path: root/drivers/net/via-velocity.h
2009-05-27net: use netdev stats in b44, sundance, via-rhine and via-velocityEric Dumazet
Use struct net_device_stats provided in struct net_device instead of private ones. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24drivers/net: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-31via-velocity: separated struct allow wholesale copy during MTU changes.Francois Romieu
It should help people fix the bugs in my code :o) Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-07-11via-velocity: remove the bounce buffersFrancois Romieu
Executive summary: the bounce buffers are in my way - they use something like a 64 * 1500 bytes area of PCI consistent area - they are not resized when the MTU changes - they are used - to hand-pad undersized packets. skb_pad anyone ? - to linearize fragmented skbs whose fragment count goes beyond the 7 fragments hardware limit in order to claim scatter-gather support Actually the SG code is commented out and I wonder if it could not be implemented (ab-)using the large send feature of the chipset since the latter should support some multi-descriptor packet transmitting. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Fixed-by: Séguier Régis <rseguier@e-teleport.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-03big-endian support for via-velocityAl Viro
* kill bitfields * annotate * add missing conversions * fix a couple of brainos in zerocopy stuff (fortunately, it's ifdef'ed out) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10via-velocity: more cleanupStephen Hemminger
Per Al's suggestion, get rid of the stupid stuff: Remove cam_type switch, And deinline things that aren't important for speed. And make big macro and inline. And remove some dead/unused code. And use const char * for chip name. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10via-velocity: use standard VLAN interface (resend)Stephen Hemminger
The via-velocity is using a non-standard VLAN interface configured via module parameters (yuck). Replace with the standard acceleration interface. It solves a number of problems with being able to handle multiple vlans, and dynamically reconfigure. This is compile tested only, don't have this board. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19[PATCH] remove an unused function from the headerHenrik Kretzschmar
Removes an unused function from the via-velocity-driver. It doesn't make the binary smaller, but the source cleaner. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] via-velocity: remove io_size struct member, it is invariantJeff Garzik
Replace io_size struct members with VELOCITY_IO_SIZE constant. Also, constify chip_info_table[]. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-27via-velocity: allow MTU size less than 1500 bytesJay Cliburn
Change the minimum allowable MTU size from 1500 bytes to 64 bytes. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
