path: root/drivers/net/wireless/arlan-main.c
2006-05-26[PATCH] arlan: fix section mismatch warningsRandy Dunlap
Fix section mismatch warnings: WARNING: drivers/net/wireless/arlan.o - Section mismatch: reference to .init.text:arlan_probe from .text between 'init_module' (at offset 0x3526) and 'cleanup_module' WARNING: drivers/net/wireless/arlan.o - Section mismatch: reference to .init.text:init_arlan_proc from .text between 'init_module' (at offset 0x3539) and 'cleanup_module' WARNING: drivers/net/wireless/arlan.o - Section mismatch: reference to .exit.text:cleanup_arlan_proc from .text between 'cleanup_module' (at offset 0x356c) and 'arlan_diagnostic_info_string' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-06-26[PATCH] arlan: module parameter fixesMagnus Damm
Make sure the code compiles with and without ARLAN_ENTRY_EXIT_DEBUGGING. Only provide parameter descriptions when parameters are defined. Remove "arlan_"-prefix to shape up built-in parameter names: arlan.arlan_debug -> arlan.debug arlan.arlan_EEPROM_bad -> arlan.EEPROM_bad arlan.arlan_entry_and_exit_debug -> arlan.entry_and_exit_debug arlan.arlan_entry_debug -> arlan.entry_debug arlan.arlan_exit_debug -> arlan.exit_debug Signed-off-by: Magnus Damm <damm@opensource.se>
