path: root/drivers/net/wireless/adm8211.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-14Merge branch 'master' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-02-08adm821: remove get_tx_stats() mac80211 opKalle Valo
get_tx_stats() will be removed from mac80211. Compile-tested only. Cc: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-28mac80211: remove struct ieee80211_if_init_confJohannes Berg
All its members (vif, mac_addr, type) are now available in the vif struct directly, so we can pass that instead of the conf struct. I generated this patch (except the mac80211 and header file changes) with this semantic patch: @@ identifier conf, fn, hw; type tp; @@ tp fn(struct ieee80211_hw *hw, -struct ieee80211_if_init_conf *conf) +struct ieee80211_vif *vif) { <... ( -conf->type +vif->type | -conf->mac_addr +vif->addr | -conf->vif +vif ) ...> } Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18drivers/net/adm8211.c: remove exceptional & on function nameJulia Lawall
In this file, function names are otherwise used as pointers without &. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-20mac80211: allow configure_filter callback to sleepJohannes Berg
Over time, a whole bunch of drivers have come up with their own scheme to delay the configure_filter operation to a workqueue. To be able to simplify things, allow configure_filter to sleep, and add a new prepare_multicast callback that drivers that need the multicast address list implement. This new callback must be atomic, but most drivers either don't care or just calculate a hash which can be done atomically and then uploaded to the hardware non-atomically. A cursory look suggests that at76c50x-usb, ar9170, mwl8k (which is actually very broken now), rt2x00, wl1251, wl1271 and zd1211 should make use of this new capability. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24adm8211: remove uneeded code during suspend/resumeLuis R. Rodriguez
mac80211 drivers do not need to stop the software queues or call their own stop() callback upon suspend as we do it for drivers. Equally drivers don't have to call their own start() or start the queues as mac80211 will do it for us. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10mac80211: push rx status into skb->cbJohannes Berg
Within mac80211, we often need to copy the rx status into skb->cb. This is wasteful, as drivers could be building it in there to start with. This patch changes the API so that drivers are expected to pass the RX status in skb->cb, now accessible as IEEE80211_SKB_RXCB(skb). It also updates all drivers to pass the rx status in there, but only by making them memcpy() it into place before the call to the receive function (ieee80211_rx(_irqsafe)). Each driver can now be optimised on its own schedule. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: unify config_interface and bss_info_changedJohannes Berg
The config_interface method is a little strange, it contains the BSSID and beacon updates, while bss_info_changed contains most other BSS information for each interface. This patch removes config_interface and rolls all the information it previously passed to drivers into bss_info_changed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-10adm8211: remove SSID codeJohannes Berg
Since adm8211 currently doesn't implement IBSS mode anyway, it can't be using the SSID. And if/when it does implement IBSS mode, we'll have to see how to make it beacon anyway. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211/drivers: rewrite the rate control APIJohannes Berg
So after the previous changes we were still unhappy with how convoluted the API is and decided to make things simpler for everybody. This completely changes the rate control API, now taking into account 802.11n with MCS rates and more control, most drivers don't support that though. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: introduce hw config change flagsJohannes Berg
This makes mac80211 notify the driver which configuration actually changed, e.g. channel etc. No driver changes, this is just plumbing, driver authors are expected to act on this if they want to. Also remove the HW CONFIG debug printk, it's incorrect, often we configure something else. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-15mac80211: use nl80211 interface typesJohannes Berg
There's really no reason for mac80211 to be using its own interface type defines. Use the nl80211 types and simplify the configuration code a bit: there's no need to translate them any more now. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-05cfg80211: keep track of supported interface modesLuis R. Rodriguez
It is obviously good for userspace to know up front which interface modes a given piece of hardware might support (even if adding such an interface might fail later because of concurrency issues), so let's make cfg80211 aware of that. For good measure, disallow adding interfaces in all other modes so drivers don't forget to announce support for one mode when they add it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Stephen Blackheath <tramp.enshrine.stephen@blacksapphire.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-26adm8211: remove unnecessary protected bit mask/checkHarvey Harrison
Removes now unused fc local var and uses the new ieee80211_hdrlen which directly uses the le16 frame control value. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: move TX info into skb->cbJohannes Berg
This patch converts mac80211 and all drivers to have transmit information and status in skb->cb rather than allocating extra memory for it and copying all the data around. To make it fit, a union is used where only data that is necessary for all steps is kept outside of the union. A number of fixes were done by Ivo, as well as the rt2x00 part of this patch. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: use rate index in TX controlJohannes Berg
This patch modifies struct ieee80211_tx_control to give band info and the rate index (instead of rate pointers) to drivers. This mostly serves to reduce the TX control structure size to make it fit into skb->cb so that the fragmentation code can put it there and we can think about passing it to drivers that way in the future. The rt2x00 driver update was done by Ivo, thanks. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: let drivers wake but not start queuesJohannes Berg
Having drivers start queues is just confusing, their ->start() callback can block and do whatever is necessary, so let mac80211 start queues and have drivers wake queues when necessary (to get packets flowing again right away.) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-14mac80211: use hardware flags for signal/noise unitsBruno Randolf
trying to clean up the signal/noise code. the previous code in mac80211 had confusing names for the related variables, did not have much definition of what units of signal and noise were provided and used implicit mechanisms from the wireless extensions. this patch introduces hardware capability flags to let the hardware specify clearly if it can provide signal and noise level values and which units it can provide. this also anticipates possible new units like RCPI in the future. for signal: IEEE80211_HW_SIGNAL_UNSPEC - unspecified, unknown, hw specific IEEE80211_HW_SIGNAL_DB - dB difference to unspecified reference point IEEE80211_HW_SIGNAL_DBM - dBm, difference to 1mW for noise we currently only have dBm: IEEE80211_HW_NOISE_DBM - dBm, difference to 1mW if IEEE80211_HW_SIGNAL_UNSPEC or IEEE80211_HW_SIGNAL_DB is used the driver has to provide the maximum value (max_signal) it reports in order for applications to make sense of the signal values. i tried my best to find out for each driver what it can provide and update it but i'm not sure (?) for some of them and used the more conservative guess in doubt. this can be fixed easily after this patch has been merged by changing the hardware flags of the driver. DRIVER SIGNAL MAX NOISE QUAL ----------------------------------------------------------------- adm8211 unspec(?) 100 n/a missing at76_usb unspec(?) (?) unused missing ath5k dBm dBm percent rssi b43legacy dBm dBm percent jssi(?) b43 dBm dBm percent jssi(?) iwl-3945 dBm dBm percent snr+more iwl-4965 dBm dBm percent snr+more p54 unspec 127 n/a missing rt2x00 dBm n/a percent rssi+tx/rx frame success rt2400 dBm n/a rt2500pci dBm n/a rt2500usb dBm n/a rt61pci dBm n/a rt73usb dBm n/a rtl8180 unspec(?) 65 n/a (?) rtl8187 unspec(?) 65 (?) noise(?) zd1211 dB(?) 100 n/a percent drivers/net/wireless/ath5k/base.c: Changes-licensed-under: 3-Clause-BSD Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07mac80211: clean up get_tx_stats callbackJohannes Berg
The callback takes a ieee80211_tx_queue_stats with a contained array of ieee80211_tx_queue_stats_data, remove the former, rename the latter to ieee80211_tx_queue_stats and make tx_stats() take the array directly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08adm8211: remove commented-out codePavel Machek
Remove some commented-out code from adm8211. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29adm8211: fix cfg80211 band API conversionJohannes Berg
Insert a missing band assignment. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29adm8211: fix sparse warningsJohannes Berg
Both of these seem to be actual errors, the first is just wrong and the second is my mistake introduced by the cfg80211 API update. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29cfg80211 API for channels/bitrates, mac80211 and driver conversionJohannes Berg
This patch creates new cfg80211 wiphy API for channel and bitrate registration and converts mac80211 and drivers to the new API. The old mac80211 API is completely ripped out. All drivers (except ath5k) are updated to the new API, in many cases I expect that optimisations can be done. Along with the regulatory code I've also ripped out the IEEE80211_HW_DEFAULT_REG_DOMAIN_CONFIGURED flag, I believe it to be unnecessary if the hardware simply gives us whatever channels it wants to support and we then enable/disable them as required, which is pretty much required for travelling. Additionally, the patch adds proper "basic" rate handling for STA mode interface, AP mode interface will have to have new API added to allow userspace to set the basic rate set, currently it'll be empty... However, the basic rate handling will need to be moved to the BSS conf stuff. I do expect there to be bugs in this, especially wrt. transmit power handling where I'm basically clueless about how it should work. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: dont use interface indices in driversJohannes Berg
This patch gets rid of the if_id stuff where possible in favour of a new per-virtual-interface structure "struct ieee80211_vif". This structure is located at the end of the per-interface structure and contains a variable length driver-use data area. This has two advantages: * removes the need to look up interfaces by if_id, this is better for working with network namespaces and performance * allows drivers to store and retrieve per-interface data without having to allocate own lists/hash tables Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28misc wireless annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[MAC80211]: add "invalid" interface typeJohannes Berg
Since I cannot convince the lazy driver authors (hello Michael) to stop (ab)using the MGMT interface type internally in their drivers, this patch introduces a new _INVALID type especially for their use and changes all affected drivers to use it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] adm8211: Detect interface up/down in suspend/resume hooks correctlyMichael Wu
Interface up/down detection was incorrectly changed during the filter API update. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] adm8211: Pass all TXed frames to tx_status_irqsafeMichael Wu
ieee80211_tx_status_irqsafe can handle the freeing of all TXed frames. Also, set excessive_retries for failed frames. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] adm8211: Use revision from pci_devMichael Wu
No need to load the revision ourselves anymore. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] adm8211: kill version printksMichael Wu
No need to pollute dmesg with copyright info. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] adm8211: Improve writing of mac addrs to registersMichael Wu
The mac address write is broken for big endian and the bssid write can be simplified. This patch does both. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] adm8211: kill interrupt loopMichael Wu
Looping in the interrupt handler is unnecessary. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: revamp interface and filter configurationJohannes Berg
Drivers are currently supposed to keep track of monitor interfaces if they allow so-called "hard" monitor, and they are also supposed to keep track of multicast etc. This patch changes that, replaces the set_multicast_list() callback with a new configure_filter() callback that takes filter flags (FIF_*) instead of interface flags (IFF_*). For a driver, this means it should open the filter as much as necessary to get all frames requested by the filter flags. Accordingly, the filter flags are named "positively", e.g. FIF_ALLMULTI. Multicast filtering is a bit special in that drivers that have no multicast address filters need to allow multicast frames through when either the FIF_ALLMULTI flag is set or when the mc_count value is positive. At the same time, drivers are no longer notified about monitor interfaces at all, this means they now need to implement the start() and stop() callbacks and the new change_filter_flags() callback. Also, the start()/stop() ordering changed, start() is now called *before* any add_interface() as it really should be, and stop() after any remove_interface(). The patch also changes the behaviour of setting the bssid to multicast for scanning when IEEE80211_HW_NO_PROBE_FILTERING is set; the IEEE80211_HW_NO_PROBE_FILTERING flag is removed and the filter flag FIF_BCN_PRBRESP_PROMISC introduced. This is a lot more efficient for hardware like b43 that supports it and other hardware can still set the BSSID to all-ones. Driver modifications by Johannes Berg (b43 & iwlwifi), Michael Wu (rtl8187, adm8211, and p54), Larry Finger (b43legacy), and Ivo van Doorn (rt2x00). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] Add adm8211 802.11b wireless driverMichael Wu
This patch adds a mac80211 wireless driver for ADMtek ADM8211 based wireless cards. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
