path: root/drivers/net/wd.c
2006-12-04[PATCH] trivial missing __init in drivers/net/*Al Viro
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19[PATCH] wd section fixAndrew Morton
WARNING: drivers/net/wd.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0xfd) and 'wd_open' WARNING: drivers/net/wd.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x14b) and 'wd_open' WARNING: drivers/net/wd.o - Section mismatch: reference to .init.data:wd_portlist from .text between 'init_module' (at offset 0x17f) and 'wd_open' Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-09[PATCH] fix a few "warning: 'cleanup_card' defined but not used"Denis Vlasenko
These warnings are emitted if non-modular network drivers are built. Fixes just move cleanup_card() definitions into #ifdef MODULE region. /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/wd.c:131: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/3c503.c:152: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/ne.c:216: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/hp.c:106: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/hp-plus.c:142: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/smc-ultra.c:172: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/e2100.c:144: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/es3210.c:159: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/lne390.c:149: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/lance.c:313: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/ac3200.c:127: warning: 'cleanup_card' defined but not used Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12[netdrvr] Fix register_netdev() races in older ISA net drivers
