x0 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffff9fffffff)
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit 64e5acb09ca6b50c97299cff9ef51299470b29f2 upstream.
Use the right function to update frequency value.
If rx skb is probe response or beacon, the wrong frequency value can
cause problem that bss info can't be updated when it should be.
Fixes: 8318d78a44d4 ("cfg80211 API for channels/bitrates, mac80211
and driver conversion")
Signed-off-by: ZHAO Gang <gamerh2o@gmail.com>
commit 693026ef2e751fd94d2e6c71028e68343cc875d5 upstream.
When b43 gets build into the kernel and it should use bcma we have to
ensure that bcma was also build into the kernel and not as a module.
In this patch this is also done for SSB, although you can not
build b43 without ssb support for now.
This fixes a build problem reported by Randy Dunlap in
5187EB95.2060605@infradead.org
Reported-By: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
commit e0e29b683d6784ef59bbc914eac85a04b650e63c upstream.
The module parameter "fwpostfix" is userspace controllable, unfiltered,
and is used to define the firmware filename. b43_do_request_fw() populates
ctx->errors[] on error, containing the firmware filename. b43err()
parses its arguments as a format string. For systems with b43 hardware,
this could lead to a uid-0 to ring-0 escalation.
CVE-2013-2852
commit 73b82bf0bfbf58e6ff328d3726934370585f6e78 upstream.
Add handling of rx descriptor underflow. This fixes a fault that could
happen on slow machines, where data is received faster than the CPU can
handle. In such a case the device will use up all rx descriptors and
refuse to send any more data before confirming that it is ok. This
patch enables necessary interrupt to discover such a situation and will
handle them by dropping everything in the ring buffer.
Reviewed-by: Michael Buesch <m@bues.ch>
Signed-off-by: Thommy Jakobsson <thommyj@gmail.com>
[bwh: Backported to 3.2: adjust context]
commit b251412db99ccd4495ce372fec7daee27bf06923 upstream.
Intermittently, b43 will report "Out of order TX status report on DMA ring".
When this happens, the driver must be reset before communication can resume.
The cause of the problem is believed to be an error in the closed-source
firmware; however, all versions of the firmware are affected.
This change uses the observation that the expected status is always 2 less
than the observed value, and supplies a fake status report to skip one
header/data pair.
Not all devices suffer from this problem, but it can occur several times
per second under heavy load. As each occurence kills the unmodified driver,
this patch makes if possible for the affected devices to function. The patch
logs only the first instance of the reset operation to prevent spamming
the logs.
Tested-by: Chris Vine <chris@cvine.freeserve.co.uk>
commit ccae0e50c16a7f7adb029c169147400d1ce9f703 upstream.
Bastian Bittorf reported that some of the silent freezes on a Linksys WRT54G
were due to overflow of the RX DMA ring buffer, which was created with 64
slots. That finding reminded me that I was seeing similar crashed on a netbook,
which also has a relatively slow processor. After increasing the number of
slots to 128, runs on the netbook that previously failed now worked; however,
I found that 109 slots had been used in one test. For that reason, the number
of slots is being increased to 256.
Cc: Bastian Bittorf <bittorf@bluebottle.com>
commit dbdedbdf4fbff3d4962a0786f37aa86dfdc48a7e upstream.
Commit 2a19032 (b43: reload phy and bss settings after core restarts)
introduced an unconditional call to b43_op_config() at the end of
b43_op_start(). When firmware fails to load this can wedge the system.
There's no need to reload the configuration after a failed
initialization anyway, so only make the call if initialization was
successful.
BugLink: http://bugs.launchpad.net/bugs/950295
Cc: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
This patch fixes the regression, introduced by
commit 17030f48e31adde5b043741c91ba143f5f7db0fd
Date: Thu, 11 Aug 2011 17:16:27 +0200
Subject: [PATCH] b43: support new RX header, noticed to be used in 598.314+ fw
in PIO case.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
ssh://ra.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits)
forcedeth: fix a few sparse warnings (variable shadowing)
forcedeth: Improve stats counters
forcedeth: remove unneeded stats updates
forcedeth: Acknowledge only interrupts that are being processed
forcedeth: fix race when unloading module
MAINTAINERS/rds: update maintainer
wanrouter: Remove kernel_lock annotations
usbnet: fix oops in usbnet_start_xmit
ixgbe: Fix compile for kernel without CONFIG_PCI_IOV defined
etherh: Add MAINTAINERS entry for etherh
bonding: comparing a u8 with -1 is always false
sky2: fix regression on Yukon Optima
netlink: clarify attribute length check documentation
netlink: validate NLA_MSECS length
i825xx:xscale:8390:freescale: Fix Kconfig dependancies
macvlan: receive multicast with local address
tg3: Update version to 3.121
tg3: Eliminate timer race with reset_task
tg3: Schedule at most one tg3_reset_task run
tg3: Obtain PCI function number from device
This fixes PHY transmission errors reported on some LP-PHY and HT-PHY
cards. For LP-PHY they were quite rare and not really noticable. On
HT-PHY they were critical, OFDM rates were not available at all.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
The driver can spam the logs with "RX: Packet dropped" messages. These drops
originate from 1. a correpted PLCP, 2. decryption errors, and 3. packet
size underruns. Condition #3 logs a separate message, thus no dropped message
is needed.
Standardize the style for compiler based printf format verification.
Standardized the location of __printf too.
Done via script and a little typing.
$ grep -rPl --include=*.[ch] -w "__attribute__" * | \
grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \
xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }'
[akpm@linux-foundation.org: revert arch bits]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
The device.h header was including module.h, making it present for
most of these drivers. But we want to clean that up. Call out the
include of module.h in the modular network drivers.
This reverts commit 55ad5962e97430c83d51df36fc18865ee4f78c48.
I assumed N is newer than LP, which isn't true. This regressed LP case.
We don't want to report random quality info (new PHYs are affected).
tx params should be configured per interface.
add ieee80211_vif param to the conf_tx callback,
and change all the drivers that use this callback.
The following spatch was used:
@rule1@
struct ieee80211_ops ops;
identifier conf_tx_op;
ops.conf_tx = conf_tx_op;
@rule2@
identifier rule1.conf_tx_op;
identifier hw, queue, params;
conf_tx_op (
- struct ieee80211_hw *hw,
+ struct ieee80211_hw *hw, struct ieee80211_vif *vif,
u16 queue,
const struct ieee80211_tx_queue_params *params) {...}
Signed-off-by: Eliad Peller <eliad@wizery.com>
TSF can be kept per vif.
Add ieee80211_vif param to set/get/reset_tsf, and move
the debugfs entries to the per-vif directory.
Update all the drivers that implement these callbacks.
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-pcie-tx.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
They have been taken from brcmsmac, add Broadcom's copyright.
In ad-hoc mode, driver b43 does not issue beacons.
Signed-off-by: Manual Munz <freifunk@somakoma.de>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Stable <stable@kernel.org>
As discussed in "Licensing wlc_phy_radio.h and brcm80211" (Message-ID:
<AANLkTinQMRGkOvi4e4JMsHGV_BF_4Rf5oHCtZgQjwQ1g@mail.gmail.com>) content
of that file is not copyrightable, just names and numbers.
It was not possible to guess the conditions from MMIO dumps. Take them
from brcmsmac code.
We've compared b43 with brcmsmac and took functions names from the
later.
This is not implemented in brcmsmac, but was noticed in (newer) wl. Can
be workaround for some hardware bug.
