path: root/drivers/net/wan/dscc4.c
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-18drivers/net/wan: remove exceptional & on function nameJulia Lawall
In this file, function names are otherwise used as pointers without &. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-03WAN: dscc4: Fix warning pointing out a bug.David S. Miller
Noticed by Stephen Rothwell: Today's linux-next build (x86_64 allmodconfig gcc-4.4.0) produced this warning: drivers/net/wan/dscc4.c: In function 'dscc4_rx_skb': drivers/net/wan/dscc4.c:670: warning: suggest parentheses around comparison in operand of '|' which actually points out a bug, I think. It is doing (x & (y | z)) != y | z when it probably means (x & (y | z)) != (y | z) Introduced by commit 5de3fcab91b0e1809eec030355d15801daf25083 ("WAN: bit and/or confusion"). Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01wan: convert drivers to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30WAN: bit and/or confusionroel kluin
Fix the tests that check whether Frame* bits are not set Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: convert remaining non-symbolic return values in ndo_start_xmit() functionsPatrick McHardy
This patch converts the remaining occurences of raw return values to their symbolic counterparts in ndo_start_xmit() functions that were missed by the previous automatic conversion. Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero is changed to explicitly use NETDEV_TX_OK. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21WAN: Convert generic HDLC drivers to netdev_ops.Krzysztof Hałasa
Also remove unneeded last_rx update from Synclink drivers. Synclink part mostly by Stephen Hemminger. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31pci: use pci_ioremap_bar() in drivers/netArjan van de Ven
Use the newly introduced pci_ioremap_bar() function in drivers/net. pci_ioremap_bar() just takes a pci device and a bar number, with the goal of making it really hard to get wrong, while also having a central place to stick sanity checks. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24drivers/net: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-23WAN: Remove unneeded "#include <net/syncppp.h>"Krzysztof Hałasa
2008-07-04WAN: convert drivers to use built-in netdev_statsKrzysztof Halasa
There is no point in using separate net_device_stats structs when the one in struct net_device is present. Compiles. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-18dscc4 endian fixesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in networks driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-26[PATCH] sem2mutex: misc static one-file mutexesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jens Axboe <axboe@suse.de> Cc: Neil Brown <neilb@cse.unsw.edu.au> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: Greg KH <greg@kroah.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] dscc4: fix dscc4_init_dummy_skb checkAlexey Dobriyan
It returns a pointer. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] drivers/net/wan/: possible cleanupsAdrian Bunk
This patch contains possible cleanups including the following: - make needlessly global code static - #if 0 the following unused global function: - sdladrv.c: sdla_intde - remove the following unused global variable: - lmc_media.c: lmc_t1_cables - remove the following unneeded EXPORT_SYMBOL's: - cycx_drv.c: cycx_inten - sdladrv.c: sdla_inten - sdladrv.c: sdla_intde - sdladrv.c: sdla_intack - sdladrv.c: sdla_intr - syncppp.c: sppp_input - syncppp.c: sppp_change_mtu Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] drivers/net: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
