path: root/drivers/net/wireless/b43/xmit.h
2011-02-25b43: fill PHY ctl word1 in TX header for N-PHYRafał Miłecki
This patch fixes tramissing on OFDM rates for PHYs 1 and 2. There is still something wrong with PHYs 3+. Tests has shown decreasing of performance on CCK rates by 1-2%, we have to live with that. Additionaly this noticeably reduces amount of PHY errors. They were mostly produced by auto-switching to higher rate for better performanced, which resulted in no transmit at all and PHY errors. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-11b43: Rewrite TX bounce buffer handlingMichael Buesch
Do not mess with the original skb, but allocate an independent bouncebuffer. This protects against bad interference with mac80211's assumptions about the skb (which already caused bugs). Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20b43: add hardware tkipgregor kowski
This add hardware tkip for b43. Signed-off-by: Gregor Kowski <gregor.kowski@gmail.com> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211/drivers: rewrite the rate control APIJohannes Berg
So after the previous changes we were still unhappy with how convoluted the API is and decided to make things simpler for everybody. This completely changes the rate control API, now taking into account 802.11n with MCS rates and more control, most drivers don't support that though. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: move TX info into skb->cbJohannes Berg
This patch converts mac80211 and all drivers to have transmit information and status in skb->cb rather than allocating extra memory for it and copying all the data around. To make it fit, a union is used where only data that is necessary for all steps is kept outside of the union. A number of fixes were done by Ivo, as well as the rt2x00 part of this patch. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08b43: Add more N-PHY stuffMichael Buesch
This adds some minor stuff for N-PHY support. Nothing special. Adds Analog switching and some TODOs for RSSI processing. Just a patch I had floating around for quite some time now. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08b43: Add PIO support for PCMCIA devicesMichael Buesch
This adds PIO support back (D'oh!) for PCMCIA devices. This is a complete rewrite of the old PIO code. It does actually work and we get reasonable performance out of it on a modern machine. On a PowerBook G4 I get a few MBit for TX and a few more for RX. So it doesn't work as well as DMA (of course), but it's a _lot_ faster than the old PIO code (only got a few kBit with that). The limiting factor is the host CPU speed. So it will generate 100% CPU usage when the network interface is heavily loaded. A voluntary preemption point in the RX path makes sure Desktop Latency isn't hurt. PIO is needed for 16bit PCMCIA devices, as we really don't want to poke with the braindead DMA mechanisms on PCMCIA sockets. Additionally, not all PCMCIA sockets do actually support DMA in 16bit mode (mine doesn't). Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-07b43: Add QOS supportMichael Buesch
This adds QOS support to the b43 driver. QOS can be disabled on driver level with a module parameter for debugging purposes. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-31b43: Drop packets that we are not able to encryptMichael Buesch
We must not transmit packets we're not able to encrypt. This fixes a bug where in a tiny timeframe after machine resume packets can get sent unencrypted and might leak information. This also fixes three small resource leakages I spotted while fixing the security problem. Properly deallocate the DMA slots in any DMA allocation error path. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28b43: Add support for new firmwareMichael Buesch
This patch adds support for new firmware. Old firmware is still supported until July 2008. To get new firmware, go to ftp://ftp.linksys.com/opensourcecode/wrt150nv11/1.51.3/ and download the tarball. We don't have a smaller tarball, yet. That will be fixed later. You can extract firmware out of the "wl_ap.o" file contained in this tarball using latest fwcutter. You must pass the option --unsupported to fwcutter. Fwcutter-010 with official support for a new firmware image will be released soon. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08b43: Fix rxheader channel parsingMichael Buesch
This patch fixes the parsing of the RX data header channel field. The current code parses the header incorrectly and passes a wrong channel number and frequency for each frame to mac80211. The FIXMEs added by this patch don't matter for now as the code where they live won't get executed anyway. They will be fixed later. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[B43]: add mac80211-based driver for modern BCM43xx devicesMichael Buesch
