path: root/drivers/net/wan
2005-07-15[WAN]: drivers/net/wan/: use of time_after macroMarcelo Feitoza Parisi
From: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Use of the time_after() macro, defined at linux/jiffies.h, which deal with wrapping correctly and are nicer to read. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-12[NET]: __be'ify *_type_trans()Alexey Dobriyan
tr_type_trans(), hippi_type_trans() left as-is. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-26[PATCH] net/farsync: add set_current_state() before schedule_timeout()Nishanth Aravamudan
Insert set_current_state() before schedule_timeout() so the function delays as expected. Without the addition, schedule_timeout() will return immediately. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org>
2005-06-26drivers/net/: Use the DMA_{64,32}BIT_MASK constantsDomen Puncer
Use the DMA_{64,32}BIT_MASK constants from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() This patch includes dma-mapping.h explicitly because it caused errors on some architectures otherwise. See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org>
2005-06-25[PATCH] Remove duplicate file in Documentation/networking ↵Tobias Klauser
(drivers_net_wan_Kconfig) wanpipe.txt and wan-router.txt in Documentation/networking contain the exact same information (diff between the two shows no drivers/net/wan/Kconfig. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Convert users to tty_unregister_ldisc()Alexey Dobriyan
tty_register_ldisc(N_FOO, NULL) => tty_unregister_ldisc(N_FOO) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] class: convert drivers/* to use the new class api instead of ↵gregkh@suse.de
class_simple Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-04Automatic merge of /spare/repo/netdev-2.6 branch iff-running
2005-05-15[PATCH] Generic HDLC updateKrzysztof Halasa
The attached patch updates generic HDLC to version 1.18. FR Cisco LMI production-tested. Please apply to Linux 2.6. Thanks. Changes: - doc updates - added Cisco LMI support to Frame-Relay code - cleaned hdlc_fr.c a bit, removed some orphaned #defines etc. - fixed a problem with non-functional LMI in FR DCE mode. - changed diagnostic messages to better conform to FR standards - all protocols: information about carrier changes (DCD line) is now printed to kernel logs. Signed-Off-By: Krzysztof Halasa <khc@pm.waw.pl>
2005-05-12[netdrvrs] Use netif_carrier_* instead of IFF_RUNNING
2005-05-04[PATCH] ISA DMA Kconfig fixes - part 3Al Viro
Drivers that expect ISA DMA API are marked as such in Kconfig. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-03[WAN]: kfree of NULL pointer is validJesper Juhl
kfree(0) is perfectly valid, checking pointers for NULL before calling kfree() on them is redundant. The patch below cleans away a few such redundant checks (and while I was around some of those bits I couldn't stop myself from making a few tiny whitespace changes as well). Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Acked-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-26[PATCH] PC300 pci_enable_device fixMarcelo Tosatti
Call pci_enable_device() before looking at IRQ and resources, and pci_disable_device() when shutting the interface down. The driver requires this fix or the "pci=routeirq" workaround on 2.6.10 and later kernels. Reported and tested by Artur Lipowski. From: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Marcelo Tosatti <marcelo.tosatti@cyclades.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
