Sourcecode files for PHY code are named by phy_XXX.{c,h}
where XXX is the PHY type.
Move the N-PHY code to match the other files.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
This patch rewrites the TX power recalculation algorithms to scale better
with changed enviromnent. If there's low
TX traffic, the power will be checked against the desired values
every 60 seconds.
If there is high TX traffic, the check is redone every 2 seconds. This improves
the reaction times a lot and confuses the rate control less.
It will also reduce the time it initially takes to tune to a new TX power
value. With the old algorithm it could take about 30 to 45 seconds to settle to
a new power value. This will happen in about two to four seconds now.
This patch implements a dynamic "ops" based PHY API.
This is needed in order to conveniently support future PHY types
to avoid the "switch"-hell.
This patch does not change any functionality. It just moves lots
of code from one place to another and adjusts it for the changed
data structures.
Remove duplicated include <linux/delay.h> in
drivers/net/wireless/b43/nphy.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
This adds some minor stuff for N-PHY support. Nothing special.
Adds Analog switching and some TODOs for RSSI processing.
Just a patch I had floating around for quite some time now.
This also adds lots of TODOs. Oh well. Lots of work. :)
This adds code and table data for channel switching on NPHYs.
This adds some code to init the 2055 radio.
This patch adds two files "tables_nphy.h" and "tables_nphy.c"
This patch adds all register definitions for the N-PHY.
This adds two new files: nphy.h and nphy.c
No functional changes to existing code.
