path: root/drivers/net/wireless/ath9k/phy.c
2009-04-22atheros: put atheros wireless drivers into ath/Luis R. Rodriguez
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22ath9k: Cleanup debug messagesSujith
Clean debug messages to use appropriate levels, remove useless messages, and trim the number of debug levels. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27ath9k: Update copyright in all the filesSujith
How time flies. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27ath9k: Enable Fractional N modeSujith
This patch enables Fractional N mode for all channel if the EEPROM says so, and also fixes the INI only when the device is not a 2 GHz only capable device. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13ath9k: Remove all the useless ah_ variable prefixesSujith
2009-02-13ath9k: Cleanup EEPROM operationsSujith
This patch removes the various function pointer assignments and unifies them in a single ops structure. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13ath9k: Merge ath_hal and ath_hal_5416 structuresSujith
Finally, merge these structures and have a single HW specific data structure. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13ath9k: Header file cleanupSujith
Split the core header files into manageable pieces. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-05ath9k: Use cleaner debug masksSujith
Remove all the useless __func__ prefixes in debug messages, and replace the DPRINTF macro with a function. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10ath9k: Refactor hw.cSujith
Split hw.c into more manageable files: ani.c calib.c eeprom.c mac.c Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-07ath9k: Add new Atheros IEEE 802.11n driverLuis R. Rodriguez
This adds the new mac80211 11n ath9k Atheros driver. Only STA support is currently enabled and tested. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Jack Howarth <howarth@bromo.msbb.uc.edu> Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
