path: root/drivers/net/wireless/airo.c
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31airo: Kill directly reference of netdev->privWang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. OK, becasue Dave S. Miller said, "every direct netdev->priv usage is a bug", and I want to kill netdev->priv later, I decided to convert all the direct reference of netdev->priv first. In this driver, I don't simply use netdev_priv() to replace netdev->priv. The reason is: Pointer netdev->priv was changed in this driver, but it shouldn't. Because the memory was allocated when alloc_netdev() and netdev->priv should always point to that memory. So I use netdev->ml_priv to replace netdev->priv. After replacing, both ai and ai->wifidev->ml_priv point to the same memory. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24wireless: Read scan flags correctly on x86-64David Kilroy
The SIOCSIWSCAN handler is passed data in an iw_point structure. Some drivers erronously use an iw_param instead. On 32 bit architectures the difference isn't noticed as the flags parameter tends to be the only one used by scan handlers and is at the same offset. On 64 bit architectures the pointer in the iw_point structure means the flag parameter is at different offsets in these structures. Thanks to Jean Tourrilhes for tracking this down for orinoco, and Pavel Roskin for confirming the fix and identifying other suspect handlers. Signed-off-by: David Kilroy <kilroyd@googlemail.com> Acked-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22wireless: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-27wireless: Small cleanupsPavel Machek
Small whitespace cleanups for wireless drivers Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-16wext: Emit event stream entries correctly when compat.David S. Miller
Three major portions to this change: 1) Add IW_EV_COMPAT_LCP_LEN, IW_EV_COMPAT_POINT_OFF, and IW_EV_COMPAT_POINT_LEN helper defines. 2) Delete iw_stream_check_add_*(), they are unused. 3) Add iw_request_info argument to iwe_stream_add_*(), and use it to size the event and pointer lengths correctly depending upon whether IW_REQUEST_FLAG_COMPAT is set or not. 4) The mechanical transformations to the drivers and wireless stack bits to get the iw_request_info passed down into the routines modified in #3. Also, explicit references to IW_EV_LCP_LEN are replaced with iwe_stream_lcp_len(info). With a lot of help and bug fixes from Masakazu Mokuno. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-14airo: use simple_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Dan Williams <dcbw@redhat.com> Cc: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tg3.c drivers/net/wireless/rt2x00/rt2x00dev.c net/mac80211/ieee80211_i.h
2008-06-04airo warning fixAndrew Morton
WARNING: space prohibited between function name and open parenthesis '(' #22: FILE: drivers/net/wireless/airo.c:2907: + while ((IN4500 (ai, COMMAND) & COMMAND_BUSY) && (delay < 10000)) { total: 0 errors, 1 warnings, 8 lines checked ./patches/wireless-airo-waitbusy-wont-delay.patch has style problems, please review. If any of these errors are false positives report them to the maintainer, see CHECKPATCH in MAINTAINERS. Please run checkpatch prior to sending patches Cc: Dan Williams <dcbw@redhat.com> Cc: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-25Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/cpmac.c net/mac80211/mlme.c
2008-05-16wireless: Create 'device' symlink in sysfsMasakazu Mokuno
Some network interfaces of the wireless drivers lack the 'device' symlink in sysfs. This patch lets the drivers create the links. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-16wireless, airo: waitbusy() won't delayRoel Kluin
There will be no delay even when COMMAND_BUSY (defined 0x8000) is set: 0x8000 & (delay < 10000) will evaluate to 0 - when delay is 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-14airo: use netstats in net_device structurePaulius Zaleckas
Use net_device_stats from net_device structure instead of local. Changed airo_read_stats function parameter to net_device. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-29wireless: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Michael Buesch <mb@bu3sch.de> Cc: Daniel Drake <dsd@gentoo.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29netdev: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root_driverAlexey Dobriyan
Use creation by full path: "driver/foo". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28airo: last of endianness annotationsAl Viro
sanitize handling of ConfigRid Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28airo: sanitize handling of StatusRidAl Viro
2008-01-28airo: sanitize APListRid handlingAl Viro
2008-01-28airo: sanitize handling of CapabilityRidAl Viro
Don't byteswap any fields, annotate. That has caught a bug, BTW - will be handled in the next patch. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28airo: sanitize handling of StatsRidAl Viro
2008-01-28airo: sanitize handling of WepKeyRidAl Viro
don't byteswap, update users to match that, annotate. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28airo: sanitize BSSListRid handlingAl Viro
Stop byteswap-in-place in readBSSListRid(), annotate the sucker. BTW, that had immediately found a bug - another codepath fetching the same struct from card did _not_ byteswap, but used ->dBm the same as everything else - host-endian. Fix in the next patch... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28bap_read()/bap_write() work with fixed-endian buffersAl Viro
2008-01-28airo: sanitize handling of SSID_ridAl Viro
* store SSID_rid without conversions * sanitize proc_SSID_on_close() (and avoid access past the end of buffer, while we are at it) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28airo: trivial endianness annotationsAl Viro
2008-01-28airo: fix writerids() endiannessAl Viro
in writerids() we do _not_ byteswap, so we want to access ->opmode as little-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28airo endianness bug: cap_rid.extSoftCapAl Viro
never had been byteswapped, used as host-endian... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28airo: bug in airo_interrupt() handling on incoming 802.11Al Viro
On big-endian we end up with swapped first two bytes in packet, due to earlier conversion to host-endian and forgotten conversion back. The code we calculated that host-endian for had been duplicated several time - it finds the 802.11 MAC header length by the first two bytes of packet; taken into a new helper (header_len(__le16 ctl)). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28airo: fix endianness bug in ->dBm handlingAl Viro
airo_translate_scan() reads BSSListRid directly, does _not_ byteswap and uses ->dBm (__le16) as host-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28airo: fix transmit_802_11_packet()Al Viro
a) gaplen would better be stored little-endian b) for control packets (shorter than 24-byte header) we ended up with bap_write(ai, hdrlen == 30 ? (const u16*)&gap.gaplen : (const u16*)&gap, 38 - hdrlen, BAP1); passing to card the data past the end of gap (i.e. random stuff from stack) and did _not_ feed the gaplen at the right offset. c) sending the contents of uninitialized fields of struct is Not Nice(tm) either Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28NULL noise in drivers/netAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28wireless: checkpatch cleanupsJeff Garzik
2008-01-28[netdrvr] irq handler minor cleanups in several driversJeff Garzik
* use irq_handler_t where appropriate * no need to use 'irq' function arg, its already stored in a data struct * rename irq handler 'irq' argument to 'dummy', where the function has been analyzed and proven not to use its first argument. * remove always-false "dev_id == NULL" test from irq handlers * remove pointless casts from void* * declance: irq argument is not const * add KERN_xxx printk prefix * fix minor whitespace weirdness Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28wireless: fix '!x & y' typo'sRoel Kluin
Fix priority mistakes similar to '!x & y' Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap hard_header_parseStephen Hemminger
Wrap the hard_header_parse function to simplify next step of header_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] remove gratuitous space in airo module descriptionBill Nottingham
Currently the modinfo looks like: description: Support for Cisco/Aironet 802.11 wireless ethernet cards. Direct support for ISA/PCI/MPI cards and support for PCMCIA when used with airo_cs. Arguably, it should be cut at the end of the first sentence. This at least makes it somewhat more legible. Signed-off-by: Bill Nottingham <notting@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[PATCH] airo: start with radio offMichal Schmidt
Don't turn the radio on until the interface is up. This saves some power in case the driver is loaded but the card is not used. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-10[PATCH] airo: simpler calling convention for enable_MAC()Michal Schmidt
Callers of enable_MAC() shouldn't have to worry about the bits in the response's status word (and most of them don't). The return value is sufficient information. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-10[PATCH] airo: fix a race causing initialization failuresMichal Schmidt
Matteo Croce reported Aironet initialization failures. They were caused by a race in airo. airo finds a free interface name, then initializes the card and finally registers the interface. Another device may get the same name in the meantime. The reason airo gets its name early is to use it in informative printks and to name the resources it requests. The printks will be just fine without the interface name and the resources can use the driver's name - that's what other network drivers do anyway. One of the talkative functions is setup_card(). It is called once before registration and can be called later again. Let's have an empty dev->name during the first call, so it doesn't print the ugly "airo(eth%d)" message. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-10[PATCH] airo: delay some initialization until the netdev is upMichal Schmidt
airo's kernel thread and the IRQ handler are needed only when the interface is up. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-10[PATCH] airo: disable the PCI device when unloading moduleMichal Schmidt
Fix an assymetry between pci_{enable,disable}_device. airo did not disable the PCI device when unloading the module. This caused suspend failures after modprobe -r airo && modprobe airo. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] airo: Make /sys/bus/pci/drivers/airo/{,un}bind workMichal Schmidt
The way airo.c keeps track of all its devices is complicated and buggy as well (del_airo_dev forgets to free the memory add_airo_dev allocates). It's cleaner to use the standard list primitives. While we're at it, it's not necessary to put PCI cards in the list, because the kernel already keeps track of them. We can take advantage of it and use the .remove callback as it was meant to be. This makes /sys/bus/pci/drivers/airo/{,un}bind work. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
